[PATCH 02/11] mtd: nand: Store nand ID in struct nand_chip
Upstream commit 7f501f0a72036dc29ad9a53811474c393634b401
Store the NAND ID in struct nand_chip to avoid passing id_data and id_len as function parameters.
Signed-off-by: Boris Brezillon boris.brezillon@free-electrons.com Acked-by: Richard Weinberger richard@nod.at Reviewed-by: Marek Vasut marek.vasut@gmail.com Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/mtd/nand/raw/nand_base.c | 54 ++++++++++++++++---------------- include/linux/mtd/rawnand.h | 15 +++++++++ 2 files changed, 42 insertions(+), 27 deletions(-)
diff --git a/drivers/mtd/nand/raw/nand_base.c b/drivers/mtd/nand/raw/nand_base.c index 9a2194ebd3..4a78770a25 100644 --- a/drivers/mtd/nand/raw/nand_base.c +++ b/drivers/mtd/nand/raw/nand_base.c @@ -4160,16 +4160,14 @@ static int nand_get_bits_per_cell(u8 cellinfo) * chip. The rest of the parameters must be decoded according to generic or * manufacturer-specific "extended ID" decoding patterns. */ -static void nand_decode_ext_id(struct mtd_info *mtd, struct nand_chip *chip, - u8 id_data[8]) +static void nand_decode_ext_id(struct mtd_info *mtd, struct nand_chip *chip) { int extid, id_len; /* The 3rd id byte holds MLC / multichip data */ - chip->bits_per_cell = nand_get_bits_per_cell(id_data[2]); + chip->bits_per_cell = nand_get_bits_per_cell(chip->id.data[2]); /* The 4th id byte is the important one */ - extid = id_data[3]; - - id_len = nand_id_len(id_data, 8); + extid = chip->id.data[3]; + id_len = chip->id.len;
/* * Field definitions are in the following datasheets: @@ -4180,8 +4178,8 @@ static void nand_decode_ext_id(struct mtd_info *mtd, struct nand_chip *chip, * Check for ID length, non-zero 6th byte, cell type, and Hynix/Samsung * ID to decide what to do. */ - if (id_len == 6 && id_data[0] == NAND_MFR_SAMSUNG && - !nand_is_slc(chip) && id_data[5] != 0x00) { + if (id_len == 6 && chip->id.data[0] == NAND_MFR_SAMSUNG && + !nand_is_slc(chip) && chip->id.data[5] != 0x00) { /* Calc pagesize */ mtd->writesize = 2048 << (extid & 0x03); extid >>= 2; @@ -4214,7 +4212,7 @@ static void nand_decode_ext_id(struct mtd_info *mtd, struct nand_chip *chip, /* Calc blocksize */ mtd->erasesize = (128 * 1024) << (((extid >> 1) & 0x04) | (extid & 0x03)); - } else if (id_len == 6 && id_data[0] == NAND_MFR_HYNIX && + } else if (id_len == 6 && chip->id.data[0] == NAND_MFR_HYNIX && !nand_is_slc(chip)) { unsigned int tmp;
@@ -4278,10 +4276,10 @@ static void nand_decode_ext_id(struct mtd_info *mtd, struct nand_chip *chip, * 110b -> 24nm * - ID byte 5, bit[7]: 1 -> BENAND, 0 -> raw SLC */ - if (id_len >= 6 && id_data[0] == NAND_MFR_TOSHIBA && + if (id_len >= 6 && chip->id.data[0] == NAND_MFR_TOSHIBA && nand_is_slc(chip) && - (id_data[5] & 0x7) == 0x6 /* 24nm */ && - !(id_data[4] & 0x80) /* !BENAND */) { + (chip->id.data[5] & 0x7) == 0x6 /* 24nm */ && + !(chip->id.data[4] & 0x80) /* !BENAND */) { mtd->oobsize = 32 * mtd->writesize >> 9; }
@@ -4294,9 +4292,9 @@ static void nand_decode_ext_id(struct mtd_info *mtd, struct nand_chip *chip, * the chip. */ static void nand_decode_id(struct mtd_info *mtd, struct nand_chip *chip, - struct nand_flash_dev *type, u8 id_data[8]) + struct nand_flash_dev *type) { - int maf_id = id_data[0]; + int maf_id = chip->id.data[0];
