[U-Boot] [PATCH] x86: dts: fix DTC unit name warnings
Fix following DTC warnings for all x86 boards.
There was a warning like: Warning (unit_address_vs_reg): Node /microcode/update@0 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /microcode/update@1 has a unit name, but no reg property
I replaced "udpate@" with "update_". Please test this patch
Signed-off-by: Heiko Schocher hs@denx.de --- This warnings pop up with the DTC compiler: $ /tmp/dtc/dtc -v Version: DTC 1.4.1-gbeef80b8
This fixes the compile warnings for: https://travis-ci.org/u-boot/u-boot/jobs/122880432
see: https://travis-ci.org/hsdenx/u-boot/jobs/123281030
Tested with sandbox, following steps work as before:
make sandbox_defconfig make ./u-boot -d u-boot.dtb
but "ut all" drops warnings ... but this patch introduced no new warnings ...
output of test/py : (deleted the long lines)
+make O=/home/hs/zug/travis/u-boot.git/build-sandbox -s sandbox_defconfig +make O=/home/hs/zug/travis/u-boot.git/build-sandbox -s -j8 platform linux2 -- Python 2.7.10, pytest-2.8.7, py-1.4.31, pluggy-0.3.1 rootdir: /home/hs/zug/travis/u-boot.git, inifile: collected 204 items
test/py/tests/test_000_version.py . test/py/tests/test_dfu.py s test/py/tests/test_env.py ........ test/py/tests/test_help.py . test/py/tests/test_hush_if_test.py ....................................................... test/py/tests/test_md.py .. test/py/tests/test_net.py .ssss test/py/tests/test_sandbox_exit.py .. test/py/tests/test_shell_basics.py .... test/py/tests/test_sleep.py . test/py/tests/test_ums.py s test/py/tests/test_unknown_cmd.py . test/py/tests/test_ut.py ......................................................................................F...................................
u_boot_console = <u_boot_console_sandbox.ConsoleSandbox object at 0x7f68ce2852d0>, ut_subtest = 'dm spi_flash'
def test_ut(u_boot_console, ut_subtest): """Execute a "ut" subtest."""
output = u_boot_console.run_command('ut ' + ut_subtest)
assert output.endswith('Failures: 0')
E assert <built-in method endswith of str object at 0x7f68cf10e6d0>('Failures: 0') E + where <built-in method endswith of str object at 0x7f68cf10e6d0> = 'Test: dm_test_spi_flash\r\r\n2097152 bytes written in 24 ms (83.3 MiB/s)\r\r\nSF: Detected M25P16 with page size 256 ...d_list( "sb save hostfs - 0 spi.bin 200000;" "sf probe;" "sf test 0 10000", -1, 0): Expected 0, got 1\r\r\nFailures: 1'.endswith
test/py/tests/test_ut.py:29: AssertionError
=> ut dm spi_flash Test: dm_test_spi_flash 2097152 bytes written in 24 ms (83.3 MiB/s) SF: Detected M25P16 with page size 256 Bytes, erase size 64 KiB, total 2 MiB SPI flash test: SF: Timeout! Erase failed Test failed ../test/dm/sf.c:34, dm_test_spi_flash(): 0 == run_command_list( "sb save hostfs - 0 spi.bin 200000;" "sf probe;" "sf test 0 10000", -1, 0): Expected 0, got 1 Failures: 1 =>
This error is also without this patch ... may I find time to fix it too...
