[U-Boot-Users] Where does u-boot start when booting Linux?
I was hoping that someone could give me a quick answer. When u-boot starts Linux, does is start from the beginning for does it jump in somewhere past decompress()?
I have been looking at the Linux code and it doesn't appear that the bdinfo structure is being handled correctly for u-boot. There is an CONFIG_EMBEDDEDBOOT option but even this only passes the boot parameter in a few instances. Does u-boot fix this somehow?
Another thing is embed_config() for the ADS8260 board, forces the baud-rate to 9600 but 2_4_devel is quite happy at 115200 as in u-boot. This is interesting since I am trying to fix a serial baud-rate problem.
TIA!
There no decompress() in the Linux kernel. So U-Boot always starts the Linux kernel right from the beginning.
I think you are looking at the wrong place. Don;t mistake the bootstrap loader for a part of theLinux kernel. We don;t use this stuff at all.
All this stuff is completely irrelevant when using U-boot.
When compiling 82xx or 8xx kernels, you always get arch/ppc/boot/simple.
bdinfo
I think I understand. For a very long time now I have been using zImage.embedded for booting. When I followed the u-boot instructions I used "vmlinux" which doesn't contain the boot loader. Right?
baud-rate
Thanks for the info. It has pointed me in a new direction. The problem I am having is the serial baud-rate is fine in u-boot but wrong when the kernel boots. Perhaps the clock dividers are setup differently by u-boot than expected by the 8260 implementation?
Suggestions welcome.
Thanks again!
What do you mean with "you get it"? It comes with the source, yes. But you don't have to use it.
Right. vmlinux does not contain the bootstral loader, all functions of which are already present in U-Boot.
Perhaps you don;t pass the baud-rate to the kernel? Did you try passing something like "console=ttyS0,$(baudrate)" ?
I tried: setenv bootargs root=/dev/nfs rw console=ttyS0,115200 tftpboot 100000 /tftpboot/mpc8266.uImage bootm 100000
When Linux boots it just prints "." instead of text.
Dear Allen,
And what does a post-mortem dump of "log_buf" show?
Allen Curtis
