[U-Boot] Pull request: u-boot-arm/master
Hello Tom,
The following changes since commit 3a9d879f6f64585b819af728b53be0a05037fe0d:
Prepare v2013.01 (2013-01-15 14:47:42 -0700)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to fd8e1c3866578d87ed14a04a59faae341fd415df:
arm: fix CONFIG_DELAY_ENVIRONMENT to act like it claims in the README (2013-02-11 10:35:26 -0700)
---------------------------------------------------------------- Albert ARIBAUD (1): Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'
Allen Martin (13): tegra: remove IRDA pinmux synonym tegra: fdt: remove clocks nodes tegra: fdt: sort dts files tegra: fdt: add apbdma node fdt: fix dts preprocessor options tegra: fdt: add back missing host1x node tegra20: fdt: add SPI SFLASH node tegra: spi: add fdt support to tegra SPI SFLASH driver tegra30: add SBC1 to periph id mapping table tegra30: fdt: add SPI SLINK nodes tegra: add addresses of SPI SLINK controllers tegra: add SPI SLINK driver tegra: cardhu: config: enable SPI
Fabio Estevam (4): woodburn: Set Write Protection GPIO as input mx6qsabre_common: Let mmc partition be board specific tools: imximage: Let .name field be more generic mxs: Use __weak annotation to simplify code
Javier Martinez Canillas (4): OMAP3: use a single board file for IGEP devices OMAP3: igep00x0: add boot status GPIO LED omap4: allow the use of a plain text env file instead boot scripts OMAP3: igep00x0: fix a build warning on IGEP boards
Jeff Lance (1): Add DDR3 support for AM335x-EVM (Version 1.5A)
Knut Wohlrab (1): mx6qsabreauto: enable USB host interface
Lars Poeschel (3): am33xx: add a pulldown macro to pinmux config pcm051: Add support for Phytec phyCORE-AM335x am335x: display msg when reading MAC from efuse
Lucas Stach (1): arm: fix CONFIG_DELAY_ENVIRONMENT to act like it claims in the README
Marc Dietrich (3): tegra: display: add board pinmux tegra: enable LCD on PAZ00 tegra: remove custom TEGRA_DEVICE_SETTINGS for board files
Marek Vasut (14): mxs: mmc: Drop unused members from struct mxsmmc_priv mxs: ssp: Pull out the SSP bus to regs conversion mx23: Add POWER and CLKCTRL register definitions mx23: ssp: Fix ssp-regs.h for MX23 mmc: Limit the number of used SSP ports on MX23 mxs: Add function to ungate the power block on MX23 mxs: Linux uses ttyAMA0 as DUART mxs: Add MX23 olinuxino board support mxs: Boost the memory power supply mxs: dma: Fix APBH DMA driver for MX23 mxs: ssp: Add SSP registers map for MX23 mxs: mmc: Allow overriding default card detect implementation mxs: mmc: Fix the MMC driver for MX23 mxs: mmc: mx23_olinuxino: Add MMC support
Otavio Salvador (14): mxs: clock: Use 'mxs' prefix for methods mx23: Add register base addresses mx23: Add iomux-mx23.h mx23: Add support on print_cpuinfo() mx23: Add boot mode description mx23: SPL: Add boot mode support mx23: SPL: Initialize DDR at 133MHz mx23: config: Enable building of u-boot.sb binary mx23: config: Enable mxsboot tool for i.MX23 based boards mxs: Fix the memory init for MX23 mxs: Add MX23 quirks into the clock code mxs: mmc: Fix MMC reset on iMX23 mx23_olinuxino: Add default environment mx23evk: Add initial board support
