[U-Boot] [PATCH] Fix jornada memory init]
Havent recieved any input and its still not applied. So bumping it yet again(#3). It only affects my specific platform.
Best wishes Kristoffer
----- Forwarded message from Kristoffer Ericson kristoffer.ericson@gmail.com -----
Date: Sat, 6 Nov 2010 14:24:27 +0100 From: Kristoffer Ericson kristoffer.ericson@gmail.com To: wd@denx.de Cc: u-boot@lists.denx.de, Kristoffer Ericson kristoffer.ericson@gmail.com Subject: [PATCH] Fix jornada memory init X-Mailer: git-send-email 1.7.3.2
* Fix memory initialization. This fixes the problem with kernel oopses during heavy load.
* Cleanup pinsetup, which for reference is among other things needed for proper flash erasing.
Signed-off-by: Kristoffer Ericson kristoffer.ericson@gmail.com --- board/jornada/setup.S | 24 ++++++++++++------------ 1 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/board/jornada/setup.S b/board/jornada/setup.S index 885e02f..cdf5f54 100644 --- a/board/jornada/setup.S +++ b/board/jornada/setup.S @@ -112,12 +112,13 @@ gafr_set: .long 0x08600000 .globl lowlevel_init lowlevel_init:
- /* set output and direction of pins */ - ldr r0, PPC_BASE - ldr r1, pin_set_out - str r1, [r0, #PPSR] - ldr r1, pin_set_dir - str r1, [r0, #PPDR] + + /* this is required for flashing */ + ldr r0, PPC_BASE + ldr r1, pin_set_out + str r1, [r0, #PPSR] + ldr r1, pin_set_dir + str r1, [r0, #PPDR]
/* Setting up the memory and stuff */ /***********************************/ @@ -190,6 +191,11 @@ lowlevel_init: ldr r3, [r2] .endr
+ ldr r2, [r0, #MDCNFG] + orr r2, r2, #0x00000003 + orr r2, r2, #0x00030000 + str r2, [r0, #MDCNFG] + ldr r1, msc0 str r1, [r0, #MSC0] ldr r1, msc1 @@ -198,13 +204,7 @@ lowlevel_init: str r1, [r0, #MSC2] ldr r1, smcnfg str r1, [r0, #SMCNFG] - ldr r1, mdcnfg - str r1, [r0, #MDCNFG] ldr r1, mecr str r1, [r0, #MECR]
- /* enable SDRAM */ - orr r1, r1, #0x00000001 - str r1, [r0, #MDCNFG] - mov pc, lr
Kristoffer Ericson
