[U-Boot] [PATCH 0/3] enable CONFIG_NET_MULTI for LAN91C96
Based on the discussion[1] here is the patchset
Patchset is based on [2], and tested on SDP3430. Other platforms would be prefered to be build/tested/fixed as required
Nishanth Menon (3): NET: LAN91C96 CONFIG_NET_MULTIify TI OMAP3: SDP3430 FIX NET_MULTI Warning LAN91C96: Enable NET_MULTI LAN driver
board/apollon/apollon.c | 12 +- board/ti/sdp3430/sdp.c | 12 +- drivers/net/Makefile | 2 +- drivers/net/lan91c96.c | 452 ++++++++++++++++----------------------- drivers/net/lan91c96.h | 110 +++++----- include/configs/B2.h | 2 +- include/configs/apollon.h | 3 +- include/configs/assabet.h | 3 +- include/configs/gcplus.h | 3 +- include/configs/lubbock.h | 3 +- include/configs/omap1510inn.h | 3 +- include/configs/omap1610h2.h | 3 +- include/configs/omap1610inn.h | 3 +- include/configs/omap2420h4.h | 3 +- include/configs/omap3_sdp3430.h | 3 +- include/configs/omap5912osk.h | 3 +- include/configs/omap730p2.h | 3 +- include/configs/pleb2.h | 6 +- include/netdev.h | 1 + 19 files changed, 277 insertions(+), 353 deletions(-)
Regards, Nishanth Menon
Ref: [1] http://www.nabble.com/-U-Boot--NET%3A-SDP3430%3A-trouble-with-shifting-from-... [2] http://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot/u-boot-ti.git
Make the lan91c96 driver capable of CONFIG_NET_MULTI to be clean for the new arch, add a a lil detect function Most of the formatting change was done to keep checkpatch silent, but a few functions and #if 0ed code which does not make sense for NET_MULTI have been removed
Now, use the lan91c96_initialize() function to init the driver
Signed-off-by: Nishanth Menon nm@ti.com Cc: Andrea Scian andrea.scian@dave-tech.it Cc: Ben Warren biggerbadderben@gmail.com Cc: Dave Peverley dpeverley@mpc-data.co.uk Cc: George G. Davis gdavis@mvista.com Cc: Kyungmin Park kyungmin.park@samsung.com Cc: Nishant Kamat nskamat@ti.com Cc: Richard Woodruff r-woodruff2@ti.com Cc: Rishi Bhattacharya rishi@ti.com Cc: Sandeep Paulraj s-paulraj@ti.com --- drivers/net/Makefile | 2 +- drivers/net/lan91c96.c | 452 +++++++++++++++++++---------------------------- drivers/net/lan91c96.h | 110 ++++++------- include/netdev.h | 1 + 4 files changed, 236 insertions(+), 329 deletions(-)
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index be5c484..a4ab447 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -44,7 +44,7 @@ COBJS-$(CONFIG_GRETH) += greth.o COBJS-$(CONFIG_INCA_IP_SWITCH) += inca-ip_sw.o COBJS-$(CONFIG_KIRKWOOD_EGIGA) += kirkwood_egiga.o COBJS-$(CONFIG_DRIVER_KS8695ETH) += ks8695eth.o -COBJS-$(CONFIG_DRIVER_LAN91C96) += lan91c96.o +COBJS-$(CONFIG_LAN91C96) += lan91c96.o COBJS-$(CONFIG_MACB) += macb.o COBJS-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o COBJS-$(CONFIG_MPC5xxx_FEC) += mpc5xxx_fec.o diff --git a/drivers/net/lan91c96.c b/drivers/net/lan91c96.c index 65565bc..90e4002 100644 --- a/drivers/net/lan91c96.c +++ b/drivers/net/lan91c96.c @@ -60,6 +60,7 @@
#include <common.h> #include <command.h> +#include <malloc.h> #include "lan91c96.h" #include <net.h>
@@ -108,11 +109,7 @@ * *------------------------------------------------------------------------ */ -#define CARDNAME "LAN91C96" - -#define SMC_BASE_ADDRESS CONFIG_LAN91C96_BASE - -#define SMC_DEV_NAME "LAN91C96" +#define DRIVER_NAME "LAN91C96" #define SMC_ALLOC_MAX_TRY 5 #define SMC_TX_TIMEOUT 30
@@ -124,64 +121,12 @@ #undef USE_32_BIT #endif
-/*----------------------------------------------------------------- - * - * The driver can be entered at any of the following entry points. - * - *----------------------------------------------------------------- - */ - -extern int eth_init (bd_t * bd); -extern void eth_halt (void); -extern int eth_rx (void); -extern int eth_send (volatile void *packet, int length); -#if 0 -static int smc_hw_init (void); -#endif - -/* - * This is called by register_netdev(). It is responsible for - * checking the portlist for the SMC9000 series chipset. If it finds - * one, then it will initialize the device, find the hardware information, - * and sets up the appropriate device parameters. - * NOTE: Interrupts are *OFF* when this procedure is called. - * - * NB:This shouldn't be static since it is referred to externally. - */ -int smc_init (void); - -/* - * This is called by unregister_netdev(). It is responsible for - * cleaning up before the driver is finally unregistered and discarded. - */ -void smc_destructor (void); - -/* - * The kernel calls this function when someone wants to use the device, - * typically 'ifconfig ethX up'. - */ -static int smc_open (bd_t *bd); - - -/* - * This is called by the kernel in response to 'ifconfig ethX down'. It - * is responsible for cleaning up everything that the open routine - * does, and maybe putting the card into a powerdown state. - */ -static int smc_close (void); - -/* - * This is a separate procedure to handle the receipt of a packet, to - * leave the interrupt code looking slightly cleaner - */ -static int smc_rcv (void); - /* See if a MAC address is defined in the current environment. If so use it. If not . print a warning and set the environment and other globals with the default. . If an EEPROM is present it really should be consulted. */ -int smc_get_ethaddr(bd_t *bd); -int get_rom_mac(unsigned char *v_rom_mac); +static int smc_get_ethaddr(bd_t *bd, struct eth_device *dev); +static int get_rom_mac(struct eth_device *dev, unsigned char *v_rom_mac);
/* ------------------------------------------------------------ * Internal routines @@ -195,7 +140,7 @@ static unsigned char smc_mac_addr[] = { 0xc0, 0x00, 0x00, 0x1b, 0x62, 0x9c }; * the default mac address. */
