[PATCH] common: relocate fdt_blob in global_data for FDTSRC_EMBED case
Patch resolves two kind of bugs, one of which is vulnerability related to KASLR.
=== Issue briefly ===
Working with FDT (via non-relocated gd::fdt_blob) from inside bootm command may lead to the reading the garbage instead of FDT nodes. And this can result in various side-effects depending on DTS nodes, being parsed during bootm.
But below is my specific story how I faced with this issue due to MESON_RNG probing failure.
=== Bugs description ===
1) Bug is revealed on: * configuration below * U-boot 2024.10 - f919c3a889f ("Prepare v2024.10")
It seems, the following patch is a trigger: ea955eea4f ("fdt: automatically add /chosen/kaslr-seed if DM_RNG is enabled")
Generally, CONFIG_OF_EMBED=y & CONFIG_RNG_MESON=y are the most valuable ones for reproducing the issue. ``` CONFIG_ARCH_FIXUP_FDT_MEMORY=y CONFIG_CMD_FDT=y CONFIG_DEFAULT_FDT_FILE="" CONFIG_FDT_64BIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_OF_LIBFDT_ASSUME_MASK=0x0 CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_OF_LIBFDT=y CONFIG_OF_LIST="meson-axg-our-device-name" CONFIG_OF_REAL=y CONFIG_OF_TRANSLATE=y CONFIG_SUPPORT_OF_CONTROL=y CONFIG_SYS_FDT_PAD=0x3000 CONFIG_TOOLS_OF_LIBFDT=y
CONFIG_DM_RNG=y CONFIG_RNG_MESON=y ```
2) Due to CONFIG_OF_EMBED, the DTS is embedded into U-boot ELF and accessible via __dtb_dt_begin symbol.
On early boot stage (board_f.c) the fdtdec_setup() is called only once before U-boot's relocation into top of RAM. fdtdec_setup() initializes gd::fdt_blob for FDTSRC_EMBED case: ``` gd->fdt_blob = dtb_dt_embedded(); gd->fdt_src = FDTSRC_EMBED; ```
3) Then reloc_fdt() is called in board_f.c
But due to CONFIG_OF_EMBED=y the reloc_fdt() does not update gd::fdt_blob value (strictly speaking, it is impossible for CONFIG_OF_EMBED=y, because U-boot ELF has not been relocated yet at this moment).
As a result after relocation we get fdt_blob, pointing to DTS address before relocation: ``` # bdinfo <...> relocaddr = 0x000000000fedf000 reloc off = 0x000000000eedf000 <...> fdt_blob = 0x010ce6c0 << points to __dtb_dt_begin before relocation new_fdt = 0x0000000000000000 << empty erroneously fdt_size = 0x0000000000000000 << zero erroneously ```
4) During bootm command (according to our ITS-config file) the Linux is loaded into 0x01080000 (which is very close to fdt_blob addr 0x010ce6c0). ``` ## Loading kernel from FIT Image at 04000000 ... Trying 'kernel' kernel subimage <...> Load Address: 0x01080000 ```
So Linux image overwrites the gd::fdt_blob memory location in RAM (0x010ce6c0).
5) Issue:
Hence any manipulation with DTS (say, via FDT API) inside implementation of bootm command leads to accessing the fdt_blob area with garbage, that can lead to two situations:
5.1) Abort.
Call to fdt_off_dt_struct() from fdt_next_tag() :: fdt_offset_ptr():: fdt_offset_ptr_() returns with garbage, that leads to tagp value being out of RAM top addr (256 Mb in our board), causing the abort: ``` Boot cmd: bootm 0x4000000#boot_evt1 bootm_run_states() <...> image_setup_libfdt() fdt_chosen() fdt_kaslrseed() uclass_get_device() uclass_get_device_tail() device_probe() device_of_to_plat() meson_rng_of_to_plat() clk_get_by_name_optional() clk_get_by_name() clk_get_by_name_nodev() ofnode_stringlist_search() fdt_stringlist_search() fdt_getprop() fdt_get_property_namelen_() fdt_first_property_offset() fdt_check_node_offset_() fdt_next_tag(): ``` tagp = fdt_offset_ptr(fdt, offset, FDT_TAGSIZE); ``` fdt_next_tag() tagp:0x22890766 fdt_next_tag() ram_top:0x10000000 (tagp OUT of RAM) "Synchronous Abort" handler, esr 0x96000010, far 0x22890766 elr: 000000000108be24 lr : 000000000108be24 (reloc) elr: 000000000ff6fe24 lr : 000000000ff6fe24 x0 : 0000000000000041 x1 : 0000000000000000 x2 : 000000000ff3b57c x3 : 0000000000000012 x4 : 000000000ded2ad5 x5 : 0000000000000020 x6 : 00000000ffffffe8 x7 : 000000000ded2f40 x8 : 00000000ffffffd8 x9 : 000000000000000d x10: 0000000000000006 x11: 000000000001869f x12: 000000000fffffff x13: 000000000fffffff x14: 0000000000000000 x15: 000000000ded2abb x16: 000000000ff3b080 x17: 0000000000000001 x18: 000000000ded3dc0 x19: 0000000022890766 x20: 00000000010cb0f0 x21: 00000000000015e4 x22: 000000000ff8f4d8 x23: 000000000000000b x24: 000000000ded2fbc x25: 000000000ffe2000 x22: 000000000ff8f4d8 x23: 000000000000000b x24: 000000000ded2fbc x25: 000000000ffe2000 x26: 000000000ffe2000 x27: 000000000000000b x28: 000000000ff9cf2d x29: 000000000ded2f40
Code: aa1603e1 91197484 52801742 94004de8 (b9400276) ```
5.2) Vulnerability situation "KASLR is disabled".
