[U-Boot] [PATCH 0/6] J721e: Add networking support
This patch enables networking support for TI's J721e SoC. Patch 1 adds a new interface to DMA uclass to get channel specific private/configuration data. Patch 2 to 4 use this interface to pass data from J721e's UDMA driver to CPSW ethernet driver. Last two patches add DMA and CPSW DT nodes and configs.
Vignesh Raghavendra (6): dma: Introduce dma_get_cfg() interface dma: ti: k3-udma: Implement dma_get_cfg() interface net: ti: am65-cpsw-nuss: Rework RX flow ID handling net: ti: am65-cpsw-nuss: Add new compatible for J721e arm: dts: k3-j721e-common-proc-board: Add DMA and CPSW related DT nodes configs: j721e_evm_a72_defconfig: Enable DMA and Ethernet
.../k3-j721e-common-proc-board-u-boot.dtsi | 268 ++++++++++++++++++ configs/j721e_evm_a72_defconfig | 8 + drivers/dma/dma-uclass.c | 12 + drivers/dma/ti/k3-udma.c | 28 ++ drivers/net/ti/am65-cpsw-nuss.c | 14 +- include/dma-uclass.h | 11 + include/dma.h | 11 + include/linux/soc/ti/ti-udma.h | 19 ++ 8 files changed, 362 insertions(+), 9 deletions(-)
Sometimes, there would be a need to exchange data between DMA provider and DMA client which are very specific to DMA driver of the SoC/platform and are not generic enough to be put into struct dma. Therefore, introduce dma_get_cfg() interface to get DMA provider specific data from client device. Clients can use unique configuration ID flags to get different configuration data from DMA driver.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/dma/dma-uclass.c | 12 ++++++++++++ include/dma-uclass.h | 11 +++++++++++ include/dma.h | 11 +++++++++++ 3 files changed, 34 insertions(+)
diff --git a/drivers/dma/dma-uclass.c b/drivers/dma/dma-uclass.c index 9c961cf1e2c7..2321fb513ba3 100644 --- a/drivers/dma/dma-uclass.c +++ b/drivers/dma/dma-uclass.c @@ -186,6 +186,18 @@ int dma_send(struct dma *dma, void *src, size_t len, void *metadata)
return ops->send(dma, src, len, metadata); } + +int dma_get_cfg(struct dma *dma, u32 cfg_id, void **cfg_data) +{ + struct dma_ops *ops = dma_dev_ops(dma->dev); + + debug("%s(dma=%p)\n", __func__, dma); + + if (!ops->get_cfg) + return -ENOSYS; + + return ops->get_cfg(dma, cfg_id, cfg_data); +} #endif /* CONFIG_DMA_CHANNELS */
int dma_get_device(u32 transfer_type, struct udevice **devp) diff --git a/include/dma-uclass.h b/include/dma-uclass.h index 31b43fb4b98e..a1d9d26ac56f 100644 --- a/include/dma-uclass.h +++ b/include/dma-uclass.h @@ -108,6 +108,17 @@ struct dma_ops { * @return zero on success, or -ve error code. */ int (*send)(struct dma *dma, void *src, size_t len, void *metadata); + /** + * get_cfg() - Get DMA channel configuration for client's use + * + * @dma: The DMA Channel to manipulate + * @cfg_id: DMA provider specific ID to identify what + * configuration data client needs + * @data: Pointer to store pointer to DMA driver specific + * configuration data for the given cfg_id (output param) + * @return zero on success, or -ve error code. + */ + int (*get_cfg)(struct dma *dma, u32 cfg_id, void **data); #endif /* CONFIG_DMA_CHANNELS */ /** * transfer() - Issue a DMA transfer. The implementation must diff --git a/include/dma.h b/include/dma.h index 32885571f7d4..426617b34edf 100644 --- a/include/dma.h +++ b/include/dma.h @@ -290,6 +290,17 @@ int dma_receive(struct dma *dma, void **dst, void *metadata); * @return zero on success, or -ve error code. */ int dma_send(struct dma *dma, void *src, size_t len, void *metadata); +/** + * dma_get_cfg() - Get DMA channel configuration for client's use + * + * @dma: The DMA Channel to manipulate + * @cfg_id: DMA provider specific ID to identify what + * configuration data client needs + * @cfg_data: Pointer to store pointer to DMA driver specific + * configuration data for the given cfg_id (output param) + * @return zero on success, or -ve error code. + */ +int dma_get_cfg(struct dma *dma, u32 cfg_id, void **cfg_data); #endif /* CONFIG_DMA_CHANNELS */
