[U-Boot] [PATCH v2] rockchip: reserve memory for rk3399 ATF data
There are 3 region used by rk3399 ATF: - bl31 code, locate at 0x10000; - cortex-m0 code and data, locate at 0xff8c0000; - bl31 data, locate at 0xff8c1000 ~ 0xff8c4000;
SPL_TEXT_BASE starts from 0xff8c2000, we need to reserve memory for ATF data, or else there will have memory corrupt after SPL load ATF image.
More detail about cortex-M0 code in ATF: https://github.com/ARM-software/arm-trusted-firmware/commit/ 8382e17c4c6bffd15119dfce1ee4372e3c1a7890
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: - use Kconfig for the reserved memory size
arch/arm/include/asm/arch-rockchip/boot0.h | 4 ++++ arch/arm/mach-rockchip/Kconfig | 8 ++++++++ 2 files changed, 12 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/boot0.h b/arch/arm/include/asm/arch-rockchip/boot0.h index 8d7bc9a..7346876 100644 --- a/arch/arm/include/asm/arch-rockchip/boot0.h +++ b/arch/arm/include/asm/arch-rockchip/boot0.h @@ -16,3 +16,7 @@ .space 0x4 /* space for the 'RK33' */ #endif b reset + +#if defined(CONFIG_ROCKCHIP_RK3399) && defined(CONFIG_SPL_BUILD) + .space CONFIG_ROCKCHIP_SPL_RESERVE_IRAM /* space for the ATF data */ +#endif diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index af0796d..979b48e 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -72,6 +72,14 @@ config ROCKCHIP_SPL_BACK_TO_BROM SPL will return to the boot rom, which will then load the U-Boot binary to keep going on.
+config ROCKCHIP_SPL_RESERVE_IRAM + hex "Size of IRAM reserved in SPL" + default 0x4000 + help + SPL may need reserve memory for firmware load by SPL, which load + address is in IRAM and may overlay with SPL text area if not + reserved. + config ROCKCHIP_BROM_HELPER bool
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com mailto:philipp.tomsich@theobroma-systems.com>
Changes in v2:
- .space CONFIG_ROCKCHIP_SPL_RESERVE_IRAM /* space for the ATF data */
- hex "Size of IRAM reserved in SPL"
- default 0x4000
- help
reserved.
-- 1.9.1
Hi Kever,
Some grammar nits below:
Am 19.04.2017 um 08:42 schrieb Kever Yang:
"regions"
3x "located"
"there will be" or "we will have"
load ATF image.
"loads the" / "loaded the"
Interesting!
Changes in v2:
- default 0x4000
- help
reserved.
"SPL may need to reserve memory for firmware loaded by SPL, whose load address is in IRAM and may overlap with SPL text area if not reserved."
Regards, Andreas
Hi Andreas,
Thanks for fixing my pool English, will update in next version.
Thanks, - Kever On 04/19/2017 09:00 PM, Andreas Färber wrote:
Hi Kever,
"regions"
3x "located"
load ATF image.
Interesting!
Changes in v2:
- default 0x4000
- help
reserved.
- config ROCKCHIP_BROM_HELPER bool
Regards, Andreas
Andreas Färber
Dr. Philipp Tomsich
Kever Yang
