[U-Boot] [PATCH v4 1/6] sunxi: R40: add gigabit ethernet clocks
Add clock control entries for the gigabit interface of the Allwinner R40/V40 CPU
Acked-by: Maxime Ripard maxime.ripard@bootlin.com Reviewed-by: Joe Hershberger joe.hershberger@ni.com Signed-off-by: Lothar Felten lothar.felten@gmail.com --- Changelog: new in v2 v2->v3->4: none
arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h index 8afeaf872e..016b811de1 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h @@ -60,7 +60,11 @@ struct sunxi_ccm_reg { u32 reserved11; u32 sata_clk_cfg; /* 0xc8 SATA clock control (R40 only) */ u32 usb_clk_cfg; /* 0xcc USB clock control */ - u32 gmac_clk_cfg; /* 0xd0 GMAC clock control */ +#ifdef CONFIG_MACH_SUN8I_R40 + u32 cir0_clk_cfg; /* 0xd0 CIR0 clock control (R40 only) */ +#else + u32 gmac_clk_cfg; /* 0xd0 GMAC clock control (not for R40) */ +#endif u32 reserved12[7]; u32 mdfs_clk_cfg; /* 0xf0 MDFS clock control */ u32 dram_clk_cfg; /* 0xf4 DRAM configuration clock control */ @@ -103,7 +107,11 @@ struct sunxi_ccm_reg { u32 mtc_clk_cfg; /* 0x158 MTC module clock */ u32 mbus0_clk_cfg; /* 0x15c MBUS0 module clock */ u32 mbus1_clk_cfg; /* 0x160 MBUS1 module clock */ +#ifdef CONFIG_MACH_SUN8I_R40 + u32 gmac_clk_cfg; /* 0x164 GMAC clock control (R40 only) */ +#else u32 reserved16; +#endif u32 mipi_dsi_clk_cfg; /* 0x168 MIPI DSI clock control */ u32 mipi_csi_clk_cfg; /* 0x16c MIPI CSI clock control */ u32 reserved17[4];
If the variant is not set and therefore NULL, do not attempt to print the variant.
Signed-off-by: Lothar Felten lothar.felten@gmail.com --- Changelog: new in v4
drivers/net/sun8i_emac.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 1f5c630e02..23c4d68f77 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -843,8 +843,7 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) priv->variant = dev_get_driver_data(dev);
if (!priv->variant) { - printf("%s: Missing variant '%s'\n", __func__, - (char *)priv->variant); + printf("%s: Missing variant\n", __func__); return -EINVAL; }
Maxime
On Tue, Jun 26, 2018 at 6:54 AM, Lothar Felten lothar.felten@gmail.com wrote:
Use driver data->variant information to select device specific pin mux and phy clock settings.
Suggested by Jagan Teki
Signed-off-by: Lothar Felten lothar.felten@gmail.com --- Changelog: new in v3 v3 -> v4 use driver data to distinguish between variants
drivers/net/sun8i_emac.c | 35 ++++++++++++++++++++--------------- 1 file changed, 20 insertions(+), 15 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 23c4d68f77..ee3b2aa7f4 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -65,11 +65,9 @@
#define AHB_GATE_OFFSET_EPHY 0
-#if defined(CONFIG_MACH_SUNXI_H3_H5) -#define SUN8I_GPD8_GMAC 2 -#else -#define SUN8I_GPD8_GMAC 4 -#endif +/* IO mux settings */ +#define SUN8I_IOMUX_H3 2 +#define SUN8I_IOMUX 4
/* H3/A64 EMAC Register's offset */ #define EMAC_CTL0 0x00 @@ -453,6 +451,7 @@ static int _sun8i_emac_eth_init(struct emac_eth_dev *priv, u8 *enetaddr)
