[U-Boot] [PATCH] drivers:video:s6e8ax0: change data_to_send array to static
This patch change 'data_to_send' array to static to avoid unaligned access exeption on some platforms (ex Trats2).
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com CC: Anatolij Gustschin agust@denx.de --- drivers/video/s6e8ax0.c | 26 +++++++++++++------------- 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/drivers/video/s6e8ax0.c b/drivers/video/s6e8ax0.c index 176c518..f6db694 100644 --- a/drivers/video/s6e8ax0.c +++ b/drivers/video/s6e8ax0.c @@ -29,7 +29,7 @@ static void s6e8ax0_panel_cond(struct mipi_dsim_device *dsim_dev) { struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; int reverse = dsim_dev->dsim_lcd_dev->reverse_panel; - const unsigned char data_to_send[] = { + static const unsigned char data_to_send[] = { 0xf8, 0x3d, 0x35, 0x00, 0x00, 0x00, 0x8d, 0x00, 0x4c, 0x6e, 0x10, 0x27, 0x7d, 0x3f, 0x10, 0x00, 0x00, 0x20, 0x04, 0x08, 0x6e, 0x00, 0x00, 0x00, 0x02, 0x08, 0x08, @@ -37,7 +37,7 @@ static void s6e8ax0_panel_cond(struct mipi_dsim_device *dsim_dev) 0xff, 0xff, 0xc8 };
- const unsigned char data_to_send_reverse[] = { + static const unsigned char data_to_send_reverse[] = { 0xf8, 0x19, 0x35, 0x00, 0x00, 0x00, 0x93, 0x00, 0x3c, 0x7d, 0x08, 0x27, 0x7d, 0x3f, 0x00, 0x00, 0x00, 0x20, 0x04, 0x08, 0x6e, 0x00, 0x00, 0x00, 0x02, 0x08, 0x08, @@ -58,7 +58,7 @@ static void s6e8ax0_panel_cond(struct mipi_dsim_device *dsim_dev) static void s6e8ax0_display_cond(struct mipi_dsim_device *dsim_dev) { struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - const unsigned char data_to_send[] = { + static const unsigned char data_to_send[] = { 0xf2, 0x80, 0x03, 0x0d };
@@ -71,7 +71,7 @@ static void s6e8ax0_gamma_cond(struct mipi_dsim_device *dsim_dev) { struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; /* 7500K 2.2 Set : 30cd */ - const unsigned char data_to_send[] = { + static const unsigned char data_to_send[] = { 0xfa, 0x01, 0x60, 0x10, 0x60, 0xf5, 0x00, 0xff, 0xad, 0xaf, 0xba, 0xc3, 0xd8, 0xc5, 0x9f, 0xc6, 0x9e, 0xc1, 0xdc, 0xc0, 0x00, 0x61, 0x00, 0x5a, 0x00, 0x74, @@ -92,7 +92,7 @@ static void s6e8ax0_gamma_update(struct mipi_dsim_device *dsim_dev) static void s6e8ax0_etc_source_control(struct mipi_dsim_device *dsim_dev) { struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - const unsigned char data_to_send[] = { + static const unsigned char data_to_send[] = { 0xf6, 0x00, 0x02, 0x00 };
@@ -104,7 +104,7 @@ static void s6e8ax0_etc_source_control(struct mipi_dsim_device *dsim_dev) static void s6e8ax0_etc_pentile_control(struct mipi_dsim_device *dsim_dev) { struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - const unsigned char data_to_send[] = { + static const unsigned char data_to_send[] = { 0xb6, 0x0c, 0x02, 0x03, 0x32, 0xff, 0x44, 0x44, 0xc0, 0x00 }; @@ -117,7 +117,7 @@ static void s6e8ax0_etc_pentile_control(struct mipi_dsim_device *dsim_dev) static void s6e8ax0_etc_mipi_control1(struct mipi_dsim_device *dsim_dev) { struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - const unsigned char data_to_send[] = { + static const unsigned char data_to_send[] = { 0xe1, 0x10, 0x1c, 0x17, 0x08, 0x1d };
@@ -129,7 +129,7 @@ static void s6e8ax0_etc_mipi_control1(struct mipi_dsim_device *dsim_dev) static void s6e8ax0_etc_mipi_control2(struct mipi_dsim_device *dsim_dev) { struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - const unsigned char data_to_send[] = { + static const unsigned char data_to_send[] = { 0xe2, 0xed, 0x07, 0xc3, 0x13, 0x0d, 0x03 };
@@ -141,7 +141,7 @@ static void s6e8ax0_etc_mipi_control2(struct mipi_dsim_device *dsim_dev) static void s6e8ax0_etc_power_control(struct mipi_dsim_device *dsim_dev) { struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - const unsigned char data_to_send[] = { + static const unsigned char data_to_send[] = { 0xf4, 0xcf, 0x0a, 0x12, 0x10, 0x19, 0x33, 0x02 };
@@ -159,7 +159,7 @@ static void s6e8ax0_etc_mipi_control3(struct mipi_dsim_device *dsim_dev) static void s6e8ax0_etc_mipi_control4(struct mipi_dsim_device *dsim_dev) { struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - const unsigned char data_to_send[] = { + static const unsigned char data_to_send[] = { 0xe4, 0x00, 0x00, 0x14, 0x80, 0x00, 0x00, 0x00 };
@@ -170,7 +170,7 @@ static void s6e8ax0_etc_mipi_control4(struct mipi_dsim_device *dsim_dev) static void s6e8ax0_elvss_set(struct mipi_dsim_device *dsim_dev) { struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - const unsigned char data_to_send[] = { + static const unsigned char data_to_send[] = { 0xb1, 0x04, 0x00 };
@@ -198,7 +198,7 @@ static void s6e8ax0_sleep_out(struct mipi_dsim_device *dsim_dev) static void s6e8ax0_apply_level1_key(struct mipi_dsim_device *dsim_dev) { struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - const unsigned char data_to_send[] = { + static const unsigned char data_to_send[] = { 0xf0, 0x5a, 0x5a };
@@ -209,7 +209,7 @@ static void s6e8ax0_apply_level1_key(struct mipi_dsim_device *dsim_dev) static void s6e8ax0_apply_mtp_key(struct mipi_dsim_device *dsim_dev) { struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - const unsigned char data_to_send[] = { + static const unsigned char data_to_send[] = { 0xf1, 0x5a, 0x5a };
On Fri, 24 May 2013 09:43:46 +0200 Piotr Wilczek p.wilczek@samsung.com wrote:
Applied to u-boot-video/master. Thanks!
Anatolij
Anatolij Gustschin
Piotr Wilczek