mtd->erasesize = type->erasesize; mtd->writesize = type->pagesize; @@ -4311,11 +4309,11 @@ static void nand_decode_id(struct mtd_info *mtd, struct nand_chip *chip, * listed in nand_ids table. * Data sheet (5 byte ID): Spansion S30ML-P ORNAND (p.39) */ - if (maf_id == NAND_MFR_AMD && id_data[4] != 0x00 && id_data[5] == 0x00 - && id_data[6] == 0x00 && id_data[7] == 0x00 + if (maf_id == NAND_MFR_AMD && chip->id.data[4] != 0x00 && chip->id.data[5] == 0x00 + && chip->id.data[6] == 0x00 && chip->id.data[7] == 0x00 && mtd->writesize == 512) { mtd->erasesize = 128 * 1024; - mtd->erasesize <<= ((id_data[3] & 0x03) << 1); + mtd->erasesize <<= ((chip->id.data[3] & 0x03) << 1); } }
@@ -4325,9 +4323,9 @@ static void nand_decode_id(struct mtd_info *mtd, struct nand_chip *chip, * page size, cell-type information). */ static void nand_decode_bbm_options(struct mtd_info *mtd, - struct nand_chip *chip, u8 id_data[8]) + struct nand_chip *chip) { - int maf_id = id_data[0]; + int maf_id = chip->id.data[0];
/* Set the bad block position */ if (mtd->writesize > 512 || (chip->options & NAND_BUSWIDTH_16)) @@ -4362,14 +4360,14 @@ static inline bool is_full_id_nand(struct nand_flash_dev *type) }
static bool find_full_id_nand(struct mtd_info *mtd, struct nand_chip *chip, - struct nand_flash_dev *type, u8 *id_data) + struct nand_flash_dev *type) { - if (!strncmp((char *)type->id, (char *)id_data, type->id_len)) { + if (!strncmp((char *)type->id, (char *)chip->id.data, type->id_len)) { mtd->writesize = type->pagesize; mtd->erasesize = type->erasesize; mtd->oobsize = type->oobsize;
- chip->bits_per_cell = nand_get_bits_per_cell(id_data[2]); + chip->bits_per_cell = nand_get_bits_per_cell(chip->id.data[2]); chip->chipsize = (uint64_t)type->chipsize << 20; chip->options |= type->options; chip->ecc_strength_ds = NAND_ECC_STRENGTH(type); @@ -4395,7 +4393,7 @@ struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, { int busw, ret; int maf_idx; - u8 id_data[8]; + u8 *id_data = chip->id.data;
/* * Reset the chip, required by some chips (e.g. Micron MT29FxGxxxxx) @@ -4453,9 +4451,11 @@ struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, */ chip->options &= ~NAND_BUSWIDTH_16;
+ chip->id.len = nand_id_len(id_data, ARRAY_SIZE(chip->id.data)); + for (; type->name != NULL; type++) { if (is_full_id_nand(type)) { - if (find_full_id_nand(mtd, chip, type, id_data)) + if (find_full_id_nand(mtd, chip, type)) goto ident_done; } else if (*dev_id == type->dev_id) { break; @@ -4483,9 +4483,9 @@ struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd,
if (!type->pagesize) { /* Decode parameters from extended ID */ - nand_decode_ext_id(mtd, chip, id_data); + nand_decode_ext_id(mtd, chip); } else { - nand_decode_id(mtd, chip, type, id_data); + nand_decode_id(mtd, chip, type); }
/* Get chip options */ @@ -4523,7 +4523,7 @@ ident_done: return ERR_PTR(-EINVAL); }
- nand_decode_bbm_options(mtd, chip, id_data); + nand_decode_bbm_options(mtd, chip);
/* Calculate the address shift from the page size */ chip->page_shift = ffs(mtd->writesize) - 1; diff --git a/include/linux/mtd/rawnand.h b/include/linux/mtd/rawnand.h index 3417ca2a0d..f2c6a978cb 100644 --- a/include/linux/mtd/rawnand.h +++ b/include/linux/mtd/rawnand.h @@ -507,6 +507,19 @@ static inline void nand_hw_control_init(struct nand_hw_control *nfc) init_waitqueue_head(&nfc->wq); }
+/* The maximum expected count of bytes in the NAND ID sequence */ +#define NAND_MAX_ID_LEN 8 + +/** + * struct nand_id - NAND id structure + * @data: buffer containing the id bytes. + * @len: ID length. + */ +struct nand_id { + u8 data[NAND_MAX_ID_LEN]; + int len; +}; + /** * struct nand_ecc_step_info - ECC step information of ECC engine * @stepsize: data bytes per ECC step @@ -888,6 +901,8 @@ nand_get_sdr_timings(const struct nand_data_interface *conf)
struct nand_chip { struct mtd_info mtd; + struct nand_id id; + void __iomem *IO_ADDR_R; void __iomem *IO_ADDR_W;
Michael Trimarchi
