[PATCH v3 0/4] Add octal DTR support for Macronix flash
This series add support for Macronix octal DTR flash, add second time Softreset with "INVERT" command extension type and follow linux kernel to enable 4byte opcode when possible.
v3: Add flag SPI_NOR_CMD_EXT_INVERT to seperate command extension types. replace CONFIG_SPI_FLASH_MACRONIX with SPI_FLASH_MACRONIX_OCTAL for spi_nor_macronix_octal_dtr_enable function. v2: add ret checking for write enable in spi_nor_macronix_octal_dtr_enable function.
JaimeLiao (4): mtd: spi-nor: macronix: add support for Macronix Octal mtd: spi-nor-core: Adding different type of command extension in Soft Reset mtd: spi-nor-core: set 4byte opcode when possible mtd: spi-nor-core: Add support for Macronix Octal flash
drivers/mtd/spi/Kconfig | 13 +++++ drivers/mtd/spi/spi-nor-core.c | 94 +++++++++++++++++++++++++++++++++- drivers/mtd/spi/spi-nor-ids.c | 22 +++++++- include/linux/mtd/spi-nor.h | 13 ++++- 4 files changed, 138 insertions(+), 4 deletions(-)
Follow patch "f6adec1af4b2f5d3012480c6cdce7743b74a6156" for adding Macronix flash in Octal DTR mode.
Enable Octal DTR mode with 20 dummy cycles to allow running at the maximum supported frequency. -https://www.mxic.com.tw/Lists/Datasheet/Attachments/7841/MX25LM51245G,%203V,...
Signed-off-by: JaimeLiao jaimeliao.tw@gmail.com --- drivers/mtd/spi/Kconfig | 7 +++ drivers/mtd/spi/spi-nor-core.c | 83 ++++++++++++++++++++++++++++++++++ include/linux/mtd/spi-nor.h | 13 +++++- 3 files changed, 101 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index 1b2ef37e92..67599b32c9 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -162,6 +162,13 @@ config SPI_FLASH_MACRONIX help Add support for various Macronix SPI flash chips (MX25Lxxx)
+config SPI_FLASH_MACRONIX_OCTAL + bool "Macronix octal flash support" + depends on SPI_FLASH_MACRONIX + help + Add support for the Macronix octal flash. This is a separate config + because the fixup hooks octal enable for this flash. + config SPI_FLASH_SPANSION bool "Spansion SPI flash support" help diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index d5d905fa5a..b8dda02aa7 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -3489,6 +3489,85 @@ static struct spi_nor_fixups mt35xu512aba_fixups = { }; #endif /* CONFIG_SPI_FLASH_MT35XU */
+#ifdef CONFIG_SPI_FLASH_MACRONIX_OCTAL +/** + * spi_nor_macronix_octal_dtr_enable() - set DTR OPI Enable bit in Configuration Register 2. + * @nor: pointer to a 'struct spi_nor' + * + * Set the DTR OPI Enable (DOPI) bit in Configuration Register 2. + * Bit 2 of Configuration Register 2 is the DOPI bit for Macronix like OPI memories. + * + * Return: 0 on success, -errno otherwise. + */ +static int spi_nor_macronix_octal_dtr_enable(struct spi_nor *nor) +{ + struct spi_mem_op op; + int ret; + u8 buf; + + ret = write_enable(nor); + if (ret) + return ret; + + buf = SPINOR_REG_MXIC_DC_20; + op = (struct spi_mem_op) + SPI_MEM_OP(SPI_MEM_OP_CMD(SPINOR_OP_WR_CR2, 1), + SPI_MEM_OP_ADDR(4, SPINOR_REG_MXIC_CR2_DC, 1), + SPI_MEM_OP_NO_DUMMY, + SPI_MEM_OP_DATA_OUT(1, &buf, 