arch/sandbox/dts/sandbox.dts | 30 ++++++++-------- arch/sandbox/dts/test.dts | 58 +++++++++++++++---------------- arch/x86/dts/bayleybay.dts | 22 ++++++------ arch/x86/dts/broadwell_som-6896.dts | 2 +- arch/x86/dts/chromebook_link.dts | 22 ++++++------ arch/x86/dts/chromebook_samus.dts | 30 ++++++++-------- arch/x86/dts/chromebox_panther.dts | 12 +++---- arch/x86/dts/conga-qeval20-qa3-e3845.dts | 20 +++++------ arch/x86/dts/cougarcanyon2.dts | 18 +++++----- arch/x86/dts/crownbay.dts | 8 ++--- arch/x86/dts/galileo.dts | 8 ++--- arch/x86/dts/minnowmax.dts | 30 ++++++++-------- arch/x86/dts/qemu-x86_i440fx.dts | 2 +- arch/x86/dts/qemu-x86_q35.dts | 2 +- arch/x86/dts/rtc.dtsi | 2 +- arch/x86/dts/serial.dtsi | 2 +- arch/x86/dts/skeleton.dtsi | 2 +- doc/device-tree-bindings/pmic/sandbox.txt | 2 +- drivers/misc/cros_ec.c | 6 ++-- include/sandbox-adc.h | 2 +- test/dm/bus.c | 4 +-- test/dm/eth.c | 4 +-- test/dm/gpio.c | 2 +- test/dm/pmic.c | 4 +-- test/dm/spmi.c | 2 +- test/dm/test-fdt.c | 16 ++++----- 26 files changed, 156 insertions(+), 156 deletions(-)
diff --git a/arch/sandbox/dts/sandbox.dts b/arch/sandbox/dts/sandbox.dts index 2ae4014..796de3a 100644 --- a/arch/sandbox/dts/sandbox.dts +++ b/arch/sandbox/dts/sandbox.dts @@ -34,13 +34,13 @@ #size-cells = <1>;
/* Information for sandbox */ - ro { + ro@0 { reg = <0 0xf000>; }; - wp-ro { + wp-ro@f000 { reg = <0xf000 0x1000>; }; - rw { + rw@10000 { reg = <0x10000 0x10000>; }; }; @@ -64,7 +64,7 @@ host-raw-interface = "lo"; };
- gpio_a: gpios@0 { + gpio_a: gpios_0 { gpio-controller; compatible = "sandbox,gpio"; #gpio-cells = <1>; @@ -72,7 +72,7 @@ num-gpios = <20>; };
- gpio_b: gpios@1 { + gpio_b: gpios_1 { gpio-controller; compatible = "sandbox,gpio"; #gpio-cells = <2>; @@ -111,7 +111,7 @@ compatible = "sandbox,i2c-rtc"; }; }; - sandbox_pmic: sandbox_pmic { + sandbox_pmic: sandbox_pmic@40 { reg = <0x40>; }; }; @@ -123,7 +123,7 @@ yres = <768>; };
- pci: pci-controller { + pci: pci-controller@0 { compatible = "sandbox,pci"; device_type = "pci"; #address-cells = <3>; @@ -133,7 +133,7 @@ pci@1f,0 { compatible = "pci-generic"; reg = <0xf800 0 0 0 0>; - emul@1f,0 { + emul_1f,0 { compatible = "sandbox,swap-case"; }; }; @@ -154,7 +154,7 @@ }; };
- reset@1 { + reset { compatible = "sandbox,reset"; };
@@ -203,21 +203,21 @@ pinctrl-0 = <&pinctrl_serial0>; };
- usb@0 { + usb0 { compatible = "sandbox,usb"; status = "disabled"; hub { compatible = "sandbox,usb-hub"; #address-cells = <1>; #size-cells = <0>; - flash-stick { + flash-stick@0 { reg = <0>; compatible = "sandbox,usb-flash"; }; }; };
- usb@1 { + usb1 { compatible = "sandbox,usb"; hub { compatible = "usb-hub"; @@ -226,7 +226,7 @@ compatible = "sandbox,usb-hub"; #address-cells = <1>; #size-cells = <0>; - flash-stick { + flash-stick@0 { reg = <0>; compatible = "sandbox,usb-flash"; sandbox,filepath = "flash.bin"; @@ -235,12 +235,12 @@ }; };
- usb@2 { + usb2 { compatible = "sandbox,usb"; status = "disabled"; };
- spmi: spmi@0 { + spmi: spmi0 { compatible = "sandbox,spmi"; #address-cells = <0x1>; #size-cells = <0x1>; diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 8930009..9c4e6e2 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -18,19 +18,19 @@ rtc0 = &rtc_0; rtc1 = &rtc_1; spi0 = "/spi@0"; - testfdt6 = "/e-test"; - testbus3 = "/some-bus"; - testfdt0 = "/some-bus/c-test@0"; - testfdt1 = "/some-bus/c-test@1"; - testfdt3 = "/b-test"; - testfdt5 = "/some-bus/c-test@5"; - testfdt8 = "/a-test"; + testfdt6 = "/e-test@3"; + testbus3 = "/some-bus@3"; + testfdt0 = "/some-bus@3/c-test@0"; + testfdt1 = "/some-bus@3/c-test@1"; + testfdt3 = "/b-test@3"; + testfdt5 = "/some-bus@3/c-test@5"; + testfdt8 = "/a-test@0"; usb0 = &usb_0; usb1 = &usb_1; usb2 = &usb_2; };
