[PATCH 01/11] board: stm32mp1: use IS_ENABLED to prevent ifdef in board_key_check
Use IS_ENABLED to prevent ifdef in board_key_check
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
board/st/stm32mp1/stm32mp1.c | 52 ++++++++++++++++++------------------ 1 file changed, 26 insertions(+), 26 deletions(-)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 1d274c3157..1ad41796fb 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -135,51 +135,51 @@ int checkboard(void)
static void board_key_check(void) { -#if defined(CONFIG_FASTBOOT) || defined(CONFIG_CMD_STM32PROG) ofnode node; struct gpio_desc gpio; enum forced_boot_mode boot_mode = BOOT_NORMAL;
+ if (!IS_ENABLED(CONFIG_FASTBOOT) && !IS_ENABLED(CONFIG_CMD_STM32PROG)) + return; + node = ofnode_path("/config"); if (!ofnode_valid(node)) { debug("%s: no /config node?\n", __func__); return; } -#ifdef CONFIG_FASTBOOT - if (gpio_request_by_name_nodev(node, "st,fastboot-gpios", 0, - &gpio, GPIOD_IS_IN)) { - debug("%s: could not find a /config/st,fastboot-gpios\n", - __func__); - } else { - if (dm_gpio_get_value(&gpio)) { - puts("Fastboot key pressed, "); - boot_mode = BOOT_FASTBOOT; - } + if (IS_ENABLED(CONFIG_FASTBOOT)) { + if (gpio_request_by_name_nodev(node, "st,fastboot-gpios", 0, + &gpio, GPIOD_IS_IN)) { + debug("%s: could not find a /config/st,fastboot-gpios\n", + __func__); + } else { + if (dm_gpio_get_value(&gpio)) { + puts("Fastboot key pressed, "); + boot_mode = BOOT_FASTBOOT; + }
- dm_gpio_free(NULL, &gpio); + dm_gpio_free(NULL, &gpio); + } } -#endif -#ifdef CONFIG_CMD_STM32PROG - if (gpio_request_by_name_nodev(node, "st,stm32prog-gpios", 0, - &gpio, GPIOD_IS_IN)) { - debug("%s: could not find a /config/st,stm32prog-gpios\n", - __func__); - } else { - if (dm_gpio_get_value(&gpio)) { - puts("STM32Programmer key pressed, "); - boot_mode = BOOT_STM32PROG; + if (IS_ENABLED(CONFIG_CMD_STM32PROG)) { + if (gpio_request_by_name_nodev(node, "st,stm32prog-gpios", 0, + &gpio, GPIOD_IS_IN)) { + debug("%s: could not find a /config/st,stm32prog-gpios\n", + __func__); + } else { + if (dm_gpio_get_value(&gpio)) { + puts("STM32Programmer key pressed, "); + boot_mode = BOOT_STM32PROG; + } + dm_gpio_free(NULL, &gpio); } - dm_gpio_free(NULL, &gpio); } -#endif - if (boot_mode != BOOT_NORMAL) { puts("entering download mode...\n"); clrsetbits_le32(TAMP_BOOT_CONTEXT, TAMP_BOOT_FORCED_MASK, boot_mode); } -#endif }
#if defined(CONFIG_USB_GADGET) && defined(CONFIG_USB_GADGET_DWC2_OTG)
Use IS_ENABLED to prevent ifdef in g_dnl_board_usb_cable_connected and in g_dnl_bind_fixup
board/st/stm32mp1/stm32mp1.c | 15 +++++++++------ 1 file changed, 9 insertions(+), 6 deletions(-)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 1ad41796fb..5c84b09c3e 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -182,13 +182,14 @@ static void board_key_check(void) } }
-#if defined(CONFIG_USB_GADGET) && defined(CONFIG_USB_GADGET_DWC2_OTG) -#include <usb/dwc2_udc.h> int g_dnl_board_usb_cable_connected(void) { struct udevice *dwc2_udc_otg; int ret;
+ if (!IS_ENABLED(CONFIG_USB_GADGET_DWC2_OTG)) + return -ENODEV; + /* if typec stusb160x is present, means DK1 or DK2 board */ ret = stusb160x_cable_connected(); if (ret >= 0) @@ -203,14 +204,17 @@ int g_dnl_board_usb_cable_connected(void) return dwc2_udc_B_session_valid(dwc2_udc_otg); }
+#ifdef CONFIG_USB_GADGET_DOWNLOAD #define STM32MP1_G_DNL_DFU_PRODUCT_NUM 0xdf11 #define STM32MP1_G_DNL_FASTBOOT_PRODUCT_NUM 0x0afb
int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) { - if (!strcmp(name, "usb_dnl_dfu")) + if (IS_ENABLED(CONFIG_DFU_OVER_USB) && + !strcmp(name, "usb_dnl_dfu")) put_unaligned(STM32MP1_G_DNL_DFU_PRODUCT_NUM, &dev->idProduct); - else if (!strcmp(name, "usb_dnl_fastboot")) + else if (IS_ENABLED(CONFIG_FASTBOOT) && + !strcmp(name, "usb_dnl_fastboot")) put_unaligned(STM32MP1_G_DNL_FASTBOOT_PRODUCT_NUM, &dev->idProduct); else @@ -218,8 +222,7 @@ int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name)
return 0; } - -#endif /* CONFIG_USB_GADGET */ +#endif /* CONFIG_USB_GADGET_DOWNLOAD */
static int get_led(struct udevice **dev, char *led_string) {
Hi Patrick
- if (!IS_ENABLED(CONFIG_USB_GADGET_DWC2_OTG))
return -ENODEV;
- /* if typec stusb160x is present, means DK1 or DK2 board */ ret = stusb160x_cable_connected(); if (ret >= 0)
- if (IS_ENABLED(CONFIG_DFU_OVER_USB) &&
put_unaligned(STM32MP1_G_DNL_DFU_PRODUCT_NUM, &dev->idProduct);!strcmp(name, "usb_dnl_dfu"))
- else if (IS_ENABLED(CONFIG_FASTBOOT) &&
put_unaligned(STM32MP1_G_DNL_FASTBOOT_PRODUCT_NUM, &dev->idProduct); else!strcmp(name, "usb_dnl_fastboot"))
return 0; }
Reviewed-by: Patrice Chotard patrice.chotard@st.com
Thanks
Patrice
On 8/13/20 9:22 AM, Patrice CHOTARD wrote:
Hi Patrick
Applied on u-boot-stm/master
Thanks
return -ENODEV;
return 0; }
Thanks
Patrice _______________________________________________ Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
Use IS_ENABLED to prevent ifdef in board_check_usb_power.