-void smc_set_mac_addr (const unsigned char *addr) +static void smc_set_mac_addr(const unsigned char *addr) { int i;
@@ -204,45 +149,21 @@ void smc_set_mac_addr (const unsigned char *addr) } }
-/* - * smc_get_macaddr is no longer used. If you want to override the default - * mac address, call smc_get_mac_addr as a part of the board initialisation. - */ - -#if 0 -void smc_get_macaddr (byte * addr) -{ - /* MAC ADDRESS AT FLASHBLOCK 1 / OFFSET 0x10 */ - unsigned char *dnp1110_mac = (unsigned char *) (0xE8000000 + 0x20010); - int i; - - - for (i = 0; i < 6; i++) { - addr[0] = *(dnp1110_mac + 0); - addr[1] = *(dnp1110_mac + 1); - addr[2] = *(dnp1110_mac + 2); - addr[3] = *(dnp1110_mac + 3); - addr[4] = *(dnp1110_mac + 4); - addr[5] = *(dnp1110_mac + 5); - } -} -#endif /* 0 */ - /*********************************************** * Show available memory * ***********************************************/ -void dump_memory_info (void) +void dump_memory_info(struct eth_device *dev) { word mem_info; word old_bank;
- old_bank = SMC_inw (LAN91C96_BANK_SELECT) & 0xF; + old_bank = SMC_inw(dev, LAN91C96_BANK_SELECT) & 0xF;
- SMC_SELECT_BANK (0); - mem_info = SMC_inw (LAN91C96_MIR); + SMC_SELECT_BANK(dev, 0); + mem_info = SMC_inw(dev, LAN91C96_MIR); PRINTK2 ("Memory: %4d available\n", (mem_info >> 8) * 2048);
- SMC_SELECT_BANK (old_bank); + SMC_SELECT_BANK(dev, old_bank); }
/* @@ -252,28 +173,15 @@ void dump_memory_info (void) static void print_packet (byte *, int); #endif
-/* #define tx_done(dev) 1 */ - - -/* this does a soft reset on the device */ -static void smc_reset (void); - -/* Enable Interrupts, Receive, and Transmit */ -static void smc_enable (void); - -/* this puts the device in an inactive state */ -static void smc_shutdown (void); - - -static int poll4int (byte mask, int timeout) +static int poll4int (struct eth_device *dev, byte mask, int timeout) { int tmo = get_timer (0) + timeout * CONFIG_SYS_HZ; int is_timeout = 0; - word old_bank = SMC_inw (LAN91C96_BANK_SELECT); + word old_bank = SMC_inw(dev, LAN91C96_BANK_SELECT);
PRINTK2 ("Polling...\n"); - SMC_SELECT_BANK (2); - while ((SMC_inw (LAN91C96_INT_STATS) & mask) == 0) { + SMC_SELECT_BANK(dev, 2); + while ((SMC_inw(dev, LAN91C96_INT_STATS) & mask) == 0) { if (get_timer (0) >= tmo) { is_timeout = 1; break; @@ -281,7 +189,7 @@ static int poll4int (byte mask, int timeout) }
/* restore old bank selection */ - SMC_SELECT_BANK (old_bank); + SMC_SELECT_BANK(dev, old_bank);
if (is_timeout) return 1; @@ -290,7 +198,7 @@ static int poll4int (byte mask, int timeout) }
/* - * Function: smc_reset( void ) + * Function: smc_reset * Purpose: * This sets the SMC91111 chip to its normal state, hopefully from whatever * mess that any other DOS driver has put it in. @@ -306,28 +214,28 @@ static int poll4int (byte mask, int timeout) * 5. clear all interrupts * */ -static void smc_reset (void) +static void smc_reset(struct eth_device *dev) { - PRINTK2 ("%s:smc_reset\n", SMC_DEV_NAME); + PRINTK2("%s:smc_reset\n", dev->name);
/* This resets the registers mostly to defaults, but doesn't affect EEPROM. That seems unnecessary */ - SMC_SELECT_BANK (0); - SMC_outw (LAN91C96_RCR_SOFT_RST, LAN91C96_RCR); + SMC_SELECT_BANK(dev, 0); + SMC_outw(dev, LAN91C96_RCR_SOFT_RST, LAN91C96_RCR);
udelay (10);
/* Disable transmit and receive functionality */ - SMC_outw (0, LAN91C96_RCR); - SMC_outw (0, LAN91C96_TCR); + SMC_outw(dev, 0, LAN91C96_RCR); + SMC_outw(dev, 0, LAN91C96_TCR);
/* set the control register */ - SMC_SELECT_BANK (1); - SMC_outw (SMC_inw (LAN91C96_CONTROL) | LAN91C96_CTR_BIT_8, + SMC_SELECT_BANK(dev, 1); + SMC_outw(dev, SMC_inw(dev, LAN91C96_CONTROL) | LAN91C96_CTR_BIT_8, LAN91C96_CONTROL);
/* Disable all interrupts */ - SMC_outb (0, LAN91C96_INT_MASK); + SMC_outb(dev, 0, LAN91C96_INT_MASK); }
/* @@ -338,24 +246,24 @@ static void smc_reset (void) * 2. Enable the transmitter * 3. Enable the receiver */ -static void smc_enable () +static void smc_enable(struct eth_device *dev) { - PRINTK2 ("%s:smc_enable\n", SMC_DEV_NAME); - SMC_SELECT_BANK (0); + PRINTK2("%s:smc_enable\n", dev->name); + SMC_SELECT_BANK(dev, 0);
/* Initialize the Memory Configuration Register. See page 49 of the LAN91C96 data sheet for details. */ - SMC_outw (LAN91C96_MCR_TRANSMIT_PAGES, LAN91C96_MCR); + SMC_outw(dev, LAN91C96_MCR_TRANSMIT_PAGES, LAN91C96_MCR);
/* Initialize the Transmit Control Register */ - SMC_outw (LAN91C96_TCR_TXENA, LAN91C96_TCR); + SMC_outw(dev, LAN91C96_TCR_TXENA, LAN91C96_TCR); /* Initialize the Receive Control Register * FIXME: * The promiscuous bit set because I could not receive ARP reply * packets from the server when I send a ARP request. It only works * when I set the promiscuous bit */ - SMC_outw (LAN91C96_RCR_RXEN | LAN91C96_RCR_PRMS, LAN91C96_RCR); + SMC_outw(dev, LAN91C96_RCR_RXEN | LAN91C96_RCR_PRMS, LAN91C96_RCR); }
/* @@ -372,18 +280,18 @@ static void smc_enable () * the manual says that it will wake up in response to any I/O requests * in the register space. Empirical results do not show this working. */ -static void smc_shutdown () +static void smc_shutdown(struct eth_device *dev) { - PRINTK2 (CARDNAME ":smc_shutdown\n"); + PRINTK2("%s:smc_shutdown\n", dev->name);
/* no more interrupts for me */ - SMC_SELECT_BANK (2); - SMC_outb (0, LAN91C96_INT_MASK); + SMC_SELECT_BANK(dev, 2); + SMC_outb(dev, 0, LAN91C96_INT_MASK);
/* and tell the card to stay away from that nasty outside world */ - SMC_SELECT_BANK (0); - SMC_outb (0, LAN91C96_RCR); - SMC_outb (0, LAN91C96_TCR); + SMC_SELECT_BANK(dev, 0); + SMC_outb(dev, 0, LAN91C96_RCR); + SMC_outb(dev, 0, LAN91C96_TCR); }