Rob Herring (2): ARM: add wfi assembly macro ARM: highbank: use wfi macro instead of inline asm
Stephen Warren (2): tegra: rename FUNCMUX_UART2_UARTB tegra: don't hard-code LCD into default TEGRA_DEVICE_SETTINGS
Tetsuyuki Kobayashi (2): arm: rmobile: kzm9g: Adjust SDRAM setting arm: rmobile: kzm9g: Adjust ETM trace clock
Thierry Reding (3): video: tegra: Update line length to match resolution tegra: Enable LCD on Medcom-Wide tegra: Enable LCD on TEC
Tom Rini (1): am33xx: Drop gpio0_7_pin_mux from phytec pcm051
Tom Warren (19): Tegra30: Add arch-tegra30 include files Tegra30: Add AVP (arm720t) files Tegra30: Add CPU (armv7) files Tegra30: Add common CPU (shared) files Tegra30: Cardhu: Add DT files Tegra30: Add generic Tegra30 build support Tegra30: Add/enable Cardhu build (T30 reference board) Tegra30: clocks: Fix clock tables for I2C and other periphs Tegra30: fdt: Update DT files with I2C info for T30/Cardhu Tegra30: I2C: Enable I2C driver on Cardhu Tegra: T20: Remove unused 'SLOW' SoC ID and PLLX table entry Tegra: Move common clock code to arch/arm/cpu/tegra-common/clock.c Tegra114: Add arch-tegra114 include files Tegra114: Add AVP (arm720t) files Tegra114: Add CPU (armv7) files Tegra114: Add common CPU (shared) files Tegra114: Dalmore: Add DT files Tegra114: Add generic Tegra114 build support Tegra114: Add/enable Dalmore build (T114 reference board)
Troy Kisky (10): imximage.cfg: run files through C preprocessor doc/README.fec_mxc: add documentation net: fec_mxc: delete CONFIG_FEC_MXC_MULTI net: fec_mxc: change fec_mii_setspeed parameter net: fec_mxc: have fecmxc_initialize call fecmxc_initialize_multi phy: add phy_find_by_mask/phy_connect_dev net: fec_mxc: use fec_set_dev_name to set name net: fec_mxc: only call phy_connect in fec_probe net: fec_mxc: get phydev before fec_probe mx6qsabrelite: search mii phy address 4-7
hvaibhav@ti.com (1): AM335X: Set fdt_high for AM335X devices to enable booting with Device Tree
.gitignore | 1 + MAINTAINERS | 8 + Makefile | 15 +- arch/arm/cpu/arm720t/tegra-common/Makefile | 1 + arch/arm/cpu/arm720t/tegra-common/cpu.c | 333 ++++++++++ arch/arm/cpu/arm720t/tegra-common/cpu.h | 70 +-- arch/arm/cpu/arm720t/tegra-common/spl.c | 3 +- arch/arm/cpu/arm720t/tegra114/Makefile | 42 ++ arch/arm/cpu/arm720t/tegra114/config.mk | 19 + arch/arm/cpu/arm720t/tegra114/cpu.c | 297 +++++++++ arch/arm/cpu/arm720t/tegra20/cpu.c | 216 +------ arch/arm/cpu/arm720t/tegra30/Makefile | 41 ++ arch/arm/cpu/arm720t/tegra30/config.mk | 19 + arch/arm/cpu/arm720t/tegra30/cpu.c | 176 ++++++ arch/arm/cpu/arm926ejs/config.mk | 2 +- arch/arm/cpu/arm926ejs/mxs/clock.c | 83 ++- arch/arm/cpu/arm926ejs/mxs/mxs.c | 25 +- arch/arm/cpu/arm926ejs/mxs/spl_boot.c | 25 + arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c | 118 +++- arch/arm/cpu/arm926ejs/mxs/spl_power_init.c | 12 + arch/arm/cpu/arm926ejs/mxs/u-boot-imx23.bd | 18 + arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/config.mk | 2 +- arch/arm/cpu/armv7/start.S | 4 +- arch/arm/cpu/armv7/tegra114/Makefile | 40 ++ arch/arm/cpu/armv7/tegra114/config.mk | 19 + arch/arm/cpu/armv7/tegra30/Makefile | 40 ++ arch/arm/cpu/armv7/tegra30/config.mk | 19 + arch/arm/cpu/tegra-common/Makefile | 2 +- arch/arm/cpu/tegra-common/ap.c | 23 +- arch/arm/cpu/tegra-common/board.c | 58 +- arch/arm/cpu/tegra-common/clock.c | 560 +++++++++++++++++ arch/arm/cpu/tegra-common/sys_info.c | 16 +- arch/arm/cpu/tegra114-common/Makefile | 41 ++ arch/arm/cpu/tegra114-common/clock.c | 655 ++++++++++++++++++++ arch/arm/cpu/tegra114-common/funcmux.c | 63 ++ arch/arm/cpu/tegra114-common/pinmux.c | 506 +++++++++++++++ arch/arm/cpu/tegra20-common/clock.c | 605 +----------------- arch/arm/cpu/tegra20-common/funcmux.c | 4 +- arch/arm/cpu/tegra20-common/pinmux.c | 2 +- arch/arm/cpu/tegra20-common/warmboot.c | 2 +- arch/arm/cpu/tegra30-common/Makefile | 44 ++ arch/arm/cpu/tegra30-common/clock.c | 618 ++++++++++++++++++ arch/arm/cpu/tegra30-common/funcmux.c | 57 ++ arch/arm/cpu/tegra30-common/pinmux.c | 506 +++++++++++++++ arch/arm/dts/tegra114.dtsi | 5 + arch/arm/dts/tegra20.dtsi | 412 ++++++------ arch/arm/dts/tegra30.dtsi | 165 +++++ arch/arm/imx-common/Makefile | 13 + arch/arm/include/asm/arch-am33xx/ddr_defs.h | 34 + arch/arm/include/asm/arch-am33xx/mux.h | 3 +- arch/arm/include/asm/arch-mxs/clock.h | 14 +- arch/arm/include/asm/arch-mxs/imx-regs.h | 7 +- arch/arm/include/asm/arch-mxs/iomux-mx23.h | 355 +++++++++++ arch/arm/include/asm/arch-mxs/regs-apbh.h | 121 ++++ arch/arm/include/asm/arch-mxs/regs-base.h | 56 +- arch/arm/include/asm/arch-mxs/regs-clkctrl-mx23.h | 221 +++++++ arch/arm/include/asm/arch-mxs/regs-digctl.h | 1 + arch/arm/include/asm/arch-mxs/regs-power-mx23.h | 358 +++++++++++ arch/arm/include/asm/arch-mxs/regs-ssp.h | 54 ++ arch/arm/include/asm/arch-mxs/sys_proto.h | 20 +- arch/arm/include/asm/arch-tegra/ap.h | 52 +- arch/arm/include/asm/arch-tegra/board.h | 7 +- arch/arm/include/asm/arch-tegra/clk_rst.h | 196 +++++- arch/arm/include/asm/arch-tegra/clock.h | 65 +- arch/arm/include/asm/arch-tegra/funcmux.h | 39 ++ arch/arm/include/asm/arch-tegra/gp_padctrl.h | 40 ++ arch/arm/include/asm/arch-tegra/pmc.h | 8 + arch/arm/include/asm/arch-tegra/tegra.h | 19 +- arch/arm/include/asm/arch-tegra/tegra_slink.h | 84 +++ arch/arm/include/asm/arch-tegra114/clock-tables.h | 402 ++++++++++++ arch/arm/include/asm/arch-tegra114/clock.h | 28 + arch/arm/include/asm/arch-tegra114/flow.h | 35 ++ arch/arm/include/asm/arch-tegra114/funcmux.h | 31 + arch/arm/include/asm/arch-tegra114/gp_padctrl.h | 59 ++ arch/arm/include/asm/arch-tegra114/gpio.h | 30 + arch/arm/include/asm/arch-tegra114/hardware.h | 22 + arch/arm/include/asm/arch-tegra114/pinmux.h | 618 ++++++++++++++++++ arch/arm/include/asm/arch-tegra114/pmu.h | 23 + arch/arm/include/asm/arch-tegra114/spl.h | 22 + arch/arm/include/asm/arch-tegra114/tegra.h | 33 + arch/arm/include/asm/arch-tegra20/clock-tables.h | 4 + arch/arm/include/asm/arch-tegra20/clock.h | 4 + arch/arm/include/asm/arch-tegra20/funcmux.h | 28 +- arch/arm/include/asm/arch-tegra20/gp_padctrl.h | 17 +- arch/arm/include/asm/arch-tegra20/pinmux.h | 1 - arch/arm/include/asm/arch-tegra20/tegra.h | 2 + arch/arm/include/asm/arch-tegra30/clock-tables.h | 382 ++++++++++++ arch/arm/include/asm/arch-tegra30/clock.h | 28 + arch/arm/include/asm/arch-tegra30/flow.h | 35 ++ arch/arm/include/asm/arch-tegra30/funcmux.h | 31 + arch/arm/include/asm/arch-tegra30/gp_padctrl.h | 59 ++ arch/arm/include/asm/arch-tegra30/gpio.h | 304 +++++++++ arch/arm/include/asm/arch-tegra30/hardware.h | 22 + arch/arm/include/asm/arch-tegra30/pinmux.h | 603 ++++++++++++++++++ arch/arm/include/asm/arch-tegra30/pmu.h | 23 + arch/arm/include/asm/arch-tegra30/spl.h | 28 + arch/arm/include/asm/arch-tegra30/tegra.h | 28 + arch/arm/include/asm/system.h | 6 + arch/arm/lib/board.c | 2 +- board/avionic-design/dts/tegra20-medcom-wide.dts | 38 +- board/avionic-design/dts/tegra20-plutux.dts | 14 - board/avionic-design/dts/tegra20-tec.dts | 56 +- board/bluegiga/apx4devkit/apx4devkit.c | 8 +- board/compal/dts/tegra20-paz00.dts | 39 +- board/compal/paz00/paz00.c | 11 + board/compulab/dts/tegra20-trimslice.dts | 18 +- board/denx/m28evk/m28evk.c | 10 +- board/esg/ima3-mx53/imximage.cfg | 120 ++-- board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg | 90 +-- .../{isee/igep0030 => freescale/mx23evk}/Makefile | 8 +- board/freescale/mx23evk/mx23evk.c | 83 +++ board/freescale/mx23evk/spl_boot.c | 104 ++++ board/freescale/mx25pdk/imximage.cfg | 77 +-- board/freescale/mx28evk/mx28evk.c | 10 +- board/freescale/mx51evk/imximage.cfg | 114 ++-- board/freescale/mx53ard/imximage_dd3.cfg | 83 +-- board/freescale/mx53evk/imximage.cfg | 86 +-- board/freescale/mx53loco/imximage.cfg | 83 +-- board/freescale/mx53smd/imximage.cfg | 83 +-- board/freescale/mx6qarm2/imximage.cfg | 88 +-- board/freescale/mx6qsabreauto/imximage.cfg | 82 +-- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 24 +- board/genesi/mx51_efikamx/imximage_mx.cfg | 132 ++-- board/genesi/mx51_efikamx/imximage_sb.cfg | 126 ++-- board/highbank/highbank.c | 3 +- board/isee/igep0020/igep0020.h | 151 ----- board/isee/igep0030/igep0030.c | 117 ---- board/isee/{igep0020 => igep00x0}/Makefile | 2 +- .../{igep0020/igep0020.c => igep00x0/igep00x0.c} | 51 +- .../{igep0030/igep0030.h => igep00x0/igep00x0.h} | 35 +- board/kmc/kzm9g/kzm9g.c | 19 +- board/nvidia/cardhu/Makefile | 44 ++ board/nvidia/cardhu/cardhu.c | 39 ++ board/nvidia/cardhu/cardhu.c.mmc | 151 +++++ board/nvidia/cardhu/pinmux-config-cardhu.h | 329 ++++++++++ board/nvidia/common/board.c | 27 +- board/nvidia/dalmore/Makefile | 36 ++ board/nvidia/dalmore/dalmore.c | 32 + board/nvidia/dalmore/pinmux-config-dalmore.h | 249 ++++++++ board/nvidia/dts/tegra114-dalmore.dts | 13 + board/nvidia/dts/tegra20-harmony.dts | 33 +- board/nvidia/dts/tegra20-seaboard.dts | 129 ++-- board/nvidia/dts/tegra20-ventana.dts | 13 - board/nvidia/dts/tegra20-whistler.dts | 10 - board/nvidia/dts/tegra30-cardhu.dts | 47 ++ board/olimex/mx23_olinuxino/Makefile | 47 ++ board/olimex/mx23_olinuxino/mx23_olinuxino.c | 71 +++ board/olimex/mx23_olinuxino/spl_boot.c | 99 +++ board/phytec/pcm051/Makefile | 46 ++ board/phytec/pcm051/board.c | 266 ++++++++ board/phytec/pcm051/board.h | 33 + board/phytec/pcm051/mux.c | 128 ++++ board/schulercontrol/sc_sps_1/sc_sps_1.c | 10 +- board/ti/am335x/board.c | 43 +- board/ttcontrol/vision2/imximage_hynix.cfg | 295 ++++----- board/woodburn/imximage.cfg | 2 +- board/woodburn/woodburn.c | 3 +- boards.cfg | 13 +- doc/README.fec_mxc | 27 + drivers/dma/apbh_dma.c | 10 +- drivers/mmc/mxsmmc.c | 102 +-- drivers/net/fec_mxc.c | 164 ++--- drivers/net/fec_mxc.h | 2 +- drivers/net/phy/phy.c | 128 ++-- drivers/spi/Makefile | 1 + drivers/spi/mxs_spi.c | 7 +- drivers/spi/tegra_slink.c | 343 ++++++++++ drivers/spi/tegra_spi.c | 45 +- drivers/video/tegra.c | 4 +- dts/Makefile | 2 +- include/configs/am335x_evm.h | 1 + include/configs/cardhu.h | 65 ++ include/configs/dalmore.h | 50 ++ include/configs/igep00x0.h | 5 + include/configs/m28evk.h | 3 +- include/configs/medcom-wide.h | 8 + include/configs/mx23_olinuxino.h | 210 +++++++ include/configs/mx23evk.h | 202 ++++++ include/configs/mx28evk.h | 1 - include/configs/mx6qsabre_common.h | 2 +- include/configs/mx6qsabreauto.h | 12 + include/configs/omap4_common.h | 17 +- include/configs/paz00.h | 9 + include/configs/pcm051.h | 301 +++++++++ include/configs/sc_sps_1.h | 1 - include/configs/tec.h | 9 +- include/configs/tegra-common-post.h | 38 +- include/configs/tegra-common.h | 160 +++++ include/configs/tegra114-common.h | 79 +++ include/configs/tegra20-common.h | 201 ++---- include/configs/tegra30-common.h | 89 +++ include/fdtdec.h | 2 + include/netdev.h | 7 + include/phy.h | 3 + include/serial.h | 2 +- lib/fdtdec.c | 2 + spl/Makefile | 9 +- tools/Makefile | 2 + tools/imximage.c | 2 +- 200 files changed, 14371 insertions(+), 2800 deletions(-) create mode 100644 arch/arm/cpu/arm720t/tegra-common/cpu.c create mode 100644 arch/arm/cpu/arm720t/tegra114/Makefile create mode 100644 arch/arm/cpu/arm720t/tegra114/config.mk create mode 100644 arch/arm/cpu/arm720t/tegra114/cpu.c create mode 100644 arch/arm/cpu/arm720t/tegra30/Makefile create mode 100644 arch/arm/cpu/arm720t/tegra30/config.mk create mode 100644 arch/arm/cpu/arm720t/tegra30/cpu.c create mode 100644 arch/arm/cpu/arm926ejs/mxs/u-boot-imx23.bd create mode 100644 arch/arm/cpu/armv7/tegra114/Makefile create mode 100644 arch/arm/cpu/armv7/tegra114/config.mk create mode 100644 arch/arm/cpu/armv7/tegra30/Makefile create mode 100644 arch/arm/cpu/armv7/tegra30/config.mk create mode 100644 arch/arm/cpu/tegra-common/clock.c create mode 100644 arch/arm/cpu/tegra114-common/Makefile create mode 100644 arch/arm/cpu/tegra114-common/clock.c create mode 100644 arch/arm/cpu/tegra114-common/funcmux.c create mode 100644 arch/arm/cpu/tegra114-common/pinmux.c create mode 100644 arch/arm/cpu/tegra30-common/Makefile create mode 100644 arch/arm/cpu/tegra30-common/clock.c create mode 100644 arch/arm/cpu/tegra30-common/funcmux.c create mode 100644 arch/arm/cpu/tegra30-common/pinmux.c create mode 100644 arch/arm/dts/tegra114.dtsi create mode 100644 arch/arm/dts/tegra30.dtsi create mode 100644 arch/arm/include/asm/arch-mxs/iomux-mx23.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-clkctrl-mx23.