Almost the same as in (5.1), but 2 situations happen (depending on the value of garbage): * call to fdt_offset_ptr_() :: fdt_off_dt_struct(fdt) returns not so big garbage, leading to tagp, being inside RAM. * or calculations of absoffset inside fdt_offset_ptr() leads to failure of the one of if() conditions with NULL as retval.
Result is fdt_next_tag() interprets the tagp as FDT_END. And we are returning from our callstack via functions' error paths, leading to "No RNG device" and "KASLR disabled due to lack of seed": ``` fdt_kaslrseed() uclass_get_device() <...> device_probe() device_of_to_plat() meson_rng_of_to_plat() clk_get_by_name() clk_get_by_name_nodev() <...> fdt_stringlist_search() fdt_getprop() fdt_get_property_namelen_() fdt_first_property_offset() fdt_check_node_offset_() fdt_next_tag(): ``` tagp = fdt_offset_ptr(fdt, offset, FDT_TAGSIZE); ``` fdt_next_tag() tagp:0000000001890677 fdt_next_tag() ram_top:0x10000000 (tagp is inside RAM) uclass_get_device_tail():486 device_probe() ret:-22 No RNG device Starting kernel ...
[ 0.000000] Linux version 6.9.12 [ 0.000000] KASLR disabled due to lack of seed ```
Signed-off-by: Evgeny Bachinin EABachinin@salutedevices.com --- Tested: * on board with Amlogic AXG SoC. * on sandbox: make sure that certain code from patch is called (of course, when CONFIG_OF_EMBED=y) * U-boot CI: https://github.com/u-boot/u-boot/pull/698/checks --- common/board_r.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/common/board_r.c b/common/board_r.c index 62228a723e12f8742437acae380e82f79903a8f5..88dc756b2a5e5a44f55f9b0fd012adc798a8afdb 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -152,6 +152,15 @@ static int initr_reloc_global_data(void) */ gd->env_addr += gd->reloc_off; #endif + + /* + * For CONFIG_OF_EMBED case the FDT is embedded into ELF, available by + * __dtb_dt_begin. After U-boot ELF self-relocation to RAM top address + * it is worth to update fdt_blob in global_data + */ + if (IS_ENABLED(CONFIG_OF_EMBED)) + gd->fdt_blob = dtb_dt_embedded(); + #ifdef CONFIG_EFI_LOADER /* * On the ARM architecture gd is mapped to a fixed register (r9 or x18).
--- base-commit: cca05617a8f585f3a98a8fa82f75cc68a530d771 change-id: 20241119-of_embed_fdt_blob_garbage-ea729a8236e1
Hello, dear reviewers!
It was my 1st attempt to use b4-tool and it did not list all relevant reviewers.
So, let me manually CC relevant stakeholders/maintainers. Please, take a look on the fix of bug/vulnerability
P.S. If you wish, advise me, please, whether I need to re-send with updated CC list or just publish v2.
- Bug is revealed on:
configuration below
CONFIG_ARCH_FIXUP_FDT_MEMORY=y CONFIG_CMD_FDT=y CONFIG_DEFAULT_FDT_FILE="" CONFIG_FDT_64BIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_OF_LIBFDT_ASSUME_MASK=0x0 CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_OF_LIBFDT=y CONFIG_OF_LIST="meson-axg-our-device-name" CONFIG_OF_REAL=y CONFIG_OF_TRANSLATE=y CONFIG_SUPPORT_OF_CONTROL=y CONFIG_SYS_FDT_PAD=0x3000 CONFIG_TOOLS_OF_LIBFDT=y CONFIG_DM_RNG=y CONFIG_RNG_MESON=y
- Due to CONFIG_OF_EMBED, the DTS is embedded into U-boot ELF and
- Then reloc_fdt() is called in board_f.c
- During bootm command (according to our ITS-config file) the Linux
- Issue:
5.1) Abort.
