[U-Boot] [PATCH] arm: sunxi: Add icnova-a20-swac defconfig and dts file
The ICnova-A20-SWAC is a baseboard, equipped with the ICnova-A20 SoM from In-Circuit:
http://wiki.in-circuit.de/index.php5?title=ICnova_A20_SODIMM http://linux-sunxi.org/In-Circuit_ICnova_A20
This patch adds support for this board, including ethernet, LCD and USB support.
Signed-off-by: Stefan Roese sr@denx.de Cc: Marcus Heuer marcus.heuer@swac.de Cc: Hans de Goede hdegoede@redhat.com Cc: Ian Campbell ijc@hellion.org.uk --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun7i-a20-icnova-a20-swac.dts | 177 +++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 + configs/icnova-a20-swac_defconfig | 21 ++++ 4 files changed, 204 insertions(+) create mode 100644 arch/arm/dts/sun7i-a20-icnova-a20-swac.dts create mode 100644 configs/icnova-a20-swac_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5f10243..1f2661c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -134,6 +134,7 @@ dtb-$(CONFIG_MACH_SUN7I) += \ sun7i-a20-cubietruck.dtb \ sun7i-a20-hummingbird.dtb \ sun7i-a20-i12-tvbox.dtb \ + sun7i-a20-icnova-a20-swac.dtb \ sun7i-a20-m3.dtb \ sun7i-a20-m5.dtb \ sun7i-a20-mk808c.dtb \ diff --git a/arch/arm/dts/sun7i-a20-icnova-a20-swac.dts b/arch/arm/dts/sun7i-a20-icnova-a20-swac.dts new file mode 100644 index 0000000..773fb6f --- /dev/null +++ b/arch/arm/dts/sun7i-a20-icnova-a20-swac.dts @@ -0,0 +1,177 @@ +/* + * Copyright 2013 Maxime Ripard + * + * Maxime Ripard maxime.ripard@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun7i-a20.dtsi" +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + model = "ICnova-A20 SWAC"; + compatible = "swac,icnova-a20-swac", "allwinner,sun7i-a20"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&cpu0 { + cpu-supply = <®_dcdc2>; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&gmac { + pinctrl-names = "default"; + pinctrl-0 = <&gmac_pins_mii_a>; + phy = <&phy1>; + phy-mode = "mii"; + status = "okay"; + + phy1: ethernet-phy@1 { + reg = <1>; + }; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins_a>; + status = "okay"; + + axp209: pmic@34 { + reg = <0x34>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins_a>; + status = "okay"; +}; + +&ir0 { + pinctrl-names = "default"; + pinctrl-0 = <&ir0_rx_pins_a>; + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_reference_design>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 8 5 GPIO_ACTIVE_HIGH>; /* PI5 */ + cd-inverted; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +#include "axp209.dtsi" + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1450000>; + regulator-name = "vdd-cpu"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-int-dll"; +}; + +®_ldo1 { + regulator-name = "vdd-rtc"; +}; + +®_ldo2 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "avcc"; +}; + +®_usb1_vbus { + status = "okay"; +}; + +®_usb2_vbus { + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usbphy { + usb1_vbus-supply = <®_usb1_vbus>; + usb2_vbus-supply = <®_usb2_vbus>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 8f95867..c60fda5 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -112,6 +112,11 @@ M: Chen-Yu Tsai wens@csie.org S: Maintained F: configs/Hummingbird_A31_defconfig
+ICnova-A20-SWAC BOARD +M: Stefan Roese sr@denx.de +S: Maintained +F: configs/icnova-a20-swac_defconfig + INET 3F BOARD M: Paul Kocialkowski contact@paulk.fr S: Maintained diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig new file mode 100644 index 0000000..bd6e0c5 --- /dev/null +++ b/configs/icnova-a20-swac_defconfig @@ -0,0 +1,21 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN7I=y +CONFIG_DRAM_CLK=384 +CONFIG_OLD_SUNXI_KERNEL_COMPAT=y +CONFIG_MMC0_CD_PIN="PI5" +CONFIG_USB0_VBUS_PIN="PG11" +CONFIG_USB0_VBUS_DET="PH7" +CONFIG_USB1_VBUS_PIN="PG10" +CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,le:45,ri:209,up:22,lo:22,hs:1,vs:1,sync:3,vmode:0" +CONFIG_VIDEO_LCD_POWER="PH22" +CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-a20-swac" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,CMD_BMP,CMD_UNZIP" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_ETH_DESIGNWARE=y +CONFIG_USB_EHCI_HCD=y
Thanks, I've merged this and it will show up in u-boot-sunxi/next soon.
I've made 2 small changes, see comments inline.
- sun7i-a20-icnova-a20-swac.dtb \ sun7i-a20-m3.dtb \ sun7i-a20-m5.dtb \ sun7i-a20-mk808c.dtb \
Please submit this file also to the upstream kernel.
