[U-Boot] [PATCH 1/9] arm64: zynqmp: Do not perform reset in case of panic
Do not perform reset when panic happens because in the next reset panic happens again and logs are overflood by the same errors. This can be enabled by default and reset can be performed via watchdog.
include/configs/xilinx_zynqmp.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 14604eb4e801..cc1a53654591 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -126,6 +126,7 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING +#define CONFIG_PANIC_HANG #define CONFIG_SYS_MAXARGS 64
/* Ethernet driver */
This was caused by: "fs/fat: Reduce stack usage" (sha1:2460098cffacd18729262e3ed36656e6943783ed) which converted fat code to use malloc. But simple malloc is not freeing space that's why full malloc implementation is needed. Malloc space is added to RAM.
configs/xilinx_zynqmp_ep_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 1 - configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 1 - configs/xilinx_zynqmp_zcu102_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 - include/configs/xilinx_zynqmp.h | 6 +++--- 9 files changed, 3 insertions(+), 11 deletions(-)
diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index ff865f1bdcd0..c9e01b19f165 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -14,7 +14,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_FASTBOOT=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index beb24346baa9..6067ab48e81d 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -15,7 +15,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_FASTBOOT=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 8c8201dfbb5c..2acc1eba295b 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -16,7 +16,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_FASTBOOT=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index 34365c8cfe82..35dce719b19b 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -12,7 +12,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index a9e7a879de42..2124d6b23c45 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -13,7 +13,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index bf27ca48db93..225bd8a5d309 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -15,7 +15,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_FASTBOOT=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index 80c5e4934844..bf8fdc2bf674 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -15,7 +15,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_FASTBOOT=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 232532c99597..6dfa11a90f75 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -15,7 +15,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_FASTBOOT=y diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index cc1a53654591..df03d6700672 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -260,14 +260,14 @@ # define CONFIG_SPL_ENV_SUPPORT # define CONFIG_SPL_HASH_SUPPORT # define CONFIG_ENV_MAX_ENTRIES 10 +#endif
-# define CONFIG_SYS_SPL_MALLOC_START 0x20000000 -# define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 +#define CONFIG_SYS_SPL_MALLOC_START 0x20000000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000
#ifdef CONFIG_SPL_SYS_MALLOC_SIMPLE # error "Disable CONFIG_SPL_SYS_MALLOC_SIMPLE. Full malloc needs to be used" #endif -#endif
#define CONFIG_BOARD_EARLY_INIT_F
This reference is needed for pinctrl driver where some signals can be routed directly to platform management unit (PMU).
arch/arm/dts/zynqmp.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index 247344fcbb86..1cf535b964b5 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -261,7 +261,7 @@ method = "smc"; };
- firmware { + pmufw: firmware { compatible = "xlnx,zynqmp-pm"; method = "smc"; interrupt-parent = <&gic>;
This patch is enabling support for SPL QSPI boot.
First of all it is necessary to generate atf-spi.ub which is different format than atf-uboot.ub (this can be made as legacy image too)
ADDR=`arm-xilinx-linux-gnueabi-readelf -a bl31.elf | grep "Entry point address" | cut -d ':' -f 2 | sed -e 's/^[ \t]*//'` aarch64-linux-gnu-objcopy -O binary bl31.elf bl31.bin ./tools/mkimage -f auto -A arm64 -T firmware -C none -O u-boot -a $ADDR -e $ADDR -n "atf1" -E -b arch/arm/dts/zynqmp-zcu102.dtb -d bl31.bin atf-uboot.ub ./tools/mkimage -A arm64 -T firmware -C none -O u-boot -a $ADDR -e $ADDR -n "atf-for-qspi" -E -d bl31.bin atf-spi.ub
This patch is using this QSPI layout with offsets: 0 boot.bin 512k atf-ub 640k u-boot.bin 1280k u-boot.img
Which corresponding by writing these images(read from MMC) mmcinfo sf probe load mmc 0 10000000 boot.bin sf erase 0 +$filesize sf write 10000000 0 $filesize load mmc 0 10000000 atf-spi.ub sf erase 0x80000 +$filesize sf write 10000000 0x80000 $filesize load mmc 0 10000000 u-boot.bin sf erase 0xa0000 +$filesize sf write 10000000 0xa0000 $filesize load mmc 0 10000000 u-boot.img sf erase 0x140000 +$filesize sf write 10000000 0x140000 $filesize
For testing u-boot running in EL3 you can break atf-spi.ub like this: sf probe sf erase 0x80000 +4
Then u-boot.img is executed.