Boot cmd: bootm 0x4000000#boot_evt1 bootm_run_states() <...> image_setup_libfdt() fdt_chosen() fdt_kaslrseed() uclass_get_device() uclass_get_device_tail() device_probe() device_of_to_plat() meson_rng_of_to_plat() clk_get_by_name_optional() clk_get_by_name() clk_get_by_name_nodev() ofnode_stringlist_search() fdt_stringlist_search() fdt_getprop() fdt_get_property_namelen_() fdt_first_property_offset() fdt_check_node_offset_() fdt_next_tag(): ``` tagp = fdt_offset_ptr(fdt, offset, FDT_TAGSIZE); ``` fdt_next_tag() tagp:0x22890766 fdt_next_tag() ram_top:0x10000000 (tagp OUT of RAM) "Synchronous Abort" handler, esr 0x96000010, far 0x22890766 elr: 000000000108be24 lr : 000000000108be24 (reloc) elr: 000000000ff6fe24 lr : 000000000ff6fe24 x0 : 0000000000000041 x1 : 0000000000000000 x2 : 000000000ff3b57c x3 : 0000000000000012 x4 : 000000000ded2ad5 x5 : 0000000000000020 x6 : 00000000ffffffe8 x7 : 000000000ded2f40 x8 : 00000000ffffffd8 x9 : 000000000000000d x10: 0000000000000006 x11: 000000000001869f x12: 000000000fffffff x13: 000000000fffffff x14: 0000000000000000 x15: 000000000ded2abb x16: 000000000ff3b080 x17: 0000000000000001 x18: 000000000ded3dc0 x19: 0000000022890766 x20: 00000000010cb0f0 x21: 00000000000015e4 x22: 000000000ff8f4d8 x23: 000000000000000b x24: 000000000ded2fbc x25: 000000000ffe2000 x22: 000000000ff8f4d8 x23: 000000000000000b x24: 000000000ded2fbc x25: 000000000ffe2000 x26: 000000000ffe2000 x27: 000000000000000b x28: 000000000ff9cf2d x29: 000000000ded2f40 Code: aa1603e1 91197484 52801742 94004de8 (b9400276)
- call to fdt_offset_ptr_() :: fdt_off_dt_struct(fdt) returns not so big garbage, leading to tagp, being inside RAM.
- or calculations of absoffset inside fdt_offset_ptr() leads to failure of the one of if() conditions with NULL as retval.
fdt_kaslrseed() uclass_get_device() <...> device_probe() device_of_to_plat() meson_rng_of_to_plat() clk_get_by_name() clk_get_by_name_nodev() <...> fdt_stringlist_search() fdt_getprop() fdt_get_property_namelen_() fdt_first_property_offset() fdt_check_node_offset_() fdt_next_tag(): ``` tagp = fdt_offset_ptr(fdt, offset, FDT_TAGSIZE); ``` fdt_next_tag() tagp:0000000001890677 fdt_next_tag() ram_top:0x10000000 (tagp is inside RAM) uclass_get_device_tail():486 device_probe() ret:-22 No RNG device Starting kernel ... [ 0.000000] Linux version 6.9.12 [ 0.000000] KASLR disabled due to lack of seed
Tested:
- on board with Amlogic AXG SoC.
- on sandbox: make sure that certain code from patch is called (of course, when CONFIG_OF_EMBED=y)
- U-boot CI: https://github.com/u-boot/u-boot/pull/698/checks
- if (IS_ENABLED(CONFIG_OF_EMBED))
Hi Evgeny,
On Fri, 29 Nov 2024 at 03:03, Evgeny Bachinin eabachinin@salutedevices.com wrote:
configuration below
- Issue:
5.1) Abort.
Tested:
U-Boot
Note that OF_EMBED is a development feature[1], for debugging with JTAG, etc. Which board is this?
Also, you should normally disable relocation (with gd->flags GD_FLG_SKIP_RELOC) when using OF_EMBED, since the code ends up elsewhere, which is a pain when debugging.
This macro is for use by fdtgrep...perhaps I should have added an underscore at the end to make that clear. So please add a function in fdtdec to handle this, calling it from initr_reloc_global_data(), perhaps.
[1] https://docs.u-boot.org/en/latest/develop/devicetree/control.html#configurat...
Hello Simon, please, see below
On Tue, Dec 03, 2024 at 08:55:15AM -0700, Simon Glass wrote:
Hi Evgeny,
configuration below
- Issue:
5.1) Abort.
Tested:
U-Boot
Yes, that's right.