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-power-mx23.h create mode 100644 arch/arm/include/asm/arch-tegra/funcmux.h create mode 100644 arch/arm/include/asm/arch-tegra/gp_padctrl.h create mode 100644 arch/arm/include/asm/arch-tegra/tegra_slink.h create mode 100644 arch/arm/include/asm/arch-tegra114/clock-tables.h create mode 100644 arch/arm/include/asm/arch-tegra114/clock.h create mode 100644 arch/arm/include/asm/arch-tegra114/flow.h create mode 100644 arch/arm/include/asm/arch-tegra114/funcmux.h create mode 100644 arch/arm/include/asm/arch-tegra114/gp_padctrl.h create mode 100644 arch/arm/include/asm/arch-tegra114/gpio.h create mode 100644 arch/arm/include/asm/arch-tegra114/hardware.h create mode 100644 arch/arm/include/asm/arch-tegra114/pinmux.h create mode 100644 arch/arm/include/asm/arch-tegra114/pmu.h create mode 100644 arch/arm/include/asm/arch-tegra114/spl.h create mode 100644 arch/arm/include/asm/arch-tegra114/tegra.h create mode 100644 arch/arm/include/asm/arch-tegra30/clock-tables.h create mode 100644 arch/arm/include/asm/arch-tegra30/clock.h create mode 100644 arch/arm/include/asm/arch-tegra30/flow.h create mode 100644 arch/arm/include/asm/arch-tegra30/funcmux.h create mode 100644 arch/arm/include/asm/arch-tegra30/gp_padctrl.h create mode 100644 arch/arm/include/asm/arch-tegra30/gpio.h create mode 100644 arch/arm/include/asm/arch-tegra30/hardware.h create mode 100644 arch/arm/include/asm/arch-tegra30/pinmux.h create mode 100644 arch/arm/include/asm/arch-tegra30/pmu.h create mode 100644 arch/arm/include/asm/arch-tegra30/spl.h create mode 100644 arch/arm/include/asm/arch-tegra30/tegra.h rename board/{isee/igep0030 => freescale/mx23evk}/Makefile (92%) create mode 100644 board/freescale/mx23evk/mx23evk.c create mode 100644 board/freescale/mx23evk/spl_boot.c delete mode 100644 board/isee/igep0020/igep0020.h delete mode 100644 board/isee/igep0030/igep0030.c rename board/isee/{igep0020 => igep00x0}/Makefile (98%) rename board/isee/{igep0020/igep0020.c => igep00x0/igep00x0.c} (86%) rename board/isee/{igep0030/igep0030.h => igep00x0/igep00x0.h} (93%) create mode 100644 board/nvidia/cardhu/Makefile create mode 100644 board/nvidia/cardhu/cardhu.c create mode 100644 board/nvidia/cardhu/cardhu.c.mmc create mode 100644 board/nvidia/cardhu/pinmux-config-cardhu.h create mode 100644 board/nvidia/dalmore/Makefile create mode 100644 board/nvidia/dalmore/dalmore.c create mode 100644 board/nvidia/dalmore/pinmux-config-dalmore.h create mode 100644 board/nvidia/dts/tegra114-dalmore.dts create mode 100644 board/nvidia/dts/tegra30-cardhu.dts create mode 100644 board/olimex/mx23_olinuxino/Makefile create mode 100644 board/olimex/mx23_olinuxino/mx23_olinuxino.c create mode 100644 board/olimex/mx23_olinuxino/spl_boot.c create mode 100644 board/phytec/pcm051/Makefile create mode 100644 board/phytec/pcm051/board.c create mode 100644 board/phytec/pcm051/board.h create mode 100644 board/phytec/pcm051/mux.c create mode 100644 doc/README.fec_mxc create mode 100644 drivers/spi/tegra_slink.c create mode 100644 include/configs/cardhu.h create mode 100644 include/configs/dalmore.h create mode 100644 include/configs/mx23_olinuxino.h create mode 100644 include/configs/mx23evk.h create mode 100644 include/configs/pcm051.h create mode 100644 include/configs/tegra-common.h create mode 100644 include/configs/tegra114-common.h create mode 100644 include/configs/tegra30-common.h
Amicalement,
On Tue, Feb 12, 2013 at 03:25:49PM +0100, Albert ARIBAUD wrote:
Hello Tom,
Applied to u-boot/master (a few days ago and forgot to send this), thanks!
Albert ARIBAUD
