[PATCH 1/1] efi_loader: use after free in efi_exit()
Do not use data from the loaded image object after deleting it.
Fixes: 126a43f15b36 ("efi_loader: unload applications upon Exit()") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/efi_loader.h | 4 ++-- lib/efi_loader/efi_boottime.c | 17 ++++++++++++----- 2 files changed, 14 insertions(+), 7 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index dc3c6ac304..0fc2255f3f 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -304,10 +304,10 @@ enum efi_image_auth_status { */ struct efi_loaded_image_obj { struct efi_object header; - efi_status_t exit_status; + efi_status_t *exit_status; efi_uintn_t *exit_data_size; u16 **exit_data; - struct jmp_buf_data exit_jmp; + struct jmp_buf_data *exit_jmp; EFIAPI efi_status_t (*entry)(efi_handle_t image_handle, struct efi_system_table *st); u16 image_type; diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 392cf865f2..3ea7e3c9bb 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2907,6 +2907,8 @@ efi_status_t EFIAPI efi_start_image(efi_handle_t image_handle, efi_status_t ret; void *info; efi_handle_t parent_image = current_image; + efi_status_t exit_status; + struct jmp_buf_data exit_jmp;
EFI_ENTRY("%p, %p, %p", image_handle, exit_data_size, exit_data);
@@ -2928,9 +2930,11 @@ efi_status_t EFIAPI efi_start_image(efi_handle_t image_handle,
image_obj->exit_data_size = exit_data_size; image_obj->exit_data = exit_data; + image_obj->exit_status = &exit_status; + image_obj->exit_jmp = &exit_jmp;
/* call the image! */ - if (setjmp(&image_obj->exit_jmp)) { + if (setjmp(&exit_jmp)) { /* * We called the entry point of the child image with EFI_CALL * in the lines below. The child image called the Exit() boot @@ -2952,10 +2956,10 @@ efi_status_t EFIAPI efi_start_image(efi_handle_t image_handle, */ assert(__efi_entry_check()); EFI_PRINT("%lu returned by started image\n", - (unsigned long)((uintptr_t)image_obj->exit_status & + (unsigned long)((uintptr_t)exit_status & ~EFI_ERROR_MASK)); current_image = parent_image; - return EFI_EXIT(image_obj->exit_status); + return EFI_EXIT(exit_status); }
current_image = image_handle; @@ -3138,6 +3142,7 @@ static efi_status_t EFIAPI efi_exit(efi_handle_t image_handle, struct efi_loaded_image *loaded_image_protocol; struct efi_loaded_image_obj *image_obj = (struct efi_loaded_image_obj *)image_handle; + struct jmp_buf_data *exit_jmp;
EFI_ENTRY("%p, %ld, %zu, %p", image_handle, exit_status, exit_data_size, exit_data); @@ -3179,6 +3184,9 @@ static efi_status_t EFIAPI efi_exit(efi_handle_t image_handle, if (ret != EFI_SUCCESS) EFI_PRINT("%s: out of memory\n", __func__); } + /* efi_delete_image() frees image_obj. Copy before the call. */ + exit_jmp = image_obj->exit_jmp; + *image_obj->exit_status = exit_status; if (image_obj->image_type == IMAGE_SUBSYSTEM_EFI_APPLICATION || exit_status != EFI_SUCCESS) efi_delete_image(image_obj, loaded_image_protocol); @@ -3192,8 +3200,7 @@ static efi_status_t EFIAPI efi_exit(efi_handle_t image_handle, */ efi_restore_gd();
- image_obj->exit_status = exit_status; - longjmp(&image_obj->exit_jmp, 1); + longjmp(exit_jmp, 1);
panic("EFI application exited"); out: -- 2.29.2
