[U-Boot] [PATCH] nios2: add memory to board info
Run setup_board_part1/2 and add memory information to board info structure. So that it can display correct values in bdinfo command.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- common/board_f.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index d88ada3..6ab74d9 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -551,7 +551,7 @@ static int display_new_sp(void) return 0; }
-#if defined(CONFIG_PPC) || defined(CONFIG_M68K) +#if defined(CONFIG_PPC) || defined(CONFIG_M68K) || defined(CONFIG_NIOS2) static int setup_board_part1(void) { bd_t *bd = gd->bd; @@ -933,7 +933,7 @@ static init_fnc_t init_sequence_f[] = { reserve_stacks, setup_dram_config, show_dram_config, -#if defined(CONFIG_PPC) || defined(CONFIG_M68K) +#if defined(CONFIG_PPC) || defined(CONFIG_M68K) || defined(CONFIG_NIOS2) setup_board_part1, INIT_FUNC_WATCHDOG_RESET setup_board_part2,
This looks like some ancient code, due to the fact that it's used on PPC and M68K only, but not on ARM for example.
Best regards, Marek Vasut
Hi Marek,
Thanks for the review. I will try to follow ARM's.
Best regards, Thomas
Use dram bank in board info, so that it displays correct memory values in bdinfo command.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 change to use dram bank.
common/cmd_bdinfo.c | 9 +++++++-- include/configs/nios2-generic.h | 1 + 2 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index ed3b935..adda55a 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -157,10 +157,15 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { + int i; bd_t *bd = gd->bd;
- print_num("mem start", (ulong)bd->bi_memstart); - print_lnum("mem size", (u64)bd->bi_memsize); + for (i = 0; i < CONFIG_NR_DRAM_BANKS; ++i) { + print_num("DRAM bank", i); + print_num("-> start", bd->bi_dram[i].start); + print_num("-> size", bd->bi_dram[i].size); + } + print_num("flash start", (ulong)bd->bi_flashstart); print_num("flash size", (ulong)bd->bi_flashsize); print_num("flash offset", (ulong)bd->bi_flashoffset); diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index b38513e..53a9f10 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -77,6 +77,7 @@ */ #define CONFIG_SYS_SDRAM_BASE 0xD0000000 #define CONFIG_SYS_SDRAM_SIZE 0x08000000 +#define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_MONITOR_IS_IN_RAM #define CONFIG_SYS_MONITOR_LEN 0x40000 /* Reserve 256k */ #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_SDRAM_BASE + \
Acked-by: Marek Vasut marex@denx.de
btw. eventually, these fragments of code might have to be unified into some common code, but that's for some other time.
Applied to u-boot-nios.
Thomas Chou
