[U-Boot] [PATCH 2/2] PPC4xx: Create "liebherr" vendor directory
In preparation of some new Liebherr boards to be added soon, a new "liebherr" vendor directory gets created, and the "lwmon5" board directory is moved into this new vendor directory.
cc: Stefan Roese sr@denx.de Signed-off-by: Wolfgang Denk wd@denx.de --- arch/powerpc/cpu/ppc4xx/Kconfig | 2 +- board/{ => liebherr}/lwmon5/Kconfig | 3 +++ board/{ => liebherr}/lwmon5/MAINTAINERS | 0 board/{ => liebherr}/lwmon5/Makefile | 0 board/{ => liebherr}/lwmon5/config.mk | 0 board/{ => liebherr}/lwmon5/init.S | 0 board/{ => liebherr}/lwmon5/kbd.c | 0 board/{ => liebherr}/lwmon5/lwmon5.c | 0 board/{ => liebherr}/lwmon5/sdram.c | 0 9 files changed, 4 insertions(+), 1 deletion(-) rename board/{ => liebherr}/lwmon5/Kconfig (78%) rename board/{ => liebherr}/lwmon5/MAINTAINERS (100%) rename board/{ => liebherr}/lwmon5/Makefile (100%) rename board/{ => liebherr}/lwmon5/config.mk (100%) rename board/{ => liebherr}/lwmon5/init.S (100%) rename board/{ => liebherr}/lwmon5/kbd.c (100%) rename board/{ => liebherr}/lwmon5/lwmon5.c (100%) rename board/{ => liebherr}/lwmon5/sdram.c (100%)
diff --git a/arch/powerpc/cpu/ppc4xx/Kconfig b/arch/powerpc/cpu/ppc4xx/Kconfig index 945e771..efd3165 100644 --- a/arch/powerpc/cpu/ppc4xx/Kconfig +++ b/arch/powerpc/cpu/ppc4xx/Kconfig @@ -152,7 +152,7 @@ source "board/gdsys/405ex/Kconfig" source "board/gdsys/dlvision/Kconfig" source "board/gdsys/gdppc440etx/Kconfig" source "board/gdsys/intip/Kconfig" -source "board/lwmon5/Kconfig" +source "board/liebherr/lwmon5/Kconfig" source "board/mosaixtech/icon/Kconfig" source "board/mpl/mip405/Kconfig" source "board/mpl/pip405/Kconfig" diff --git a/board/lwmon5/Kconfig b/board/liebherr/lwmon5/Kconfig similarity index 78% rename from board/lwmon5/Kconfig rename to board/liebherr/lwmon5/Kconfig index 7b8c605..7f1bb40 100644 --- a/board/lwmon5/Kconfig +++ b/board/liebherr/lwmon5/Kconfig @@ -3,6 +3,9 @@ if TARGET_LWMON5 config SYS_BOARD default "lwmon5"
+config SYS_VENDOR + default "liebherr" + config SYS_CONFIG_NAME default "lwmon5"
diff --git a/board/lwmon5/MAINTAINERS b/board/liebherr/lwmon5/MAINTAINERS similarity index 100% rename from board/lwmon5/MAINTAINERS rename to board/liebherr/lwmon5/MAINTAINERS diff --git a/board/lwmon5/Makefile b/board/liebherr/lwmon5/Makefile similarity index 100% rename from board/lwmon5/Makefile rename to board/liebherr/lwmon5/Makefile diff --git a/board/lwmon5/config.mk b/board/liebherr/lwmon5/config.mk similarity index 100% rename from board/lwmon5/config.mk rename to board/liebherr/lwmon5/config.mk diff --git a/board/lwmon5/init.S b/board/liebherr/lwmon5/init.S similarity index 100% rename from board/lwmon5/init.S rename to board/liebherr/lwmon5/init.S diff --git a/board/lwmon5/kbd.c b/board/liebherr/lwmon5/kbd.c similarity index 100% rename from board/lwmon5/kbd.c rename to board/liebherr/lwmon5/kbd.c diff --git a/board/lwmon5/lwmon5.c b/board/liebherr/lwmon5/lwmon5.c similarity index 100% rename from board/lwmon5/lwmon5.c rename to board/liebherr/lwmon5/lwmon5.c diff --git a/board/lwmon5/sdram.c b/board/liebherr/lwmon5/sdram.c similarity index 100% rename from board/lwmon5/sdram.c rename to board/liebherr/lwmon5/sdram.c
Hi Wolfgang,
+config SYS_VENDOR
- default "liebherr"
- config SYS_CONFIG_NAME default "lwmon5"
You missed to change the location of bsp files in the MAINTAINERS file:
LWMON5 BOARD M: Stefan Roese sr@denx.de S: Maintained F: board/lwmon5/ ...