@@ -405,7 +313,8 @@ static void smc_shutdown () * Enable the transmit interrupt, so I know if it failed * Free the kernel data if I actually sent it. */ -static int smc_send_packet (volatile void *packet, int packet_length) +static int smc_send_packet(struct eth_device *dev, volatile void *packet, + int packet_length) { byte packet_no; unsigned long ioaddr; @@ -417,7 +326,7 @@ static int smc_send_packet (volatile void *packet, int packet_length) byte status;
- PRINTK3 ("%s:smc_hardware_send_packet\n", SMC_DEV_NAME); + PRINTK3("%s:smc_hardware_send_packet\n", dev->name);
length = ETH_ZLEN < packet_length ? packet_length : ETH_ZLEN;
@@ -437,30 +346,31 @@ static int smc_send_packet (volatile void *packet, int packet_length) numPages >>= 8; /* Divide by 256 */
if (numPages > 7) { - printf ("%s: Far too big packet error. \n", SMC_DEV_NAME); + printf("%s: Far too big packet error. \n", dev->name); return 0; }
/* now, try to allocate the memory */
- SMC_SELECT_BANK (2); - SMC_outw (LAN91C96_MMUCR_ALLOC_TX | numPages, LAN91C96_MMU); + SMC_SELECT_BANK(dev, 2); + SMC_outw(dev, LAN91C96_MMUCR_ALLOC_TX | numPages, LAN91C96_MMU);
again: try++; time_out = MEMORY_WAIT_TIME; do { - status = SMC_inb (LAN91C96_INT_STATS); + status = SMC_inb(dev, LAN91C96_INT_STATS); if (status & LAN91C96_IST_ALLOC_INT) {
- SMC_outb (LAN91C96_IST_ALLOC_INT, LAN91C96_INT_STATS); + SMC_outb(dev, LAN91C96_IST_ALLOC_INT, + LAN91C96_INT_STATS); break; } } while (--time_out);
if (!time_out) { PRINTK2 ("%s: memory allocation, try %d failed ...\n", - SMC_DEV_NAME, try); + dev->name, try); if (try < SMC_ALLOC_MAX_TRY) goto again; else @@ -468,30 +378,30 @@ static int smc_send_packet (volatile void *packet, int packet_length) }
PRINTK2 ("%s: memory allocation, try %d succeeded ...\n", - SMC_DEV_NAME, try); + dev->name, try);
/* I can send the packet now.. */
- ioaddr = SMC_BASE_ADDRESS; + ioaddr = dev->iobase;
buf = (byte *) packet;
/* If I get here, I _know_ there is a packet slot waiting for me */ - packet_no = SMC_inb (LAN91C96_ARR); + packet_no = SMC_inb(dev, LAN91C96_ARR); if (packet_no & LAN91C96_ARR_FAILED) { /* or isn't there? BAD CHIP! */ - printf ("%s: Memory allocation failed. \n", SMC_DEV_NAME); + printf("%s: Memory allocation failed. \n", dev->name); return 0; }
/* we have a packet address, so tell the card to use it */ - SMC_outb (packet_no, LAN91C96_PNR); + SMC_outb(dev, packet_no, LAN91C96_PNR);
/* point to the beginning of the packet */ - SMC_outw (LAN91C96_PTR_AUTO_INCR, LAN91C96_POINTER); + SMC_outw(dev, LAN91C96_PTR_AUTO_INCR, LAN91C96_POINTER);
- PRINTK3 ("%s: Trying to xmit packet of length %x\n", - SMC_DEV_NAME, length); + PRINTK3("%s: Trying to xmit packet of length %x\n", + dev->name, length);
#if SMC_DEBUG > 2 printf ("Transmitting Packet\n"); @@ -501,11 +411,11 @@ static int smc_send_packet (volatile void *packet, int packet_length) /* send the packet length ( +6 for status, length and ctl byte ) and the status word ( set to zeros ) */ #ifdef USE_32_BIT - SMC_outl ((length + 6) << 16, LAN91C96_DATA_HIGH); + SMC_outl(dev, (length + 6) << 16, LAN91C96_DATA_HIGH); #else - SMC_outw (0, LAN91C96_DATA_HIGH); + SMC_outw(dev, 0, LAN91C96_DATA_HIGH); /* send the packet length ( +6 for status words, length, and ctl */ - SMC_outw ((length + 6), LAN91C96_DATA_HIGH); + SMC_outw(dev, (length + 6), LAN91C96_DATA_HIGH); #endif /* USE_32_BIT */
/* send the actual data @@ -516,54 +426,52 @@ static int smc_send_packet (volatile void *packet, int packet_length) * almost as much time as is saved? */ #ifdef USE_32_BIT - SMC_outsl (LAN91C96_DATA_HIGH, buf, length >> 2); + SMC_outsl(dev, LAN91C96_DATA_HIGH, buf, length >> 2); if (length & 0x2) - SMC_outw (*((word *) (buf + (length & 0xFFFFFFFC))), + SMC_outw(dev, *((word *) (buf + (length & 0xFFFFFFFC))), LAN91C96_DATA_HIGH); #else - SMC_outsw (LAN91C96_DATA_HIGH, buf, (length) >> 1); + SMC_outsw(dev, LAN91C96_DATA_HIGH, buf, (length) >> 1); #endif /* USE_32_BIT */
/* Send the last byte, if there is one. */ if ((length & 1) == 0) { - SMC_outw (0, LAN91C96_DATA_HIGH); + SMC_outw(dev, 0, LAN91C96_DATA_HIGH); } else { - SMC_outw (buf[length - 1] | 0x2000, LAN91C96_DATA_HIGH); + SMC_outw(dev, buf[length - 1] | 0x2000, LAN91C96_DATA_HIGH); }
/* and let the chipset deal with it */ - SMC_outw (LAN91C96_MMUCR_ENQUEUE, LAN91C96_MMU); + SMC_outw(dev, LAN91C96_MMUCR_ENQUEUE, LAN91C96_MMU);
/* poll for TX INT */ - if (poll4int (LAN91C96_MSK_TX_INT, SMC_TX_TIMEOUT)) { + if (poll4int (dev, LAN91C96_MSK_TX_INT, SMC_TX_TIMEOUT)) { /* sending failed */ - PRINTK2 ("%s: TX timeout, sending failed...\n", SMC_DEV_NAME); + PRINTK2("%s: TX timeout, sending failed...\n", dev->name);
/* release packet */ - SMC_outw (LAN91C96_MMUCR_RELEASE_TX, LAN91C96_MMU); + SMC_outw(dev, LAN91C96_MMUCR_RELEASE_TX, LAN91C96_MMU);
/* wait for MMU getting ready (low) */ - while (SMC_inw (LAN91C96_MMU) & LAN91C96_MMUCR_NO_BUSY) { + while (SMC_inw(dev, LAN91C96_MMU) & LAN91C96_MMUCR_NO_BUSY) udelay (10); - }
- PRINTK2 ("MMU ready\n"); + PRINTK2("MMU ready\n");
return 0; } else { /* ack. int */ - SMC_outw (LAN91C96_IST_TX_INT, LAN91C96_INT_STATS); + SMC_outw(dev, LAN91C96_IST_TX_INT, LAN91C96_INT_STATS);
- PRINTK2 ("%s: Sent packet of length %d \n", SMC_DEV_NAME, length); + PRINTK2("%s: Sent packet of length %d \n", dev->name, length);
PRINTK2 ("MMU ready\n"); } @@ -571,20 +479,6 @@ static int smc_send_packet (volatile void *packet, int packet_length) return length; }
-/*------------------------------------------------------------------------- - * smc_destructor( struct net_device * dev ) - * Input parameters: - * dev, pointer to the device structure - * - * Output: - * None. - *-------------------------------------------------------------------------- - */ -void smc_destructor () -{ - PRINTK2 (CARDNAME ":smc_destructor\n"); -} -