board/st/stm32mp1/stm32mp1.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 5c84b09c3e..3182f44598 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -288,7 +288,6 @@ static void __maybe_unused led_error_blink(u32 nb_blink) hang(); }
-#ifdef CONFIG_ADC static int board_check_usb_power(void) { struct ofnode_phandle_args adc_args; @@ -300,6 +299,10 @@ static int board_check_usb_power(void) int ret, uV, adc_count; u32 nb_blink; u8 i; + + if (!IS_ENABLED(CONFIG_ADC)) + return -ENODEV; + node = ofnode_path("/config"); if (!ofnode_valid(node)) { debug("%s: no /config node?\n", __func__); @@ -422,7 +425,6 @@ static int board_check_usb_power(void)
return 0; } -#endif /* CONFIG_ADC */
static void sysconf_init(void) { @@ -699,10 +701,8 @@ int board_late_init(void) } #endif
-#ifdef CONFIG_ADC /* for DK1/DK2 boards */ board_check_usb_power(); -#endif /* CONFIG_ADC */
return 0; }
Hi Patrick
- if (!IS_ENABLED(CONFIG_ADC))
return -ENODEV;
- node = ofnode_path("/config"); if (!ofnode_valid(node)) { debug("%s: no /config node?\n", __func__);
return 0; }
Thanks
Patrice
Hi Patrick
return -ENODEV;
return 0; }
Thanks
Patrice
Hi Patrick
Thanks
return -ENODEV;
return 0; }
Thanks
Use IS_ENABLED to prevent ifdef in sysconf_init.
board/st/stm32mp1/stm32mp1.c | 11 +++-------- 1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 3182f44598..a0a2f9978f 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -428,14 +428,11 @@ static int board_check_usb_power(void)
static void sysconf_init(void) { -#ifndef CONFIG_TFABOOT u8 *syscfg; -#ifdef CONFIG_DM_REGULATOR struct udevice *pwr_dev; struct udevice *pwr_reg; struct udevice *dev; u32 otp = 0; -#endif int ret; u32 bootr, val;
@@ -453,7 +450,6 @@ static void sysconf_init(void) bootr |= (bootr & SYSCFG_BOOTR_BOOT_MASK) << SYSCFG_BOOTR_BOOTPD_SHIFT; writel(bootr, syscfg + SYSCFG_BOOTR);
-#ifdef CONFIG_DM_REGULATOR /* High Speed Low Voltage Pad mode Enable for SPI, SDMMC, ETH, QSPI * and TRACE. Needed above ~50MHz and conditioned by AFMUX selection. * The customer will have to disable this for low frequencies @@ -470,7 +466,7 @@ static void sysconf_init(void) ret = uclass_get_device_by_driver(UCLASS_PMIC, DM_GET_DRIVER(stm32mp_pwr_pmic), &pwr_dev); - if (!ret) { + if (!ret && IS_ENABLED(CONFIG_DM_REGULATOR)) { ret = uclass_get_device_by_driver(UCLASS_MISC, DM_GET_DRIVER(stm32mp_bsec), &dev); @@ -507,7 +503,6 @@ static void sysconf_init(void) debug("VDD unknown"); } } -#endif
/* activate automatic I/O compensation * warning: need to ensure CSI enabled and ready in clock driver @@ -524,7 +519,6 @@ static void sysconf_init(void) }
clrbits_le32(syscfg + SYSCFG_CMPCR, SYSCFG_CMPCR_SW_CTRL); -#endif }
#ifdef CONFIG_DM_REGULATOR @@ -647,7 +641,8 @@ int board_init(void) regulators_enable_boot_on(_DEBUG); #endif
- sysconf_init(); + if (!IS_ENABLED(CONFIG_TFABOOT)) + sysconf_init();
if (CONFIG_IS_ENABLED(LED)) led_default_state();
Hi Patrick
- if (!ret) {
- if (!ret && IS_ENABLED(CONFIG_DM_REGULATOR)) { ret = uclass_get_device_by_driver(UCLASS_MISC, DM_GET_DRIVER(stm32mp_bsec), &dev);
- sysconf_init();
sysconf_init();
Thanks
Patrice
On 8/13/20 9:23 AM, Patrice CHOTARD wrote:
Hi Patrick
Thanks
- if (!ret) {
- sysconf_init();
sysconf_init();
Thanks
Use CONFIG_IS_ENABLED to prevent ifdef in set_dfu_alt_inf.
