[U-Boot] [PATCH v2 1/2] spl: spl_mmc: Clearer structure in spl_mmc_load_image and cosmetics
This refactors spl_mmc_load_image to use a switch/case structure and easier to understand spl_start_uboot checks. This also introduces some more automatic fallback on the next mmc boot mode as long as it keeps failing.
Lines that go beyond 80 chars are also reduced by reducing the number of tabs. Debug and error strings are refctored to match a common style.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- common/spl/spl_mmc.c | 124 +++++++++++++++++++++++++++++---------------------- 1 file changed, 70 insertions(+), 54 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index e580f22..d8be1f0 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -21,7 +21,7 @@ static int mmc_load_image_raw_sector(struct mmc *mmc, unsigned long sector) struct image_header *header;
header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - - sizeof(struct image_header)); + sizeof(struct image_header));
/* read image header to find the image size & load address */ err = mmc->block_dev.block_read(0, sector, 1, header); @@ -35,7 +35,7 @@ static int mmc_load_image_raw_sector(struct mmc *mmc, unsigned long sector)
/* convert size to sectors - round up */ image_size_sectors = (spl_image.size + mmc->read_bl_len - 1) / - mmc->read_bl_len; + mmc->read_bl_len;
/* Read the header too to avoid extra memcpy */ err = mmc->block_dev.block_read(0, sector, image_size_sectors, @@ -44,7 +44,7 @@ static int mmc_load_image_raw_sector(struct mmc *mmc, unsigned long sector) end: #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT if (err == 0) - printf("spl: mmc blk read err - %lu\n", err); + printf("spl: mmc block read error\n"); #endif
return (err == 0); @@ -69,33 +69,37 @@ static int mmc_load_image_raw_partition(struct mmc *mmc, int partition) #ifdef CONFIG_SPL_OS_BOOT static int mmc_load_image_raw_os(struct mmc *mmc) { - if (!mmc->block_dev.block_read(0, - CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR, - CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS, - (void *)CONFIG_SYS_SPL_ARGS_ADDR)) { + unsigned long err; + + err = mmc->block_dev.block_read(0, + CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR, + CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS, + (void *)CONFIG_SYS_SPL_ARGS_ADDR); + if (err) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - printf("mmc args blk read error\n"); + printf("spl: mmc block read error\n"); #endif return -1; }
return mmc_load_image_raw_sector(mmc, - CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR); + CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR); } #endif
void spl_mmc_load_image(void) { struct mmc *mmc; - int err; u32 boot_mode; + int err;
mmc_initialize(gd->bd); + /* We register only one device. So, the dev id is always 0 */ mmc = find_mmc_device(0); if (!mmc) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - puts("spl: mmc device not found!!\n"); + puts("spl: mmc device not found\n"); #endif hang(); } @@ -103,16 +107,22 @@ void spl_mmc_load_image(void) err = mmc_init(mmc); if (err) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - printf("spl: mmc init failed: err - %d\n", err); + printf("spl: mmc init failed with error: %d\n", err); #endif hang(); }
