[PATCH 11/15] cmd: bdinfo: enable -e when CONFIG_CMD_NET_LWIP=y
Support "bdinfo -e" when lwIP is selected.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org --- cmd/bdinfo.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/cmd/bdinfo.c b/cmd/bdinfo.c index 79106caeec..690fb894bf 100644 --- a/cmd/bdinfo.c +++ b/cmd/bdinfo.c @@ -152,7 +152,7 @@ static int bdinfo_print_all(struct bd_info *bd) bdinfo_print_num_l("relocaddr", gd->relocaddr); bdinfo_print_num_l("reloc off", gd->reloc_off); printf("%-12s= %u-bit\n", "Build", (uint)sizeof(void *) * 8); - if (IS_ENABLED(CONFIG_CMD_NET)) + if (IS_ENABLED(CONFIG_CMD_NET) || IS_ENABLED(CONFIG_CMD_NET_LWIP)) print_eth(); bdinfo_print_num_l("fdt_blob", (ulong)map_to_sysmem(gd->fdt_blob)); bdinfo_print_num_l("new_fdt", (ulong)map_to_sysmem(gd->new_fdt)); @@ -198,7 +198,8 @@ int do_bdinfo(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) case 'a': return bdinfo_print_all(bd); case 'e': - if (!IS_ENABLED(CONFIG_CMD_NET)) + if (!IS_ENABLED(CONFIG_CMD_NET) && + !IS_ENABLED(CONFIG_CMD_NET_LWIP)) return CMD_RET_USAGE; print_eth(); return CMD_RET_SUCCESS;
On Wed, 22 May 2024 at 19:04, Jerome Forissier jerome.forissier@linaro.org wrote:
-- 2.40.1
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Ilias Apalodimas
Jerome Forissier