static int parse_phy_pins(struct udevice *dev) { + struct emac_eth_dev *priv = dev_get_priv(dev); int offset; const char *pin_name; int drive, pull = SUN4I_PINCTRL_NO_PULL, i; @@ -494,7 +493,11 @@ static int parse_phy_pins(struct udevice *dev) if (pin < 0) continue;
- sunxi_gpio_set_cfgpin(pin, SUN8I_GPD8_GMAC); + if (priv->variant == H3_EMAC) + sunxi_gpio_set_cfgpin(pin, SUN8I_IOMUX_H3); + else + sunxi_gpio_set_cfgpin(pin, SUN8I_IOMUX); + if (drive != ~0) sunxi_gpio_set_drv(pin, drive); if (pull != ~0) @@ -618,16 +621,18 @@ static void sun8i_emac_board_setup(struct emac_eth_dev *priv) { struct sunxi_ccm_reg *ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE;
-#ifdef CONFIG_MACH_SUNXI_H3_H5 - /* Only H3/H5 have clock controls for internal EPHY */ - if (priv->use_internal_phy) { - /* Set clock gating for ephy */ - setbits_le32(&ccm->bus_gate4, BIT(AHB_GATE_OFFSET_EPHY)); - - /* Deassert EPHY */ - setbits_le32(&ccm->ahb_reset2_cfg, BIT(AHB_RESET_OFFSET_EPHY)); + if (priv->variant == H3_EMAC) { + /* Only H3/H5 have clock controls for internal EPHY */ + if (priv->use_internal_phy) { + /* Set clock gating for ephy */ + setbits_le32(&ccm->bus_gate4, + BIT(AHB_GATE_OFFSET_EPHY)); + + /* Deassert EPHY */ + setbits_le32(&ccm->ahb_reset2_cfg, + BIT(AHB_RESET_OFFSET_EPHY)); + } } -#endif
/* Set clock gating for emac */ setbits_le32(&ccm->ahb_gate0, BIT(AHB_GATE_OFFSET_GMAC));
Add support for the GMAC found in the Allwinner R40/V40 SoC.
The R40 GMAC interface is not controlled by the syscon register but has a separate configuration register in the CCU. The clock gate and reset bits are in a different register compared to the other SoCs supported by this driver. The driver uses the -gmac suffix for the R40 because the R40 also has a different 100 MBit MAC (EMAC).
drivers/net/sun8i_emac.c | 79 ++++++++++++++++++++++++++++++++---------------- 1 file changed, 53 insertions(+), 26 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index ee3b2aa7f4..3ba3a1ff8b 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -67,6 +67,7 @@
/* IO mux settings */ #define SUN8I_IOMUX_H3 2 +#define SUN8I_IOMUX_R40 5 #define SUN8I_IOMUX 4
/* H3/A64 EMAC Register's offset */ @@ -97,6 +98,7 @@ enum emac_variant { A83T_EMAC = 1, H3_EMAC, A64_EMAC, + R40_GMAC, };
struct emac_dma_desc { @@ -278,6 +280,9 @@ static int sun8i_emac_set_syscon(struct emac_eth_dev *priv)
reg = readl(priv->sysctl_reg + 0x30);
+ if (priv->variant == R40_GMAC) + return 0; + if (priv->variant == H3_EMAC) { ret = sun8i_emac_set_syscon_ephy(priv, ®); if (ret) @@ -495,6 +500,8 @@ static int parse_phy_pins(struct udevice *dev)
if (priv->variant == H3_EMAC) sunxi_gpio_set_cfgpin(pin, SUN8I_IOMUX_H3); + else if (priv->variant == R40_GMAC) + sunxi_gpio_set_cfgpin(pin, SUN8I_IOMUX_R40); else sunxi_gpio_set_cfgpin(pin, SUN8I_IOMUX);
@@ -634,11 +641,26 @@ static void sun8i_emac_board_setup(struct emac_eth_dev *priv) } }