Other than this:
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
cc: Stefan Roese sr@denx.de Signed-off-by: Wolfgang Denk wd@denx.de --- Changes v2: Fix directory name in MAINTAINERS file Tnx to Stefan Roese for pointing out.
arch/powerpc/cpu/ppc4xx/Kconfig | 2 +- board/{ => liebherr}/lwmon5/Kconfig | 3 +++ board/{ => liebherr}/lwmon5/MAINTAINERS | 2 +- board/{ => liebherr}/lwmon5/Makefile | 0 board/{ => liebherr}/lwmon5/config.mk | 0 board/{ => liebherr}/lwmon5/init.S | 0 board/{ => liebherr}/lwmon5/kbd.c | 0 board/{ => liebherr}/lwmon5/lwmon5.c | 0 board/{ => liebherr}/lwmon5/sdram.c | 0 9 files changed, 5 insertions(+), 2 deletions(-) rename board/{ => liebherr}/lwmon5/Kconfig (78%) rename board/{ => liebherr}/lwmon5/MAINTAINERS (81%) rename board/{ => liebherr}/lwmon5/Makefile (100%) rename board/{ => liebherr}/lwmon5/config.mk (100%) rename board/{ => liebherr}/lwmon5/init.S (100%) rename board/{ => liebherr}/lwmon5/kbd.c (100%) rename board/{ => liebherr}/lwmon5/lwmon5.c (100%) rename board/{ => liebherr}/lwmon5/sdram.c (100%)
diff --git a/board/lwmon5/MAINTAINERS b/board/liebherr/lwmon5/MAINTAINERS similarity index 81% rename from board/lwmon5/MAINTAINERS rename to board/liebherr/lwmon5/MAINTAINERS index 3ea1888..df45730 100644 --- a/board/lwmon5/MAINTAINERS +++ b/board/liebherr/lwmon5/MAINTAINERS @@ -1,6 +1,6 @@ LWMON5 BOARD M: Stefan Roese sr@denx.de S: Maintained -F: board/lwmon5/ +F: board/liebherr/lwmon5/ F: include/configs/lwmon5.h F: configs/lwmon5_defconfig diff --git a/board/lwmon5/Makefile b/board/liebherr/lwmon5/Makefile similarity index 100% rename from board/lwmon5/Makefile rename to board/liebherr/lwmon5/Makefile diff --git a/board/lwmon5/config.mk b/board/liebherr/lwmon5/config.mk similarity index 100% rename from board/lwmon5/config.mk rename to board/liebherr/lwmon5/config.mk diff --git a/board/lwmon5/init.S b/board/liebherr/lwmon5/init.S similarity index 100% rename from board/lwmon5/init.S rename to board/liebherr/lwmon5/init.S diff --git a/board/lwmon5/kbd.c b/board/liebherr/lwmon5/kbd.c similarity index 100% rename from board/lwmon5/kbd.c rename to board/liebherr/lwmon5/kbd.c diff --git a/board/lwmon5/lwmon5.c b/board/liebherr/lwmon5/lwmon5.c similarity index 100% rename from board/lwmon5/lwmon5.c rename to board/liebherr/lwmon5/lwmon5.c diff --git a/board/lwmon5/sdram.c b/board/liebherr/lwmon5/sdram.c similarity index 100% rename from board/lwmon5/sdram.c rename to board/liebherr/lwmon5/sdram.c
Applied to u-boot-ppc4xx/master.
Thanks, Stefan
Dear Stefan,
Indeed. Fixed in v2. Thanks!
Stefan Roese