/* * Open and Initialize the board @@ -592,20 +486,20 @@ void smc_destructor () * Set up everything, reset the card, etc .. * */ -static int smc_open (bd_t *bd) +static int smc_open(bd_t *bd, struct eth_device *dev) { int i, err; /* used to set hw ethernet address */
- PRINTK2 ("%s:smc_open\n", SMC_DEV_NAME); + PRINTK2("%s:smc_open\n", dev->name);
/* reset the hardware */
- smc_reset (); - smc_enable (); - - SMC_SELECT_BANK (1); + smc_reset(dev); + smc_enable(dev);
- err = smc_get_ethaddr (bd); /* set smc_mac_addr, and sync it with u-boot globals */ + SMC_SELECT_BANK(dev, 1); + /* set smc_mac_addr, and sync it with u-boot globals */ + err = smc_get_ethaddr(bd, dev); if (err < 0) return -1; #ifdef USE_32_BIT @@ -614,11 +508,11 @@ static int smc_open (bd_t *bd)
address = smc_mac_addr[i + 1] << 8; address |= smc_mac_addr[i]; - SMC_outw (address, LAN91C96_IA0 + i); + SMC_outw(dev, address, LAN91C96_IA0 + i); } #else for (i = 0; i < 6; i++) - SMC_outb (smc_mac_addr[i], LAN91C96_IA0 + i); + SMC_outb(dev, smc_mac_addr[i], LAN91C96_IA0 + i); #endif return 0; } @@ -635,7 +529,7 @@ static int smc_open (bd_t *bd) * o otherwise, read in the packet *------------------------------------------------------------- */ -static int smc_rcv () +static int smc_rcv(struct eth_device *dev) { int packet_number; word status; @@ -647,26 +541,26 @@ static int smc_rcv () #endif
- SMC_SELECT_BANK (2); - packet_number = SMC_inw (LAN91C96_FIFO); + SMC_SELECT_BANK(dev, 2); + packet_number = SMC_inw(dev, LAN91C96_FIFO);
if (packet_number & LAN91C96_FIFO_RXEMPTY) { return 0; }
- PRINTK3 ("%s:smc_rcv\n", SMC_DEV_NAME); + PRINTK3("%s:smc_rcv\n", dev->name); /* start reading from the start of the packet */ - SMC_outw (LAN91C96_PTR_READ | LAN91C96_PTR_RCV | + SMC_outw(dev, LAN91C96_PTR_READ | LAN91C96_PTR_RCV | LAN91C96_PTR_AUTO_INCR, LAN91C96_POINTER);
/* First two words are status and packet_length */ #ifdef USE_32_BIT - stat_len = SMC_inl (LAN91C96_DATA_HIGH); + stat_len = SMC_inl(dev, LAN91C96_DATA_HIGH); status = stat_len & 0xffff; packet_length = stat_len >> 16; #else - status = SMC_inw (LAN91C96_DATA_HIGH); - packet_length = SMC_inw (LAN91C96_DATA_HIGH); + status = SMC_inw(dev, LAN91C96_DATA_HIGH); + packet_length = SMC_inw(dev, LAN91C96_DATA_HIGH); #endif
packet_length &= 0x07ff; /* mask off top bits */ @@ -690,13 +584,14 @@ static int smc_rcv () to send the DWORDs or the bytes first, or some mixture. A mixture might improve already slow PIO performance */ - SMC_insl (LAN91C96_DATA_HIGH, NetRxPackets[0], packet_length >> 2); + SMC_insl(dev, LAN91C96_DATA_HIGH, NetRxPackets[0], + packet_length >> 2); /* read the left over bytes */ if (packet_length & 3) { int i;
byte *tail = (byte *) (NetRxPackets[0] + (packet_length & ~3)); - dword leftover = SMC_inl (LAN91C96_DATA_HIGH); + dword leftover = SMC_inl(dev, LAN91C96_DATA_HIGH);
for (i = 0; i < (packet_length & 3); i++) *tail++ = (byte) (leftover >> (8 * i)) & 0xff; @@ -704,13 +599,14 @@ static int smc_rcv () #else PRINTK3 (" Reading %d words and %d byte(s) \n", (packet_length >> 1), packet_length & 1); - SMC_insw (LAN91C96_DATA_HIGH, NetRxPackets[0], packet_length >> 1); + SMC_insw(dev, LAN91C96_DATA_HIGH, NetRxPackets[0], + packet_length >> 1);
#if SMC_DEBUG > 2 printf ("Receiving Packet\n"); - print_packet (NetRxPackets[0], packet_length); + print_packet((byte *)NetRxPackets[0], packet_length); #endif } else { /* error ... */ @@ -718,13 +614,13 @@ static int smc_rcv () is_error = 1; }
- while (SMC_inw (LAN91C96_MMU) & LAN91C96_MMUCR_NO_BUSY) + while (SMC_inw(dev, LAN91C96_MMU) & LAN91C96_MMUCR_NO_BUSY) udelay (1); /* Wait until not busy */
/* error or good, tell the card to get rid of this packet */ - SMC_outw (LAN91C96_MMUCR_RELEASE_RX, LAN91C96_MMU); + SMC_outw(dev, LAN91C96_MMUCR_RELEASE_RX, LAN91C96_MMU);
if (!is_error) { @@ -745,18 +641,18 @@ static int smc_rcv () * an 'ifconfig ethX down' * -----------------------------------------------------*/ -static int smc_close () +static int smc_close(struct eth_device *dev) { - PRINTK2 ("%s:smc_close\n", SMC_DEV_NAME); + PRINTK2("%s:smc_close\n", dev->name);
/* clear everything */ - smc_shutdown (); + smc_shutdown(dev);
return 0; }
#if SMC_DEBUG > 2 -static void print_packet (byte * buf, int length) +static void print_packet(byte *buf, int length) { #if 0 int i; @@ -792,86 +688,40 @@ static void print_packet (byte * buf, int length) } #endif /* SMC_DEBUG > 2 */
-int eth_init (bd_t * bd) -{ - return (smc_open(bd)); -} - -void eth_halt () +static int lan91c96_init(struct eth_device *dev, bd_t *bd) { - smc_close (); + return smc_open(bd, dev); }
-int eth_rx () +static void lan91c96_halt(struct eth_device *dev) { - return smc_rcv (); + smc_close(dev); }
-int eth_send (volatile void *packet, int length) +static int lan91c96_recv(struct eth_device *dev) { - return smc_send_packet (packet, length); + return smc_rcv(dev); }
- -#if 0 -/*------------------------------------------------------------------------- - * smc_hw_init() - * - * Function: - * Reset and enable the device, check if the I/O space location - * is correct - * - * Input parameters: - * None - * - * Output: - * 0 --> success - * 1 --> error - *-------------------------------------------------------------------------- - */ -static int smc_hw_init () +static int lan91c96_send(struct eth_device *dev, volatile void *packet, + int length) { - unsigned short status_test; - - /* The attribute register of the LAN91C96 is located at address - 0x0e000000 on the lubbock platform */ - volatile unsigned *attaddr = (unsigned *) (0x0e000000); - - /* first reset, then enable the device. Sequence is critical */ - attaddr[LAN91C96_ECOR] |= LAN91C96_ECOR_SRESET; - udelay (100); - attaddr[LAN91C96_ECOR] &= ~LAN91C96_ECOR_SRESET; - attaddr[LAN91C96_ECOR] |= LAN91C96_ECOR_ENABLE; - - /* force 16-bit mode */ - attaddr[LAN91C96_ECSR] &= ~LAN91C96_ECSR_IOIS8; - udelay (100); - - /* check if the I/O address is correct, the upper byte of the - bank select register should read 0x33 */ - - status_test = SMC_inw (LAN91C96_BANK_SELECT); - if ((status_test & 0xFF00) != 0x3300) { - printf ("Failed to initialize ethernetchip\n"); - return 1; - } - return 0; + return smc_send_packet(dev, packet, length); } -#endif /* 0 */
