The following changes since commit 85bafb6da4dddfffa78479aa49a72ae48578a4ce:
Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriq (2014-11-26 11:23:26 -0500)
git://git.denx.de/u-boot-nand-flash.git
for you to fetch changes up to b19157bf3f2345586f2db8a0f8f92cc54f527952:
mtd: nand: s3c: Unify the register definition and naming (2014-11-26 23:21:43 -0600)
---------------------------------------------------------------- Marek Vasut (1): mtd: nand: s3c: Unify the register definition and naming
Masahiro Yamada (2): mtd: denali: use CONFIG_SYS_NAND_SELF_INIT mtd: denali: set some registers after nand_scan_ident()
Rostislav Lisovy (1): nand: reinstate lazy bad block scanning
Sanchayan Maity (1): mtd/nand/vf610_nfc: Disable subpage writes
arch/arm/include/asm/arch-s3c24x0/s3c2410.h | 4 +- arch/arm/include/asm/arch-s3c24x0/s3c2440.h | 4 +- arch/arm/include/asm/arch-s3c24x0/s3c24x0.h | 31 ++++--- drivers/mtd/nand/Kconfig | 7 ++ drivers/mtd/nand/denali.c | 132 ++++++++++++++++++++-------- drivers/mtd/nand/denali.h | 5 +- drivers/mtd/nand/nand_base.c | 10 ++- drivers/mtd/nand/s3c2410_nand.c | 38 ++++---- drivers/mtd/nand/vf610_nfc.c | 3 + 9 files changed, 152 insertions(+), 82 deletions(-)
Scott Wood
