[U-Boot] Pull request: u-boot-mmc 12082015
Hi Tom,
The following changes since commit e2c1c5bae619d2e87505de99f907a26237640bc9:
Merge git://git.denx.de/u-boot-dm (2015-08-10 10:06:07 -0400)
git://git.denx.de/u-boot-mmc.git master
for you to fetch changes up to 956f662b1f79ae7455bc6aaa9defc2a756e8e9ca:
mmc_spi: Big-endian support (2015-08-12 10:41:14 +0300)
---------------------------------------------------------------- Marek Vasut (3): mmc: dw_mmc: Stop bounce buffer even in case of failure mmc: dw_mmc: Zap endless timeout mmc: dw_mmc: Improve handling of data transfer failure
Simon Glass (3): mmc: dw_mmc: Avoid using printf() for errors mmc: dw_mmc: Support bypass mode with the get_mmc_clk() method dw_mmc: Calculate dwmmc FIFO threshold size if not provided
Yoshinori Sato (1): mmc_spi: Big-endian support
drivers/mmc/dw_mmc.c | 61 +++++++++++++++++++++++++++++++++++++++++++------------------ drivers/mmc/exynos_dw_mmc.c | 2 +- drivers/mmc/mmc_spi.c | 10 +++++----- include/dwmmc.h | 16 +++++++++++++++- 4 files changed, 64 insertions(+), 25 deletions(-)
Regards
— Pantelis
On Wednesday, August 12, 2015 at 09:48:28 AM, Pantelis Antoniou wrote:
Hi Tom,
This patch still has open questions, I think you should drop it for now.
Best regards, Marek Vasut
Hi Tom,
Hi Tom,
After all the hoopla, I’ve removed the offending patch; here’s a new pull request.
for you to fetch changes up to 6f67b69b1592662ec49485101a2358b71070bf57:
mmc_spi: Big-endian support (2015-08-13 11:24:26 +0300)
Simon Glass (2): mmc: dw_mmc: Avoid using printf() for errors dw_mmc: Calculate dwmmc FIFO threshold size if not provided
drivers/mmc/dw_mmc.c | 59 ++++++++++++++++++++++++++++++++++++++++++----------------- drivers/mmc/mmc_spi.c | 10 +++++----- 2 files changed, 47 insertions(+), 22 deletions(-)
Regards
— Pantelis
On Thu, Aug 13, 2015 at 11:42:38AM +0300, Pantelis Antoniou wrote:
Hi Tom,
Hi Tom,
Pantelis Antoniou
