[U-Boot] [PULL] u-boot-atmel/master -> u-boot-arm/master
Dear Albert Aribaud,
please pull these changes from u-boot-atmel/master into u-boot-arm/master.
This request contains one avr32 related patch which is required to get the macb change compile clean. Therefore this one is included here rather than going through u-boot-avr32.
The following changes since commit 0a26e1d6c394aacbf1153977b7348d1dff85db3f:
arm: fix a double-definition error of _start symbol (2014-06-09 10:36:40 +0200)
git://git.denx.de/u-boot-atmel.git master
for you to fetch changes up to 6dbeb893c4a7668d0098318d6668ccf59bfbfdea:
arm: ethernut5: convert to generic board (2014-06-14 18:13:15 +0200)
---------------------------------------------------------------- Andreas Bießmann (2): avr32: migrate cache functions macb: make checkpatch clean
Tim Schendekehl (1): arm: ethernut5: convert to generic board
Wu, Josh (3): net: macb: enable dcache in macb video: atmel_hlcdfb: enable dcache support ARMv7: at91: enable ICache and DCache.
arch/arm/cpu/armv7/at91/cpu.c | 2 + arch/avr32/cpu/cache.c | 20 ++-- .../avr32/include/asm/arch-at32ap700x/cacheflush.h | 2 - arch/avr32/include/asm/dma-mapping.h | 6 +- arch/avr32/lib/board.c | 4 +- drivers/net/macb.c | 113 +++++++++++++++----- drivers/video/atmel_hlcdfb.c | 6 ++ include/configs/ethernut5.h | 2 + 8 files changed, 110 insertions(+), 45 deletions(-)
Hi Andreas,
On Sat, 14 Jun 2014 18:19:26 +0200, Andreas Bießmann andreas.devel@googlemail.com wrote:
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Andreas Bießmann