- a-test { + a-test@0 { reg = <0 1>; compatible = "denx,u-boot-fdt-test"; ping-expect = <0>; @@ -43,23 +43,23 @@ <&gpio_b 9 0xc 3 2 1>; };
- junk { + junk@1 { reg = <1 1>; compatible = "not,compatible"; };
- no-compatible { + no-compatible@2 { reg = <2 1>; };
- b-test { + b-test@3 { reg = <3 1>; compatible = "denx,u-boot-fdt-test"; ping-expect = <3>; ping-add = <3>; };
- some-bus { + some-bus@3 { #address-cells = <1>; #size-cells = <0>; compatible = "denx,u-boot-test-bus"; @@ -86,14 +86,14 @@ }; };
- d-test { + d-test@3 { reg = <3 1>; ping-expect = <6>; ping-add = <6>; compatible = "google,another-fdt-test"; };
- e-test { + e-test@3 { reg = <3 1>; ping-expect = <6>; ping-add = <6>; @@ -108,7 +108,7 @@ compatible = "denx,u-boot-fdt-test"; };
- clk@0 { + clk { compatible = "sandbox,clk"; };
@@ -124,7 +124,7 @@ fake-host-hwaddr = <0x00 0x00 0x66 0x44 0x22 0x11>; };
- eth_3: sbe5 { + eth_3: sbe5@10005000 { compatible = "sandbox,eth"; reg = <0x10005000 0x1000>; fake-host-hwaddr = <0x00 0x00 0x66 0x44 0x22 0x33>; @@ -184,12 +184,12 @@ }; };
- adc@0 { + adc { compatible = "sandbox,adc"; vdd-supply = <&buck2>; vss-microvolts = <0>; @@ -220,7 +220,7 @@ compatible = "sandbox,mmc"; };
- pci: pci-controller { + pci: pci-controller@0 { compatible = "sandbox,pci"; device_type = "pci"; #address-cells = <3>; @@ -230,7 +230,7 @@ pci@1f,0 { compatible = "pci-generic"; reg = <0xf800 0 0 0 0>; - emul@1f,0 { + emul_1f,0 { compatible = "sandbox,swap-case"; }; }; @@ -240,20 +240,20 @@ compatible = "sandbox,ram"; };
- reset@0 { + reset0 { compatible = "sandbox,warm-reset"; };
- reset@1 { + reset1 { compatible = "sandbox,reset"; };
- rproc_1: rproc@1 { + rproc_1: rproc1 { compatible = "sandbox,test-processor"; remoteproc-name = "remoteproc-test-dev1"; };
- rproc_2: rproc@2 { + rproc_2: rproc2 { compatible = "sandbox,test-processor"; internal-memory-mapped; remoteproc-name = "remoteproc-test-dev2"; @@ -296,21 +296,21 @@ u-boot,dm-pre-reloc; };
- usb_0: usb@0 { + usb_0: usb0 { compatible = "sandbox,usb"; status = "disabled"; hub { compatible = "sandbox,usb-hub"; #address-cells = <1>; #size-cells = <0>; - flash-stick { + flash-stick@0 { reg = <0>; compatible = "sandbox,usb-flash"; }; }; };
- usb_1: usb@1 { + usb_1: usb1 { compatible = "sandbox,usb"; hub { compatible = "usb-hub"; @@ -346,12 +346,12 @@ }; };
- usb_2: usb@2 { + usb_2: usb2 { compatible = "sandbox,usb"; status = "disabled"; };
- spmi: spmi@0 { + spmi: spmi0 { compatible = "sandbox,spmi"; #address-cells = <0x1>; #size-cells = <0x1>; diff --git a/arch/x86/dts/bayleybay.dts b/arch/x86/dts/bayleybay.dts index 4ea9262..207e7e0 100644 --- a/arch/x86/dts/bayleybay.dts +++ b/arch/x86/dts/bayleybay.dts @@ -65,7 +65,7 @@ }; };
- pci { + pci@0 { compatible = "pci-x86"; #address-cells = <3>; #size-cells = <2>; @@ -155,49 +155,49 @@ compatible = "winbond,w25q64dw", "spi-flash"; memory-map = <0xff800000 0x00800000>; - rw-mrc-cache { + rw-mrc-cache@6e0000 { label = "rw-mrc-cache"; reg = <0x006e0000 0x00010000>; }; }; };
- gpioa { + gpioa@0 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0 0x20>; bank-name = "A"; };
- gpiob { + gpiob@20 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0x20 0x20>; bank-name = "B"; };
- gpioc { + gpioc@40 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0x40 0x20>; bank-name = "C"; };
- gpiod { + gpiod@60 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0x60 0x20>; bank-name = "D"; };