-/* smc_get_ethaddr (bd_t * bd) +/* smc_get_ethaddr * * This checks both the environment and the ROM for an ethernet address. If * found, the environment takes precedence. */
-int smc_get_ethaddr (bd_t * bd) +static int smc_get_ethaddr(bd_t *bd, struct eth_device *dev) { uchar v_mac[6];
if (!eth_getenv_enetaddr("ethaddr", v_mac)) { /* get ROM mac value if any */ - if (!get_rom_mac(v_mac)) { + if (!get_rom_mac(dev, v_mac)) { printf("\n*** ERROR: ethaddr is NOT set !!\n"); return -1; } @@ -888,7 +738,7 @@ int smc_get_ethaddr (bd_t * bd) * Note, this has omly been tested for the OMAP730 P2. */
-int get_rom_mac (unsigned char *v_rom_mac) +static int get_rom_mac(struct eth_device *dev, unsigned char *v_rom_mac) { #ifdef HARDCODE_MAC /* used for testing or to supress run time warnings */ char hw_mac_addr[] = { 0x02, 0x80, 0xad, 0x20, 0x31, 0xb8 }; @@ -897,11 +747,75 @@ int get_rom_mac (unsigned char *v_rom_mac) return (1); #else int i; - SMC_SELECT_BANK (1); + SMC_SELECT_BANK(dev, 1); for (i=0; i<6; i++) { - v_rom_mac[i] = SMC_inb (LAN91C96_IA0 + i); + v_rom_mac[i] = SMC_inb(dev, LAN91C96_IA0 + i); } return (1); #endif } + +/* Structure to detect the device IDs */ +struct id_type { + u8 id; + char *name; +}; +static struct id_type supported_chips[] = { + {0, ""}, /* Dummy entry to prevent id check failure */ + {9, "LAN91C110"}, + {8, "LAN91C100FD"}, + {7, "LAN91C100"}, + {5, "LAN91C95"}, + {4, "LAN91C94/LAN91C96"}, + {3, "LAN91C90/LAN91C92"}, +}; +/* lan91c96_detect_chip + * See: + * http://www.embeddedsys.com/subpages/resources/images/documents/LAN91C96_data... + * page 71 - that is the closest we get to detect this device + */ +static int lan91c96_detect_chip(struct eth_device *dev) +{ + u8 chip_id; + int r; + SMC_SELECT_BANK(dev, 3); + chip_id = SMC_inw(dev, 0xA) & LAN91C96_REV_REVID; + SMC_SELECT_BANK(dev, 0); + for (r = 0; r < sizeof(supported_chips) / sizeof(struct id_type); r++) + if (chip_id == supported_chips[r].id) + return r; + return 0; +} + +int lan91c96_initialize(u8 dev_num, int base_addr) +{ + struct eth_device *dev; + int r = 0; + + dev = malloc(sizeof(*dev)); + if (!dev) { + free(dev); + return 0; + } + memset(dev, 0, sizeof(*dev)); + + dev->iobase = base_addr; + + /* Try to detect chip. Will fail if not present. */ + r = lan91c96_detect_chip(dev); + if (!r) { + free(dev); + return 0; + } + get_rom_mac(dev, dev->enetaddr); + + dev->init = lan91c96_init; + dev->halt = lan91c96_halt; + dev->send = lan91c96_send; + dev->recv = lan91c96_recv; + sprintf(dev->name, "%s-%hu", supported_chips[r].name, dev_num); + + eth_register(dev); + return 0; +} diff --git a/drivers/net/lan91c96.h b/drivers/net/lan91c96.h index 5beddda..6fbb0e3 100644 --- a/drivers/net/lan91c96.h +++ b/drivers/net/lan91c96.h @@ -46,14 +46,6 @@ #include <asm/io.h> #include <config.h>
-/* - * This function may be called by the board specific initialisation code - * in order to override the default mac address. - */ - -void smc_set_mac_addr(const unsigned char *addr); - - /* I want some simple types */
typedef unsigned char byte; @@ -86,66 +78,71 @@ typedef unsigned long int dword; #define SMC_IO_SHIFT 0 #endif
-#define SMCREG(r) (SMC_BASE_ADDRESS+((r)<<SMC_IO_SHIFT)) +#define SMCREG(edev, r) ((edev)->iobase+((r)<<SMC_IO_SHIFT))
-#define SMC_inl(r) (*((volatile dword *)SMCREG(r))) -#define SMC_inw(r) (*((volatile word *)SMCREG(r))) -#define SMC_inb(p) ({ \ +#define SMC_inl(edev, r) (*((volatile dword *)SMCREG(edev, r))) +#define SMC_inw(edev, r) (*((volatile word *)SMCREG(edev, r))) +#define SMC_inb(edev, p) ({ \ unsigned int __p = p; \ - unsigned int __v = SMC_inw(__p & ~1); \ + unsigned int __v = SMC_inw(edev, __p & ~1); \ if (__p & 1) __v >>= 8; \ else __v &= 0xff; \ __v; })
-#define SMC_outl(d,r) (*((volatile dword *)SMCREG(r)) = d) -#define SMC_outw(d,r) (*((volatile word *)SMCREG(r)) = d) -#define SMC_outb(d,r) ({ word __d = (byte)(d); \ - word __w = SMC_inw((r)&~1); \ +#define SMC_outl(edev, d, r) (*((volatile dword *)SMCREG(edev, r)) = d) +#define SMC_outw(edev, d, r) (*((volatile word *)SMCREG(edev, r)) = d) +#define SMC_outb(edev, d, r) ({ word __d = (byte)(d); \ + word __w = SMC_inw(edev, (r)&~1); \ __w &= ((r)&1) ? 0x00FF : 0xFF00; \ __w |= ((r)&1) ? __d<<8 : __d; \ - SMC_outw(__w,(r)&~1); \ + SMC_outw(edev, __w, (r)&~1); \ })
-#define SMC_outsl(r,b,l) ({ int __i; \ +#define SMC_outsl(edev, r, b, l) ({ int __i; \ dword *__b2; \ __b2 = (dword *) b; \ for (__i = 0; __i < l; __i++) { \ - SMC_outl( *(__b2 + __i), r ); \ + SMC_outl(edev, *(__b2 + __i),\ + r); \ } \ })
-#define SMC_outsw(r,b,l) ({ int __i; \ +#define SMC_outsw(edev, r, b, l) ({ int __i; \ word *__b2; \ __b2 = (word *) b; \ for (__i = 0; __i < l; __i++) { \ - SMC_outw( *(__b2 + __i), r ); \ + SMC_outw(edev, *(__b2 + __i),\ + r); \ } \ })
-#define SMC_insl(r,b,l) ({ int __i ; \ +#define SMC_insl(edev, r, b, l) ({ int __i ; \ dword *__b2; \ __b2 = (dword *) b; \ for (__i = 0; __i < l; __i++) { \ - *(__b2 + __i) = SMC_inl(r); \ - SMC_inl(0); \ + *(__b2 + __i) = SMC_inl(edev,\ + r); \ + SMC_inl(edev, 0); \ }; \ })