Due to the legacy, it's ok for us (for now) when dtb is inside U-Boot ELF. We are migrating from Amlogic vendor source code base into upstream one and chose more obvious and fast way (OF_EMBED), available and workable both in vendor's (old) U-Boot and in upstream one. One day, we will get rid of OF_EMBED, being fully on mainline sources...
Nevertheless, option exists and it is not prohibited for usage. And as my patch reveals there were bugs, one of which led to KASLR disabled on real production board.
Our production device is based on Amlogic SoC A113X (AXG family) and is not public. The closest board is S400 [1].
Thank you for your advise! I'll take it into account.
Sorry, did not grasp your comment. What macro? P.S I tried to guess you talked about FDTSRC_EMBED or OF_EMBED, but anyway I can't relate them with fdtgrep by seeking in repo.
Have I understood you right? You meant to move initialization of fdt_blob by dtb_dt_embedded() into a separate function something like this: ``` diff --git a/common/board_r.c b/common/board_r.c index abe2395346..424954ea67 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -159,7 +159,7 @@ static int initr_reloc_global_data(void) * it is worth to update fdt_blob in global_data */ if (IS_ENABLED(CONFIG_OF_EMBED)) - gd->fdt_blob = dtb_dt_embedded(); + fdtdec_setup_embed()
#ifdef CONFIG_EFI_LOADER /* diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 6865f78c70..484954a262 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1664,6 +1664,12 @@ static void setup_multi_dtb_fit(void) } }
+void fdtdec_setup_embed(void) +{ + gd->fdt_blob = dtb_dt_embedded(); + gd->fdt_src = FDTSRC_EMBED; +} + int fdtdec_setup(void) { int ret = -ENOENT; @@ -1698,8 +1704,7 @@ int fdtdec_setup(void) gd->fdt_blob = fdt_find_separate(); gd->fdt_src = FDTSRC_SEPARATE; } else { /* embed dtb in ELF file for testing / development */ - gd->fdt_blob = dtb_dt_embedded(); - gd->fdt_src = FDTSRC_EMBED; + fdtdec_setup_embed(); } } ```
[1] https://docs.u-boot.org/en/latest/board/amlogic/s400.html
Kind regards,
Hi Evgeny,
On Wed, 4 Dec 2024 at 12:57, Evgeny Bachinin eabachinin@salutedevices.com wrote:
Hi Evgeny,
configuration below
- Issue:
5.1) Abort.
Tested:
U-Boot
Yes, that's right.
I am surprised that OF_EMBED is faster. It really shouldn't make any difference.
Oh I mean fdtdec
diff --git a/common/board_r.c b/common/board_r.c index abe2395346..424954ea67 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -159,7 +159,7 @@ static int initr_reloc_global_data(void) * it is worth to update fdt_blob in global_data */ if (IS_ENABLED(CONFIG_OF_EMBED)) - gd->fdt_blob = dtb_dt_embedded(); + fdtdec_setup_embed() #ifdef CONFIG_EFI_LOADER /* diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 6865f78c70..484954a262 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1664,6 +1664,12 @@ static void setup_multi_dtb_fit(void) } } +void fdtdec_setup_embed(void) +{ + gd->fdt_blob = dtb_dt_embedded(); + gd->fdt_src = FDTSRC_EMBED; +} + int fdtdec_setup(void) { int ret = -ENOENT; @@ -1698,8 +1704,7 @@ int fdtdec_setup(void) gd->fdt_blob = fdt_find_separate(); gd->fdt_src = FDTSRC_SEPARATE; } else { /* embed dtb in ELF file for testing / development */ - gd->fdt_blob = dtb_dt_embedded(); - gd->fdt_src = FDTSRC_EMBED; + fdtdec_setup_embed(); } }
Yes that's right...it keeps the access to dtb_dt_embedded() within fdtdec
Hello Simon,
On Thu, Dec 05, 2024 at 10:57:36AM -0700, Simon Glass wrote:
Hi Evgeny,
Hi Evgeny,
U-Boot
Fixed in follow up patch series [1]
Yes, that's right.
Oh, sorry for misleading (I'm not about performance).
Under "faster" I meant the speed of adaptation the approach with OF_EMBED both on Vendor and mainline U-Boots. We had to externally pass the dtb into build system via EXT_DTB (in Vendor U-Boot), but, unfortunately, the Vendor U-Boot (basing on 2015.01) can't use EXT_DTB without OF_EMBED=y.
Oh I mean fdtdec
Thank you for idea. Have been done in the follow up patch-series [1]
Links: [1] https://lore.kernel.org/u-boot/20241211-dtb_dt_embedded_within_fdtdec-v1-0-7...
Evgeny Bachinin
Evgeny Bachinin
