[U-Boot] [GIT PULL] u-boot-mips/master
Hi Tom,
this pull-request introduces: - new board: MIPSfpga - new board: Boston with variants for MIPS32r2/MIPS64r2 and BE/LE - updates to DM core code needed for Boston board - support for L2 cache and MIPS coherency manager - various fixes on cache initialization
The following changes since commit 9b1b6d42256a4c2e59c803afdbf90d39371e61ba:
Revert "Increase default of CONFIG_SYS_MALLOC_F_LEN for SPL_OF_CONTROL" (2016-09-19 15:20:09 -0400)
git://git.denx.de/u-boot-mips.git master
for you to fetch changes up to 31d36f748c52b22833aa946f6c406cc8fb2f1908:
MIPS: Hang if run on a secondary CPU (2016-09-21 17:04:53 +0200)
---------------------------------------------------------------- Paul Burton (28): board_f: Add a mach_cpu_init callback MIPS: ath79: Use mach_cpu_init instead of arch_cpu_init MIPS: Probe cache line sizes once during boot MIPS: Enable use of the instruction cache earlier MIPS: Preserve Config implementation-defined bits MIPS: If we don't need DDR for cache init, init cache first MIPS: Define register names for cache init MIPS: Map CM Global Control Registers MIPS: L2 cache support MIPS: Join the coherent domain when a CM is present MIPS: Malta: Enable CM & L2 support MIPS: Ensure Config.K0=2 applies before any memory accesses MIPS: Clear hazard between TagLo writes & cache ops MIPS: Ensure cache ops complete in mips_cache_reset clk: Use dummy clk_get_by_* functions when CONFIG_CLK is disabled serial: ns16550: Support clocks via phandle dt-bindings: Add interrupt-controller/mips-gic.h header pci: xilinx: Add a driver for Xilinx AXI to PCIe bridge pci: Flip condition for detecting non-PCI parent devices net: pch_gbe: Use dm_pci_map_bar to discover MMIO base net: pch_gbe: Make 64 bit safe dm: regmap: Implement simple regmap_read & regmap_write dm: core: Match compatible strings in order of priority dm: syscon: Provide a generic syscon driver clk: boston: Providea simple driver for Boston board clocks boston: Introduce support for the MIPS Boston development board MIPS: Fix cache maintenance in relocate_code & simplify MIPS: Hang if run on a secondary CPU
Zubair Lutfullah Kakakhel (5): net: emaclite: Use ioremap_nocache net: emaclite: use __raw_readl/writel instead of weird define net: emaclite: Enable driver for MIPS mips: xilfpga: Add device tree files mips: Add MIPSfpga platform support
arch/mips/Kconfig | 57 +++++++++++++++++ arch/mips/cpu/Makefile | 2 + arch/mips/cpu/cm_init.S | 45 ++++++++++++++ arch/mips/cpu/cpu.c | 7 +++ arch/mips/cpu/start.S | 93 +++++++++++++++++----------- arch/mips/cpu/u-boot.lds | 2 + arch/mips/dts/Makefile | 2 + arch/mips/dts/img,boston.dts | 222 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/mips/dts/microAptiv.dtsi | 21 +++++++ arch/mips/dts/nexys4ddr.dts | 62 +++++++++++++++++++ arch/mips/include/asm/cache.h | 9 +++ arch/mips/include/asm/cm.h | 62 +++++++++++++++++++ arch/mips/include/asm/global_data.h | 7 +++ arch/mips/include/asm/mipsregs.h | 13 ++++ arch/mips/lib/cache.c | 101 ++++++++++++++++++++++++------ arch/mips/lib/cache_init.S | 271 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------ arch/mips/mach-ath79/cpu.c | 2 +- board/imgtec/boston/Kconfig | 16 +++++ board/imgtec/boston/MAINTAINERS | 6 ++ board/imgtec/boston/Makefile | 9 +++ board/imgtec/boston/boston-lcd.h | 21 +++++++ board/imgtec/boston/boston-regs.h | 26 ++++++++ board/imgtec/boston/checkboard.c | 30 +++++++++ board/imgtec/boston/ddr.c | 30 +++++++++ board/imgtec/boston/lowlevel_init.S | 56 +++++++++++++++++ board/imgtec/malta/lowlevel_init.S | 6 -- board/imgtec/xilfpga/Kconfig | 15 +++++ board/imgtec/xilfpga/MAINTAINERS | 6 ++ board/imgtec/xilfpga/Makefile | 7 +++ board/imgtec/xilfpga/README | 55 +++++++++++++++++ board/imgtec/xilfpga/xilfpga.c | 20 ++++++ common/board_f.c | 6 ++ configs/boston32r2_defconfig | 41 +++++++++++++ configs/boston32r2el_defconfig | 42 +++++++++++++ configs/boston64r2_defconfig | 41 +++++++++++++ configs/boston64r2el_defconfig | 42 +++++++++++++ configs/imgtec_xilfpga_defconfig | 25 ++++++++ doc/README.boston | 58 ++++++++++++++++++ drivers/clk/Kconfig | 8 +++ drivers/clk/Makefile | 1 + drivers/clk/clk_boston.c | 97 +++++++++++++++++++++++++++++ drivers/core/lists.c | 78 +++++++++++++----------- drivers/core/regmap.c | 20 ++++++ drivers/core/syscon-uclass.c | 11 ++++ drivers/net/Kconfig | 2 +- drivers/net/pch_gbe.c | 28 ++++----- drivers/net/xilinx_emaclite.c | 90 ++++++++++++++------------- drivers/pci/Kconfig | 7 +++ drivers/pci/Makefile | 1 + drivers/pci/pci-uclass.c | 2 +- drivers/pci/pcie_xilinx.c | 220 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/serial/ns16550.c | 21 ++++++- include/clk.h | 2 +- include/configs/boston.h | 81 ++++++++++++++++++++++++ include/configs/imgtec_xilfpga.h | 68 +++++++++++++++++++++ include/dt-bindings/clock/boston-clock.h | 13 ++++ include/dt-bindings/interrupt-controller/mips-gic.h | 9 +++ 57 files changed, 2115 insertions(+), 180 deletions(-) create mode 100644 arch/mips/cpu/cm_init.S create mode 100644 arch/mips/dts/img,boston.dts create mode 100644 arch/mips/dts/microAptiv.dtsi create mode 100644 arch/mips/dts/nexys4ddr.dts create mode 100644 arch/mips/include/asm/cm.h create mode 100644 board/imgtec/boston/Kconfig create mode 100644 board/imgtec/boston/MAINTAINERS create mode 100644 board/imgtec/boston/Makefile create mode 100644 board/imgtec/boston/boston-lcd.h create mode 100644 board/imgtec/boston/boston-regs.h create mode 100644 board/imgtec/boston/checkboard.c create mode 100644 board/imgtec/boston/ddr.c create mode 100644 board/imgtec/boston/lowlevel_init.S create mode 100644 board/imgtec/xilfpga/Kconfig create mode 100644 board/imgtec/xilfpga/MAINTAINERS create mode 100644 board/imgtec/xilfpga/Makefile create mode 100644 board/imgtec/xilfpga/README create mode 100644 board/imgtec/xilfpga/xilfpga.c create mode 100644 configs/boston32r2_defconfig create mode 100644 configs/boston32r2el_defconfig create mode 100644 configs/boston64r2_defconfig create mode 100644 configs/boston64r2el_defconfig create mode 100644 configs/imgtec_xilfpga_defconfig create mode 100644 doc/README.boston create mode 100644 drivers/clk/clk_boston.c create mode 100644 drivers/pci/pcie_xilinx.c create mode 100644 include/configs/boston.h create mode 100644 include/configs/imgtec_xilfpga.h create mode 100644 include/dt-bindings/clock/boston-clock.h create mode 100644 include/dt-bindings/interrupt-controller/mips-gic.h
Since we return -ENOSYS in some cases we must have <asm/errno.> available.
Signed-off-by: Tom Rini trini@konsulko.com --- include/clk.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/clk.h b/include/clk.h index 9b2452268d40..94c003714700 100644 --- a/include/clk.h +++ b/include/clk.h @@ -10,6 +10,7 @@ #define _CLK_H_
#include <linux/types.h> +#include <asm/errno.h>
/** * A clock is a hardware signal that oscillates autonomously at a specific
On Wed, Sep 21, 2016 at 05:49:14PM +0200, Daniel Schwierzeck wrote:
Hi Tom,
Daniel Schwierzeck
