Dear Tom,
The following changes since commit af04f37a78c7e61597fb9ed6db2c8f8d7f8b0f92:
Merge tag 'u-boot-stm32-20240419' of https://source.denx.de/u-boot/custodians/u-boot-stm (2024-04-19 14:25:04 -0600)
https://source.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2024-07-rc1-3
for you to fetch changes up to 52c62acc349a0ec1ba26ae497913ad34ee3de733:
x86: all firmware tables must be paragraph aligned (2024-04-20 10:15:03 +0200)
Gitlab CI showed no issues: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/20447
---------------------------------------------------------------- Pull request efi-2024-07-rc1-3
Documentation:
* sort env sub-commands alphabetically * update list of aliases for the env command
UEFI:
* allow enabling SetVariable at runtime for future OS supported writing to ubootefi.var * use event callback for initrd deregistration
Others:
* correct alignment of x86 firmware tables
---------------------------------------------------------------- Heinrich Schuchardt (5): doc: sort env sub-commands alphabetically doc: update list of aliases for the env command cmd: eficonfig: check initrd path allocation efi_loader: typo mstching x86: all firmware tables must be paragraph aligned
Ilias Apalodimas (4): efi_loader: conditionally enable SetvariableRT efi_loader: Add OS notifications for SetVariable at runtime efi_loader: add an EFI variable with the file contents efi_selftest: add tests for setvariableRT
Masahisa Kojima (1): efi_loader: use event callback for initrd deregistration
arch/x86/lib/tables.c | 2 + cmd/eficonfig.c | 2 +- doc/usage/cmd/env.rst | 35 ++-- include/efi_loader.h | 4 + include/efi_variable.h | 16 +- lib/charset.c | 2 +- lib/efi_loader/Kconfig | 16 ++ lib/efi_loader/efi_helper.c | 5 - lib/efi_loader/efi_load_initrd.c | 82 +++++--- lib/efi_loader/efi_runtime.c | 42 ++++ lib/efi_loader/efi_var_common.c | 8 +- lib/efi_loader/efi_var_mem.c | 151 +++++++++------ lib/efi_loader/efi_variable.c | 122 ++++++++++-- lib/efi_loader/efi_variable_tee.c | 5 - lib/efi_selftest/efi_selftest_variables_runtime.c | 222 +++++++++++++++++++++- 15 files changed, 583 insertions(+), 131 deletions(-)
On Sat, Apr 20, 2024 at 12:09:37PM +0200, Heinrich Schuchardt wrote:
Dear Tom,