- /* Set clock gating for emac */ - setbits_le32(&ccm->ahb_gate0, BIT(AHB_GATE_OFFSET_GMAC)); - - /* De-assert EMAC */ - setbits_le32(&ccm->ahb_reset0_cfg, BIT(AHB_RESET_OFFSET_GMAC)); + if (priv->variant == R40_GMAC) { + /* Set clock gating for emac */ + setbits_le32(&ccm->ahb_reset1_cfg, BIT(AHB_RESET_OFFSET_GMAC)); + + /* De-assert EMAC */ + setbits_le32(&ccm->ahb_gate1, BIT(AHB_GATE_OFFSET_GMAC)); + + /* Select RGMII for R40 */ + setbits_le32(&ccm->gmac_clk_cfg, + CCM_GMAC_CTRL_TX_CLK_SRC_INT_RGMII | + CCM_GMAC_CTRL_GPIT_RGMII); + setbits_le32(&ccm->gmac_clk_cfg, + CCM_GMAC_CTRL_TX_CLK_DELAY(CONFIG_GMAC_TX_DELAY)); + } else { + /* Set clock gating for emac */ + setbits_le32(&ccm->ahb_gate0, BIT(AHB_GATE_OFFSET_GMAC)); + + /* De-assert EMAC */ + setbits_le32(&ccm->ahb_reset0_cfg, BIT(AHB_RESET_OFFSET_GMAC)); + } }
#if defined(CONFIG_DM_GPIO) @@ -805,22 +827,32 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) return -EINVAL; }
- offset = fdtdec_lookup_phandle(gd->fdt_blob, node, "syscon"); - if (offset < 0) { - debug("%s: cannot find syscon node\n", __func__); - return -EINVAL; - } - reg = fdt_getprop(gd->fdt_blob, offset, "reg", NULL); - if (!reg) { - debug("%s: cannot find reg property in syscon node\n", - __func__); + priv->variant = dev_get_driver_data(dev); + + if (!priv->variant) { + printf("%s: Missing variant\n", __func__); return -EINVAL; } - priv->sysctl_reg = fdt_translate_address((void *)gd->fdt_blob, - offset, reg); - if (priv->sysctl_reg == FDT_ADDR_T_NONE) { - debug("%s: Cannot find syscon base address\n", __func__); - return -EINVAL; + + if (priv->variant != R40_GMAC) { + offset = fdtdec_lookup_phandle(gd->fdt_blob, node, "syscon"); + if (offset < 0) { + debug("%s: cannot find syscon node\n", __func__); + return -EINVAL; + } + reg = fdt_getprop(gd->fdt_blob, offset, "reg", NULL); + if (!reg) { + debug("%s: cannot find reg property in syscon node\n", + __func__); + return -EINVAL; + } + priv->sysctl_reg = fdt_translate_address((void *)gd->fdt_blob, + offset, reg); + if (priv->sysctl_reg == FDT_ADDR_T_NONE) { + debug("%s: Cannot find syscon base address\n", + __func__); + return -EINVAL; + } }
pdata->phy_interface = -1; @@ -845,13 +877,6 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) return -EINVAL; }
- priv->variant = dev_get_driver_data(dev); - - if (!priv->variant) { - printf("%s: Missing variant\n", __func__); - return -EINVAL; - } - if (priv->variant == H3_EMAC) { int parent = fdt_parent_offset(gd->fdt_blob, offset);
@@ -892,6 +917,8 @@ static const struct udevice_id sun8i_emac_eth_ids[] = { .data = (uintptr_t)A64_EMAC }, {.compatible = "allwinner,sun8i-a83t-emac", .data = (uintptr_t)A83T_EMAC }, + {.compatible = "allwinner,sun8i-r40-gmac", + .data = (uintptr_t)R40_GMAC }, { } };
Add a device tree node for the Allwinner R40/V40 GMAC gigabit ethernet interface. The R40 SoC does not use the syscon register for GMAC settings. The gigabit ethernet interface can only be routed to a fixed set of pins.