board/st/common/stm32mp_dfu.c | 20 +++++++++++--------- 1 file changed, 11 insertions(+), 9 deletions(-)
diff --git a/board/st/common/stm32mp_dfu.c b/board/st/common/stm32mp_dfu.c index 0cda9196f9..2fb307efe4 100644 --- a/board/st/common/stm32mp_dfu.c +++ b/board/st/common/stm32mp_dfu.c @@ -113,11 +113,13 @@ void set_dfu_alt_info(char *interface, char *devstr) snprintf(buf, DFU_ALT_BUF_LEN, "ram 0=%s", CONFIG_DFU_ALT_RAM0);
- if (!uclass_get_device(UCLASS_MMC, 0, &dev)) - board_get_alt_info_mmc(dev, buf); + if (CONFIG_IS_ENABLED(MMC)) { + if (!uclass_get_device(UCLASS_MMC, 0, &dev)) + board_get_alt_info_mmc(dev, buf);
- if (!uclass_get_device(UCLASS_MMC, 1, &dev)) - board_get_alt_info_mmc(dev, buf); + if (!uclass_get_device(UCLASS_MMC, 1, &dev)) + board_get_alt_info_mmc(dev, buf); + }
if (CONFIG_IS_ENABLED(MTD)) { /* probe all MTD devices */ @@ -139,12 +141,12 @@ void set_dfu_alt_info(char *interface, char *devstr) board_get_alt_info_mtd(mtd, buf); }
-#ifdef CONFIG_DFU_VIRT - strncat(buf, "&virt 0=OTP", DFU_ALT_BUF_LEN); + if (IS_ENABLED(CONFIG_DFU_VIRT)) { + strncat(buf, "&virt 0=OTP", DFU_ALT_BUF_LEN);
- if (IS_ENABLED(CONFIG_PMIC_STPMIC1)) - strncat(buf, "&virt 1=PMIC", DFU_ALT_BUF_LEN); -#endif + if (IS_ENABLED(CONFIG_PMIC_STPMIC1)) + strncat(buf, "&virt 1=PMIC", DFU_ALT_BUF_LEN); + }
env_set("dfu_alt_info", buf); puts("DFU alt info setting: done\n");
Hi Patrick
- if (CONFIG_IS_ENABLED(MMC)) {
- if (IS_ENABLED(CONFIG_DFU_VIRT)) {
-#endif
Thanks
Patrice
Hi Patrick
Thanks
-#endif
Thanks
Use IS_ENABLED to prevent ifdef in dk2_i2c1_fix.
board/st/stm32mp1/stm32mp1.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index a0a2f9978f..985233f2b3 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -521,7 +521,6 @@ static void sysconf_init(void) clrbits_le32(syscfg + SYSCFG_CMPCR, SYSCFG_CMPCR_SW_CTRL); }
-#ifdef CONFIG_DM_REGULATOR /* Fix to make I2C1 usable on DK2 for touchscreen usage in kernel */ static int dk2_i2c1_fix(void) { @@ -529,6 +528,9 @@ static int dk2_i2c1_fix(void) struct gpio_desc hdmi, audio; int ret = 0;
+ if (!IS_ENABLED(CONFIG_DM_REGULATOR)) + return -ENODEV; + node = ofnode_path("/soc/i2c@40012000/hdmi-transmitter@39"); if (!ofnode_valid(node)) { pr_debug("%s: no hdmi-transmitter@39 ?\n", __func__); @@ -586,7 +588,6 @@ static bool board_is_dk2(void)
return false; } -#endif
static bool board_is_ev1(void) { @@ -634,12 +635,11 @@ int board_init(void) if (board_is_ev1()) board_ev1_init();
-#ifdef CONFIG_DM_REGULATOR if (board_is_dk2()) dk2_i2c1_fix();
- regulators_enable_boot_on(_DEBUG); -#endif + if (IS_ENABLED(CONFIG_DM_REGULATOR)) + regulators_enable_boot_on(_DEBUG);
if (!IS_ENABLED(CONFIG_TFABOOT)) sysconf_init();
Hi Patrick
- if (!IS_ENABLED(CONFIG_DM_REGULATOR))
return -ENODEV;
- node = ofnode_path("/soc/i2c@40012000/hdmi-transmitter@39"); if (!ofnode_valid(node)) { pr_debug("%s: no hdmi-transmitter@39 ?\n", __func__);
-#endif
Thanks
Patrice
Hi Patrick
Thanks
return -ENODEV;
-#endif
Thanks
Use IS_ENABLED to prevent ifdef in board_late_init.
