[U-Boot] [PATCH] powerpc/t104xrdb, t1040qds : Update FMAN microcode NOR address
FMAN microcode image address range on NOR flash changed from (0xeff00000 to 0xebf1ffff) to (0xeff10000 to 0xeff1ffff)
The change has been done - to support FMAN microcode flashing via promjet mechanism as promjet uses address based on offsets. Based on this address of FMAN microcode flash on promjet flash should be 0x0 But 0x0 offset is already use for rcw on promjet flash. To take care of this limitation FMAN microcode address has been changed. Now, FMAN microcode address on promjet flash is 0x10000
- FMAN microcode is of size 64KB so it will fit into 0xeff10000 to 0xeff1ffff.
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Vijay Rai vijay.rai@freescale.com Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com --- board/freescale/t1040qds/README | 4 ++-- board/freescale/t104xrdb/README | 4 ++-- include/configs/T1040QDS.h | 2 +- include/configs/T1040RDB.h | 2 +- include/configs/T1042RDB_PI.h | 2 +- 5 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/board/freescale/t1040qds/README b/board/freescale/t1040qds/README index 8160ca0..a2e2300 100644 --- a/board/freescale/t1040qds/README +++ b/board/freescale/t1040qds/README @@ -120,14 +120,14 @@ NOR Flash memory Map on T1040QDS Start End Definition Size 0xEFF40000 0xEFFFFFFF u-boot (current bank) 768KB 0xEFF20000 0xEFF3FFFF u-boot env (current bank) 128KB -0xEFF00000 0xEFF1FFFF FMAN Ucode (current bank) 128KB +0xEFF10000 0xEFF1FFFF FMAN Ucode (current bank) 64KB 0xED300000 0xEFEFFFFF rootfs (alt bank) 44MB 0xEC800000 0xEC8FFFFF Hardware device tree (alt bank) 1MB 0xEC020000 0xEC7FFFFF Linux.uImage (alt bank) 7MB + 875KB 0xEC000000 0xEC01FFFF RCW (alt bank) 128KB 0xEBF40000 0xEBFFFFFF u-boot (alt bank) 768KB 0xEBF20000 0xEBF3FFFF u-boot env (alt bank) 128KB -0xEBF00000 0xEBF1FFFF FMAN ucode (alt bank) 128KB +0xEBF10000 0xEBF1FFFF FMAN ucode (alt bank) 64KB 0xE9300000 0xEBEFFFFF rootfs (current bank) 44MB 0xE8800000 0xE88FFFFF Hardware device tree (cur bank) 11MB + 512KB 0xE8020000 0xE86FFFFF Linux.uImage (current bank) 7MB + 875KB diff --git a/board/freescale/t104xrdb/README b/board/freescale/t104xrdb/README index 1da52bb..ae68135 100644 --- a/board/freescale/t104xrdb/README +++ b/board/freescale/t104xrdb/README @@ -163,14 +163,14 @@ NOR Flash memory Map Start End Definition Size 0xEFF40000 0xEFFFFFFF u-boot (current bank) 768KB 0xEFF20000 0xEFF3FFFF u-boot env (current bank) 128KB -0xEFF00000 0xEFF1FFFF FMAN Ucode (current bank) 128KB +0xEFF10000 0xEFF1FFFF FMAN Ucode (current bank) 64KB 0xED300000 0xEFEFFFFF rootfs (alt bank) 44MB 0xEC800000 0xEC8FFFFF Hardware device tree (alt bank) 1MB 0xEC020000 0xEC7FFFFF Linux.uImage (alt bank) 7MB + 875KB 0xEC000000 0xEC01FFFF RCW (alt bank) 128KB 0xEBF40000 0xEBFFFFFF u-boot (alt bank) 768KB 0xEBF20000 0xEBF3FFFF u-boot env (alt bank) 128KB -0xEBF00000 0xEBF1FFFF FMAN ucode (alt bank) 128KB +0xEBF10000 0xEBF1FFFF FMAN ucode (alt bank) 64KB 0xE9300000 0xEBEFFFFF rootfs (current bank) 44MB 0xE8800000 0xE88FFFFF Hardware device tree (cur bank) 11MB + 512KB 0xE8020000 0xE86FFFFF Linux.uImage (current bank) 7MB + 875KB diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 75ea125..15e1f51a 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -592,7 +592,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF10000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/T1040RDB.h b/include/configs/T1040RDB.h index 7cfda50..f38857a 100644 --- a/include/configs/T1040RDB.h +++ b/include/configs/T1040RDB.h @@ -531,7 +531,7 @@ #define CONFIG_SYS_QE_FMAN_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF10000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) diff --git a/include/configs/T1042RDB_PI.h b/include/configs/T1042RDB_PI.h index ed9ca8a..d59901a 100644 --- a/include/configs/T1042RDB_PI.h +++ b/include/configs/T1042RDB_PI.h @@ -539,7 +539,7 @@ #define CONFIG_SYS_QE_FMAN_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF10000 #endif #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH)
NACK.
The tool is not broken. I have made a configuration to use PROMJET to download all images successfully.
York
Priyanka Jain
York Sun