-#define SMC_insw(r,b,l) ({ int __i ; \ +#define SMC_insw(edev, r, b, l) ({ int __i ; \ word *__b2; \ __b2 = (word *) b; \ for (__i = 0; __i < l; __i++) { \ - *(__b2 + __i) = SMC_inw(r); \ - SMC_inw(0); \ + *(__b2 + __i) = SMC_inw(edev,\ + r); \ + SMC_inw(edev, 0); \ }; \ })
-#define SMC_insb(r,b,l) ({ int __i ; \ +#define SMC_insb(edev, r, b, l) ({ int __i ; \ byte *__b2; \ __b2 = (byte *) b; \ for (__i = 0; __i < l; __i++) { \ - *(__b2 + __i) = SMC_inb(r); \ - SMC_inb(0); \ + *(__b2 + __i) = SMC_inb(edev,\ + r); \ + SMC_inb(edev, 0); \ }; \ })
@@ -155,40 +152,35 @@ typedef unsigned long int dword; * We have only 16 Bit PCMCIA access on Socket 0 */
-#define SMC_inw(r) (*((volatile word *)(SMC_BASE_ADDRESS+(r)))) -#define SMC_inb(r) (((r)&1) ? SMC_inw((r)&~1)>>8 : SMC_inw(r)&0xFF) +#define SMC_inw(edev, r) (*((volatile word *)((edev)->iobase+(r)))) +#define SMC_inb(edev, r) (((r)&1) ? SMC_inw(edev, (r)&~1)>>8 :\ + SMC_inw(edev, r)&0xFF)
-#define SMC_outw(d,r) (*((volatile word *)(SMC_BASE_ADDRESS+(r))) = d) -#define SMC_outb(d,r) ({ word __d = (byte)(d); \ - word __w = SMC_inw((r)&~1); \ +#define SMC_outw(edev, d, r) (*((volatile word *)((edev)->iobase+(r))) = d) +#define SMC_outb(edev, d, r) ({ word __d = (byte)(d); \ + word __w = SMC_inw(edev, (r)&~1); \ __w &= ((r)&1) ? 0x00FF : 0xFF00; \ __w |= ((r)&1) ? __d<<8 : __d; \ - SMC_outw(__w,(r)&~1); \ + SMC_outw(edev, __w, (r)&~1); \ }) -#if 0 -#define SMC_outsw(r,b,l) outsw(SMC_BASE_ADDRESS+(r), (b), (l)) -#else -#define SMC_outsw(r,b,l) ({ int __i; \ +#define SMC_outsw(edev, r, b, l) ({ int __i; \ word *__b2; \ __b2 = (word *) b; \ for (__i = 0; __i < l; __i++) { \ - SMC_outw( *(__b2 + __i), r); \ + SMC_outw(edev, *(__b2 + __i),\ + r); \ } \ }) -#endif
-#if 0 -#define SMC_insw(r,b,l) insw(SMC_BASE_ADDRESS+(r), (b), (l)) -#else -#define SMC_insw(r,b,l) ({ int __i ; \ +#define SMC_insw(edev, r, b, l) ({ int __i ; \ word *__b2; \ __b2 = (word *) b; \ for (__i = 0; __i < l; __i++) { \ - *(__b2 + __i) = SMC_inw(r); \ - SMC_inw(0); \ + *(__b2 + __i) = SMC_inw(edev,\ + r); \ + SMC_inw(edev, 0); \ }; \ }) -#endif
#endif
@@ -608,25 +600,25 @@ typedef unsigned long int dword;
/* select a register bank, 0 to 3 */
-#define SMC_SELECT_BANK(x) { SMC_outw( x, LAN91C96_BANK_SELECT ); } +#define SMC_SELECT_BANK(edev, x) { SMC_outw(edev, x, LAN91C96_BANK_SELECT); }
/* this enables an interrupt in the interrupt mask register */ -#define SMC_ENABLE_INT(x) {\ +#define SMC_ENABLE_INT(edev, x) {\ unsigned char mask;\ - SMC_SELECT_BANK(2);\ - mask = SMC_inb( LAN91C96_INT_MASK );\ + SMC_SELECT_BANK(edev, 2);\ + mask = SMC_inb(edev, LAN91C96_INT_MASK);\ mask |= (x);\ - SMC_outb( mask, LAN91C96_INT_MASK ); \ + SMC_outb(edev, mask, LAN91C96_INT_MASK); \ }
/* this disables an interrupt from the interrupt mask register */
-#define SMC_DISABLE_INT(x) {\ +#define SMC_DISABLE_INT(edev, x) {\ unsigned char mask;\ - SMC_SELECT_BANK(2);\ - mask = SMC_inb( LAN91C96_INT_MASK );\ + SMC_SELECT_BANK(edev, 2);\ + mask = SMC_inb(edev, LAN91C96_INT_MASK);\ mask &= ~(x);\ - SMC_outb( mask, LAN91C96_INT_MASK ); \ + SMC_outb(edev, mask, LAN91C96_INT_MASK); \ }
/*---------------------------------------------------------------------- diff --git a/include/netdev.h b/include/netdev.h index a50ec67..9baccd4 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -57,6 +57,7 @@ int greth_initialize(bd_t *bis); void gt6426x_eth_initialize(bd_t *bis); int inca_switch_initialize(bd_t *bis); int kirkwood_egiga_initialize(bd_t *bis); +int lan91c96_initialize(u8 dev_num, int base_addr); int macb_eth_initialize(int id, void *regs, unsigned int phy_addr); int mcdmafec_initialize(bd_t *bis); int mcffec_initialize(bd_t *bis);
Enable the NET MULTI option and remove build warning
Tested: SDP3430
Signed-off-by: Nishanth Menon nm@ti.com Cc: Ben Warren biggerbadderben@gmail.com Cc: Sandeep Paulraj s-paulraj@ti.com --- board/ti/sdp3430/sdp.c | 12 +++++++----- include/configs/omap3_sdp3430.h | 3 ++- 2 files changed, 9 insertions(+), 6 deletions(-)
diff --git a/board/ti/sdp3430/sdp.c b/board/ti/sdp3430/sdp.c index 40cf26f..0d8e20d 100644 --- a/board/ti/sdp3430/sdp.c +++ b/board/ti/sdp3430/sdp.c @@ -22,6 +22,7 @@ * MA 02111-1307 USA */ #include <common.h> +#include <netdev.h> #include <twl4030.h> #include <asm/io.h> #include <asm/arch/mux.h> @@ -125,12 +126,13 @@ int board_init(void) #define ETH_CONTROL_REG (CONFIG_LAN91C96_BASE + 0x30b)
/** - * @brief ether_init Take the Ethernet controller out of reset and wait + * @brief board_eth_init Take the Ethernet controller out of reset and wait * for the EEPROM load to complete. */ -static void ether_init(void) +int board_eth_init(bd_t *bis) { -#ifdef CONFIG_DRIVER_LAN91C96 + int rc = 0; +#ifdef CONFIG_LAN91C96 int cnt = 20;
writew(0x0, LAN_RESET_REGISTER); @@ -155,10 +157,11 @@ static void ether_init(void)
writeb(readb(ETH_CONTROL_REG) & ~0x1, ETH_CONTROL_REG); udelay(1000); + rc = lan91c96_initialize(0, CONFIG_LAN91C96_BASE); reset_err_out: - return;
#endif + return rc; }
/** @@ -187,7 +190,6 @@ int misc_init_r(void) * VSIM - off (init, variable) for MMC1.DAT[3..7], SIM * VPLL2 - 1.8V */ - ether_init();
return 0; } diff --git a/include/configs/omap3_sdp3430.h b/include/configs/omap3_sdp3430.h index 229dc5e..7401671 100644 --- a/include/configs/omap3_sdp3430.h +++ b/include/configs/omap3_sdp3430.h @@ -200,7 +200,8 @@ */ #if defined(CONFIG_CMD_NET)
-#define CONFIG_DRIVER_LAN91C96 +#define CONFIG_NET_MULTI +#define CONFIG_LAN91C96 #define CONFIG_LAN91C96_BASE DEBUG_BASE #define CONFIG_LAN91C96_EXT_PHY
This modification is NOT tested on any of the platforms modified as I dont have them. please help by testing+building+fixing
