[U-Boot] [PATCH] MIPS: start.S: unify and simplify reset vector handling
From: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Adopt reset vector handling from Yamon.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- arch/mips/cpu/mips32/start.S | 185 +++++++++---------------------------------- arch/mips/cpu/mips64/start.S | 55 +++++++------ 2 files changed, 64 insertions(+), 176 deletions(-)
diff --git a/arch/mips/cpu/mips32/start.S b/arch/mips/cpu/mips32/start.S index 65acf7d..a7cd2c4 100644 --- a/arch/mips/cpu/mips32/start.S +++ b/arch/mips/cpu/mips32/start.S @@ -47,19 +47,16 @@ .set pop .endm
-#define RVECENT(f,n) \ - b f; nop -#define XVECENT(f,bev) \ - b f ; \ - li k0,bev - .set noreorder
.globl _start .text _start: - RVECENT(reset,0) # U-boot entry point - RVECENT(reset,1) # software reboot + /* U-boot entry point */ + b reset + nop + nop + nop #ifdef CONFIG_SYS_XWAY_EBU_BOOTCFG /* * Almost all Lantiq XWAY SoC devices have an external bus unit (EBU) to @@ -71,139 +68,40 @@ _start: .word CONFIG_SYS_XWAY_EBU_BOOTCFG .word 0x00000000 #else - RVECENT(romReserved,2) + .word 0xffffffff + .word 0xffffffff #endif - RVECENT(romReserved,3) - RVECENT(romReserved,4) - RVECENT(romReserved,5) - RVECENT(romReserved,6) - RVECENT(romReserved,7) - RVECENT(romReserved,8) - RVECENT(romReserved,9) - RVECENT(romReserved,10) - RVECENT(romReserved,11) - RVECENT(romReserved,12) - RVECENT(romReserved,13) - RVECENT(romReserved,14) - RVECENT(romReserved,15) - RVECENT(romReserved,16) - RVECENT(romReserved,17) - RVECENT(romReserved,18) - RVECENT(romReserved,19) - RVECENT(romReserved,20) - RVECENT(romReserved,21) - RVECENT(romReserved,22) - RVECENT(romReserved,23) - RVECENT(romReserved,24) - RVECENT(romReserved,25) - RVECENT(romReserved,26) - RVECENT(romReserved,27) - RVECENT(romReserved,28) - RVECENT(romReserved,29) - RVECENT(romReserved,30) - RVECENT(romReserved,31) - RVECENT(romReserved,32) - RVECENT(romReserved,33) - RVECENT(romReserved,34) - RVECENT(romReserved,35) - RVECENT(romReserved,36) - RVECENT(romReserved,37) - RVECENT(romReserved,38) - RVECENT(romReserved,39) - RVECENT(romReserved,40) - RVECENT(romReserved,41) - RVECENT(romReserved,42) - RVECENT(romReserved,43) - RVECENT(romReserved,44) - RVECENT(romReserved,45) - RVECENT(romReserved,46) - RVECENT(romReserved,47) - RVECENT(romReserved,48) - RVECENT(romReserved,49) - RVECENT(romReserved,50) - RVECENT(romReserved,51) - RVECENT(romReserved,52) - RVECENT(romReserved,53) - RVECENT(romReserved,54) - RVECENT(romReserved,55) - RVECENT(romReserved,56) - RVECENT(romReserved,57) - RVECENT(romReserved,58) - RVECENT(romReserved,59) - RVECENT(romReserved,60) - RVECENT(romReserved,61) - RVECENT(romReserved,62) - RVECENT(romReserved,63) - XVECENT(romExcHandle,0x200) # bfc00200: R4000 tlbmiss vector - RVECENT(romReserved,65) - RVECENT(romReserved,66) - RVECENT(romReserved,67) - RVECENT(romReserved,68) - RVECENT(romReserved,69) - RVECENT(romReserved,70) - RVECENT(romReserved,71) - RVECENT(romReserved,72) - RVECENT(romReserved,73) - RVECENT(romReserved,74) - RVECENT(romReserved,75) - RVECENT(romReserved,76) - RVECENT(romReserved,77) - RVECENT(romReserved,78) - RVECENT(romReserved,79) - XVECENT(romExcHandle,0x280) # bfc00280: R4000 xtlbmiss vector - RVECENT(romReserved,81) - RVECENT(romReserved,82) - RVECENT(romReserved,83) - RVECENT(romReserved,84) - RVECENT(romReserved,85) - RVECENT(romReserved,86) - RVECENT(romReserved,87) - RVECENT(romReserved,88) - RVECENT(romReserved,89) - RVECENT(romReserved,90) - RVECENT(romReserved,91) - RVECENT(romReserved,92) - RVECENT(romReserved,93) - RVECENT(romReserved,94) - RVECENT(romReserved,95) - XVECENT(romExcHandle,0x300) # bfc00300: R4000 cache vector - RVECENT(romReserved,97) - RVECENT(romReserved,98) - RVECENT(romReserved,99) - RVECENT(romReserved,100) - RVECENT(romReserved,101) - RVECENT(romReserved,102) - RVECENT(romReserved,103) - RVECENT(romReserved,104) - RVECENT(romReserved,105) - RVECENT(romReserved,106) - RVECENT(romReserved,107) - RVECENT(romReserved,108) - RVECENT(romReserved,109) - RVECENT(romReserved,110) - RVECENT(romReserved,111) - XVECENT(romExcHandle,0x380) # bfc00380: R4000 general vector - RVECENT(romReserved,113) - RVECENT(romReserved,114) - RVECENT(romReserved,115) - RVECENT(romReserved,116) - RVECENT(romReserved,116) - RVECENT(romReserved,118) - RVECENT(romReserved,119) - RVECENT(romReserved,120) - RVECENT(romReserved,121) - RVECENT(romReserved,122) - RVECENT(romReserved,123) - RVECENT(romReserved,124) - RVECENT(romReserved,125) - RVECENT(romReserved,126) - RVECENT(romReserved,127)
- /* - * We hope there are no more reserved vectors! - * 128 * 8 == 1024 == 0x400 - * so this is address R_VEC+0x400 == 0xbfc00400 - */ +.org 0x200 + /* TLB refill, 32 bit task */ +1: b 1b + nop + +.org 0x280 + /* XTLB refill, 64 bit task */ +1: b 1b + nop + +.org 0x300 + /* Cache error exception */ +1: b 1b + nop + +.org 0x380 + /* General exception */ +1: b 1b + nop + +.org 0x400 + /* Catch interrupt exceptions */ +1: b 1b + nop + +.org 0x480 + /* EJTAG debug exception */ +1: b 1b + nop + .align 4 reset:
@@ -351,12 +249,3 @@ in_ram: move a1, s2
.end relocate_code - - /* Exception handlers */ -romReserved: - b romReserved - nop - -romExcHandle: - b romExcHandle - nop diff --git a/arch/mips/cpu/mips64/start.S b/arch/mips/cpu/mips64/start.S index 1522594..0628211 100644 --- a/arch/mips/cpu/mips64/start.S +++ b/arch/mips/cpu/mips64/start.S @@ -52,40 +52,44 @@ .globl _start .text _start: - .org 0x000 + /* U-boot entry point */ b reset nop - .org 0x080 - b romReserved nop - .org 0x100 - b romReserved nop - .org 0x180 - b romReserved + .word 0xffffffff + .word 0xffffffff + +.org 0x200 + /* TLB refill, 32 bit task */ +1: b 1b nop - .org 0x200 - b romReserved + +.org 0x280 + /* XTLB refill, 64 bit task */ +1: b 1b nop - .org 0x280 - b romReserved + +.org 0x300 + /* Cache error exception */ +1: b 1b nop - .org 0x300 - b romReserved + +.org 0x380 + /* General exception */ +1: b 1b nop - .org 0x380 - b romReserved + +.org 0x400 + /* Catch interrupt exceptions */ +1: b 1b nop - .org 0x480 - b romReserved + +.org 0x480 + /* EJTAG debug exception */ +1: b 1b nop
- /* - * We hope there are no more reserved vectors! - * 128 * 8 == 1024 == 0x400 - * so this is address R_VEC+0x400 == 0xbfc00400 - */ - .org 0x500 .align 4 reset:
@@ -238,8 +242,3 @@ in_ram: move a1, s2
Hi Daniel,
- b f; nop
b f ; \
li k0,bev
.set noreorder
.globl _start .text
_start:
- /* U-boot entry point */
- b reset
nop
nop
nop
We should use '.org 0x010' here, that would make it it consistent with the rest of the code. Additionally, that would make it possible to remove the last two 'nop' instructions before the ifdef.