#if CONFIG_IS_ENABLED(DMA)
Implement dma_get_cfg() interface to pass flow id information for DMA clients to use. This is needed because on K3 SoCs, CPSW (ethernet) and UDMA (DMA provider) support "flows" within a given RX DMA channel. This allows different network packets to be segregated while using same RX DMA channel. In order for basic ethernet to work, CPSW slave must be aware of the flow ID allocated for the RX channel by the DMA driver. This interface allows CPSW to query flow ID from DMA provider and configure it in CPSW HW.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/dma/ti/k3-udma.c | 28 ++++++++++++++++++++++++++++ include/linux/soc/ti/ti-udma.h | 19 +++++++++++++++++++ 2 files changed, 47 insertions(+)
diff --git a/drivers/dma/ti/k3-udma.c b/drivers/dma/ti/k3-udma.c index 7336bad99412..3d24d8a7ff12 100644 --- a/drivers/dma/ti/k3-udma.c +++ b/drivers/dma/ti/k3-udma.c @@ -108,6 +108,8 @@ struct udma_chan { struct udma_rchan *rchan; struct udma_rflow *rflow;
+ struct ti_udma_drv_chan_cfg_data cfg_data; + u32 bcnt; /* number of bytes completed since the start of the channel */
bool pkt_mode; /* TR or packet */ @@ -1530,6 +1532,11 @@ static int udma_request(struct dma *dma) uc->desc_rx_cur = 0; uc->num_rx_bufs = 0;
+ if (uc->dir == DMA_DEV_TO_MEM) { + uc->cfg_data.flow_id_base = uc->rflow->id; + uc->cfg_data.flow_id_cnt = 1; + } + return 0; }
@@ -1804,6 +1811,26 @@ int udma_prepare_rcv_buf(struct dma *dma, void *dst, size_t size) return 0; }
+static int udma_get_cfg(struct dma *dma, u32 id, void **data) +{ + struct udma_dev *ud = dev_get_priv(dma->dev); + struct udma_chan *uc; + + if (dma->id >= (ud->rchan_cnt + ud->tchan_cnt)) { + dev_err(dma->dev, "invalid dma ch_id %lu\n", dma->id); + return -EINVAL; + } + + switch (id) { + case TI_UDMA_CHAN_PRIV_INFO: + uc = &ud->channels[dma->id]; + *data = &uc->cfg_data; + return 0; + } + + return -EINVAL; +} + static const struct dma_ops udma_ops = { .transfer = udma_transfer, .of_xlate = udma_of_xlate, @@ -1814,6 +1841,7 @@ static const struct dma_ops udma_ops = { .send = udma_send, .receive = udma_receive, .prepare_rcv_buf = udma_prepare_rcv_buf, + .get_cfg = udma_get_cfg, };
static const struct udevice_id udma_ids[] = { diff --git a/include/linux/soc/ti/ti-udma.h b/include/linux/soc/ti/ti-udma.h index e9d4226c48d9..04e354fb2d69 100644 --- a/include/linux/soc/ti/ti-udma.h +++ b/include/linux/soc/ti/ti-udma.h @@ -21,4 +21,23 @@ struct ti_udma_drv_packet_data { u32 dest_tag; };
+/** + * struct ti_udma_drv_chan_cfg_data - TI UDMA per channel specific + * configuration data + * + * @flow_id_base: Start index of flow ID allocated to this channel + * @flow_id_cnt: Number of flows allocated for this channel starting at + * flow_id_base + * + * TI UDMA channel specific data returned as part of dma_get_cfg() call + * from the DMA client driver. + */ +struct ti_udma_drv_chan_cfg_data { + u32 flow_id_base; + u32 flow_id_cnt; +}; + +/* TI UDMA specific flag IDs for dma_get_cfg() call */ +#define TI_UDMA_CHAN_PRIV_INFO 0 + #endif /* __TI_UDMA_H */
Get flow ID information for RX DMA channel using dma_get_cfg() interface instead of reading from DT. This is required in order to avoid DT update whenever there is change in the range of flow ID allocated to the host.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/net/ti/am65-cpsw-nuss.c | 13 ++++--------- 1 file changed, 4 insertions(+), 9 deletions(-)