Signed-off-by: Nishanth Menon nm@ti.com Cc: Andrea Scian andrea.scian@dave-tech.it Cc: Ben Warren biggerbadderben@gmail.com Cc: Dave Peverley dpeverley@mpc-data.co.uk Cc: George G. Davis gdavis@mvista.com Cc: Kyungmin Park kyungmin.park@samsung.com Cc: Nishant Kamat nskamat@ti.com Cc: Richard Woodruff r-woodruff2@ti.com Cc: Rishi Bhattacharya rishi@ti.com Cc: Sandeep Paulraj s-paulraj@ti.com --- board/apollon/apollon.c | 12 +++++++----- include/configs/B2.h | 2 +- include/configs/apollon.h | 3 ++- include/configs/assabet.h | 3 ++- include/configs/gcplus.h | 3 ++- include/configs/lubbock.h | 3 ++- include/configs/omap1510inn.h | 3 ++- include/configs/omap1610h2.h | 3 ++- include/configs/omap1610inn.h | 3 ++- include/configs/omap2420h4.h | 3 ++- include/configs/omap5912osk.h | 3 ++- include/configs/omap730p2.h | 3 ++- include/configs/pleb2.h | 6 ++++-- 13 files changed, 32 insertions(+), 18 deletions(-)
diff --git a/board/apollon/apollon.c b/board/apollon/apollon.c index 8964eba..b93e880 100644 --- a/board/apollon/apollon.c +++ b/board/apollon/apollon.c @@ -24,6 +24,7 @@ * MA 02111-1307 USA */ #include <common.h> +#include <netdev.h> #include <asm/arch/omap2420.h> #include <asm/io.h> #include <asm/arch/bits.h> @@ -138,13 +139,14 @@ void wait_for_command_complete(unsigned int wd_base) }
/******************************************************************* - * Routine:ether_init + * Routine:board_eth_init * Description: take the Ethernet controller out of reset and wait * for the EEPROM load to complete. ******************************************************************/ -void ether_init(void) +int board_eth_init(bd_t *bis) { -#ifdef CONFIG_DRIVER_LAN91C96 + int rc = 0; +#ifdef CONFIG_LAN91C96 int cnt = 20;
__raw_writeb(0x03, OMAP2420_CTRL_BASE + 0x0f2); /*protect->gpio74 */ @@ -171,10 +173,10 @@ void ether_init(void)
mask_config_reg(ETH_CONTROL_REG, 0x01); udelay(1000); - + rc = lan91c96_initialize(0, CONFIG_LAN91C96_BASE); eth_reset_err_out: - return; #endif + return rc; }
/********************************************** diff --git a/include/configs/B2.h b/include/configs/B2.h index e5439f3..d7806e9 100644 --- a/include/configs/B2.h +++ b/include/configs/B2.h @@ -58,7 +58,7 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_LAN91C96 +#define CONFIG_LAN91C96 #define CONFIG_LAN91C96_BASE 0x04000300 /* base address */ #define CONFIG_SMC_USE_32_BIT #undef CONFIG_SHOW_ACTIVITY diff --git a/include/configs/apollon.h b/include/configs/apollon.h index 575f60e..be0dc04 100644 --- a/include/configs/apollon.h +++ b/include/configs/apollon.h @@ -87,7 +87,8 @@ /* * SMC91c96 Etherent */ -#define CONFIG_DRIVER_LAN91C96 +#define CONFIG_NET_MULTI +#define CONFIG_LAN91C96 #define CONFIG_LAN91C96_BASE (APOLLON_CS1_BASE+0x300) #define CONFIG_LAN91C96_EXT_PHY
diff --git a/include/configs/assabet.h b/include/configs/assabet.h index 8c5b84c..d17d4bd 100644 --- a/include/configs/assabet.h +++ b/include/configs/assabet.h @@ -53,7 +53,8 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_LAN91C96 /* we have an SMC9194 on-board */ +#define CONFIG_NET_MULTI +#define CONFIG_LAN91C96 /* we have an SMC9194 on-board */ #define CONFIG_LAN91C96_BASE 0x18000000
/* diff --git a/include/configs/gcplus.h b/include/configs/gcplus.h index 85db4f5..41294b9 100644 --- a/include/configs/gcplus.h +++ b/include/configs/gcplus.h @@ -66,7 +66,8 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_LAN91C96 /* we have an SMC9194 on-board */ +#define CONFIG_NET_MULTI +#define CONFIG_LAN91C96 /* we have an SMC9194 on-board */ #define CONFIG_LAN91C96_BASE 0x100e0000
/* diff --git a/include/configs/lubbock.h b/include/configs/lubbock.h index 43913ca..0a69210 100644 --- a/include/configs/lubbock.h +++ b/include/configs/lubbock.h @@ -58,7 +58,8 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_LAN91C96 +#define CONFIG_NET_MULTI +#define CONFIG_LAN91C96 #define CONFIG_LAN91C96_BASE 0x0C000000
/* diff --git a/include/configs/omap1510inn.h b/include/configs/omap1510inn.h index 8408209..b0ebafd 100644 --- a/include/configs/omap1510inn.h +++ b/include/configs/omap1510inn.h @@ -60,7 +60,8 @@ #define CONFIG_SMC9196_BASE 0x08000300 #define CONFIG_SMC9196_EXT_PHY */ -#define CONFIG_DRIVER_LAN91C96 +#define CONFIG_NET_MULTI +#define CONFIG_LAN91C96 #define CONFIG_LAN91C96_BASE 0x08000300 #define CONFIG_LAN91C96_EXT_PHY
diff --git a/include/configs/omap1610h2.h b/include/configs/omap1610h2.h index 42e0198..0bbb5b3 100644 --- a/include/configs/omap1610h2.h +++ b/include/configs/omap1610h2.h @@ -57,7 +57,8 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_LAN91C96 +#define CONFIG_NET_MULTI +#define CONFIG_LAN91C96 #define CONFIG_LAN91C96_BASE 0x04000300 #define CONFIG_LAN91C96_EXT_PHY
diff --git a/include/configs/omap1610inn.h b/include/configs/omap1610inn.h index 22c873e..832dd42 100644 --- a/include/configs/omap1610inn.h +++ b/include/configs/omap1610inn.h @@ -58,7 +58,8 @@ */ /* */ -#define CONFIG_DRIVER_LAN91C96 +#define CONFIG_NET_MULTI +#define CONFIG_LAN91C96 #define CONFIG_LAN91C96_BASE 0x04000300 #define CONFIG_LAN91C96_EXT_PHY
diff --git a/include/configs/omap2420h4.h b/include/configs/omap2420h4.h index 9c18842..6ab4438 100644 --- a/include/configs/omap2420h4.h +++ b/include/configs/omap2420h4.h @@ -81,7 +81,8 @@ /* * SMC91c96 Etherent */ -#define CONFIG_DRIVER_LAN91C96 +#define CONFIG_NET_MULTI +#define CONFIG_LAN91C96 #define CONFIG_LAN91C96_BASE (H4_CS1_BASE+0x300) #define CONFIG_LAN91C96_EXT_PHY