board/st/stm32mp1/stm32mp1.c | 60 ++++++++++++++++++------------------ 1 file changed, 30 insertions(+), 30 deletions(-)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 985233f2b3..a9705baa24 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -654,47 +654,47 @@ int board_init(void)
int board_late_init(void) { -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG const void *fdt_compat; int fdt_compat_len; int ret; u32 otp; struct udevice *dev; char buf[10]; + char dtb_name[256]; + int buf_len; + + if (IS_ENABLED(CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG)) { + fdt_compat = fdt_getprop(gd->fdt_blob, 0, "compatible", + &fdt_compat_len); + if (fdt_compat && fdt_compat_len) { + if (strncmp(fdt_compat, "st,", 3) != 0) { + env_set("board_name", fdt_compat); + } else { + env_set("board_name", fdt_compat + 3);
- fdt_compat = fdt_getprop(gd->fdt_blob, 0, "compatible", - &fdt_compat_len); - if (fdt_compat && fdt_compat_len) { - if (strncmp(fdt_compat, "st,", 3) != 0) { - env_set("board_name", fdt_compat); - } else { - char dtb_name[256]; - int buf_len = sizeof(dtb_name); + buf_len = sizeof(dtb_name); + strncpy(dtb_name, fdt_compat + 3, buf_len); + buf_len -= strlen(fdt_compat + 3); + strncat(dtb_name, ".dtb", buf_len); + env_set("fdtfile", dtb_name); + } + } + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(stm32mp_bsec), + &dev);
- env_set("board_name", fdt_compat + 3); + if (!ret) + ret = misc_read(dev, STM32_BSEC_SHADOW(BSEC_OTP_BOARD), + &otp, sizeof(otp)); + if (ret > 0 && otp) { + snprintf(buf, sizeof(buf), "0x%04x", otp >> 16); + env_set("board_id", buf);
- strncpy(dtb_name, fdt_compat + 3, buf_len); - buf_len -= strlen(fdt_compat + 3); - strncat(dtb_name, ".dtb", buf_len); - env_set("fdtfile", dtb_name); + snprintf(buf, sizeof(buf), "0x%04x", + ((otp >> 8) & 0xF) - 1 + 0xA); + env_set("board_rev", buf); } } - ret = uclass_get_device_by_driver(UCLASS_MISC, - DM_GET_DRIVER(stm32mp_bsec), - &dev); - - if (!ret) - ret = misc_read(dev, STM32_BSEC_SHADOW(BSEC_OTP_BOARD), - &otp, sizeof(otp)); - if (ret > 0 && otp) { - snprintf(buf, sizeof(buf), "0x%04x", otp >> 16); - env_set("board_id", buf); - - snprintf(buf, sizeof(buf), "0x%04x", - ((otp >> 8) & 0xF) - 1 + 0xA); - env_set("board_rev", buf); - } -#endif
Hi Patrick
- int buf_len;
- if (IS_ENABLED(CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG)) {
&fdt_compat_len);
} else {
&fdt_compat_len);
} else {
char dtb_name[256];
&dev);
if (!ret)
&otp, sizeof(otp));
} }env_set("board_rev", buf);
&dev);
- if (!ret)
&otp, sizeof(otp));
-#endif
Thanks
Patrice
On 8/13/20 9:24 AM, Patrice CHOTARD wrote:
Hi Patrick
Thanks
- int buf_len;
&fdt_compat_len);
} else {
&fdt_compat_len);
} else {
char dtb_name[256];
&dev);
if (!ret)
&otp, sizeof(otp));
&dev);
- if (!ret)
&otp, sizeof(otp));
-#endif
Thanks
Patrice
Use IS_ENABLED to prevent ifdef in env functions: - env_get_location - env_ext4_get_intf - mmc_get_env_dev
board/st/stm32mp1/stm32mp1.c | 36 +++++++++++++++++------------------- 1 file changed, 17 insertions(+), 19 deletions(-)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index a9705baa24..08d18b6da8 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -785,31 +785,33 @@ enum env_location env_get_location(enum env_operation op, int prio) return ENVL_UNKNOWN;
switch (bootmode & TAMP_BOOT_DEVICE_MASK) { -#if CONFIG_IS_ENABLED(ENV_IS_IN_MMC) case BOOT_FLASH_SD: case BOOT_FLASH_EMMC: - return ENVL_MMC; -#endif -#if CONFIG_IS_ENABLED(ENV_IS_IN_EXT4) - case BOOT_FLASH_SD: - case BOOT_FLASH_EMMC: - return ENVL_EXT4; -#endif -#if CONFIG_IS_ENABLED(ENV_IS_IN_UBI) + if (CONFIG_IS_ENABLED(ENV_IS_IN_MMC)) + return ENVL_MMC; + else if (CONFIG_IS_ENABLED(ENV_IS_IN_EXT4)) + return ENVL_EXT4; + else + return ENVL_NOWHERE; + case BOOT_FLASH_NAND: case BOOT_FLASH_SPINAND: - return ENVL_UBI; -#endif -#if CONFIG_IS_ENABLED(ENV_IS_IN_SPI_FLASH) + if (CONFIG_IS_ENABLED(ENV_IS_IN_UBI)) + return ENVL_UBI; + else + return ENVL_NOWHERE; + case BOOT_FLASH_NOR: - return ENVL_SPI_FLASH; -#endif + if (CONFIG_IS_ENABLED(ENV_IS_IN_SPI_FLASH)) + return ENVL_SPI_FLASH; + else + return ENVL_NOWHERE; + default: return ENVL_NOWHERE; } }
-#if defined(CONFIG_ENV_IS_IN_EXT4) const char *env_ext4_get_intf(void) { u32 bootmode = get_bootmode(); @@ -830,16 +832,12 @@ const char *env_ext4_get_dev_part(void)
return dev_part[(bootmode & TAMP_BOOT_INSTANCE_MASK) - 1]; } -#endif - -#if defined(CONFIG_ENV_IS_IN_MMC) int mmc_get_env_dev(void) { u32 bootmode = get_bootmode();
return (bootmode & TAMP_BOOT_INSTANCE_MASK) - 1; } -#endif
#if defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd)
Hi Patrick
- env_get_location
- env_ext4_get_intf
- mmc_get_env_dev
return ENVL_MMC;
return ENVL_EXT4;
return ENVL_MMC;
return ENVL_EXT4;
else
- case BOOT_FLASH_NAND: case BOOT_FLASH_SPINAND:
return ENVL_UBI;
return ENVL_UBI;
else
- case BOOT_FLASH_NOR:
-#endif
else
- default: return ENVL_NOWHERE; }
Thanks
Patrice
Hi Patrick
- env_get_location
- env_ext4_get_intf
- mmc_get_env_dev
Thanks
return ENVL_MMC;
return ENVL_EXT4;
return ENVL_MMC;
return ENVL_EXT4;
else
return ENVL_UBI;
return ENVL_UBI;
else
-#endif
else
Thanks
Use IS_ENABLED to prevent ifdef in ft_board_setup.