- gpioe { + gpioe@80 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0x80 0x20>; bank-name = "E"; };
- gpiof { + gpiof@a0 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0xA0 0x20>; @@ -245,13 +245,13 @@ };
microcode { - update@0 { + update_0 { #include "microcode/m0230671117.dtsi" }; - update@1 { + update_1 { #include "microcode/m0130673322.dtsi" }; - update@2 { + update_2 { #include "microcode/m0130679901.dtsi" }; }; diff --git a/arch/x86/dts/broadwell_som-6896.dts b/arch/x86/dts/broadwell_som-6896.dts index 4bb0a34..674d09a 100644 --- a/arch/x86/dts/broadwell_som-6896.dts +++ b/arch/x86/dts/broadwell_som-6896.dts @@ -21,7 +21,7 @@ stdout-path = "/serial"; };
- pci { + pci@0 { compatible = "pci-x86"; #address-cells = <3>; #size-cells = <2>; diff --git a/arch/x86/dts/chromebook_link.dts b/arch/x86/dts/chromebook_link.dts index fb1b31d..41aae38 100644 --- a/arch/x86/dts/chromebook_link.dts +++ b/arch/x86/dts/chromebook_link.dts @@ -64,7 +64,7 @@ intel,duplicate-por; };
- pch_pinctrl { + pch_pinctrl@0 { compatible = "intel,x86-pinctrl"; u-boot,dm-pre-reloc; reg = <0 0>; @@ -217,7 +217,7 @@
- pci { + pci@0 { compatible = "pci-x86"; #address-cells = <3>; #size-cells = <2>; @@ -235,7 +235,7 @@ spd { #address-cells = <1>; #size-cells = <0>; - elpida_4Gb_1600_x16 { + elpida_4Gb_1600_x16@0 { reg = <0>; data = [92 10 0b 03 04 19 02 02 03 52 01 08 0a 00 fe 00 @@ -270,7 +270,7 @@ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00]; }; - samsung_4Gb_1600_1.35v_x16 { + samsung_4Gb_1600_1.35v_x16@1 { reg = <1>; data = [92 11 0b 03 04 19 02 02 03 11 01 08 0a 00 fe 00 @@ -305,7 +305,7 @@ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00]; }; - micron_4Gb_1600_1.35v_x16 { + micron_4Gb_1600_1.35v_x16@2 { reg = <2>; data = [92 11 0b 03 04 19 02 02 03 11 01 08 0a 00 fe 00 @@ -397,14 +397,14 @@ compatible = "winbond,w25q64", "spi-flash"; memory-map = <0xff800000 0x00800000>; - rw-mrc-cache { + rw-mrc-cache@3e0000 { label = "rw-mrc-cache"; reg = <0x003e0000 0x00010000>; }; }; };
- gpio_a: gpioa { + gpio_a: gpioa@0 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; #gpio-cells = <2>; @@ -413,7 +413,7 @@ bank-name = "A"; };
- gpio_b: gpiob { + gpio_b: gpiob@30 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; #gpio-cells = <2>; @@ -422,7 +422,7 @@ bank-name = "B"; };
- gpio_c: gpioc { + gpio_c: gpioc@40 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; #gpio-cells = <2>; @@ -471,13 +471,13 @@ }; };
- tpm { + tpm@fed40000 { reg = <0xfed40000 0x5000>; compatible = "infineon,slb9635lpc"; };
microcode { - update@0 { + update_1 { #include "microcode/m12306a9_0000001b.dtsi" }; }; diff --git a/arch/x86/dts/chromebook_samus.dts b/arch/x86/dts/chromebook_samus.dts index 5dd3e57..103e26f 100644 --- a/arch/x86/dts/chromebook_samus.dts +++ b/arch/x86/dts/chromebook_samus.dts @@ -65,7 +65,7 @@ intel,duplicate-por; };
- pch_pinctrl { + pch_pinctrl@0 { compatible = "intel,x86-broadwell-pinctrl"; u-boot,dm-pre-reloc; reg = <0 0>; @@ -131,7 +131,7 @@ pirq-apic = <PIRQ_APIC_ROUTE>; };
- soc_gpio@0 { + soc_gpio { config = <0 &gpio_unused 0>, /* unused */ <1 &gpio_unused 0>, /* unused */ @@ -231,7 +231,7 @@ }; };