- Copyright 2013 Maxime Ripard
- Maxime Ripard maxime.ripard@free-electrons.com
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
- model = "ICnova-A20 SWAC";
- compatible = "swac,icnova-a20-swac", "allwinner,sun7i-a20";
- aliases {
serial0 = &uart0;
- chosen {
+&cpu0 {
- cpu-supply = <®_dcdc2>;
+&ehci0 {
- status = "okay";
+&ehci1 {
- status = "okay";
+&gmac {
- pinctrl-names = "default";
- pinctrl-0 = <&gmac_pins_mii_a>;
- phy = <&phy1>;
- phy-mode = "mii";
- status = "okay";
- phy1: ethernet-phy@1 {
reg = <1>;
+&i2c0 {
- pinctrl-0 = <&i2c0_pins_a>;
- status = "okay";
- axp209: pmic@34 {
reg = <0x34>;
+&i2c1 {
- pinctrl-0 = <&i2c1_pins_a>;
- status = "okay";
+&ir0 {
- pinctrl-0 = <&ir0_rx_pins_a>;
- status = "okay";
+&mmc0 {
- pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_reference_design>;
- vmmc-supply = <®_vcc3v3>;
- bus-width = <4>;
- cd-gpios = <&pio 8 5 GPIO_ACTIVE_HIGH>; /* PI5 */
- cd-inverted;
- status = "okay";
+&ohci0 {
- status = "okay";
+&ohci1 {
- status = "okay";
+®_dcdc2 {
- regulator-always-on;
- regulator-min-microvolt = <1000000>;
- regulator-max-microvolt = <1450000>;
- regulator-name = "vdd-cpu";
+®_dcdc3 {
- regulator-max-microvolt = <1400000>;
- regulator-name = "vdd-int-dll";
+®_ldo1 {
- regulator-name = "vdd-rtc";
+®_ldo2 {
- regulator-min-microvolt = <3000000>;
- regulator-max-microvolt = <3000000>;
- regulator-name = "avcc";
+®_usb1_vbus {
- status = "okay";
+®_usb2_vbus {
- status = "okay";
+&uart0 {
- pinctrl-0 = <&uart0_pins_a>;
- status = "okay";
+&usbphy {
- usb1_vbus-supply = <®_usb1_vbus>;
- usb2_vbus-supply = <®_usb2_vbus>;
- status = "okay";
- INET 3F BOARD M: Paul Kocialkowski contact@paulk.fr S: Maintained
I've dropped this, I understand that you need it, but I do not believe that ANY defconfig's as shipped upstream should set this.
I've dropped AXP209_POWER from these, in u-boot-sunxi/next this has been turned into a Kconfig bool which is enabled by default on sun7i.
Regards,
Hans
Yes. The name of the DT especially doesn't really make sense. The "SWAC" name isn't referenced anywhere, the module cannot be used alone, and there's a single combination available (A20 SODIMM + ADB4006)
And I'm *not* the copyright owner here.
Maxime
Hi Maxime,
At least one other combination is available. A custom board from SWAC equipped with the SoM. What is the preferred method to support SoM's with multiple baseboards? Something like:
sun7i-a20-icnova.dtsi sun7i-a20-icnova-adb4006.dts sun7i-a20-icnova-swac.dts
Okay. Hans, do you want me to change this (and potential other changes as well - see file naming above) via a follow-up patch once its available in mainline U-Boot?
Thanks, Stefan
On 19-10-15 12:48, Stefan Roese wrote:
Hi Maxime,
Actually I would prefer to get this right in one go, esp. the filename bits, having u-boot and the kernel disagreeing on the dtb filename is no good. So I plan to remove this version of the patch from u-boot-sunxi/next for now. Once you and Maxime agree on a dts / dtb filename please submit a new version and I'll merge that one instead.
Regards,
Hans
Hi Hans,
On 19.10.2015 13:44, Hans de Goede wrote:
<snip>
Sure. Lets do it this way.
Thanks, Stefan
Wasn't our policy supposed to be that we (u-boot) would only take DTS files which were at least on their way to mainline Linux (i.e. in Maxime's tree)?
Ian.
On Mon, Oct 19, 2015 at 12:48:35PM +0200, Stefan Roese wrote:
Hi Maxime,
Ah, my bad then. I was under the impression that you were adding support for the SoM + ADB4006. Sorry.
Yep, that would make much more sense. I have an ADB4006 here, so I can do that one if you want, but we should totally split the common part in a DTSI.
Maxime
Hi Maxime,
No problem.
Okay. I'll try to find some time tomorrow to split this and send you a first version for Linux this time. Since I don't have the ADB4006 baseboard it would be great if you could step in here.
Thanks, Stefan
That can come as a second step, but yep, let's do it this way.
Thanks! Maxime
Hi Hans,
Thanks.
<snip>
Hmmm. I would prefer to have this added to the defconfig as well. As it very likely leads to confusion when updating to a newer U-Boot version which will not support the old kernel. Why not give the users / maintainers the freedom to choose this for themselves?
Understood.
Thanks, Stefan
On 19-10-15 12:38, Stefan Roese wrote:
Hi Hans,
Thanks.
<snip>
Users are free to choose this, they can always enable this themselves after running make foo_defconfig.
As for why not give the MAINTAINERS a choice on this, as said I believe that we should not shipp defconfigs with this set by default as part of mainline u-boot. The reasons for this are:
1) It is inconsistent with what we are doing for all other sunxi boards where we are primarily targetting mainline
2) It communicates that CONFIG_OLD_SUNXI_KERNEL_COMPAT is an officially supported end-user feature, where as in reality it is targeted at developers who need to run an old sunxi kernel every now and then to see how that kernel exactly programs certain registers, etc.
3) It means we ship with a severely crippled defconfig for mainline kernel users, mainline users will loose both smp and hyp mode support on the A20 when this option is set.
I'm sorry but I'm not going to budge on this one, having CONFIG_OLD_SUNXI_KERNEL_COMPAT=y in a defconfig is simply not acceptable IMHO. It is not a board specific thing, and there are very good reasons why it defaults to n in board/sunxi/Kconfig
Understood.
Thanks, Stefan
Regards,
Hans
Agreed.
Ian.
Hi Hans,
Thanks.
<snip>
Understood.
Thanks, Stefan
Hans de Goede
Ian Campbell
Maxime Ripard
Stefan Roese
