[U-Boot] [PATCH] fsl_sfp : Modify macros as per changes in SFP v3.4
In SFP v3.4 support for 8 keys in SRK table has been added which leads to corresponding changes in OSPR key revocation field. So modify OSPR_KEY_REVOC_XXX macros accordingly.
Signed-off-by: Sumit Garg sumit.garg@nxp.com --- include/fsl_sfp.h | 23 +++++++++++++++-------- 1 file changed, 15 insertions(+), 8 deletions(-)
diff --git a/include/fsl_sfp.h b/include/fsl_sfp.h index 2976a2c..42ff942 100644 --- a/include/fsl_sfp.h +++ b/include/fsl_sfp.h @@ -32,7 +32,7 @@ /* Number of SRKH registers */ #define NUM_SRKH_REGS 8
-#if defined(CONFIG_SYS_FSL_SFP_VER_3_2) || \ +#if defined(CONFIG_SYS_FSL_SFP_VER_3_2) || \ defined(CONFIG_SYS_FSL_SFP_VER_3_4) struct ccsr_sfp_regs { u32 ospr; /* 0x200 */ @@ -57,7 +57,7 @@ struct ccsr_sfp_regs { u32 srk_hash[NUM_SRKH_REGS]; /* 0x23c Super Root Key Hash */ u32 oem_uid; /* 0x9c OEM Unique ID */ u8 reserved2[0x04]; - u32 ovpr; /* 0xA4 Intent To Secure */ + u32 ovpr; /* 0xA4 Intent To Secure */ u8 reserved4[0x08]; u32 fsl_uid; /* 0xB0 FSL Unique ID */ u8 reserved5[0x04]; @@ -68,19 +68,26 @@ struct ccsr_sfp_regs { #else struct ccsr_sfp_regs { u8 reserved0[0x40]; - u32 ospr; /* 0x40 OEM Security Policy Register */ + u32 ospr; /* 0x40 OEM Security Policy Register */ u8 reserved2[0x38]; u32 srk_hash[8]; /* 0x7c Super Root Key Hash */ - u32 oem_uid; /* 0x9c OEM Unique ID */ + u32 oem_uid; /* 0x9c OEM Unique ID */ u8 reserved4[0x4]; - u32 ovpr; /* 0xA4 OEM Validation Policy Register */ + u32 ovpr; /* 0xA4 OEM Validation Policy Register */ u8 reserved8[0x8]; - u32 fsl_uid; /* 0xB0 FSL Unique ID */ + u32 fsl_uid; /* 0xB0 FSL Unique ID */ }; #endif + #define ITS_MASK 0x00000004 #define ITS_BIT 2 -#define OSPR_KEY_REVOC_SHIFT 13 -#define OSPR_KEY_REVOC_MASK 0x0000e000 + +#if defined(CONFIG_SYS_FSL_SFP_VER_3_4) +#define OSPR_KEY_REVOC_SHIFT 9 +#define OSPR_KEY_REVOC_MASK 0x0000fe00 +#else +#define OSPR_KEY_REVOC_SHIFT 13 +#define OSPR_KEY_REVOC_MASK 0x0000e000 +#endif /* CONFIG_SYS_FSL_SFP_VER_3_4 */
#endif
I guess you mean "SFP v3.4 supports 8 keys ...".
Please don't mix whitespace change in this patch.
York
-----Original Message----- From: york sun Sent: Wednesday, August 31, 2016 9:04 PM To: Sumit Garg sumit.garg@nxp.com; u-boot@lists.denx.de Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Ruchika Gupta ruchika.gupta@nxp.com Subject: Re: [u-boot-release] [PATCH] fsl_sfp : Modify macros as per changes in SFP v3.4
I will correct this.
York
Should I split this patch and make a separate patch for the cleanup?
-Sumit
York
A cleanup is welcomed. If needed, it should be in a separated patch.
York
Sumit Garg
york sun