- pci { + pci@0 { compatible = "pci-x86"; #address-cells = <3>; #size-cells = <2>; @@ -249,7 +249,7 @@ spd { #address-cells = <1>; #size-cells = <0>; - samsung_4 { + samsung_4@6 { reg = <6>; data = [91 20 f1 03 04 11 05 0b 03 11 01 08 0a 00 50 01 @@ -284,7 +284,7 @@ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00]; }; - hynix-h9ccnnnbltmlar-ntm-lpddr3-32 { + hynix-h9ccnnnbltmlar-ntm-lpddr3-32@8 { /* * banks 8, ranks 2, rows 14, * columns 10, density 4096 mb, x32 @@ -323,7 +323,7 @@ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00]; }; - samsung_8 { + samsung_8@10 { reg = <10>; data = [91 20 f1 03 04 12 05 0a 03 11 01 08 0a 00 50 01 @@ -358,7 +358,7 @@ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00]; }; - hynix-h9ccnnnbltmlar-ntm-lpddr3-16 { + hynix-h9ccnnnbltmlar-ntm-lpddr3-16@12 { /* * banks 8, ranks 2, rows 14, * columns 11, density 4096 mb, x16 @@ -397,7 +397,7 @@ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00]; }; - hynix-h9ccnnncltmlar-lpddr3 { + hynix-h9ccnnncltmlar-lpddr3@13 { /* * banks 8, ranks 2, rows 15, * columns 11, density 8192 mb, x16 @@ -436,7 +436,7 @@ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00]; }; - elpida-edfb232a1ma { + elpida-edfb232a1ma@15 { /* * banks 8, ranks 2, rows 15, * columns 11, density 8192 mb, x16 @@ -539,14 +539,14 @@ compatible = "winbond,w25q64", "spi-flash"; memory-map = <0xff800000 0x00800000>; - rw-mrc-cache { + rw-mrc-cache@3e0000 { label = "rw-mrc-cache"; reg = <0x003e0000 0x00010000>; }; }; };
- gpio_a: gpioa { + gpio_a: gpioa@0 { compatible = "intel,broadwell-gpio"; u-boot,dm-pre-reloc; #gpio-cells = <2>; @@ -555,7 +555,7 @@ bank-name = "A"; };
- gpio_b: gpiob { + gpio_b: gpiob@1 { compatible = "intel,broadwell-gpio"; u-boot,dm-pre-reloc; #gpio-cells = <2>; @@ -564,7 +564,7 @@ bank-name = "B"; };
- gpio_c: gpioc { + gpio_c: gpioc@2 { compatible = "intel,broadwell-gpio"; u-boot,dm-pre-reloc; #gpio-cells = <2>; @@ -614,13 +614,13 @@ }; };
microcode { - update@0 { + update_1 { #include "microcode/mc0306d4_00000018.dtsi" }; }; diff --git a/arch/x86/dts/chromebox_panther.dts b/arch/x86/dts/chromebox_panther.dts index 480b366..4f88778 100644 --- a/arch/x86/dts/chromebox_panther.dts +++ b/arch/x86/dts/chromebox_panther.dts @@ -22,7 +22,7 @@ stdout-path = "/serial"; };
- pci { + pci@0 { compatible = "pci-x86"; #address-cells = <3>; #size-cells = <2>; @@ -48,28 +48,28 @@ compatible = "winbond,w25q64", "spi-flash"; memory-map = <0xff800000 0x00800000>; - rw-mrc-cache { + rw-mrc-cache@3e0000 { label = "rw-mrc-cache"; reg = <0x003e0000 0x00010000>; }; }; };
- gpioa { + gpioa@0 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0 0x10>; bank-name = "A"; };
- gpiob { + gpiob@30 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0x30 0x10>; bank-name = "B"; };
- gpioc { + gpioc@40 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0x40 0x10>; @@ -78,7 +78,7 @@ }; };
- tpm { + tpm@fed40000 { reg = <0xfed40000 0x5000>; compatible = "infineon,slb9635lpc"; }; diff --git a/arch/x86/dts/conga-qeval20-qa3-e3845.dts b/arch/x86/dts/conga-qeval20-qa3-e3845.dts index 478dece..e0da067 100644 --- a/arch/x86/dts/conga-qeval20-qa3-e3845.dts +++ b/arch/x86/dts/conga-qeval20-qa3-e3845.dts @@ -69,7 +69,7 @@ }; };
- pci { + pci@0 { compatible = "intel,pci-baytrail", "pci-x86"; #address-cells = <3>; #size-cells = <2>; @@ -159,49 +159,49 @@ compatible = "stmicro,n25q064a", "spi-flash"; memory-map = <0xff800000 0x00800000>; - rw-mrc-cache { + rw-mrc-cache@6f0000 { label = "rw-mrc-cache"; reg = <0x006f0000 0x00010000>; }; }; };
- gpiof { + gpiof@a0 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0xA0 0x20>; @@ -268,10 +268,10 @@ };
microcode { - update@0 { + update_0 { #include "microcode/m0130673322.dtsi" }; - update@1 { + update_1 { #include "microcode/m0130679901.dtsi" }; }; diff --git a/arch/x86/dts/cougarcanyon2.dts b/arch/x86/dts/cougarcanyon2.dts index d415566..b2637b8 100644 --- a/arch/x86/dts/cougarcanyon2.dts +++ b/arch/x86/dts/cougarcanyon2.dts @@ -29,19 +29,19 @@ };
