[U-Boot] [PATCH 1/2] .gitignore: sort normal pattern rules alphabetically
Follow Linux commit 1377dd3e2987 (".gitignore: sort normal pattern rules alphabetically").
This would allow us to easily catch duplicated patterns if any.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
.gitignore | 30 +++++++++++++----------------- 1 file changed, 13 insertions(+), 17 deletions(-)
diff --git a/.gitignore b/.gitignore index 9110eda..4d4c486 100644 --- a/.gitignore +++ b/.gitignore @@ -3,29 +3,29 @@ # subdirectories here. Add them in the ".gitignore" file # in that subdirectory instead. # -# Normal rules +# Normal rules (sorted alphabetically) # .* -*.o -*.o.* *.a -*.s -*.su -*.mod.c +*.bin +*.cfgtmp +*.elf +*.exe +*.gcda +*.gcno *.i *.lex.c *.lst +*.mod.c +*.o +*.o.* *.order -*.elf -*.swp -*.bin *.patch -*.cfgtmp +*.s +*.su +*.swp *.tab.[ch]
-# host programs on Cygwin -*.exe - # Build tree /build-*
@@ -86,7 +86,3 @@ GTAGS *.orig *~ #*# - -# gcc code coverage files -*.gcda -*.gcno
Follow Linux commit 10b62a2f785a (".gitignore: move *.dtb and *.dtb.S patterns to the top-level .gitignore").
.gitignore | 2 ++ arch/arc/dts/.gitignore | 1 - arch/arm/dts/.gitignore | 1 - arch/microblaze/dts/.gitignore | 1 - arch/mips/dts/.gitignore | 1 - arch/nios2/dts/.gitignore | 1 - arch/sandbox/dts/.gitignore | 1 - arch/x86/dts/.gitignore | 1 - dts/.gitignore | 2 -- 9 files changed, 2 insertions(+), 9 deletions(-) delete mode 100644 arch/arc/dts/.gitignore delete mode 100644 arch/arm/dts/.gitignore delete mode 100644 arch/microblaze/dts/.gitignore delete mode 100644 arch/mips/dts/.gitignore delete mode 100644 arch/nios2/dts/.gitignore delete mode 100644 arch/sandbox/dts/.gitignore delete mode 100644 arch/x86/dts/.gitignore delete mode 100644 dts/.gitignore
diff --git a/.gitignore b/.gitignore index 4d4c486..6bb0ade 100644 --- a/.gitignore +++ b/.gitignore @@ -9,6 +9,8 @@ *.a *.bin *.cfgtmp +*.dtb +*.dtb.S *.elf *.exe *.gcda diff --git a/arch/arc/dts/.gitignore b/arch/arc/dts/.gitignore deleted file mode 100644 index b60ed20..0000000 --- a/arch/arc/dts/.gitignore +++ /dev/null @@ -1 +0,0 @@ -*.dtb diff --git a/arch/arm/dts/.gitignore b/arch/arm/dts/.gitignore deleted file mode 100644 index b60ed20..0000000 --- a/arch/arm/dts/.gitignore +++ /dev/null @@ -1 +0,0 @@ -*.dtb diff --git a/arch/microblaze/dts/.gitignore b/arch/microblaze/dts/.gitignore deleted file mode 100644 index b60ed20..0000000 --- a/arch/microblaze/dts/.gitignore +++ /dev/null @@ -1 +0,0 @@ -*.dtb diff --git a/arch/mips/dts/.gitignore b/arch/mips/dts/.gitignore deleted file mode 100644 index b60ed20..0000000 --- a/arch/mips/dts/.gitignore +++ /dev/null @@ -1 +0,0 @@ -*.dtb diff --git a/arch/nios2/dts/.gitignore b/arch/nios2/dts/.gitignore deleted file mode 100644 index b60ed20..0000000 --- a/arch/nios2/dts/.gitignore +++ /dev/null @@ -1 +0,0 @@ -*.dtb diff --git a/arch/sandbox/dts/.gitignore b/arch/sandbox/dts/.gitignore deleted file mode 100644 index b60ed20..0000000 --- a/arch/sandbox/dts/.gitignore +++ /dev/null @@ -1 +0,0 @@ -*.dtb diff --git a/arch/x86/dts/.gitignore b/arch/x86/dts/.gitignore deleted file mode 100644 index b60ed20..0000000 --- a/arch/x86/dts/.gitignore +++ /dev/null @@ -1 +0,0 @@ -*.dtb diff --git a/dts/.gitignore b/dts/.gitignore deleted file mode 100644 index 1b37180..0000000 --- a/dts/.gitignore +++ /dev/null @@ -1,2 +0,0 @@ -*.dtb -*.dtb.S
Masahiro Yamada
