[PATCH v1 0/1] GPIO buttons keyboard driver update
Remove need of dts binding for button keyboard since it reuses gpio-keys binding. Select gpio-keys driver if button keyboard is selected since button keyboard can not operate on its own.
Svyatoslav Ryhel (1): input: button_kbd: make driver complementary to gpio buttons
drivers/input/Kconfig | 2 +- drivers/input/button_kbd.c | 10 ++++------ 2 files changed, 5 insertions(+), 7 deletions(-)
Tested-by: Svyatoslav Ryhel clamor95@gmail.com # HTC One X T30 Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/input/Kconfig | 2 +- drivers/input/button_kbd.c | 10 ++++------ 2 files changed, 5 insertions(+), 7 deletions(-)
diff --git a/drivers/input/Kconfig b/drivers/input/Kconfig index 2a373c778a..17c1088545 100644 --- a/drivers/input/Kconfig +++ b/drivers/input/Kconfig @@ -48,8 +48,8 @@ config APPLE_SPI_KEYB
config BUTTON_KEYBOARD bool "Buttons as keyboard" - depends on BUTTON_GPIO depends on DM_KEYBOARD + select BUTTON_GPIO help Enable support for mapping buttons to keycode events. Use linux,code button driver dt node to define button-event mapping. diff --git a/drivers/input/button_kbd.c b/drivers/input/button_kbd.c index 99e65f12f0..74fadfca8b 100644 --- a/drivers/input/button_kbd.c +++ b/drivers/input/button_kbd.c @@ -111,16 +111,14 @@ static int button_kbd_probe(struct udevice *dev) return 0; }
-static const struct udevice_id button_kbd_ids[] = { - { .compatible = "button-kbd" }, - { } -}; - U_BOOT_DRIVER(button_kbd) = { .name = "button_kbd", .id = UCLASS_KEYBOARD, - .of_match = button_kbd_ids, .ops = &button_kbd_ops, .priv_auto = sizeof(struct button_kbd_priv), .probe = button_kbd_probe, }; + +U_BOOT_DRVINFO(button_kbd) = { + .name = "button_kbd" +};
Thanks! Do I need someone else to be able to merge this or your review is enough?
Best regards, Svyatoslav R.
вт, 21 лют. 2023 р. о 21:37 Simon Glass sjg@chromium.org пише:
Hi Svyatoslav,
If there is no input maintainer, It should just get picked up by Tom at some point.
Svyatoslav Ryhel