Signed-off-by: Lothar Felten lothar.felten@gmail.com --- Changelog: new in v2 v2 -> v3 omit syscon node for R40 v3 -> v4 remove phy-mode from gmac node
arch/arm/dts/sun8i-r40.dtsi | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/arch/arm/dts/sun8i-r40.dtsi b/arch/arm/dts/sun8i-r40.dtsi index 0aa76a2f10..3a0b3ab543 100644 --- a/arch/arm/dts/sun8i-r40.dtsi +++ b/arch/arm/dts/sun8i-r40.dtsi @@ -52,6 +52,7 @@ interrupt-parent = <&gic>;
aliases { + ethernet0 = &gmac; };
chosen { @@ -161,6 +162,15 @@ #interrupt-cells = <3>; #gpio-cells = <3>;
+ gmac_pins_rgmii: gmac_rgmii { + pins = "PA0", "PA1", "PA2", + "PA3", "PA4", "PA5", "PA6", + "PA7", "PA8", "PA10", + "PA11", "PA12", "PA13", + "PA15", "PA16"; + function = "gmac"; + }; + i2c0_pins: i2c0_pins { pins = "PB0", "PB1"; function = "i2c0"; @@ -202,6 +212,26 @@ #size-cells = <0>; };
+ gmac: ethernet@01c50000 { + compatible = "allwinner,sun8i-r40-gmac"; + reg = <0x01c50000 0x2000>; + interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + clocks = <&osc24M>, <&osc24M>; + clock-names = "stmmaceth", "allwinner_gmac_tx"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&gmac_pins_rgmii>; + status = "disabled"; + + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + }; + }; + gic: interrupt-controller@1c81000 { compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic"; reg = <0x01c81000 0x1000>,
On Tue, Jun 26, 2018 at 7:54 PM, Lothar Felten lothar.felten@gmail.com wrote:
aliases {
ethernet0 = &gmac; }; chosen {
"PA15", "PA16";
function = "gmac";
Where did this second clock come from?
#size-cells = <0>;
mdio: mdio {
#size-cells = <0>;
Also, please have the new nodes match what is in the Linux kernel's device tree. This would make it easier to sync up without differences scattered all over.
ChenYu
-- 2.14.1
Enable the gigabit ethernet for the Bananapi M2 Ultra board. Tested on BananaPi M2 Berry (R40), custom board (V40)
Reviewed-by: Joe Hershberger joe.hershberger@ni.com Signed-off-by: Lothar Felten lothar.felten@gmail.com --- Changelog: new in v2 v2 -> v3 remove unused CONFIG_SUN7I_GMAC v3 -> v4 include device tree node, enable ALDO2
arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts | 15 +++++++++++++++ configs/Bananapi_M2_Ultra_defconfig | 5 +++++ 2 files changed, 20 insertions(+)
diff --git a/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts b/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts index ab471ab0bf..c2284aed5a 100644 --- a/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts +++ b/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts @@ -67,3 +67,18 @@ pinctrl-0 = <&uart0_pb_pins>; status = "okay"; }; + +&gmac { + pinctrl-names = "default"; + pinctrl-0 = <&gmac_pins_rgmii>; + status = "okay"; + phy-handle = <&rgmii_phy>; + phy-mode = "rgmii"; +}; + +&mdio { + rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; diff --git a/configs/Bananapi_M2_Ultra_defconfig b/configs/Bananapi_M2_Ultra_defconfig index 37cc2df5dc..4ce1a905ea 100644 --- a/configs/Bananapi_M2_Ultra_defconfig +++ b/configs/Bananapi_M2_Ultra_defconfig @@ -14,6 +14,11 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set CONFIG_SCSI_AHCI=y CONFIG_AXP_DLDO4_VOLT=2500 +CONFIG_AXP_ALDO2_VOLT=2500 CONFIG_AXP_ELDO3_VOLT=1200 CONFIG_SCSI=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_SUN8I_EMAC=y +CONFIG_RGMII=y +CONFIG_MACPWR="PA17" +CONFIG_DM_GPIO=y
+&gmac {
- pinctrl-names = "default";
- pinctrl-0 = <&gmac_pins_rgmii>;
- status = "okay";
- phy-handle = <&rgmii_phy>;
- phy-mode = "rgmii";
+&mdio {
- rgmii_phy: ethernet-phy@1 {
reg = <1>;
Why is that option needed?
Maxime
Chen-Yu Tsai
Joe Hershberger
Lothar Felten
Maxime Ripard