- .word 0xffffffff
- .word 0xffffffff
I assume that Yamon uses these two words to ensure that there will be no instructions at this address because this overlaps with the REVISION register on the MIPS boards. U-Boot does not support MIPS development boards yet, so strictly speaking we don't need this at the moment.
#endif
+.org 0x200
The indentation of this looks weird. All other pseudo op-codes are preceded by a tab. It would be more consistent to add a tab before each '.org'.
- /* TLB refill, 32 bit task */
+1: b 1b
nop
- .org 0x000
- /* U-boot entry point */ b reset nop
- .org 0x080
- b romReserved nop
- .org 0x100
- b romReserved nop
- .org 0x180
- b romReserved
- .word 0xffffffff
- .word 0xffffffff
These two words and the preceding two nop instructions should be removed as well.
+.org 0x200
+1: b 1b nop
- .org 0x200
The previous comment for the '.org' op-codes applies here as well. Even the patch would be a bit simpler if you would not remove the leading tabs.
-Gabor
2013/1/31 Gabor Juhos juhosg@openwrt.org:
Hi Daniel,
- b f; nop
b f ; \
li k0,bev
.set noreorder .globl _start .text
_start:
b reset
nop
nop
nop
ok, fixed
.word 0xffffffff
.word 0xffffffff
ok, I only init the words for Lantiq SoC's and let the assembler fill the gap with zeroes
#endif
+.org 0x200
yes, fixed
+1: b 1b
nop
.org 0x000
.org 0x080
b romReserved nop
.org 0x100
b romReserved nop
.org 0x180
b romReserved
.word 0xffffffff
.word 0xffffffff
+.org 0x200
+1: b 1b nop
.org 0x200
-Gabor
thanks for the comments
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- Changes for v2: - optimized U-Boot entry point on MIPS32 - fix indentation of .org
--- arch/mips/cpu/mips32/start.S | 186 +++++++++---------------------------------- arch/mips/cpu/mips64/start.S | 47 +++++------ 2 files changed, 57 insertions(+), 176 deletions(-)
diff --git a/arch/mips/cpu/mips32/start.S b/arch/mips/cpu/mips32/start.S index 65acf7d..7373d4e 100644 --- a/arch/mips/cpu/mips32/start.S +++ b/arch/mips/cpu/mips32/start.S @@ -47,19 +47,16 @@ .set pop .endm
.globl _start .text _start: - RVECENT(reset,0) # U-boot entry point - RVECENT(reset,1) # software reboot + /* U-boot entry point */ + b reset + nop + + .org 0x10 #ifdef CONFIG_SYS_XWAY_EBU_BOOTCFG /* * Almost all Lantiq XWAY SoC devices have an external bus unit (EBU) to @@ -69,141 +66,39 @@ _start: * device with correct parameters. This config option is board-specific. */ .word CONFIG_SYS_XWAY_EBU_BOOTCFG - .word 0x00000000 -#else - RVECENT(romReserved,2) + .word 0x0 #endif - RVECENT(romReserved,3) - RVECENT(romReserved,4) - RVECENT(romReserved,5) - RVECENT(romReserved,6) - RVECENT(romReserved,7) - RVECENT(romReserved,8) - RVECENT(romReserved,9) - RVECENT(romReserved,10) - RVECENT(romReserved,11) - RVECENT(romReserved,12) - RVECENT(romReserved,13) - RVECENT(romReserved,14) - RVECENT(romReserved,15) - RVECENT(romReserved,16) - RVECENT(romReserved,17) - RVECENT(romReserved,18) - RVECENT(romReserved,19) - RVECENT(romReserved,20) - RVECENT(romReserved,21) - RVECENT(romReserved,22) - RVECENT(romReserved,23) - RVECENT(romReserved,24) - RVECENT(romReserved,25) - RVECENT(romReserved,26) - RVECENT(romReserved,27) - RVECENT(romReserved,28) - RVECENT(romReserved,29) - RVECENT(romReserved,30) - RVECENT(romReserved,31) - RVECENT(romReserved,32) - RVECENT(romReserved,33) - RVECENT(romReserved,34) - RVECENT(romReserved,35) - RVECENT(romReserved,36) - RVECENT(romReserved,37) - RVECENT(romReserved,38) - RVECENT(romReserved,39) - RVECENT(romReserved,40) - RVECENT(romReserved,41) - RVECENT(romReserved,42) - RVECENT(romReserved,43) - RVECENT(romReserved,44) - RVECENT(romReserved,45) - RVECENT(romReserved,46) - RVECENT(romReserved,47) - RVECENT(romReserved,48) - RVECENT(romReserved,49) - RVECENT(romReserved,50) - RVECENT(romReserved,51) - RVECENT(romReserved,52) - RVECENT(romReserved,53) - RVECENT(romReserved,54) - RVECENT(romReserved,55) - RVECENT(romReserved,56) - RVECENT(romReserved,57) - RVECENT(romReserved,58) - RVECENT(romReserved,59) - RVECENT(romReserved,60) - RVECENT(romReserved,61) - RVECENT(romReserved,62) - RVECENT(romReserved,63) - XVECENT(romExcHandle,0x200) # bfc00200: R4000 tlbmiss vector - RVECENT(romReserved,65) - RVECENT(romReserved,66) - RVECENT(romReserved,67) - RVECENT(romReserved,68) - RVECENT(romReserved,69) - RVECENT(romReserved,70) - RVECENT(romReserved,71) - RVECENT(romReserved,72) - RVECENT(romReserved,73) - RVECENT(romReserved,74) - RVECENT(romReserved,75) - RVECENT(romReserved,76) - RVECENT(romReserved,77) - RVECENT(romReserved,78) - RVECENT(romReserved,79) - XVECENT(romExcHandle,0x280) # bfc00280: R4000 xtlbmiss vector - RVECENT(romReserved,81) - RVECENT(romReserved,82) - RVECENT(romReserved,83) - RVECENT(romReserved,84) - RVECENT(romReserved,85) - RVECENT(romReserved,86) - RVECENT(romReserved,87) - RVECENT(romReserved,88) - RVECENT(romReserved,89) - RVECENT(romReserved,90) - RVECENT(romReserved,91) - RVECENT(romReserved,92) - RVECENT(romReserved,93) - RVECENT(romReserved,94) - RVECENT(romReserved,95) - XVECENT(romExcHandle,0x300) # bfc00300: R4000 cache vector - RVECENT(romReserved,97) - RVECENT(romReserved,98) - RVECENT(romReserved,99) - RVECENT(romReserved,100) - RVECENT(romReserved,101) - RVECENT(romReserved,102) - RVECENT(romReserved,103) - RVECENT(romReserved,104) - RVECENT(romReserved,105) - RVECENT(romReserved,106) - RVECENT(romReserved,107) - RVECENT(romReserved,108) - RVECENT(romReserved,109) - RVECENT(romReserved,110) - RVECENT(romReserved,111) - XVECENT(romExcHandle,0x380) # bfc00380: R4000 general vector - RVECENT(romReserved,113) - RVECENT(romReserved,114) - RVECENT(romReserved,115) - RVECENT(romReserved,116) - RVECENT(romReserved,116) - RVECENT(romReserved,118) - RVECENT(romReserved,119) - RVECENT(romReserved,120) - RVECENT(romReserved,121) - RVECENT(romReserved,122) - RVECENT(romReserved,123) - RVECENT(romReserved,124) - RVECENT(romReserved,125) - RVECENT(romReserved,126) - RVECENT(romReserved,127)
- /* - * We hope there are no more reserved vectors! - * 128 * 8 == 1024 == 0x400 - * so this is address R_VEC+0x400 == 0xbfc00400 - */ + .org 0x200 + /* TLB refill, 32 bit task */ +1: b 1b + nop + + .org 0x280 + /* XTLB refill, 64 bit task */ +1: b 1b + nop + + .org 0x300 + /* Cache error exception */ +1: b 1b + nop + + .org 0x380 + /* General exception */ +1: b 1b + nop + + .org 0x400 + /* Catch interrupt exceptions */ +1: b 1b + nop + + .org 0x480 + /* EJTAG debug exception */ +1: b 1b + nop + .align 4 reset:
@@ -351,12 +246,3 @@ in_ram: move a1, s2
.end relocate_code - - /* Exception handlers */ -romReserved: - b romReserved - nop - -romExcHandle: - b romExcHandle - nop diff --git a/arch/mips/cpu/mips64/start.S b/arch/mips/cpu/mips64/start.S index 1522594..c0ae41a 100644 --- a/arch/mips/cpu/mips64/start.S +++ b/arch/mips/cpu/mips64/start.S @@ -52,40 +52,40 @@ .globl _start .text _start: - .org 0x000 + /* U-boot entry point */ b reset nop - .org 0x080 - b romReserved - nop - .org 0x100 - b romReserved - nop - .org 0x180 - b romReserved - nop + .org 0x200 - b romReserved + /* TLB refill, 32 bit task */ +1: b 1b nop + .org 0x280 - b romReserved + /* XTLB refill, 64 bit task */ +1: b 1b nop + .org 0x300 - b romReserved + /* Cache error exception */ +1: b 1b nop + .org 0x380 - b romReserved + /* General exception */ +1: b 1b nop + + .org 0x400 + /* Catch interrupt exceptions */ +1: b 1b + nop + .org 0x480 - b romReserved + /* EJTAG debug exception */ +1: b 1b nop
@@ -238,8 +238,3 @@ in_ram: move a1, s2
Hi Daniel,
Looks good, I have only one minor comment below.
Changes for v2:
- b f; nop
b f ; \
li k0,bev
.set noreorder
.globl _start .text
_start:
- b reset
nop
- .org 0x10
The .org should be within the ifdef. Although it does not change the generated binary code, but logically it would be a more correct place. Sorry, I should have mentioned that in the previous mail.
-Gabor
2013/2/1 Gabor Juhos juhosg@openwrt.org:
Hi Daniel,
Changes for v2:
- b f; nop
b f ; \
li k0,bev
_start:
b reset
nop
.org 0x10
-Gabor
I think we should keep it outside. If we add qemu-malta, then we get another #if branch. I also would like to move some register inits (watch, timer, status) to slightly reduce binary size.
Hello Daniel,
Daniel Schwierzeck wrote on 2013-02-01:
Hi Daniel,
Changes for v2:
arch/mips/cpu/mips32/start.S | 186 +++++++++---------------------------------- arch/mips/cpu/mips64/start.S | 47 +++++------ 2 files changed, 57 insertions(+), 176 deletions(-) diff --git a/arch/mips/cpu/mips32/start.S b/arch/mips/cpu/mips32/start.S index 65acf7d..7373d4e 100644 --- a/arch/mips/cpu/mips32/start.S +++ b/arch/mips/cpu/mips32/start.S @@ -47,19 +47,16 @@ .set pop .endm -#define RVECENT(f,n) \
- b f; nop
b f ; \
li k0,bev
_start:
b reset
nop
.org 0x10
-Gabor
In addition you could completely remove these exception vectors for u-boot binaries, which will be loaded from SPI- or NAND-flash (or some other storage, which is not memory mapped), which typically involves some ROM code. In this case, the vectors are already part of the ROM.
Best Regards, Thomas
b reset
nop
.org 0x10
-Gabor
Ok, it does not really matter now. The .org can be moved into the ifdef later when there will be a board which needs some other magic value at 0x14 for example.
Hm, do you want to initialize those registers between the reserved vectors?
-Gabor
Daniel Schwierzeck
Gabor Juhos
Langer Thomas (LQDE RD ST PON SW)