microcode { - update@0 { + update_0 { #include "microcode/m12306a2_00000008.dtsi" }; - update@1 { + update_1 { #include "microcode/m12306a4_00000007.dtsi" }; - update@2 { + update_2 { #include "microcode/m12306a5_00000007.dtsi" }; - update@3 { + update_3 { #include "microcode/m12306a8_00000010.dtsi" }; - update@4 { + update_4 { #include "microcode/m12306a9_0000001b.dtsi" }; }; @@ -51,7 +51,7 @@ fsp,enable-ht; };
- pci { + pci@0 { #address-cells = <3>; #size-cells = <2>; compatible = "pci-x86"; @@ -78,21 +78,21 @@ }; };
- gpioa { + gpioa@10 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0 0x10>; bank-name = "A"; };
- gpioc { + gpioc@40 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0x40 0x10>; diff --git a/arch/x86/dts/crownbay.dts b/arch/x86/dts/crownbay.dts index 337513b..4cd9b4d 100644 --- a/arch/x86/dts/crownbay.dts +++ b/arch/x86/dts/crownbay.dts @@ -59,12 +59,12 @@ };
microcode { - update@0 { + update_0 { #include "microcode/m0220661105_cv.dtsi" }; };
- pci { + pci@0 { #address-cells = <3>; #size-cells = <2>; compatible = "pci-x86"; @@ -227,14 +227,14 @@ }; };
- gpiob { + gpiob@20 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0x20 0x20>; diff --git a/arch/x86/dts/galileo.dts b/arch/x86/dts/galileo.dts index 21c3641..f2cd456 100644 --- a/arch/x86/dts/galileo.dts +++ b/arch/x86/dts/galileo.dts @@ -56,7 +56,7 @@ dram-faw = <0x00009c40>; };
- pci { + pci@0 { #address-cells = <3>; #size-cells = <2>; compatible = "pci-x86"; @@ -128,21 +128,21 @@ compatible = "winbond,w25q64", "spi-flash"; memory-map = <0xff800000 0x00800000>; - rw-mrc-cache { + rw-mrc-cache@10000 { label = "rw-mrc-cache"; reg = <0x00010000 0x00010000>; }; }; };
- gpiob { + gpiob@20 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0x20 0x20>; diff --git a/arch/x86/dts/minnowmax.dts b/arch/x86/dts/minnowmax.dts index 60bd05a..37ab8ae 100644 --- a/arch/x86/dts/minnowmax.dts +++ b/arch/x86/dts/minnowmax.dts @@ -31,7 +31,7 @@ compatible = "intel,x86-pinctrl";
/* GPIO E0 */ - soc_gpio_s5_0@0 { + soc_gpio_s5_0 { gpio-offset = <0x80 0>; pad-offset = <0x1d0>; mode-gpio; @@ -40,7 +40,7 @@ };
/* GPIO E1 */ - soc_gpio_s5_1@0 { + soc_gpio_s5_1 { gpio-offset = <0x80 1>; pad-offset = <0x210>; mode-gpio; @@ -49,7 +49,7 @@ };
/* GPIO E2 */ - soc_gpio_s5_2@0 { + soc_gpio_s5_2 { gpio-offset = <0x80 2>; pad-offset = <0x1e0>; mode-gpio; @@ -57,7 +57,7 @@ direction = <PIN_OUTPUT>; };
- pin_usb_host_en0@0 { + pin_usb_host_en0 { gpio-offset = <0x80 8>; pad-offset = <0x260>; mode-gpio; @@ -65,7 +65,7 @@ direction = <PIN_OUTPUT>; };
- pin_usb_host_en1@0 { + pin_usb_host_en1 { gpio-offset = <0x80 9>; pad-offset = <0x250>; mode-gpio; @@ -98,7 +98,7 @@
- pci { + pci@0 { compatible = "intel,pci-baytrail", "pci-x86"; #address-cells = <3>; #size-cells = <2>; @@ -188,49 +188,49 @@ compatible = "stmicro,n25q064a", "spi-flash"; memory-map = <0xff800000 0x00800000>; - rw-mrc-cache { + rw-mrc-cache@6f0000 { label = "rw-mrc-cache"; reg = <0x006f0000 0x00010000>; }; }; };
- gpiof { + gpiof@a0 { compatible = "intel,ich6-gpio"; u-boot,dm-pre-reloc; reg = <0xA0 0x20>; @@ -296,10 +296,10 @@ };
microcode { - update@0 { + update_0 { #include "microcode/m0130673322.dtsi" }; - update@1 { + update_1 { #include "microcode/m0130679901.dtsi" }; }; diff --git a/arch/x86/dts/qemu-x86_i440fx.dts b/arch/x86/dts/qemu-x86_i440fx.dts index 9c3f2a0..3d81e9d 100644 --- a/arch/x86/dts/qemu-x86_i440fx.dts +++ b/arch/x86/dts/qemu-x86_i440fx.dts @@ -42,7 +42,7 @@ clock-frequency = <1000000000>; };
- pci { + pci@0 { compatible = "pci-x86"; #address-cells = <3>; #size-cells = <2>; diff --git a/arch/x86/dts/qemu-x86_q35.dts b/arch/x86/dts/qemu-x86_q35.dts index 5d601b3..931c258 100644 --- a/arch/x86/dts/qemu-x86_q35.dts +++ b/arch/x86/dts/qemu-x86_q35.dts @@ -53,7 +53,7 @@ clock-frequency = <1000000000>; };