arch/arm/dts/zynqmp.dtsi | 1 + include/configs/xilinx_zynqmp.h | 9 +++++++++ 2 files changed, 10 insertions(+)
diff --git a/arch/arm/dts/zynqmp.dtsi b/arch/arm/dts/zynqmp.dtsi index 1cf535b964b5..5bdab6116451 100644 --- a/arch/arm/dts/zynqmp.dtsi +++ b/arch/arm/dts/zynqmp.dtsi @@ -804,6 +804,7 @@ };
qspi: spi@ff0f0000 { + u-boot,dm-pre-reloc; compatible = "xlnx,zynqmp-qspi-1.0"; status = "disabled"; clock-names = "ref_clk", "pclk"; diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index df03d6700672..c2350f523f2d 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -236,6 +236,15 @@
#define CONFIG_SPL_FRAMEWORK
+#if defined(CONFIG_SPL_SPI_FLASH_SUPPORT) +# define CONFIG_SPL_SPI_LOAD +# define CONFIG_SYS_SPI_KERNEL_OFFS 0x80000 +# define CONFIG_SYS_SPI_ARGS_OFFS 0xa0000 +# define CONFIG_SYS_SPI_ARGS_SIZE 0xa0000 + +# define CONFIG_SYS_SPI_U_BOOT_OFFS 0x170000 +#endif + /* u-boot is like dtb */ #define CONFIG_SPL_FS_LOAD_ARGS_NAME "u-boot.bin" #define CONFIG_SYS_SPL_ARGS_ADDR 0x8000000
Setup proper dependency in Kconfig for SPL_CLK.
arch/arm/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index e50ba930a17c..16be179c8ba5 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -773,7 +773,7 @@ config ARCH_ZYNQMP select SUPPORT_SPL select CLK select SPL_BOARD_INIT if SPL - select SPL_CLK + select SPL_CLK if SPL select DM_USB if USB imply FAT_WRITE
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Dont read boot mode register directly read it using zynqmp_mmio_read().
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
board/xilinx/zynqmp/zynqmp.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index f769db7e81b9..8c859ed8ff8b 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -343,13 +343,17 @@ int board_late_init(void) u8 bootmode; const char *mode; char *new_targets; + int ret;
if (!(gd->flags & GD_FLG_ENV_DEFAULT)) { debug("Saved variables - Skipping\n"); return 0; }
- reg = readl(&crlapb_base->boot_mode); + ret = zynqmp_mmio_read((ulong)&crlapb_base->boot_mode, ®); + if (ret) + return -EINVAL; + if (reg >> BOOT_MODE_ALT_SHIFT) reg >>= BOOT_MODE_ALT_SHIFT;
Setup bootmode variable based on bootmode selection. This is helping with setting up boot method. Also setup sdbootdevice.
