[U-Boot-Users] [PATCH] Remove unneeded #include <malloc.h>
Hi Wolfgang,
this u-patch is remnant of my effort to have malloc pool in SDRAM and the rest of U-Boot in SRAM.
Best regards, ladis
Index: common/env_dataflash.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/common/env_dataflash.c,v retrieving revision 1.1 diff -u -r1.1 env_dataflash.c --- common/env_dataflash.c 6 Dec 2003 23:55:11 -0000 1.1 +++ common/env_dataflash.c 22 Feb 2005 11:04:56 -0000 @@ -24,7 +24,6 @@ #include <command.h> #include <environment.h> #include <linux/stddef.h> -#include <malloc.h> #include <dataflash.h>
env_t *env_ptr = NULL; Index: common/env_eeprom.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/common/env_eeprom.c,v retrieving revision 1.2 diff -u -r1.2 env_eeprom.c --- common/env_eeprom.c 27 Jun 2003 21:32:31 -0000 1.2 +++ common/env_eeprom.c 22 Feb 2005 11:04:56 -0000 @@ -31,7 +31,6 @@ #include <command.h> #include <environment.h> #include <linux/stddef.h> -#include <malloc.h>
Index: common/env_nand.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/common/env_nand.c,v retrieving revision 1.2 diff -u -r1.2 env_nand.c --- common/env_nand.c 19 Jun 2004 21:19:12 -0000 1.2 +++ common/env_nand.c 22 Feb 2005 11:04:56 -0000 @@ -36,7 +36,6 @@ #include <command.h> #include <environment.h> #include <linux/stddef.h> -#include <malloc.h> #include <linux/mtd/nand.h>
#if ((CONFIG_COMMANDS&(CFG_CMD_ENV|CFG_CMD_NAND)) == (CFG_CMD_ENV|CFG_CMD_NAND)) Index: common/env_nowhere.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/common/env_nowhere.c,v retrieving revision 1.1.1.1 diff -u -r1.1.1.1 env_nowhere.c --- common/env_nowhere.c 18 Sep 2002 11:09:59 -0000 1.1.1.1 +++ common/env_nowhere.c 22 Feb 2005 11:04:56 -0000 @@ -31,7 +31,6 @@ #include <command.h> #include <environment.h> #include <linux/stddef.h> -#include <malloc.h>
Index: common/env_nvram.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/common/env_nvram.c,v retrieving revision 1.3 diff -u -r1.3 env_nvram.c --- common/env_nvram.c 27 Jun 2003 21:32:31 -0000 1.3 +++ common/env_nvram.c 22 Feb 2005 11:04:56 -0000 @@ -47,7 +47,6 @@ #include <command.h> #include <environment.h> #include <linux/stddef.h> -#include <malloc.h>
#ifdef CFG_NVRAM_ACCESS_ROUTINE extern void *nvram_read(void *dest, const long src, size_t count); Index: common/main.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/common/main.c,v retrieving revision 1.21 diff -u -r1.21 main.c --- common/main.c 9 Jan 2005 23:33:50 -0000 1.21 +++ common/main.c 22 Feb 2005 11:04:56 -0000 @@ -26,7 +26,6 @@ #include <common.h> #include <watchdog.h> #include <command.h> -#include <malloc.h>
#ifdef CFG_HUSH_PARSER #include <hush.h>
Added, thanks. Please don't forget the CHANGELOG entries!
Ladislav Michl