board/st/stm32mp1/stm32mp1.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 08d18b6da8..4d26738a24 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -842,14 +842,14 @@ int mmc_get_env_dev(void) #if defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { -#ifdef CONFIG_FDT_FIXUP_PARTITIONS struct node_info nodes[] = { { "st,stm32f469-qspi", MTD_DEV_TYPE_NOR, }, { "st,stm32f469-qspi", MTD_DEV_TYPE_SPINAND}, { "st,stm32mp15-fmc2", MTD_DEV_TYPE_NAND, }, }; - fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); -#endif + + if (IS_ENABLED(CONFIG_FDT_FIXUP_PARTITIONS)) + fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes));
return 0; }
Hi Patrick
-#endif
Thanks
Patrice
Hi Patrick
Thanks
-#endif
Thanks
Use IS_ENABLED to prevent ifdef in bsec driver.
arch/arm/mach-stm32mp/bsec.c | 86 +++++++++++++++++++----------------- 1 file changed, 46 insertions(+), 40 deletions(-)
diff --git a/arch/arm/mach-stm32mp/bsec.c b/arch/arm/mach-stm32mp/bsec.c index 0c56b440f5..a9b9bd0902 100644 --- a/arch/arm/mach-stm32mp/bsec.c +++ b/arch/arm/mach-stm32mp/bsec.c @@ -74,7 +74,6 @@ static bool bsec_read_lock(u32 address, u32 otp) return !!(readl(address + bank) & bit); }
-#ifndef CONFIG_TFABOOT /** * bsec_check_error() - Check status of one otp * @base: base address of bsec IP @@ -279,7 +278,6 @@ static int bsec_program_otp(long base, u32 val, u32 otp)
return ret; } -#endif /* CONFIG_TFABOOT */
/* BSEC MISC driver *******************************************************/ struct stm32mp_bsec_platdata { @@ -288,15 +286,17 @@ struct stm32mp_bsec_platdata {
static int stm32mp_bsec_read_otp(struct udevice *dev, u32 *val, u32 otp) { -#ifdef CONFIG_TFABOOT - return stm32_smc(STM32_SMC_BSEC, - STM32_SMC_READ_OTP, - otp, 0, val); -#else - struct stm32mp_bsec_platdata *plat = dev_get_platdata(dev); + struct stm32mp_bsec_platdata *plat; u32 tmp_data = 0; int ret;
+ if (IS_ENABLED(CONFIG_TFABOOT)) + return stm32_smc(STM32_SMC_BSEC, + STM32_SMC_READ_OTP, + otp, 0, val); + + plat = dev_get_platdata(dev); + /* read current shadow value */ ret = bsec_read_shadow(plat->base, &tmp_data, otp); if (ret) @@ -313,21 +313,22 @@ static int stm32mp_bsec_read_otp(struct udevice *dev, u32 *val, u32 otp)
/* restore shadow value */ ret = bsec_write_shadow(plat->base, tmp_data, otp); + return ret; -#endif }
static int stm32mp_bsec_read_shadow(struct udevice *dev, u32 *val, u32 otp) { -#ifdef CONFIG_TFABOOT - return stm32_smc(STM32_SMC_BSEC, - STM32_SMC_READ_SHADOW, - otp, 0, val); -#else - struct stm32mp_bsec_platdata *plat = dev_get_platdata(dev); + struct stm32mp_bsec_platdata *plat; + + if (IS_ENABLED(CONFIG_TFABOOT)) + return stm32_smc(STM32_SMC_BSEC, + STM32_SMC_READ_SHADOW, + otp, 0, val); + + plat = dev_get_platdata(dev);
return bsec_read_shadow(plat->base, val, otp); -#endif }
static int stm32mp_bsec_read_lock(struct udevice *dev, u32 *val, u32 otp) @@ -342,33 +343,38 @@ static int stm32mp_bsec_read_lock(struct udevice *dev, u32 *val, u32 otp)