board/xilinx/zynqmp/zynqmp.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 8c859ed8ff8b..7aa9628414fe 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -364,23 +364,28 @@ int board_late_init(void) case USB_MODE: puts("USB_MODE\n"); mode = "usb"; + env_set("modeboot", "usb_dfu_spl"); break; case JTAG_MODE: puts("JTAG_MODE\n"); mode = "pxe dhcp"; + env_set("modeboot", "jtagboot"); break; case QSPI_MODE_24BIT: case QSPI_MODE_32BIT: mode = "qspi0"; puts("QSPI_MODE\n"); + env_set("modeboot", "qspiboot"); break; case EMMC_MODE: puts("EMMC_MODE\n"); mode = "mmc0"; + env_set("modeboot", "emmcboot"); break; case SD_MODE: puts("SD_MODE\n"); mode = "mmc0"; + env_set("modeboot", "sdboot"); break; case SD1_LSHFT_MODE: puts("LVL_SHFT_"); @@ -389,13 +394,16 @@ int board_late_init(void) puts("SD_MODE1\n"); #if defined(CONFIG_ZYNQ_SDHCI0) && defined(CONFIG_ZYNQ_SDHCI1) mode = "mmc1"; + env_set("sdbootdev", "1"); #else mode = "mmc0"; #endif + env_set("modeboot", "sdboot"); break; case NAND_MODE: puts("NAND_MODE\n"); mode = "nand0"; + env_set("modeboot", "nandboot"); break; default: mode = "";
Enable USB3.0 and SATA phy for zcu102 boards.
arch/arm/dts/zynqmp-zcu102-revA.dts | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/arch/arm/dts/zynqmp-zcu102-revA.dts b/arch/arm/dts/zynqmp-zcu102-revA.dts index a2128ebfd8c8..2e382562c496 100644 --- a/arch/arm/dts/zynqmp-zcu102-revA.dts +++ b/arch/arm/dts/zynqmp-zcu102-revA.dts @@ -14,6 +14,7 @@ #include "zynqmp-clk.dtsi" #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/pinctrl/pinctrl-zynqmp.h> +#include <dt-bindings/phy/phy.h>
/ { model = "ZynqMP ZCU102 RevA"; @@ -884,6 +885,8 @@ drivers/hwmon/pmbus/Makefile:11:obj-$(CONFIG_SENSORS_MAX20751) += max20751.o ceva,p1-comwake-params = /bits/ 8 <0x06 0x14 0x08 0x0E>; ceva,p1-burst-params = /bits/ 8 <0x13 0x08 0x4A 0x06>; ceva,p1-retry-params = /bits/ 16 <0x96A4 0x3FFC>; + phy-names = "sata-phy"; + phys = <&lane3 PHY_TYPE_SATA 1 1 125000000>; };
/* SD1 with level shifter */ @@ -895,6 +898,10 @@ drivers/hwmon/pmbus/Makefile:11:obj-$(CONFIG_SENSORS_MAX20751) += max20751.o xlnx,mio_bank = <1>; };
+&serdes { + status = "okay"; +}; + &uart0 { status = "okay"; pinctrl-names = "default"; @@ -917,6 +924,10 @@ drivers/hwmon/pmbus/Makefile:11:obj-$(CONFIG_SENSORS_MAX20751) += max20751.o &dwc3_0 { status = "okay"; dr_mode = "host"; + snps,usb3_lpm_capable; + phy-names = "usb3-phy"; + phys = <&lane2 PHY_TYPE_USB3 0 2 26000000>; + maximum-speed = "super-speed"; };
&watchdog0 {
clk command provides an option to see actual clock setting.
configs/xilinx_zynqmp_ep_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 1 + configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revA_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 + 8 files changed, 8 insertions(+)
diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index c9e01b19f165..4e29cc782032 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -24,6 +24,7 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_CMD_THOR_DOWNLOAD=y # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_CLK=y CONFIG_CMD_DFU=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 6067ab48e81d..c2805ac08125 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -22,6 +22,7 @@ CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 2acc1eba295b..3a5fe1331cf1 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -22,6 +22,7 @@ CONFIG_FASTBOOT=y CONFIG_FASTBOOT_FLASH=y CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index 35dce719b19b..18f2eed7f0aa 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index 2124d6b23c45..75ebd223cdf4 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL=y CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index 225bd8a5d309..a72781000c1e 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -23,6 +23,7 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_EEPROM=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index bf8fdc2bf674..94116ec61b59 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -23,6 +23,7 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_EEPROM=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 6dfa11a90f75..d6c49cdfad5b 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -23,6 +23,7 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_CMD_THOR_DOWNLOAD=y CONFIG_CMD_EEPROM=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y
Michal Simek