diff --git a/include/configs/omap5912osk.h b/include/configs/omap5912osk.h index d0ce9dc..bc660e3 100644 --- a/include/configs/omap5912osk.h +++ b/include/configs/omap5912osk.h @@ -61,7 +61,8 @@ */ /* */ -#define CONFIG_DRIVER_LAN91C96 +#define CONFIG_NET_MULTI +#define CONFIG_LAN91C96 #define CONFIG_LAN91C96_BASE 0x04800300 #define CONFIG_LAN91C96_EXT_PHY
diff --git a/include/configs/omap730p2.h b/include/configs/omap730p2.h index 32a9b23..a6a8a02 100644 --- a/include/configs/omap730p2.h +++ b/include/configs/omap730p2.h @@ -65,7 +65,8 @@ * Hardware drivers */
diff --git a/include/configs/pleb2.h b/include/configs/pleb2.h index 635ef71..9e69411 100644 --- a/include/configs/pleb2.h +++ b/include/configs/pleb2.h @@ -56,8 +56,10 @@ */
/* None - PLEB 2 doesn't have any of this. - #define CONFIG_DRIVER_LAN91C96 - #define CONFIG_LAN91C96_BASE 0x0C000000 */ + #define CONFIG_NET_MULTI + #define CONFIG_LAN91C96 + #define CONFIG_LAN91C96_BASE 0x0C000000 + */
/* * select serial console configuration
On the testing front.. Regression testing on MAKEALL shows
#warning Ethernet driver .. error killing for assabet, gcplus, lubbock, omap1510inn, omap1610h2, omap2420h4, omap3_sdp3430, omap5912osk and omap730p2
There is a regression on B2.
et/libnet.a(net.o): In function `NetSendPacket': u-boot-ti/net/net.c:623: undefined reference to `eth_send' net/libnet.a(net.o): In function `NetReceive': u-boot-ti/net/net.c:1433: undefined reference to `eth_send'
Likely because you missed adding #define CONFIG_NET_MULTI to the config file.
apollon, does not configure. Not your fault but testing on it is going to be hard ;) Here is the error :
System not configured - see README make: *** [all] Error 1
No new additions to apollon should be made until the base cause of the apollon failure is fixed.
So 1. Fix B2. 2. Remove apollon changes 3. Wait for runtime testing.
I am not in favor of including this patch in the 2009.11 as we will likely apply the patch after waiting a reasonable amount of time on the runtime testing. Which is not the same as knowing we aren't breaking the old boards.
Tom
- MA 02111-1307 USA
- Routine:ether_init
- Routine:board_eth_init
- Description: take the Ethernet controller out of reset and wait
- int rc = 0;
- rc = lan91c96_initialize(0, CONFIG_LAN91C96_BASE);
eth_reset_err_out:
- return;
#endif
- return rc;
- Hardware drivers
- SMC91c96 Etherent
- Hardware drivers
- Hardware drivers
- Hardware drivers
- Hardware drivers
- SMC91c96 Etherent
- Hardware drivers
- #define CONFIG_NET_MULTI
- select serial console configuration
Tom,
<snip>
This is in no way a candidate for 2009.11. As I mentioned in my initial
review, it will soon be queued up in net/next, which will be merged to main/next soon.
regards, Ben
Nishanth,
I expect that all of these boards are now broken, since you haven't provided board_eth_init() functions for them.
Applying to net/next anyway to make it easy to get everything working.
thanks, Ben
Nishanth,
You've update the config files for a bunch of boards, but have not added board_eth_init() functions for them. Am I missing something? If this is indeed the case, I can't push these patches upstream from the net tree because the associated boards will break.
regards, Ben
Ben Warren had written, on 12/07/2009 03:09 PM, the following:
Nishanth,
I have added the init where they have been previously used for the old lan91c96 driver. I think the only one which was actively using it was apollon, which means the rest of the platforms probably dont use the old lan driver properly in the first place. I have maintained status quo there instead of introducing a change which may break them.
<recipient list trimmed>
Nishanth,
Nishanth,
I understand where you're coming from, but having the CONFIG option in the board's header file indicates that this board probably has a LAN chip. Without board_eth_init() support, the CONFIG option is pointless. I'd prefer to add full support, then if the user doesn't want it they can #undef in the header.
If you don't have time to do this, I can take care of it.
regards, Ben
Tested: SDP3430
Great! Thanks!
I'll keep my fingers crossed that it will work on the other boards, too, and will get an ack.
Best regards
Dirk
Nishanth,
Tested: SDP3430
Applied to net/next
thanks, Ben
Nishanth,
applied to net/next
thanks, Ben
Dear Nishanth Menon,
"for the new arch" is not really helpful for the commit message - for example, I don't know what you are referring to here. Also, your keyboard seems to have got stuck at the "add a a lil" part.
Can you please update the commit message?
Eventually Ben accepts just the new commit message and edits it when applying the patch?
Wolfgang Denk said the following on 11/22/2009 05:01 PM:
ok.. here it goes:
Make the lan91c96 driver capable of CONFIG_NET_MULTI to be clean for the new network driver architecture, add a little detect function
let me know if you want me to post again.
Hi Nishanth,
On first pass review, this looks great! There are a few things I'd like to do to improve the driver, but it has nothing to do with converting to NET_MULTI.
I'm going to fire up a net-next branch this weekend and will try to apply it there.
regards, Ben
-----Original Message----- From: Ben Warren [mailto:biggerbadderben@gmail.com] Sent: Friday, October 16, 2009 11:30 AM Nishanth Menon wrote:
Gee thanks..
Having very less knowledge on lan91c96 itself, I can help be the guinea pig for testing on SDP3430 at least :)
Did this get into the net-next branch? [1] did not seem to have it.
Regards, Nishanth Menon Ref: [1] http://git.denx.de/?p=u-boot/u-boot-net.git;a=shortlog;h=refs/heads/next
Unfortunately, for me 'this weekend' quite often leaves 'this' open to interpretation. Bill Clinton would be proud.
Soon...
regards, Ben
participants (6)
Ben Warren
Dirk Behme
Menon, Nishanth
Nishanth Menon
Tom