static int stm32mp_bsec_write_otp(struct udevice *dev, u32 val, u32 otp) { -#ifdef CONFIG_TFABOOT - return stm32_smc_exec(STM32_SMC_BSEC, - STM32_SMC_PROG_OTP, - otp, val); -#else - struct stm32mp_bsec_platdata *plat = dev_get_platdata(dev); + struct stm32mp_bsec_platdata *plat; + + if (IS_ENABLED(CONFIG_TFABOOT)) + return stm32_smc_exec(STM32_SMC_BSEC, + STM32_SMC_PROG_OTP, + otp, val); + + plat = dev_get_platdata(dev);
return bsec_program_otp(plat->base, val, otp); -#endif + }
static int stm32mp_bsec_write_shadow(struct udevice *dev, u32 val, u32 otp) { -#ifdef CONFIG_TFABOOT - return stm32_smc_exec(STM32_SMC_BSEC, - STM32_SMC_WRITE_SHADOW, - otp, val); -#else - struct stm32mp_bsec_platdata *plat = dev_get_platdata(dev); + struct stm32mp_bsec_platdata *plat; + + if (IS_ENABLED(CONFIG_TFABOOT)) + return stm32_smc_exec(STM32_SMC_BSEC, + STM32_SMC_WRITE_SHADOW, + otp, val); + + plat = dev_get_platdata(dev);
return bsec_write_shadow(plat->base, val, otp); -#endif }
static int stm32mp_bsec_write_lock(struct udevice *dev, u32 val, u32 otp) { -#ifdef CONFIG_TFABOOT + if (!IS_ENABLED(CONFIG_TFABOOT)) + return -ENOTSUPP; + if (val == 1) return stm32_smc_exec(STM32_SMC_BSEC, STM32_SMC_WRLOCK_OTP, @@ -377,9 +383,6 @@ static int stm32mp_bsec_write_lock(struct udevice *dev, u32 val, u32 otp) return 0; /* nothing to do */
return -EINVAL; -#else - return -ENOTSUPP; -#endif }
static int stm32mp_bsec_read(struct udevice *dev, int offset, @@ -481,18 +484,21 @@ static int stm32mp_bsec_ofdata_to_platdata(struct udevice *dev)
static int stm32mp_bsec_probe(struct udevice *dev) { -#if !defined(CONFIG_TFABOOT) && !defined(CONFIG_SPL_BUILD) int otp; - struct stm32mp_bsec_platdata *plat = dev_get_platdata(dev); + struct stm32mp_bsec_platdata *plat;
/* * update unlocked shadow for OTP cleared by the rom code * only executed in U-Boot proper when TF-A is not used */ - for (otp = 57; otp <= BSEC_OTP_MAX_VALUE; otp++) - if (!bsec_read_SR_lock(plat->base, otp)) - bsec_shadow_register(plat->base, otp); -#endif + + if (!IS_ENABLED(CONFIG_TFABOOT) && !IS_ENABLED(CONFIG_SPL_BUILD)) { + plat = dev_get_platdata(dev); + + for (otp = 57; otp <= BSEC_OTP_MAX_VALUE; otp++) + if (!bsec_read_SR_lock(plat->base, otp)) + bsec_shadow_register(plat->base, otp); + }
return 0; }
Hi Patrick
- bsec_check_error() - Check status of one otp
- @base: base address of bsec IP
STM32_SMC_READ_OTP,
otp, 0, val);
-#else
STM32_SMC_READ_OTP,
otp, 0, val);
- return ret;
-#endif }
otp, 0, val);
-#else
otp, 0, val);
-#endif }
STM32_SMC_PROG_OTP,
otp, val);
-#else
STM32_SMC_PROG_OTP,
otp, val);
-#endif
otp, val);
-#else
otp, val);
-#endif }
- if (!IS_ENABLED(CONFIG_TFABOOT))
return -ENOTSUPP;
- if (val == 1) return stm32_smc_exec(STM32_SMC_BSEC, STM32_SMC_WRLOCK_OTP,
- return -ENOTSUPP;
-#endif }
- update unlocked shadow for OTP cleared by the rom code
- only executed in U-Boot proper when TF-A is not used
-#endif
Thanks
Patrice
Hi Patrick
Thanks
STM32_SMC_READ_OTP,
otp, 0, val);
-#else
STM32_SMC_READ_OTP,
otp, 0, val);
- return ret;
-#endif }
otp, 0, val);
-#else
otp, 0, val);
-#endif }
STM32_SMC_PROG_OTP,
otp, val);
-#else
STM32_SMC_PROG_OTP,
otp, val);
-#endif
otp, val);
-#else
otp, val);
-#endif }
return -ENOTSUPP;
- return -ENOTSUPP;
-#endif }
-#endif
Thanks
Use IS_ENABLED to prevent ifdef in stm32prog command.