diff --git a/drivers/net/ti/am65-cpsw-nuss.c b/drivers/net/ti/am65-cpsw-nuss.c index 06b06639506a..2e14f4be862f 100644 --- a/drivers/net/ti/am65-cpsw-nuss.c +++ b/drivers/net/ti/am65-cpsw-nuss.c @@ -99,7 +99,6 @@ struct am65_cpsw_common {
u32 port_num; struct am65_cpsw_port ports[AM65_CPSW_CPSWNU_MAX_PORTS]; - u32 rflow_id_base;
struct mii_dev *bus; u32 bus_freq; @@ -276,6 +275,7 @@ static int am65_cpsw_start(struct udevice *dev) struct am65_cpsw_common *common = priv->cpsw_common; struct am65_cpsw_port *port = &common->ports[priv->port_id]; struct am65_cpsw_port *port0 = &common->ports[0]; + struct ti_udma_drv_chan_cfg_data *dma_rx_cfg_data; int ret, i;
ret = power_domain_on(&common->pwrdmn); @@ -341,7 +341,8 @@ static int am65_cpsw_start(struct udevice *dev) writel(PKTSIZE_ALIGN, port0->port_base + AM65_CPSW_PN_RX_MAXLEN_REG);
/* set base flow_id */ - writel(common->rflow_id_base, + dma_get_cfg(&common->dma_rx, 0, (void **)&dma_rx_cfg_data); + writel(dma_rx_cfg_data->flow_id_base, port0->port_base + AM65_CPSW_P0_FLOW_ID_REG);
/* Reset and enable the ALE */ @@ -669,11 +670,6 @@ static int am65_cpsw_probe_cpsw(struct udevice *dev) AM65_CPSW_CPSW_NU_ALE_BASE; cpsw_common->mdio_base = cpsw_common->ss_base + AM65_CPSW_MDIO_BASE;
- cpsw_common->rflow_id_base = 0; - cpsw_common->rflow_id_base = - dev_read_u32_default(dev, "ti,rx-flow-id-base", - cpsw_common->rflow_id_base); - ports_np = dev_read_subnode(dev, "ports"); if (!ofnode_valid(ports_np)) { ret = -ENOENT; @@ -761,12 +757,11 @@ static int am65_cpsw_probe_cpsw(struct udevice *dev) if (ret) goto out;
- dev_info(dev, "K3 CPSW: nuss_ver: 0x%08X cpsw_ver: 0x%08X ale_ver: 0x%08X Ports:%u rflow_id_base:%u mdio_freq:%u\n", + dev_info(dev, "K3 CPSW: nuss_ver: 0x%08X cpsw_ver: 0x%08X ale_ver: 0x%08X Ports:%u mdio_freq:%u\n", readl(cpsw_common->ss_base), readl(cpsw_common->cpsw_base), readl(cpsw_common->ale_base), cpsw_common->port_num, - cpsw_common->rflow_id_base, cpsw_common->bus_freq);
out:
Add new compatible to handle J721e SoC
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/net/ti/am65-cpsw-nuss.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/net/ti/am65-cpsw-nuss.c b/drivers/net/ti/am65-cpsw-nuss.c index 2e14f4be862f..b606ff0ade2a 100644 --- a/drivers/net/ti/am65-cpsw-nuss.c +++ b/drivers/net/ti/am65-cpsw-nuss.c @@ -772,6 +772,7 @@ out:
static const struct udevice_id am65_cpsw_nuss_ids[] = { { .compatible = "ti,am654-cpsw-nuss" }, + { .compatible = "ti,j721e-cpsw-nuss" }, { } };
Add DT nodes related to DMA and CPSW to -u-boot.dtsi to get networking up on J721e EVM.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- .../k3-j721e-common-proc-board-u-boot.dtsi | 268 ++++++++++++++++++ 1 file changed, 268 insertions(+)
diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index 541da22c4889..c4f2dd6b4fb2 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -3,15 +3,97 @@ * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ */
+#include <dt-bindings/dma/k3-udma.h> +#include <dt-bindings/net/ti-dp83867.h> + / { chosen { stdout-path = "serial2:115200n8"; tick-timer = &timer1; }; + + aliases { + ethernet0 = &cpsw_port1; + }; };
