[PATCH] stv0991: remove specific CONFIG_STV0991 configs
Remove the following STV0991 specific configs: - CONFIG_STV0991 (never used, only defined in CONFIG_SYS_EXTRA_OPTIONS) - CONFIG_STV0991_HZ (replaced by generic CONFIG_SYS_HZ) - CONFIG_STV0991_HZ_CLOCK (replaced by generic CONFIG_SYS_HZ_CLOCK)
This patch allows to reduce the file config_whitelist.txt.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/cpu/armv7/stv0991/timer.c | 6 +++--- arch/arm/include/asm/arch-stv0991/stv0991_gpt.h | 4 ++-- configs/stv0991_defconfig | 1 - scripts/config_whitelist.txt | 3 --- 4 files changed, 5 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv7/stv0991/timer.c b/arch/arm/cpu/armv7/stv0991/timer.c index 07033acb5c..67764ccf66 100644 --- a/arch/arm/cpu/armv7/stv0991/timer.c +++ b/arch/arm/cpu/armv7/stv0991/timer.c @@ -18,7 +18,7 @@ static struct stv0991_cgu_regs *const stv0991_cgu_regs = \ (struct stv0991_cgu_regs *) (CGU_BASE_ADDR);
#define READ_TIMER() (readl(&gpt1_regs_ptr->cnt) & GPT_FREE_RUNNING) -#define GPT_RESOLUTION (CONFIG_STV0991_HZ_CLOCK / CONFIG_STV0991_HZ) +#define GPT_RESOLUTION (CONFIG_SYS_HZ_CLOCK / CONFIG_SYS_HZ)
DECLARE_GLOBAL_DATA_PTR;
@@ -67,7 +67,7 @@ void __udelay(unsigned long usec) { ulong tmo; ulong start = get_timer_masked(); - ulong tenudelcnt = CONFIG_STV0991_HZ_CLOCK / (1000 * 100); + ulong tenudelcnt = CONFIG_SYS_HZ_CLOCK / (1000 * 100); ulong rndoff;
rndoff = (usec % 10) ? 1 : 0; @@ -110,5 +110,5 @@ unsigned long long get_ticks(void) */ ulong get_tbclk(void) { - return CONFIG_STV0991_HZ; + return CONFIG_SYS_HZ; } diff --git a/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h b/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h index cd27472ad7..f1d5667c32 100644 --- a/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h +++ b/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h @@ -36,7 +36,7 @@ struct gpt_regs *const gpt1_regs_ptr = #define GPT_FREE_RUNNING 0xFFFF
/* Timer, HZ specific defines */ -#define CONFIG_STV0991_HZ 1000 -#define CONFIG_STV0991_HZ_CLOCK (27*1000*1000)/GPT_PRESCALER_128 +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_HZ_CLOCK ((27 * 1000 * 1000) / GPT_PRESCALER_128)
#endif diff --git a/configs/stv0991_defconfig b/configs/stv0991_defconfig index b6ec831e6d..e06664047f 100644 --- a/configs/stv0991_defconfig +++ b/configs/stv0991_defconfig @@ -12,7 +12,6 @@ CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_SYS_MALLOC_LEN=0x14000 CONFIG_DEFAULT_DEVICE_TREE="stv0991" CONFIG_SYS_LOAD_ADDR=0x0 -CONFIG_SYS_EXTRA_OPTIONS="STV0991" CONFIG_BOOTDELAY=3 CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 61ae682dcd..58f4b02f60 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1303,9 +1303,6 @@ CONFIG_STANDALONE_LOAD_ADDR CONFIG_STATIC_BOARD_REV CONFIG_STD_DEVICES_SETTINGS CONFIG_STM32_FLASH -CONFIG_STV0991 -CONFIG_STV0991_HZ -CONFIG_STV0991_HZ_CLOCK CONFIG_SXNI855T CONFIG_SYSFS CONFIG_SYSMGR_ISWGRP_HANDOFF
Hi Patrick
- return CONFIG_SYS_HZ;
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
Hi Patrick
On 10/8/21 8:09 AM, Patrice CHOTARD wrote:
Hi Patrick
Thanks Patrice _______________________________________________ Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
Applied on u-boot-stm32 for next
Thanks Patrice
Patrice CHOTARD
Patrick Delaunay
