[U-Boot] [PATCH 1/1] console: Improve TFTP booting performance
TFTP booting is observed a little bit slow, especially when a USB keyboard is installed. The fix is to check whether Ctrl-C key is pressed every CONFIG_CTRLC_POLL_MS ms. If CONFIG_CTRLC_POLL_MS is not defined in configuration file, we define it as 1000.
Signed-off-by: Jim Lin jilin@nvidia.com --- common/console.c | 12 ++++++++++++ 1 files changed, 12 insertions(+), 0 deletions(-)
diff --git a/common/console.c b/common/console.c index bf73178..3339a93 100644 --- a/common/console.c +++ b/common/console.c @@ -524,9 +524,21 @@ int vprintf(const char *fmt, va_list args) /* test if ctrl-c was pressed */ static int ctrlc_disabled = 0; /* see disable_ctrl() */ static int ctrlc_was_pressed = 0; +#ifndef CONFIG_CTRLC_POLL_MS +/* + * Process Ctrl-C every 1000 ms by default to improve performance + * (like TFTP boot) when interlaced with other tasks. + */ +#define CONFIG_CTRLC_POLL_MS 1000 +#endif +static unsigned long ctrlc_ts = CONFIG_CTRLC_POLL_MS; int ctrlc(void) { if (!ctrlc_disabled && gd->have_console) { + if (get_timer(ctrlc_ts) < CONFIG_CTRLC_POLL_MS) + return 0; + else + ctrlc_ts = get_timer(0); if (tstc()) { switch (getc()) { case 0x03: /* ^C - Control C */
Dear Jim Lin,
CONFIG_* variables MUST be documented in the README.
Dear Jim Lin,
...also:
- Process Ctrl-C every 1000 ms by default to improve performance
- (like TFTP boot) when interlaced with other tasks.
Don't set such a default. If this is good for you, OK. But for all others, the behaviour should not change at all.
Also, are you positively sure that your callto get_timer() does not mess up with other timers in the network subsystem?
On Fri, 2013-01-25 at 17:20 +0800, Wolfgang Denk wrote:
Dear Jim Lin,
...also:
OK. I will rewrite and check again. Thanks.
--nvpublic
Jim Lin
