[U-Boot] [PATCH v3] powerpc/p1022ds: Add sdcard and spi boot support to P1022DS
Signed-off-by: Dirk Eibach eibach@gdsys.de Cc: Timur Tabi timur@freescale.com --- Changes in v2: - add Cc - split up original patch series Changes in v3: - use clrsetbits() instead of clrbits()/setbits() - remove dead code - remove unnecessary #undef
board/freescale/p1022ds/p1022ds.c | 3 ++ board/freescale/p1022ds/tlb.c | 10 ++++++ boards.cfg | 4 ++ include/configs/P1022DS.h | 56 +++++++++++++++++++++++++++++++++--- 4 files changed, 68 insertions(+), 5 deletions(-)
diff --git a/board/freescale/p1022ds/p1022ds.c b/board/freescale/p1022ds/p1022ds.c index 456d9b0..fd4193d 100644 --- a/board/freescale/p1022ds/p1022ds.c +++ b/board/freescale/p1022ds/p1022ds.c @@ -37,6 +37,9 @@ int board_early_init_f(void) { ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR;
+ /* Reset eLBC_DIU and SPI_eLBC in case we are booting from SD */ + clrsetbits_be32(&gur->pmuxcr, 0x00600000, 0x80000000); + /* Set pmuxcr to allow both i2c1 and i2c2 */ setbits_be32(&gur->pmuxcr, 0x1000);
diff --git a/board/freescale/p1022ds/tlb.c b/board/freescale/p1022ds/tlb.c index e620112..1e9969f 100644 --- a/board/freescale/p1022ds/tlb.c +++ b/board/freescale/p1022ds/tlb.c @@ -71,6 +71,16 @@ struct fsl_e_tlb_entry tlb_table[] = { SET_TLB_ENTRY(1, PIXIS_BASE, PIXIS_BASE_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 7, BOOKE_PAGESZ_4K, 1), + +#if defined(CONFIG_SYS_RAMBOOT) + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 8, BOOKE_PAGESZ_1G, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000, + CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 9, BOOKE_PAGESZ_1G, 1) +#endif };
int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 24c5879..8de4235 100644 --- a/boards.cfg +++ b/boards.cfg @@ -700,6 +700,10 @@ P1021RDB-PC_SDCARD powerpc mpc85xx p1_p2_rdb_pc freesca P1021RDB-PC_SPIFLASH powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1021RDB,SPIFLASH P1022DS powerpc mpc85xx p1022ds freescale P1022DS_36BIT powerpc mpc85xx p1022ds freescale - P1022DS:36BIT +P1022DS_36BIT_SDCARD powerpc mpc85xx p1022ds freescale - P1022DS:36BIT,SDCARD +P1022DS_36BIT_SPIFLASH powerpc mpc85xx p1022ds freescale - P1022DS:36BIT,SPIFLASH +P1022DS_SDCARD powerpc mpc85xx p1022ds freescale - P1022DS:SDCARD +P1022DS_SPIFLASH powerpc mpc85xx p1022ds freescale - P1022DS:SPIFLASH P1023RDS powerpc mpc85xx p1023rds freescale - P1023RDS P1023RDS_NAND powerpc mpc85xx p1023rds freescale - P1023RDS:NAND P1024RDB powerpc mpc85xx p1_p2_rdb_pc freescale - p1_p2_rdb_pc:P1024RDB diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 70d751d..213c5e3 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -26,6 +26,18 @@ #define CONFIG_P1022DS #define CONFIG_MP /* support multiple processors */
+#ifdef CONFIG_SDCARD +#define CONFIG_RAMBOOT_SDCARD 1 +#define CONFIG_SYS_TEXT_BASE 0x11000000 +#define CONFIG_RESET_VECTOR_ADDRESS 0x1107fffc +#endif + +#ifdef CONFIG_SPIFLASH +#define CONFIG_RAMBOOT_SPIFLASH 1 +#define CONFIG_SYS_TEXT_BASE 0x11000000 +#define CONFIG_RESET_VECTOR_ADDRESS 0x1107fffc +#endif + #ifndef CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_TEXT_BASE 0xeff80000 #endif @@ -54,6 +66,7 @@
#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() #define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() + #define CONFIG_ICS307_REFCLK_HZ 33333000 /* ICS307 clock chip ref freq */
/* @@ -138,6 +151,12 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */
+#if defined(CONFIG_RAMBOOT_NAND) || defined(CONFIG_RAMBOOT_SDCARD) || \ + defined(CONFIG_RAMBOOT_SPIFLASH) +#define CONFIG_SYS_RAMBOOT +#define CONFIG_SYS_EXTRA_ENV_RELOC +#endif + #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI #define CONFIG_SYS_FLASH_EMPTY_INFO @@ -403,11 +422,38 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 +#if defined(CONFIG_SYS_RAMBOOT) +#if defined(CONFIG_RAMBOOT_NAND) +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define CONFIG_ENV_OFFSET ((512 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) +#elif defined(CONFIG_RAMBOOT_SPIFLASH) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 10000000 +#define CONFIG_ENV_SPI_MODE 0 +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x100000 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#elif defined(CONFIG_RAMBOOT_SDCARD) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_FSL_FIXED_MMC_LOCATION +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_SYS_MMC_ENV_DEV 0 +#else + #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ + #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) + #define CONFIG_ENV_SIZE 0x2000 +#endif +#else + #define CONFIG_ENV_IS_IN_FLASH + #define CONFIG_ENV_OVERWRITE + #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) + #define CONFIG_ENV_SIZE 0x2000 + #define CONFIG_ENV_SECT_SIZE 0x20000 +#endif
#define CONFIG_LOADS_ECHO #define CONFIG_SYS_LOADS_BAUD_CHANGE
Can you give me some instructions on how to test this? I'm working on adding NAND boot support to the P1022, so I need to make sure I don't conflict with your patch.
Changes in v2:
- add Cc
Changes in v3:
- remove dead code
- /* Reset eLBC_DIU and SPI_eLBC in case we are booting from SD */
- clrsetbits_be32(&gur->pmuxcr, 0x00600000, 0x80000000);
Should there be an #ifdef around this, like maybe:
#if defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) /* Reset eLBC_DIU and SPI_eLBC when we are booting from SD */ clrsetbits_be32(&gur->pmuxcr, 0x00600000, 0x80000000); #endif
Please use #ifdef instead of "#if defined" where possible.
- SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE,
- SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE + 0x40000000,
+#endif };
Unrelated whitespace change, please remove.
- defined(CONFIG_RAMBOOT_SPIFLASH)
- Environment
- #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */
- #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000)
- #define CONFIG_ENV_SIZE 0x2000
Shouldn't this be
#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SIZE)
Otherwise, the environment won't fit?
+#endif +#else
- #define CONFIG_ENV_IS_IN_FLASH
- #define CONFIG_ENV_OVERWRITE
- #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE)
- #define CONFIG_ENV_SECT_SIZE 0x20000
- Environment
+#define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) +#elif defined(CONFIG_RAMBOOT_SPIFLASH) #define +CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 10000000 +#define CONFIG_ENV_SPI_MODE 0 +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x100000 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#elif defined(CONFIG_RAMBOOT_SDCARD) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_FSL_FIXED_MMC_LOCATION +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_SYS_MMC_ENV_DEV 0 +#else
memory only */
Shouldn't this be
Probably you are right. Though these lines are inspired by other Freescale boards. git grep -3 "CONFIG_SYS_MONITOR_BASE - 0x1000" include/configs gives lots of examples where it is set up this way and probably needs fixing. Maybe it was originally copied from one of the places where CONFIG_ENV_SIZE is 0x200 and the 0x1000 value was not adjusted.
I will fix it for P1022DS in the v4 patch.
Cheers Dirk
Dirk Eibach
Eibach, Dirk
Timur Tabi