- pci { + pci@0 { compatible = "pci-x86"; #address-cells = <3>; #size-cells = <2>; diff --git a/arch/x86/dts/rtc.dtsi b/arch/x86/dts/rtc.dtsi index 1797e04..9b09d7e 100644 --- a/arch/x86/dts/rtc.dtsi +++ b/arch/x86/dts/rtc.dtsi @@ -1,5 +1,5 @@ / { - rtc { + rtc@70 { compatible = "motorola,mc146818"; u-boot,dm-pre-reloc; reg = <0x70 2>; diff --git a/arch/x86/dts/serial.dtsi b/arch/x86/dts/serial.dtsi index 54c3faf..02be132 100644 --- a/arch/x86/dts/serial.dtsi +++ b/arch/x86/dts/serial.dtsi @@ -1,5 +1,5 @@ / { - serial: serial { + serial: serial@3f8 { compatible = "ns16550"; reg = <0x3f8 8>; reg-shift = <0>; diff --git a/arch/x86/dts/skeleton.dtsi b/arch/x86/dts/skeleton.dtsi index b41d241..a20da0a 100644 --- a/arch/x86/dts/skeleton.dtsi +++ b/arch/x86/dts/skeleton.dtsi @@ -9,5 +9,5 @@ #size-cells = <1>; chosen { }; aliases { }; - memory { device_type = "memory"; reg = <0 0>; }; + memory@0 { device_type = "memory"; reg = <0 0>; }; }; diff --git a/doc/device-tree-bindings/pmic/sandbox.txt b/doc/device-tree-bindings/pmic/sandbox.txt index d84c977..c1bef4c 100644 --- a/doc/device-tree-bindings/pmic/sandbox.txt +++ b/doc/device-tree-bindings/pmic/sandbox.txt @@ -24,7 +24,7 @@ Optional subnodes:
Example:
-sandbox_pmic { +sandbox_pmic@40 { compatible = "sandbox,pmic"; reg = <0x40>;
diff --git a/drivers/misc/cros_ec.c b/drivers/misc/cros_ec.c index e3229ef..e3e2835 100644 --- a/drivers/misc/cros_ec.c +++ b/drivers/misc/cros_ec.c @@ -1038,11 +1038,11 @@ int cros_ec_decode_ec_flash(const void *blob, int node, const char *name = fdt_get_name(blob, node, NULL); enum ec_flash_region region;
- if (0 == strcmp(name, "ro")) { + if (0 == strcmp(name, "ro@0")) { region = EC_FLASH_REGION_RO; - } else if (0 == strcmp(name, "rw")) { + } else if (0 == strcmp(name, "rw@10000")) { region = EC_FLASH_REGION_RW; - } else if (0 == strcmp(name, "wp-ro")) { + } else if (0 == strcmp(name, "wp-ro@f000")) { region = EC_FLASH_REGION_WP_RO; } else { debug("Unknown EC flash region name '%s'\n", name); diff --git a/include/sandbox-adc.h b/include/sandbox-adc.h index 79ff01c..bfc9ce8 100644 --- a/include/sandbox-adc.h +++ b/include/sandbox-adc.h @@ -8,7 +8,7 @@ #ifndef _SANDBOX_ADC_H_ #define _SANDBOX_ADC_H_
-#define SANDBOX_ADC_DEVNAME "adc@0" +#define SANDBOX_ADC_DEVNAME "adc" #define SANDBOX_ADC_DATA_MASK 0xffff /* 16-bits resolution */ #define SANDBOX_ADC_CHANNELS 4 #define SANDBOX_ADC_CHANNEL0_DATA 0x0 diff --git a/test/dm/bus.c b/test/dm/bus.c index 3b5a23b..9e97629 100644 --- a/test/dm/bus.c +++ b/test/dm/bus.c @@ -156,9 +156,9 @@ static int dm_test_bus_children_funcs(struct unit_test_state *uts) ut_asserteq(-ENODEV, device_get_child_by_seq(bus, 2, &dev));
/* Looking for something that is not a child */ - node = fdt_path_offset(blob, "/junk"); + node = fdt_path_offset(blob, "/junk@1"); ut_asserteq(-ENODEV, device_find_child_by_of_offset(bus, node, &dev)); - node = fdt_path_offset(blob, "/d-test"); + node = fdt_path_offset(blob, "/d-test@3"); ut_asserteq(-ENODEV, device_find_child_by_of_offset(bus, node, &dev));
/* Find a valid child */ diff --git a/test/dm/eth.c b/test/dm/eth.c index 6288ae2..ec68a54 100644 --- a/test/dm/eth.c +++ b/test/dm/eth.c @@ -171,9 +171,9 @@ static int _dm_test_eth_rotate2(struct unit_test_state *uts) ut_asserteq_str("eth@10004000", getenv("ethact"));
/* Make sure we can handle device name which is not eth# */ - setenv("ethact", "sbe5"); + setenv("ethact", "sbe5@10005000"); ut_assertok(net_loop(PING)); - ut_asserteq_str("sbe5", getenv("ethact")); + ut_asserteq_str("sbe5@10005000", getenv("ethact"));
