[U-Boot-Users] Raw binary u-boot.bin is bigger that elf file u-boot
Hello All,
I am compiling u-boot version 1.1.0 for SC520_CDP board. I ma trying to compile on a P.C with redhat version 9 and the tools provided along with it.Compilation is sucessful after few errors being handles. I ma running the command "make u-boot.bin" to get binary file. The out file sizes are as follows.
u-boot - 60442 bytes u-boot.bin - 947911360 bytes. u-boot.map - 116152 bytes.
This is really confusing since we get the raw binary by running the "objcopy" tool on the ELF format file u-boot.
I treid version 1.0.0 but have same problem
Any help on this shall be really helpful
This can happen easily if there are (huge) gaps in your image's address map. Run "objdump -h" to check this.
Check your linker script and compare against the memory map needed for your hardware.
Hello All,
I got the following by running "objdump -h u-boot" , I have no idea what has to be done with this .
|----------------------------------------------------------------------------------------------------------------------| u-boot: file format elf32-i386
Sections: Idx Name Size VMA LMA File off Algn 0 .text 000157a7 387c0000 387c0000 00001000 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 1 .rodata 000074ec 387d57c0 387d57c0 000167c0 2**5 CONTENTS, ALLOC, LOAD, READONLY, DATA 2 .data 00000df8 00400000 387dccac 0001e000 2**5 CONTENTS, ALLOC, LOAD, DATA 3 .got 00000000 00400df8 00400df8 00021000 2**0 CONTENTS 4 .bss 000062c0 00400e00 00400e00 00000e00 2**5 ALLOC 5 .realmode 00000166 000007c0 387ddaa4 0001f7c0 2**0 CONTENTS, ALLOC, LOAD, READONLY, CODE 6 .bios 0000053e 00000000 387ddc0a 00020000 2**0 CONTENTS, ALLOC, LOAD, READONLY, CODE 7 .u_boot_cmd 00000438 00000540 00000540 00000540 2**2 CONTENTS, ALLOC, LOAD, DATA 8 .start16 000000ad 0000ff00 387fff00 00020f00 2**0 CONTENTS, ALLOC, LOAD, READONLY, CODE 9 .reset 00000010 0000fff0 387ffff0 00020ff0 2**0 CONTENTS, ALLOC, LOAD, READONLY, CODE 10 .stab 00002c7c 00000000 00000000 00021000 2**2 CONTENTS, READONLY, DEBUGGING 11 .stabstr 000001d9 00000000 00000000 00023c7c 2**0 CONTENTS, READONLY, DEBUGGING 12 .debug_abbrev 00007bdd 00000000 00000000 00023e55 2**0 CONTENTS, READONLY, DEBUGGING 13 .debug_info 000467ac 00000000 00000000 0002ba32 2**0 CONTENTS, READONLY, DEBUGGING 14 .debug_line 0000a236 00000000 00000000 000721de 2**0 CONTENTS, READONLY, DEBUGGING 15 .debug_frame 0000521c 00000000 00000000 0007c414 2**2 CONTENTS, READONLY, DEBUGGING 16 .debug_pubnames 00002849 00000000 00000000 00081630 2**0 CONTENTS, READONLY, DEBUGGING 17 .debug_aranges 000007e0 00000000 00000000 00083e79 2**0 CONTENTS, READONLY, DEBUGGING 18 .debug_ranges 00000470 00000000 00000000 00084659 2**0 CONTENTS, READONLY, DEBUGGING 19 .debug_str 00005658 00000000 00000000 00084ac9 2**0 CONTENTS, READONLY, DEBUGGING 20 .comment 00000cc0 00000000 00000000 0008a121 2**0 CONTENTS, READONLY |----------------------------------------------------------------------------------------------------------------------|
Regarding the linker script what exaclty should i look for, more details would be helful.
Anyway i have added the LD command from the compilation windows.
|----------------------------------------------------------------------------------------------------------------------| ld -Bstatic -T /home/rashetty/u-boot-1.0.0/board/sc520_cdp/u-boot.lds -Ttext 0x387c0000 $UNDEF_SYM cpu/i386/start.o cpu/i386/start16.o cpu/i386/reset.o \ --start-group board/sc520_cdp/libsc520_cdp.a cpu/i386/libi386.a lib_i386/libi386.a fs/jffs2/libjffs2.a fs/fdos/libfdos.a fs/fat/libfat.a net/libnet.a disk/libdisk.a rtc/librtc.a dtt/libdtt.a drivers/libdrivers.a drivers/sk98lin/libsk98lin.a post/libpost.a post/cpu/libcpu.a common/libcommon.a lib_generic/libgeneric.a -L /usr/lib/gcc-lib/i386-redhat-linux/3.2.2 -lgcc --end-group \ -Map u-boot.map -o u-boot |----------------------------------------------------------------------------------------------------------------------|
I am doing this for first time. More detailed information would be more helpful for newbie like me.
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de COMPONENT EQUIVALENCY NOTICE: The Subatomic Particles (Electrons, Protons, etc.) Comprising This Product Are Exactly the Same in Every Measurable Respect as Those Used in the Products of Other Manufactu- rers, and No Claim to the Contrary May Legitimately Be Expressed or Implied.
On Wed, 2005-01-26 at 18:08, raj wrote:
Hello All,
It might be instructive to see my missive earlier this month:
From: Jon Loeliger jdl@freescale.com To: u-boot-users u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] Why objdump Creates 4G U-Boot Images Date: Thu, 20 Jan 2005 16:26:28 -0600
Enjoy, jdl
Jon Loeliger
raj