1)); + + ret = spi_mem_exec_op(nor->spi, &op); + if (ret) + return ret; + + ret = spi_nor_wait_till_ready(nor); + if (ret) + return ret; + + nor->read_dummy = MXIC_MAX_DC; + ret = write_enable(nor); + if (ret) + return ret; + + buf = SPINOR_REG_MXIC_OPI_DTR_EN; + op = (struct spi_mem_op) + SPI_MEM_OP(SPI_MEM_OP_CMD(SPINOR_OP_WR_CR2, 1), + SPI_MEM_OP_ADDR(4, SPINOR_REG_MXIC_CR2_MODE, 1), + SPI_MEM_OP_NO_DUMMY, + SPI_MEM_OP_DATA_OUT(1, &buf, 1)); + + ret = spi_mem_exec_op(nor->spi, &op); + if (ret) { + dev_err(nor->dev, "Failed to enable octal DTR mode\n"); + return ret; + } + nor->reg_proto = SNOR_PROTO_8_8_8_DTR; + + return 0; +} + +static void macronix_octal_default_init(struct spi_nor *nor) +{ + nor->octal_dtr_enable = spi_nor_macronix_octal_dtr_enable; +} + +static void macronix_octal_post_sfdp_fixup(struct spi_nor *nor, + struct spi_nor_flash_parameter *params) +{ + /* + * Adding SNOR_HWCAPS_PP_8_8_8_DTR in hwcaps.mask when + * SPI_NOR_OCTAL_DTR_READ flag exists. + */ + if (params->hwcaps.mask & SNOR_HWCAPS_READ_8_8_8_DTR) + params->hwcaps.mask |= SNOR_HWCAPS_PP_8_8_8_DTR; +} + +static struct spi_nor_fixups macronix_octal_fixups = { + .default_init = macronix_octal_default_init, + .post_sfdp = macronix_octal_post_sfdp_fixup, +}; +#endif /* CONFIG_SPI_FLASH_MACRONIX_OCTAL */ + /** spi_nor_octal_dtr_enable() - enable Octal DTR I/O if needed * @nor: pointer to a 'struct spi_nor' * @@ -3655,6 +3734,10 @@ void spi_nor_set_fixups(struct spi_nor *nor) if (!strcmp(nor->info->name, "mt35xu512aba")) nor->fixups = &mt35xu512aba_fixups; #endif + +#ifdef CONFIG_SPI_FLASH_MACRONIX_OCTAL + nor->fixups = ¯onix_octal_fixups; +#endif }
int spi_nor_scan(struct spi_nor *nor) diff --git a/include/linux/mtd/spi-nor.h b/include/linux/mtd/spi-nor.h index 7ddc4ba2bf..2ad579f66d 100644 --- a/include/linux/mtd/spi-nor.h +++ b/include/linux/mtd/spi-nor.h @@ -116,8 +116,17 @@ #define XSR_RDY BIT(7) /* Ready */
/* Used for Macronix and Winbond flashes. */ -#define SPINOR_OP_EN4B 0xb7 /* Enter 4-byte mode */ -#define SPINOR_OP_EX4B 0xe9 /* Exit 4-byte mode */ +#define SPINOR_OP_EN4B 0xb7 /* Enter 4-byte mode */ +#define SPINOR_OP_EX4B 0xe9 /* Exit 4-byte mode */ +#define SPINOR_OP_RD_CR2 0x71 /* Read configuration register 2 */ +#define SPINOR_OP_WR_CR2 0x72 /* Write configuration register 2 */ +#define SPINOR_OP_MXIC_DTR_RD 0xee /* Fast Read opcode in DTR mode */ +#define SPINOR_REG_MXIC_CR2_MODE 0x00000000 /* For setting octal DTR mode */ +#define SPINOR_REG_MXIC_OPI_DTR_EN 0x2 /* Enable Octal DTR */ +#define SPINOR_REG_MXIC_OPI_DTR_DIS 0x1 /* Disable Octal DTR */ +#define SPINOR_REG_MXIC_CR2_DC 0x00000300 /* For setting dummy cycles */ +#define SPINOR_REG_MXIC_DC_20 0x0 /* Setting dummy cycles to 20 */ +#define MXIC_MAX_DC 20 /* Maximum value of dummy cycles */
/* Used for Spansion flashes only. */ #define SPINOR_OP_BRWR 0x17 /* Bank register write */
Power-on-Reset is a method to restore flash back to 1S-1S-1S mode from 8D-8D-8D in the begging of probe.
Command extension type is not standardized across flash vendors in DTR mode.
