[U-Boot] [PATCH] ARM: at91: Fix PMC bit definitions
Add missing parenthesis around the variable into the macro.
Signed-off-by: Marek Vasut marex@denx.de Cc: Andreas Bießmann andreas.devel@googlemail.com --- arch/arm/mach-at91/include/mach/at91_pmc.h | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-at91/include/mach/at91_pmc.h b/arch/arm/mach-at91/include/mach/at91_pmc.h index 7684f09..680ceb0 100644 --- a/arch/arm/mach-at91/include/mach/at91_pmc.h +++ b/arch/arm/mach-at91/include/mach/at91_pmc.h @@ -67,18 +67,18 @@ typedef struct at91_pmc { #define AT91_PMC_MOR_MOSCEN 0x01 #define AT91_PMC_MOR_OSCBYPASS 0x02 #define AT91_PMC_MOR_MOSCRCEN 0x08 -#define AT91_PMC_MOR_OSCOUNT(x) ((x & 0xff) << 8) -#define AT91_PMC_MOR_KEY(x) ((x & 0xff) << 16) +#define AT91_PMC_MOR_OSCOUNT(x) (((x) & 0xff) << 8) +#define AT91_PMC_MOR_KEY(x) (((x) & 0xff) << 16) #define AT91_PMC_MOR_MOSCSEL (1 << 24)
-#define AT91_PMC_PLLXR_DIV(x) (x & 0xFF) -#define AT91_PMC_PLLXR_PLLCOUNT(x) ((x & 0x3F) << 8) -#define AT91_PMC_PLLXR_OUT(x) ((x & 0x03) << 14) +#define AT91_PMC_PLLXR_DIV(x) ((x) & 0xFF) +#define AT91_PMC_PLLXR_PLLCOUNT(x) (((x) & 0x3F) << 8) +#define AT91_PMC_PLLXR_OUT(x) (((x) & 0x03) << 14) #if defined(CONFIG_SAMA5D2) || defined(CONFIG_SAMA5D3) || \ defined(CONFIG_SAMA5D4) -#define AT91_PMC_PLLXR_MUL(x) ((x & 0x7F) << 18) +#define AT91_PMC_PLLXR_MUL(x) (((x) & 0x7F) << 18) #else -#define AT91_PMC_PLLXR_MUL(x) ((x & 0x7FF) << 16) +#define AT91_PMC_PLLXR_MUL(x) (((x) & 0x7FF) << 16) #endif #define AT91_PMC_PLLAR_29 0x20000000 #define AT91_PMC_PLLBR_USBDIV_1 0x00000000 @@ -158,7 +158,7 @@ typedef struct at91_pmc { #define AT91_PMC_PCR_CMD_WRITE (0x1 << 12) #define AT91_PMC_PCR_DIV (0x3 << 16) #define AT91_PMC_PCR_GCKDIV (0xff << 20) -#define AT91_PMC_PCR_GCKDIV_(x) ((x & 0xff) << 20) +#define AT91_PMC_PCR_GCKDIV_(x) (((x) & 0xff) << 20) #define AT91_PMC_PCR_GCKDIV_OFFSET 20 #define AT91_PMC_PCR_EN (0x1 << 28) #define AT91_PMC_PCR_GCKEN (0x1 << 29)
Reviewed-by: Andreas Bießmann andreas@biessmann.org
Dear Marek Vasut,
Marek Vasut marex@denx.de writes:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