.../cmd_stm32prog/cmd_stm32prog.c | 5 +- .../mach-stm32mp/cmd_stm32prog/stm32prog.c | 100 ++++++++++-------- 2 files changed, 58 insertions(+), 47 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c index cbf0120adc..49dd25b28f 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/cmd_stm32prog.c @@ -14,7 +14,6 @@ struct stm32prog_data *stm32prog_data;
static void enable_vidconsole(void) { -#ifdef CONFIG_DM_VIDEO char *stdname; char buf[64];
@@ -35,7 +34,6 @@ static void enable_vidconsole(void) snprintf(buf, sizeof(buf), "%s,vidconsole", stdname); env_set("stderr", buf); } -#endif }
static int do_stm32prog(struct cmd_tbl *cmdtp, int flag, int argc, @@ -86,7 +84,8 @@ static int do_stm32prog(struct cmd_tbl *cmdtp, int flag, int argc, "script@1"); }
- enable_vidconsole(); + if (IS_ENABLED(CONFIG_DM_VIDEO)) + enable_vidconsole();
data = (struct stm32prog_data *)malloc(sizeof(*data));
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c index e4199dbaa5..ec3355d816 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c @@ -544,10 +544,8 @@ static int init_device(struct stm32prog_data *data, { struct mmc *mmc = NULL; struct blk_desc *block_dev = NULL; -#ifdef CONFIG_MTD struct mtd_info *mtd = NULL; char mtd_id[16]; -#endif int part_id; int ret; u64 first_addr = 0, last_addr = 0; @@ -557,8 +555,11 @@ static int init_device(struct stm32prog_data *data, const char *part_name;
switch (dev->target) { -#ifdef CONFIG_MMC case STM32PROG_MMC: + if (!IS_ENABLED(CONFIG_MMC)) { + stm32prog_err("unknown device type = %d", dev->target); + return -ENODEV; + } mmc = find_mmc_device(dev->dev_id); if (!mmc || mmc_init(mmc)) { stm32prog_err("mmc device %d not found", dev->dev_id); @@ -589,11 +590,13 @@ static int init_device(struct stm32prog_data *data, first_addr, last_addr); pr_debug(" full_update = %d\n", dev->full_update); break; -#endif -#ifdef CONFIG_MTD case STM32PROG_NOR: case STM32PROG_NAND: case STM32PROG_SPI_NAND: + if (!IS_ENABLED(CONFIG_MTD)) { + stm32prog_err("unknown device type = %d", dev->target); + return -ENODEV; + } get_mtd_by_target(mtd_id, dev->target, dev->dev_id); pr_debug("%s\n", mtd_id);
@@ -612,7 +615,6 @@ static int init_device(struct stm32prog_data *data, first_addr, last_addr); dev->mtd = mtd; break; -#endif case STM32PROG_RAM: first_addr = gd->bd->bi_dram[0].start; last_addr = first_addr + gd->bd->bi_dram[0].size; @@ -744,8 +746,7 @@ static int init_device(struct stm32prog_data *data, part_found = true; }
-#ifdef CONFIG_MTD - if (mtd) { + if (IS_ENABLED(CONFIG_MTD) && mtd) { char mtd_part_id[32]; struct part_info *mtd_part; struct mtd_device *mtd_dev; @@ -766,7 +767,7 @@ static int init_device(struct stm32prog_data *data, part_name = mtd_part->name; part_found = true; } -#endif + if (!part_found) { stm32prog_err("%s (0x%x): Invalid partition", part->name, part->id); @@ -873,9 +874,8 @@ static int treat_partition_list(struct stm32prog_data *data) return 0; }
-static int create_partitions(struct stm32prog_data *data) +static int create_gpt_partitions(struct stm32prog_data *data) { -#ifdef CONFIG_MMC int offset = 0; const int buflen = SZ_8K; char *buf; @@ -991,7 +991,6 @@ static int create_partitions(struct stm32prog_data *data) run_command("mtd list", 0); #endif free(buf); -#endif
return 0; } @@ -1070,28 +1069,35 @@ static int stm32prog_alt_add(struct stm32prog_data *data, offset += snprintf(buf + offset, ALT_BUF_LEN - offset, " %d;", part->part_id); } + ret = -ENODEV; switch (part->target) { -#ifdef CONFIG_MMC case STM32PROG_MMC: - sprintf(dfustr, "mmc"); - sprintf(devstr, "%d", part->dev_id); + if (IS_ENABLED(CONFIG_MMC)) { + ret = 0; + sprintf(dfustr, "mmc"); + sprintf(devstr, "%d", part->dev_id); + } break; -#endif -#ifdef CONFIG_MTD case STM32PROG_NAND: case STM32PROG_NOR: case STM32PROG_SPI_NAND: - sprintf(dfustr, "mtd"); - get_mtd_by_target(devstr, part->target, part->dev_id); + if (IS_ENABLED(CONFIG_MTD)) { + ret = 0; + sprintf(dfustr, "mtd"); + get_mtd_by_target(devstr, part->target, part->dev_id); + } break; -#endif case STM32PROG_RAM: + ret = 0; sprintf(dfustr, "ram"); sprintf(devstr, "0"); break; default: + break; + } + if (ret) { stm32prog_err("invalid target: %d", part->target); - return -ENODEV; + return ret; } pr_debug("dfu_alt_add(%s,%s,%s)\n", dfustr, devstr, buf); ret = dfu_alt_add(dfu, dfustr, devstr, buf); @@ -1213,13 +1219,14 @@ int stm32prog_otp_write(struct stm32prog_data *data, u32 offset, u8 *buffer, int stm32prog_otp_read(struct stm32prog_data *data, u32 offset, u8 *buffer, long *size) { -#ifndef CONFIG_ARM_SMCCC - stm32prog_err("OTP update not supported"); - - return -1; -#else int result = 0;
