[U-Boot] [PATCH] powerpc/usb: Depricate usb_phy_type and usb_dr_mode uboot env variables
Remove getting values of usb mode and phy_type from "usb_dr_mode" and "usb_phy_type" uboot env variables. Now, these are determined only from hwconfig string
Signed-off-by: Ramneek Mehresh ramneek.mehresh@freescale.com --- arch/powerpc/cpu/mpc8xxx/fdt.c | 22 ---------------------- 1 file changed, 22 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/fdt.c b/arch/powerpc/cpu/mpc8xxx/fdt.c index 89966e0..eb7cbbc 100644 --- a/arch/powerpc/cpu/mpc8xxx/fdt.c +++ b/arch/powerpc/cpu/mpc8xxx/fdt.c @@ -121,11 +121,8 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) { const char *modes[] = { "host", "peripheral", "otg" }; const char *phys[] = { "ulpi", "utmi" }; - const char *mode = NULL; - const char *phy_type = NULL; const char *dr_mode_type = NULL; const char *dr_phy_type = NULL; - char usb1_defined = 0; int usb_mode_off = -1; int usb_phy_off = -1; char str[5]; @@ -159,12 +156,6 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) dr_mode_type = modes[mode_idx]; dr_phy_type = phys[phy_idx];
- /* use usb_dr_mode and usb_phy_type if - usb1_defined = 0; these variables are to - be deprecated */ - if (!strcmp(str, "usb1")) - usb1_defined = 1; - if (mode_idx < 0 && phy_idx < 0) { printf("WARNING: invalid phy or mode\n"); return; @@ -183,19 +174,6 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) if (usb_phy_off < 0) return; } - - if (!usb1_defined) { - int usb_off = -1; - mode = getenv("usb_dr_mode"); - phy_type = getenv("usb_phy_type"); - if (mode || phy_type) { - printf("WARNING: usb_dr_mode and usb_phy_type " - "are to be deprecated soon. Use " - "hwconfig to set these values instead!!\n"); - fdt_fixup_usb_mode_phy_type(blob, mode, - phy_type, usb_off); - } - } } #endif /* defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) */
Ramneek Mehresh