&cbass_main{ u-boot,dm-spl; + + cbass_main_navss: interconnect0 { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + dma-coherent; + dma-ranges; + ranges; + + ti,sci-dev-id = <199>; + u-boot,dm-spl; + + main_navss_intr: interrupt-controller1 { + compatible = "ti,sci-intr"; + interrupt-controller; + interrupt-parent = <&gic500>; + #interrupt-cells = <3>; + ti,sci = <&dmsc>; + ti,sci-dst-id = <14>; + ti,sci-rm-range-girq = <0>, <2>; + }; + + main_udmass_inta: interrupt-controller@33d00000 { + compatible = "ti,sci-inta"; + reg = <0x0 0x33d00000 0x0 0x100000>; + interrupt-controller; + interrupt-parent = <&main_navss_intr>; + #interrupt-cells = <3>; + ti,sci = <&dmsc>; + ti,sci-dev-id = <209>; + ti,sci-rm-range-vint = <0xa>; + ti,sci-rm-range-global-event = <0xd>; + }; + + main_ringacc: ringacc@3c000000 { + compatible = "ti,am654-navss-ringacc"; + reg = <0x0 0x3c000000 0x0 0x400000>, + <0x0 0x38000000 0x0 0x400000>, + <0x0 0x31120000 0x0 0x100>, + <0x0 0x33000000 0x0 0x40000>; + reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target"; + ti,num-rings = <1024>; + ti,sci-rm-range-gp-rings = <0x1>; /* GP ring range */ + ti,sci = <&dmsc>; + ti,sci-dev-id = <211>; + interrupt-parent = <&main_udmass_inta>; + u-boot,dm-spl; + }; + + main_udmap: udmap@31150000 { + compatible = "ti,j721e-navss-main-udmap"; + reg = <0x0 0x31150000 0x0 0x100>, + <0x0 0x34000000 0x0 0x100000>, + <0x0 0x35000000 0x0 0x100000>; + reg-names = "gcfg", "rchanrt", "tchanrt"; + #dma-cells = <3>; + + ti,ringacc = <&main_ringacc>; + ti,psil-base = <0x1000>; + + interrupt-parent = <&main_udmass_inta>; + + ti,sci = <&dmsc>; + ti,sci-dev-id = <212>; + + ti,sci-rm-range-tchan = <0x0d>, /* TX_CHAN */ + <0x0f>, /* TX_HCHAN */ + <0x10>; /* TX_UHCHAN */ + ti,sci-rm-range-rchan = <0x0a>, /* RX_CHAN */ + <0x0b>, /* RX_HCHAN */ + <0x0c>; /* RX_UHCHAN */ + ti,sci-rm-range-rflow = <0x00>; /* GP RFLOW */ + u-boot,dm-spl; + }; + }; };
&cbass_mcu_wakeup { @@ -24,6 +106,138 @@ clock-frequency = <25000000>; u-boot,dm-spl; }; + + mcu_conf: scm_conf@40f00000 { + compatible = "syscon", "simple-mfd"; + reg = <0x0 0x40f00000 0x0 0x20000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0x40f00000 0x20000>; + + phy_sel: cpsw-phy-sel@4040 { + compatible = "ti,am654-cpsw-phy-sel"; + reg = <0x4040 0x4>; + reg-names = "gmii-sel"; + }; + }; + + mcu_cpsw: ethernet@046000000 { + compatible = "ti,j721e-cpsw-nuss"; + #address-cells = <2>; + #size-cells = <2>; + reg = <0x0 0x46000000 0x0 0x200000>; + reg-names = "cpsw_nuss"; + ranges; + dma-coherent; + clocks = <&k3_clks 18 22>; + clock-names = "fck"; + power-domains = <&k3_pds 18 TI_SCI_PD_EXCLUSIVE>; + ti,psil-base = <0x7000>; + cpsw-phy-sel = <&phy_sel>; + + interrupt-parent = <&main_udmass_inta>; + + dmas = <&main_udmap &mcu_cpsw 0 UDMA_DIR_TX>, + <&main_udmap &mcu_cpsw 1 UDMA_DIR_TX>, + <&main_udmap &mcu_cpsw 2 UDMA_DIR_TX>, + <&main_udmap &mcu_cpsw 3 UDMA_DIR_TX>, + <&main_udmap &mcu_cpsw 4 UDMA_DIR_TX>, + <&main_udmap &mcu_cpsw 5 UDMA_DIR_TX>, + <&main_udmap &mcu_cpsw 6 UDMA_DIR_TX>, + <&main_udmap &mcu_cpsw 7 UDMA_DIR_TX>, + <&main_udmap &mcu_cpsw 0 UDMA_DIR_RX>; + dma-names = "tx0", "tx1", "tx2", "tx3", + "tx4", "tx5", "tx6", "tx7", + "rx"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + host: host@0 { + reg = <0>; + ti,label = "host"; + }; + + cpsw_port1: port@1 { + reg = <1>; + ti,mac-only; + ti,label = "port1"; + ti,syscon-efuse = <&mcu_conf 0x200>; + }; + }; + + davinci_mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + bus_freq = <1000000>; + }; + + cpts { + clocks = <&k3_clks 18 2>; + clock-names = "cpts"; + interrupts-extended = <&gic500 GIC_SPI 858 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "cpts"; + ti,cpts-ext-ts-inputs = <4>; + ti,cpts-periodic-outputs = <2>; + }; + + ti,psil-config0 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config1 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config2 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config3 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config4 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config5 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config6 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + + ti,psil-config7 { + linux,udma-mode = <UDMA_PKT_MODE>; + statictr-type = <PSIL_STATIC_TR_NONE>; + ti,needs-epib; + ti,psd-size = <16>; + }; + }; };