+ if (!IS_ENABLED(CONFIG_ARM_SMCCC)) { + stm32prog_err("OTP update not supported"); + + return -1; + } + pr_debug("%s: %x %lx\n", __func__, offset, *size); /* alway read for first packet */ if (!offset) { @@ -1255,19 +1262,19 @@ end_otp_read: pr_debug("%s: result %i\n", __func__, result);
return result; -#endif }
int stm32prog_otp_start(struct stm32prog_data *data) { -#ifndef CONFIG_ARM_SMCCC - stm32prog_err("OTP update not supported"); - - return -1; -#else int result = 0; struct arm_smccc_res res;
+ if (!IS_ENABLED(CONFIG_ARM_SMCCC)) { + stm32prog_err("OTP update not supported"); + + return -1; + } + if (!data->otp_part) { stm32prog_err("start OTP without data"); return -1; @@ -1302,7 +1309,6 @@ int stm32prog_otp_start(struct stm32prog_data *data) pr_debug("%s: result %i\n", __func__, result);
int stm32prog_pmic_write(struct stm32prog_data *data, u32 offset, u8 *buffer, @@ -1538,19 +1544,20 @@ static int part_delete(struct stm32prog_data *data, struct stm32prog_part_t *part) { int ret = 0; -#ifdef CONFIG_MMC unsigned long blks, blks_offset, blks_size; struct blk_desc *block_dev = NULL; - #endif -#ifdef CONFIG_MTD char cmdbuf[40]; char devstr[10]; -#endif
printf("Erasing %s ", part->name); switch (part->target) { -#ifdef CONFIG_MMC case STM32PROG_MMC: + if (!IS_ENABLED(CONFIG_MMC)) { + ret = -1; + stm32prog_err("%s (0x%x): erase invalid", + part->name, part->id); + break; + } printf("on mmc %d: ", part->dev->dev_id); block_dev = mmc_get_blk_desc(part->dev->mmc); blks_offset = lldiv(part->addr, part->dev->mmc->read_bl_len); @@ -1576,11 +1583,15 @@ static int part_delete(struct stm32prog_data *data, part->name, part->id); } break; -#endif -#ifdef CONFIG_MTD case STM32PROG_NOR: case STM32PROG_NAND: case STM32PROG_SPI_NAND: + if (!IS_ENABLED(CONFIG_MTD)) { + ret = -1; + stm32prog_err("%s (0x%x): erase invalid", + part->name, part->id); + break; + } get_mtd_by_target(devstr, part->target, part->dev->dev_id); printf("on %s: ", devstr); sprintf(cmdbuf, "mtd erase %s 0x%llx 0x%llx", @@ -1591,7 +1602,6 @@ static int part_delete(struct stm32prog_data *data, part->name, part->id, cmdbuf); } break; -#endif case STM32PROG_RAM: printf("on ram: "); memset((void *)(uintptr_t)part->addr, 0, (size_t)part->size); @@ -1639,9 +1649,11 @@ static void stm32prog_devices_init(struct stm32prog_data *data) goto error; }
- ret = create_partitions(data); - if (ret) - goto error; + if (IS_ENABLED(CONFIG_MMC)) { + ret = create_gpt_partitions(data); + if (ret) + goto error; + }
/* delete partition GPT or MTD */ for (i = 0; i < data->part_nb; i++) {
Hi Patrick
return -ENODEV;
mmc = find_mmc_device(dev->dev_id); if (!mmc || mmc_init(mmc)) { stm32prog_err("mmc device %d not found", dev->dev_id);}
return -ENODEV;
get_mtd_by_target(mtd_id, dev->target, dev->dev_id); pr_debug("%s\n", mtd_id);}
-#ifdef CONFIG_MTD
if (mtd) {
- if (!part_found) { stm32prog_err("%s (0x%x): Invalid partition", part->name, part->id);
- ret = -ENODEV; switch (part->target) {
ret = 0;
break;}
ret = 0;
break;}
sprintf(dfustr, "ram"); sprintf(devstr, "0"); break; default:ret = 0;
break;
- if (ret) { stm32prog_err("invalid target: %d", part->target);
return -ENODEV;
} pr_debug("dfu_alt_add(%s,%s,%s)\n", dfustr, devstr, buf); ret = dfu_alt_add(dfu, dfustr, devstr, buf);return ret;
- return -1;
- if (!IS_ENABLED(CONFIG_ARM_SMCCC)) {
return -1;
- pr_debug("%s: %x %lx\n", __func__, offset, *size); /* alway read for first packet */ if (!offset) {
- return -1;
return -1;
- if (!data->otp_part) { stm32prog_err("start OTP without data"); return -1;
- #endif
ret = -1;
break;
printf("on mmc %d: ", part->dev->dev_id); block_dev = mmc_get_blk_desc(part->dev->mmc); blks_offset = lldiv(part->addr, part->dev->mmc->read_bl_len);}
ret = -1;
break;
get_mtd_by_target(devstr, part->target, part->dev->dev_id); printf("on %s: ", devstr); sprintf(cmdbuf, "mtd erase %s 0x%llx 0x%llx",}
- if (ret)
goto error;
if (ret)
goto error;
Thanks
Patrice
On 8/13/20 9:25 AM, Patrice CHOTARD wrote:
Hi Patrick
Thanks
return -ENODEV;
return -ENODEV;
-#ifdef CONFIG_MTD
if (mtd) {
ret = 0;
break;}
ret = 0;
break;}
break;
return -ENODEV;
- return -1;
return -1;
- return -1;
return -1;
- #endif
ret = -1;
break;
ret = -1;
break;
- if (ret)
goto error;
if (ret)
goto error;
Thanks
Hi Patrick
- if (!IS_ENABLED(CONFIG_FASTBOOT) && !IS_ENABLED(CONFIG_CMD_STM32PROG))
return;
- node = ofnode_path("/config"); if (!ofnode_valid(node)) { debug("%s: no /config node?\n", __func__); return; }
__func__);
- } else {
- if (IS_ENABLED(CONFIG_FASTBOOT)) {
__func__);
} else {
__func__);
- } else {
- if (IS_ENABLED(CONFIG_CMD_STM32PROG)) {
__func__);
} else {
}dm_gpio_free(NULL, &gpio);
-#endif
-#endif }
Thanks
Patrice
On 8/13/20 9:51 AM, Patrice CHOTARD wrote:
Hi Patrick
Thanks
return;
__func__);
- } else {
__func__);
} else {
__func__);
- } else {
__func__);
} else {
-#endif
-#endif }
Thanks
Patrice CHOTARD
Patrick Delaunay