boot_mode = spl_boot_mode(); - if (boot_mode == MMCSD_MODE_RAW) { - debug("boot mode - RAW\n"); + switch (boot_mode) { + case MMCSD_MODE_RAW: + debug("spl: mmc boot mode: raw\n"); + #ifdef CONFIG_SPL_OS_BOOT - if (spl_start_uboot() || mmc_load_image_raw_os(mmc)) + if (!spl_start_uboot()) { + err = mmc_load_image_raw_os(mmc); + if (!err) + return; + } #endif #ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION err = mmc_load_image_raw_partition(mmc, @@ -121,34 +131,45 @@ void spl_mmc_load_image(void) err = mmc_load_image_raw_sector(mmc, CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR); #endif + if (!err) + return; #if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) - } - if (err || boot_mode == MMCSD_MODE_FS) { - debug("boot mode - FS\n"); + case MMCSD_MODE_FS: + debug("spl: mmc boot mode: fs\n"); + #ifdef CONFIG_SPL_FAT_SUPPORT #ifdef CONFIG_SPL_OS_BOOT - if (spl_start_uboot() || spl_load_image_fat_os(&mmc->block_dev, - CONFIG_SYS_MMCSD_FS_BOOT_PARTITION)) + if (!spl_start_uboot()) { + err = spl_load_image_fat_os(&mmc->block_dev, + CONFIG_SYS_MMCSD_FS_BOOT_PARTITION); + if (!err) + return; + } #endif err = spl_load_image_fat(&mmc->block_dev, - CONFIG_SYS_MMCSD_FS_BOOT_PARTITION, - CONFIG_SPL_FS_LOAD_PAYLOAD_NAME); - if(err) -#endif /* CONFIG_SPL_FAT_SUPPORT */ - { + CONFIG_SYS_MMCSD_FS_BOOT_PARTITION, + CONFIG_SPL_FS_LOAD_PAYLOAD_NAME); + if (!err) + return; +#endif #ifdef CONFIG_SPL_EXT_SUPPORT #ifdef CONFIG_SPL_OS_BOOT - if (spl_start_uboot() || spl_load_image_ext_os(&mmc->block_dev, - CONFIG_SYS_MMCSD_FS_BOOT_PARTITION)) + if (!spl_start_uboot()) { + err = spl_load_image_ext_os(&mmc->block_dev, + CONFIG_SYS_MMCSD_FS_BOOT_PARTITION)) + if (!err) + return; + } #endif err = spl_load_image_ext(&mmc->block_dev, - CONFIG_SYS_MMCSD_FS_BOOT_PARTITION, - CONFIG_SPL_FS_LOAD_PAYLOAD_NAME); -#endif /* CONFIG_SPL_EXT_SUPPORT */ - } -#endif /* defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) */ + CONFIG_SYS_MMCSD_FS_BOOT_PARTITION, + CONFIG_SPL_FS_LOAD_PAYLOAD_NAME); + if (!err) + return; +#endif +#endif #ifdef CONFIG_SUPPORT_EMMC_BOOT - } else if (boot_mode == MMCSD_MODE_EMMCBOOT) { + case MMCSD_MODE_EMMCBOOT: /* * We need to check what the partition is configured to. * 1 and 2 match up to boot0 / boot1 and 7 is user data @@ -161,36 +182,31 @@ void spl_mmc_load_image(void)
if (mmc_switch_part(0, part)) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - puts("MMC partition switch failed\n"); + puts("spl: mmc partition switch failed\n"); #endif hang(); } + #ifdef CONFIG_SPL_OS_BOOT - if (spl_start_uboot() || mmc_load_image_raw_os(mmc)) + if (!spl_start_uboot()) { + err = mmc_load_image_raw_os(mmc); + if (!err) + return; + } #endif err = mmc_load_image_raw_sector(mmc, CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR); + if (!err) + return; #endif - } - - switch(boot_mode){ - case MMCSD_MODE_RAW: -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) - case MMCSD_MODE_FS: -#endif -#ifdef CONFIG_SUPPORT_EMMC_BOOT - case MMCSD_MODE_EMMCBOOT: -#endif - /* Boot mode is ok. Nothing to do. */ - break; - case MMCSD_MODE_UNDEFINED: - default: + case MMCSD_MODE_UNDEFINED: + default: #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - puts("spl: wrong MMC boot mode\n"); + if (err) + puts("spl: mmc: no boot mode left to try\n"); + else + puts("spl: mmc: wrong boot mode\n"); #endif - hang(); - } - - if (err) hang(); + } }
This adds support for providing a partition number instead of a sector for eMMC.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- common/spl/spl_mmc.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index d8be1f0..9d8af51 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -194,8 +194,13 @@ void spl_mmc_load_image(void) return; } #endif +#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION + err = mmc_load_image_raw_partition(mmc, + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION); +#else err = mmc_load_image_raw_sector(mmc, CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR); +#endif if (!err) return; #endif
Paul Kocialkowski
