[U-Boot] [PATCH] arm: spl: Align default board_init_f comment with code
The default board_init_f() implementation performs a call to board_init_r() as the last step of the sequence. Fix the comment for this function to reflect the actual execution flow.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- arch/arm/lib/spl.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/lib/spl.c b/arch/arm/lib/spl.c index d737a5c..e428868 100644 --- a/arch/arm/lib/spl.c +++ b/arch/arm/lib/spl.c @@ -27,7 +27,7 @@ gd_t gdata __attribute__ ((section(".data"))); /* * In the context of SPL, board_init_f must ensure that any clocks/etc for * DDR are enabled, ensure that the stack pointer is valid, clear the BSS - * and call board_init_f. We provide this version by default but mark it + * and call board_init_r. We provide this version by default but mark it * as __weak to allow for platforms to do this in their own way if needed. */ void __weak board_init_f(ulong dummy)
Andreas Dannenberg
