[PATCH] mkeficapsule: Free up resources used for adding public key to dtb
Fix the issues flagged by Coverity on resources not being released in the add_public_key function.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- tools/mkeficapsule.c | 13 +++++++++++-- 1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/tools/mkeficapsule.c b/tools/mkeficapsule.c index 270943fc90..caf0a1b231 100644 --- a/tools/mkeficapsule.c +++ b/tools/mkeficapsule.c @@ -150,6 +150,7 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if (srcfd == -1) { fprintf(stderr, "%s: Can't open %s: %s\n", __func__, pkey_file, strerror(errno)); + ret = -1; goto err; }
@@ -157,6 +158,7 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if (ret == -1) { fprintf(stderr, "%s: Can't stat %s: %s\n", __func__, pkey_file, strerror(errno)); + ret = -1; goto err; }
@@ -167,6 +169,7 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if ((sptr == MAP_FAILED) || (errno != 0)) { fprintf(stderr, "%s: Failed to mmap %s:%s\n", __func__, pkey_file, strerror(errno)); + ret = -1; goto err; }
@@ -175,6 +178,7 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if (destfd == -1) { fprintf(stderr, "%s: Can't open %s: %s\n", __func__, dtb_file, strerror(errno)); + ret = -1; goto err; }
@@ -189,6 +193,7 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if (ftruncate(destfd, dtb.st_size)) { fprintf(stderr, "%s: Can't expand %s: %s\n", __func__, dtb_file, strerror(errno)); + ret = -1; goto err;; }
@@ -199,11 +204,13 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if ((dptr == MAP_FAILED) || (errno != 0)) { fprintf(stderr, "%s: Failed to mmap %s:%s\n", __func__, dtb_file, strerror(errno)); + ret = -1; goto err; }
if (fdt_check_header(dptr)) { fprintf(stderr, "%s: Invalid FDT header\n", __func__); + ret = -1; goto err; }
@@ -211,6 +218,7 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if (ret) { fprintf(stderr, "%s: Cannot expand FDT: %s\n", __func__, fdt_strerror(ret)); + ret = -1; goto err; }
@@ -219,10 +227,11 @@ static int add_public_key(const char *pkey_file, const char *dtb_file, if (ret < 0) { fprintf(stderr, "%s: Unable to add public key to the FDT\n", __func__); + ret = -1; goto err; }
- return 0; + ret = 0;
err: if (sptr) @@ -237,7 +246,7 @@ err: if (destfd >= 0) close(destfd);
- return -1; + return ret; }
static int create_fwbin(char *path, char *bin, efi_guid_t *guid,
goto err; }ret = -1;
goto err;;ret = -1;
Thanks for providing the patch.
Please, remove the duplicate semicolon here.
main() should return the constant EXIT_FAILURE (glibc defines this as 1) if a failure occurs, not -1.
scripts/checkpatch.pl -f tools/mkeficapsule.c reports some other style issues:
CHECK: Unnecessary parentheses around 'sptr == MAP_FAILED' #167: FILE: tools/mkeficapsule.c:167: + if ((sptr == MAP_FAILED) || (errno != 0)) {
CHECK: Unnecessary parentheses around 'errno != 0' #167: FILE: tools/mkeficapsule.c:167: + if ((sptr == MAP_FAILED) || (errno != 0)) {
WARNING: Statements terminations use 1 semicolon #192: FILE: tools/mkeficapsule.c:192: + goto err;;
CHECK: Unnecessary parentheses around 'dptr == MAP_FAILED' #199: FILE: tools/mkeficapsule.c:199: + if ((dptr == MAP_FAILED) || (errno != 0)) {
CHECK: Unnecessary parentheses around 'errno != 0' #199: FILE: tools/mkeficapsule.c:199: + if ((dptr == MAP_FAILED) || (errno != 0)) {
In U-Boot we prefer to avoid terms like (errno != 0) in a logical statement:
if (dptr == MAP_FAILED || errno) {
But it is completely unnecessary to check errno at all here because errno is only set if mmap() returns MAP_FAILED (see the mmap() man-page). So the line should be:
192 if (dptr == MAP_FAILED) {
Now you can remove the following line:
195: - errno = 0;
Best regards
Heinrich
ret = -1;
goto err; }
ret = -1;
goto err; }
- ret = 0;
- return -1;
- return ret;
Sughosh Ganu