&secure_proxy_main { @@ -52,6 +266,29 @@
&wkup_pmx0 { u-boot,dm-spl; + mcu_cpsw_pins_default: mcu_cpsw_pins_default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x0058, PIN_OUTPUT, 0) /* (N4) MCU_RGMII1_TX_CTL */ + J721E_WKUP_IOPAD(0x005c, PIN_INPUT, 0) /* (N5) MCU_RGMII1_RX_CTL */ + J721E_WKUP_IOPAD(0x0060, PIN_OUTPUT, 0) /* (M2) MCU_RGMII1_TD3 */ + J721E_WKUP_IOPAD(0x0064, PIN_OUTPUT, 0) /* (M3) MCU_RGMII1_TD2 */ + J721E_WKUP_IOPAD(0x0068, PIN_OUTPUT, 0) /* (M4) MCU_RGMII1_TD1 */ + J721E_WKUP_IOPAD(0x006c, PIN_OUTPUT, 0) /* (M5) MCU_RGMII1_TD0 */ + J721E_WKUP_IOPAD(0x0078, PIN_INPUT, 0) /* (L2) MCU_RGMII1_RD3 */ + J721E_WKUP_IOPAD(0x007c, PIN_INPUT, 0) /* (L5) MCU_RGMII1_RD2 */ + J721E_WKUP_IOPAD(0x0080, PIN_INPUT, 0) /* (M6) MCU_RGMII1_RD1 */ + J721E_WKUP_IOPAD(0x0084, PIN_INPUT, 0) /* (L6) MCU_RGMII1_RD0 */ + J721E_WKUP_IOPAD(0x0070, PIN_INPUT, 0) /* (N1) MCU_RGMII1_TXC */ + J721E_WKUP_IOPAD(0x0074, PIN_INPUT, 0) /* (M1) MCU_RGMII1_RXC */ + >; + }; + + mcu_mdio_pins_default: mcu_mdio1_pins_default { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x008c, PIN_OUTPUT, 0) /* (L1) MCU_MDIO0_MDC */ + J721E_WKUP_IOPAD(0x0088, PIN_INPUT, 0) /* (L4) MCU_MDIO0_MDIO */ + >; + }; };
&main_pmx0 { @@ -73,3 +310,34 @@ &main_sdhci1 { u-boot,dm-spl; }; + +&mcu_cpsw { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>; +}; + +&davinci_mdio { + phy0: ethernet-phy@0 { + reg = <0>; + /* TODO: phy reset: TCA9555RTWR(i2c:0x21)[p04].GPIO_MCU_RGMII_RSTN */ + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + }; +}; + +&cpsw_port1 { + phy-mode = "rgmii-rxid"; + phy-handle = <&phy0>; +}; + +&mcu_cpsw { + reg = <0x0 0x46000000 0x0 0x200000>, + <0x0 0x40f00200 0x0 0x2>; + reg-names = "cpsw_nuss", "mac_efuse"; + + cpsw-phy-sel@40f04040 { + compatible = "ti,am654-cpsw-phy-sel"; + reg= <0x0 0x40f04040 0x0 0x4>; + reg-names = "gmii-sel"; + }; +};
Enable configs related to DMA and Ethernet so as to support networking at U-Boot prompt
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- configs/j721e_evm_a72_defconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index f9396e612b02..748179e82317 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -49,6 +49,7 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="k3-j721e-common-proc-board" CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y @@ -59,6 +60,8 @@ CONFIG_SPL_OF_TRANSLATE=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_CLK_TI_SCI=y +CONFIG_DMA_CHANNELS=y +CONFIG_TI_K3_NAVSS_UDMA=y CONFIG_TI_SCI_PROTOCOL=y CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y @@ -77,6 +80,10 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_HBMC_AM654=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_TI=y +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH=y +CONFIG_TI_AM65_CPSW_NUSS=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set CONFIG_SPL_PINCTRL=y @@ -91,6 +98,7 @@ CONFIG_RESET_TI_SCI=y CONFIG_SCSI=y CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y +CONFIG_SOC_TI=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_CADENCE_QSPI=y
I assume this series has dependencies. Right?
No compile time dependencies and system will boot to U-Boot prompt. But for ethernet functionality to work we need base DMA support: http://patchwork.ozlabs.org/project/uboot/list/?series=142768
Grygorii Strashko
Joe Hershberger
Vignesh Raghavendra
