[U-Boot] Please pull u-boot-mpc83xx
WD,
u-boot-mpc83xx added support for two new boards - the keymile1 and the SIMPC8313 - plus PCI-E support and mostly nand-related fixes. Please pull:
The following changes since commit 6dadc9195ad642cc662632f4d92f92d3d71e8bf2: Mike Frysinger (1): Blackfin: use common strmhz() in system output
git://git.denx.de/u-boot-mpc83xx.git master
Anton Vorontsov (3): mpc83xx: Add support for MPC83xx PCI-E controllers mpc83xx: Add PCI-E support for MPC8315ERDB boards mpc83xx: Add PCI-E support for MPC837XEMDS boards
Heiko Schocher (3): powerpc: 83xx: add support for the kmeter1 board powerpc: keymile: Add a check for the PIGGY debug board powerpc, keymile boards: extract identical config options
Ira Snyder (2): 83xx: PCI agent mode fixes for multi-board systems MPC8349EMDS: do not setup unused PCI clock outputs in PCI agent mode
Ron Madrid (2): mpc83xx: Size optimization of start.S mpc83xx: New board support for SIMPC8313
Scott Wood (1): 83xx: Use the proper sequence for updating IMMR.
MAINTAINERS | 5 + MAKEALL | 2 + Makefile | 18 + board/freescale/mpc8315erdb/mpc8315erdb.c | 52 +++ board/freescale/mpc8349emds/pci.c | 7 - board/freescale/mpc837xemds/mpc837xemds.c | 6 +- board/freescale/mpc837xemds/pci.c | 89 +++++- board/freescale/mpc837xemds/pci.h | 6 + board/keymile/common/common.c | 23 +- board/keymile/common/common.h | 20 + board/keymile/kmeter1/Makefile | 53 +++ board/keymile/kmeter1/config.mk | 24 ++ board/keymile/kmeter1/kmeter1.c | 158 ++++++++ board/keymile/mgcoge/mgcoge.c | 10 +- board/keymile/mgsuvd/mgsuvd.c | 8 +- board/sheldon/simpc8313/Makefile | 50 +++ board/sheldon/simpc8313/config.mk | 13 + board/sheldon/simpc8313/sdram.c | 193 ++++++++++ board/sheldon/simpc8313/simpc8313.c | 134 +++++++ cpu/mpc83xx/Makefile | 1 + cpu/mpc83xx/pci.c | 5 + cpu/mpc83xx/pcie.c | 314 +++++++++++++++ cpu/mpc83xx/speed.c | 4 +- cpu/mpc83xx/start.S | 95 +++-- doc/README.kmeter1 | 91 +++++ doc/README.simpc8313 | 80 ++++ include/asm-ppc/global_data.h | 2 +- include/asm-ppc/immap_83xx.h | 119 ++++++- include/configs/MPC8315ERDB.h | 21 + include/configs/MPC837XEMDS.h | 21 + include/configs/SIMPC8313.h | 544 +++++++++++++++++++++++++++ include/configs/keymile-common.h | 113 ++++++ include/configs/kmeter1.h | 457 ++++++++++++++++++++++ include/configs/mgcoge.h | 51 +--- include/configs/mgsuvd.h | 72 +---- include/mpc83xx.h | 68 +++- include/pci.h | 4 + nand_spl/board/sheldon/simpc8313/Makefile | 100 +++++ nand_spl/board/sheldon/simpc8313/u-boot.lds | 52 +++ 39 files changed, 2883 insertions(+), 202 deletions(-) create mode 100644 board/freescale/mpc837xemds/pci.h create mode 100644 board/keymile/common/common.h create mode 100644 board/keymile/kmeter1/Makefile create mode 100644 board/keymile/kmeter1/config.mk create mode 100644 board/keymile/kmeter1/kmeter1.c create mode 100644 board/sheldon/simpc8313/Makefile create mode 100644 board/sheldon/simpc8313/config.mk create mode 100644 board/sheldon/simpc8313/sdram.c create mode 100644 board/sheldon/simpc8313/simpc8313.c create mode 100644 cpu/mpc83xx/pcie.c create mode 100644 doc/README.kmeter1 create mode 100644 doc/README.simpc8313 create mode 100644 include/configs/SIMPC8313.h create mode 100644 include/configs/keymile-common.h create mode 100644 include/configs/kmeter1.h create mode 100644 nand_spl/board/sheldon/simpc8313/Makefile create mode 100644 nand_spl/board/sheldon/simpc8313/u-boot.lds
Thanks,
Kim
Dear Kim Phillips,
In message 20090123181051.dc935d8f.kim.phillips@freescale.com you wrote:
WD,
Done, thanks.
Kim Phillips