For suiting different vendor flash devices, adding a flag to seperate types if nor->cmd_ext_type didn't configure from SFDP.
Signed-off-by: JaimeLiao jaimeliao.tw@gmail.com --- drivers/mtd/spi/Kconfig | 6 ++++++ drivers/mtd/spi/spi-nor-core.c | 7 ++++++- 2 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index 67599b32c9..d850480401 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -97,6 +97,12 @@ config SPI_FLASH_SMART_HWCAPS can support a type of operation in a much more refined way compared to using flags like SPI_RX_DUAL, SPI_TX_QUAD, etc.
+config SPI_NOR_CMD_EXT_INVERT + bool "Command extension type is INVERT for SPI NOR flashed" + default n + help + Define command extension type is INVERT. + config SPI_FLASH_SOFT_RESET bool "Software Reset support for SPI NOR flashes" default n diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index b8dda02aa7..4bcd58d839 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -3661,7 +3661,12 @@ static int spi_nor_soft_reset(struct spi_nor *nor) enum spi_nor_cmd_ext ext;
ext = nor->cmd_ext_type; - nor->cmd_ext_type = SPI_NOR_EXT_REPEAT; + if (!nor->cmd_ext_type) { + nor->cmd_ext_type = SPI_NOR_EXT_REPEAT; +#ifdef CONFIG_SPI_NOR_CMD_EXT_INVERT + nor->cmd_ext_type = SPI_NOR_EXT_INVERT; +#endif + }
op = (struct spi_mem_op)SPI_MEM_OP(SPI_MEM_OP_CMD(SPINOR_OP_SRSTEN, 0), SPI_MEM_OP_NO_DUMMY,
Typo: begging -> beginning
No, the code does not do what the commit message says. The code only sets the extension for soft reset, which is then reset back to the default at the end of the function. Then we read from SFDP and do the usual initialization.
Let's only have this extension for the soft reset on boot, and then let the usual initialization process discover it via SFDP. This will make the code a little less complicated IMO.
So I suggest calling it SPI_NOR_BOOT_SOFT_RESET_EXT.
- bool "Command extension type is INVERT for SPI NOR flashed"
- default n
- help
And explain here that this only sets the extension for the soft reset on boot since we can't discover it at that point. Then we drop the information and rediscover it as normal via SFDP or flash fixup hooks.
- if (!nor->cmd_ext_type) {
Use (nor->cmd_ext_type == SPI_NOR_EXT_NONE). Also add a comment explaining here why you do this check.
Avoid using #ifdef. You can replace it with
if (CONFIG_IS_ENABLED(SPI_NOR_CMD_EXT_INVERT)) nor->cmd_ext_type = SPI_NOR_EXT_INVERT; else nor->cmd_ext_type = SPI_NOR_EXT_REPEAT;
-- 2.17.1
Following linux kernel to check address width and 4byte flag to enable 4byte opcode setting.
Signed-off-by: JaimeLiao jaimeliao.tw@gmail.com --- drivers/mtd/spi/spi-nor-core.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 4bcd58d839..81c61d87bc 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -3902,6 +3902,10 @@ int spi_nor_scan(struct spi_nor *nor) return -EINVAL; }
+ /* Set 4byte opcodes when possible. */ + if (nor->addr_width == 4 && info->flags & SPI_NOR_4B_OPCODES) + spi_nor_set_4byte_opcodes(nor, info); + /* Send all the required SPI flash commands to initialize device */ ret = spi_nor_init(nor); if (ret)
- /* Set 4byte opcodes when possible. */
- if (nor->addr_width == 4 && info->flags & SPI_NOR_4B_OPCODES)
This is already done a few lines above. Why do you need to do it again?
