10 Jul
2006
10 Jul
'06
2:17 p.m.
Hi, Can i strip u-boot?.
Suppose i want only the serial interface support. can i turn off other interface support?.
How do i go about doing it?.
Please Advice,
Regards, sriram
10 Jul
10 Jul
2:56 p.m.
In message 8bf247760607100517o35fdc099ucadf7b37c5693832@mail.gmail.com you wrote:
Yes. The "u-boot.bin" file is such a stripped, binary only image. Or use the ${CROSS_COMPILE}strip" command manually oin the "u-boot" ELF file.
Yes.
I take it that it may be a two-pass sort of solution.
In the first pass, RTFM.
Then adjust your board configuration.
Software Engineering: Embedded and Realtime Systems, Embedded Linux
Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
In theory, there is no difference between theory and practice. In
practice, however, there is.
6876
1 comments
2 participants
Ram
