[U-Boot] [GIT PULL] u-boot-mips/master
Hi Tom,
Travis-CI build is green (one job has failed due to job time limit)
https://travis-ci.org/danielschwierzeck/u-boot/builds/180114376
The following changes since commit 6b29a395b62965eef6b5065d3a526a8588a92038:
Merge git://git.denx.de/u-boot-mpc85xx (2016-11-29 19:42:48 -0500)
git://git.denx.de/u-boot-mips.git master
for you to fetch changes up to 6fd596a1aa57bd431263f45b0c57ee8ae6b2403c:
MIPS: Fix map_physmem for cached mappings (2016-11-30 16:18:19 +0100)
---------------------------------------------------------------- Daniel Schwierzeck (9): MIPS: make inclusion of ROM exception vectors configurable MIPS: fix ROM exception vectors MIPS: fix iand optimize setup of CP0 registers MIPS: factor out code for initial stack and global data MIPS: add possibility to setup initial stack and global data in SRAM MIPS: add asm-offsets for struct pt_regs MIPS: reserve space for exception vectors MIPS: add handling for generic and EJTAG exceptions common/board_f: enable initr_trap for MIPS
Marek Vasut (1): mips: Let cache.h be included from assembly source
Paul Burton (2): MIPS: Use ram_top, not bi_memsize, in arch_lmb_reserve MIPS: Fix map_physmem for cached mappings
arch/mips/Kconfig | 32 +++++++++++++++++++ arch/mips/cpu/start.S | 173 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------------------------ arch/mips/include/asm/asm-offsets.h | 5 +++ arch/mips/include/asm/cache.h | 2 ++ arch/mips/include/asm/io.h | 2 +- arch/mips/include/asm/mipsregs.h | 1 + arch/mips/include/asm/system.h | 8 +++++ arch/mips/include/asm/u-boot-mips.h | 4 +++ arch/mips/lib/Makefile | 3 ++ arch/mips/lib/asm-offsets.c | 61 ++++++++++++++++++++++++++++++++++++ arch/mips/lib/bootm.c | 2 +- arch/mips/lib/genex.S | 224 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/mips/lib/stack.c | 19 ++++++++++++ arch/mips/lib/traps.c | 106 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/mips/mach-ath79/Kconfig | 2 ++ arch/mips/mach-pic32/Kconfig | 1 + common/board_r.c | 4 +-- 17 files changed, 584 insertions(+), 65 deletions(-) create mode 100644 arch/mips/include/asm/asm-offsets.h create mode 100644 arch/mips/lib/asm-offsets.c create mode 100644 arch/mips/lib/genex.S create mode 100644 arch/mips/lib/stack.c create mode 100644 arch/mips/lib/traps.c
On Wed, Nov 30, 2016 at 07:13:51PM +0100, Daniel Schwierzeck wrote:
Hi Tom,
Note that if you head to https://travis-ci.org/danielschwierzeck/u-boot/jobs/180114393 you can tell it to re-start the job and it _should_ complete in time. But that said, that also just failed for me and I think that means I'm going to split it into ARM32 and ARM64 builds so it's not so close to failing due to time.
Are there other parts of the Ci20 series you could apply as well? I'm keen to see this (and then Ci40) go in as I have both platforms and would like to get them in mainline and then worked into my test.py framework, thanks!
Am 30.11.2016 um 20:01 schrieb Tom Rini:
Hi Tom,
not in this pull request. I'm going to create a new one when the review has finished.
Hi Tom,
Daniel Schwierzeck