- /* Send all the required SPI flash commands to initialize device */ ret = spi_nor_init(nor); if (ret)
-- 2.17.1
if (spi_nor_protocol_is_dtr(nor->read_proto)) { /* Always use 4-byte addresses in DTR mode. */ nor->addr_width = 4;
because of nor->addr_width have been set to 4 when protocol is dtr
} else if (nor->addr_width) { /* already configured from SFDP */ } else if (info->addr_width) { nor->addr_width = info->addr_width; } else { nor->addr_width = 3; } if (nor->addr_width == 3 && mtd->size > SZ_16M) {
#ifndef CONFIG_SPI_FLASH_BAR /* enable 4-byte addressing if the device exceeds 16MiB */ nor->addr_width = 4; if (JEDEC_MFR(info) == SNOR_MFR_SPANSION || info->flags & SPI_NOR_4B_OPCODES) spi_nor_set_4byte_opcodes(nor, info);
nor->addr_width is equal 4 when protocol is dtr so we need a judgement to do spi_nor_set_4byte_opcodes(nor, info)
#else /* Configure the BAR - discover bank cmds and read current bank */ nor->addr_width = 3; ret = read_bar(nor, info); if (ret < 0) return ret; #endif }
Pratyush Yadav p.yadav@ti.com 於 2021年9月25日 週六 上午2:29寫道:
-- 2.17.1
-- Regards, Pratyush Yadav Texas Instruments Inc.
Adding Macronix Octal flash for Octal DTR support.
The octaflash series can be divided into the following types:
MX25 series : Serial NOR Flash. MX66 series : Serial NOR Flash with stacked die.(Size larger than 1Gb) LM/UM series : Up to 250MHz clock frequency with both DTR/STR operation. LW/UW series : Support simultaneous Read-while-Write operation in multiple bank architecture. Read-while-write feature which means read data one bank while another bank is programing or erasing.
MX25LM : 3.0V Octal I/O -https://www.mxic.com.tw/Lists/Datasheet/Attachments/7841/MX25LM51245G,%203V,...
MX25UM : 1.8V Octal I/O -https://www.mxic.com.tw/Lists/Datasheet/Attachments/7525/MX25UM51245G%20Extr...
MX66LM : 3.0V Octal I/O with stacked die -https://www.mxic.com.tw/Lists/Datasheet/Attachments/7929/MX66LM1G45G,%203V,%...
MX66UM : 1.8V Octal I/O with stacked die -https://www.mxic.com.tw/Lists/Datasheet/Attachments/7721/MX66UM1G45G,%201.8V...
MX25LW : 3.0V Octal I/O with Read-while-Write MX25UW : 1.8V Octal I/O with Read-while-Write MX66LW : 3.0V Octal I/O with Read-while-Write and stack die MX66UW : 1.8V Octal I/O with Read-while-Write and stack die
About LW/UW series, please contact us freely if you have any questions. For adding Octal NOR Flash IDs, we have validated each Flash on plateform zynq-picozed.
Signed-off-by: JaimeLiao jaimeliao.tw@gmail.com --- drivers/mtd/spi/spi-nor-ids.c | 22 +++++++++++++++++++++- 1 file changed, 21 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index cb3a08872d..5c13ea3a78 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -169,7 +169,27 @@ const struct flash_info spi_nor_ids[] = { { INFO("mx66l1g45g", 0xc2201b, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("mx25l1633e", 0xc22415, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | SECT_4K) }, { INFO("mx25r6435f", 0xc22817, 0, 64 * 1024, 128, SECT_4K) }, - { INFO("mx66uw2g345g", 0xc2943c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66uw2g345gx0", 0xc2943c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66lm1g45g", 0xc2853b, 0, 32 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25lm51245g", 0xc2853a, 0, 16 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25lw51245g", 0xc2863a, 0, 16 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25lm25645g", 0xc28539, 0, 8 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66um2g45g", 0xc2803c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66uw2g345g", 0xc2843c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66um1g45g", 0xc2803b, 0, 32 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66uw1g45g", 0xc2813b, 0, 32 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25um51245g", 0xc2803a, 0, 16 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw51245g", 0xc2813a, 0, 16 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw51345g", 0xc2843a, 0, 16 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25um25645g", 0xc28039, 0, 8 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw25645g", 0xc28139, 0, 8 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25um25345g", 0xc28339, 0, 8 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw25345g", 0xc28439, 0, 8 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw12845g", 0xc28138, 0, 4 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw12a45g", 0xc28938, 0, 4 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw12345g", 0xc28438, 0, 4 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw6445g", 0xc28137, 0, 2 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw6345g", 0xc28437, 0, 2 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, #endif
#ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */
JaimeLiao
liao jaime
Pratyush Yadav