return 0; } diff --git a/test/dm/gpio.c b/test/dm/gpio.c index 727db18..437fc27 100644 --- a/test/dm/gpio.c +++ b/test/dm/gpio.c @@ -183,7 +183,7 @@ static int dm_test_gpio_phandles(struct unit_test_state *uts) struct udevice *dev, *gpio_a, *gpio_b;
ut_assertok(uclass_get_device(UCLASS_TEST_FDT, 0, &dev)); - ut_asserteq_str("a-test", dev->name); + ut_asserteq_str("a-test@0", dev->name);
ut_assertok(gpio_request_by_name(dev, "test-gpios", 1, &desc, 0)); ut_assertok(uclass_get_device(UCLASS_GPIO, 1, &gpio_a)); diff --git a/test/dm/pmic.c b/test/dm/pmic.c index 422ea3e..bd652c6 100644 --- a/test/dm/pmic.c +++ b/test/dm/pmic.c @@ -26,7 +26,7 @@ DECLARE_GLOBAL_DATA_PTR; /* Test PMIC get method */ static int dm_test_power_pmic_get(struct unit_test_state *uts) { - const char *name = "sandbox_pmic"; + const char *name = "sandbox_pmic@40"; struct udevice *dev;
ut_assertok(pmic_get(name, &dev)); @@ -42,7 +42,7 @@ DM_TEST(dm_test_power_pmic_get, DM_TESTF_SCAN_FDT); /* Test PMIC I/O */ static int dm_test_power_pmic_io(struct unit_test_state *uts) { - const char *name = "sandbox_pmic"; + const char *name = "sandbox_pmic@40"; uint8_t out_buffer, in_buffer; struct udevice *dev; int reg_count, i; diff --git a/test/dm/spmi.c b/test/dm/spmi.c index d519a90..f5693e8 100644 --- a/test/dm/spmi.c +++ b/test/dm/spmi.c @@ -21,7 +21,7 @@ DECLARE_GLOBAL_DATA_PTR; /* Test if bus childs got probed propperly*/ static int dm_test_spmi_probe(struct unit_test_state *uts) { - const char *name = "spmi@0"; + const char *name = "spmi0"; struct udevice *bus, *dev;
ut_assertok(uclass_get_device(UCLASS_SPMI, 0, &bus)); diff --git a/test/dm/test-fdt.c b/test/dm/test-fdt.c index 49a36cb..32a2b1d 100644 --- a/test/dm/test-fdt.c +++ b/test/dm/test-fdt.c @@ -190,10 +190,10 @@ static int dm_test_fdt_uclass_seq(struct unit_test_state *uts)
/* A few basic santiy tests */ ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_FDT, 3, true, &dev)); - ut_asserteq_str("b-test", dev->name); + ut_asserteq_str("b-test@3", dev->name);
ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_FDT, 8, true, &dev)); - ut_asserteq_str("a-test", dev->name); + ut_asserteq_str("a-test@0", dev->name);
ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 5, true, &dev)); @@ -201,7 +201,7 @@ static int dm_test_fdt_uclass_seq(struct unit_test_state *uts)
/* Test aliases */ ut_assertok(uclass_get_device_by_seq(UCLASS_TEST_FDT, 6, &dev)); - ut_asserteq_str("e-test", dev->name); + ut_asserteq_str("e-test@3", dev->name);
ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 7, true, &dev)); @@ -211,18 +211,18 @@ static int dm_test_fdt_uclass_seq(struct unit_test_state *uts) * node */ ut_assertok(uclass_get_device_by_seq(UCLASS_TEST_FDT, 3, &dev)); - ut_asserteq_str("b-test", dev->name); + ut_asserteq_str("b-test@3", dev->name);
/* * d-test wants sequence number 3 also, but it can't have it because * b-test gets it first. */ ut_assertok(uclass_get_device(UCLASS_TEST_FDT, 2, &dev)); - ut_asserteq_str("d-test", dev->name); + ut_asserteq_str("d-test@3", dev->name);
/* d-test actually gets 0 */ ut_assertok(uclass_get_device_by_seq(UCLASS_TEST_FDT, 0, &dev)); - ut_asserteq_str("d-test", dev->name); + ut_asserteq_str("d-test@3", dev->name);
/* initially no one wants seq 1 */ ut_asserteq(-ENODEV, uclass_get_device_by_seq(UCLASS_TEST_FDT, 1, @@ -245,11 +245,11 @@ static int dm_test_fdt_offset(struct unit_test_state *uts) struct udevice *dev; int node;
- node = fdt_path_offset(blob, "/e-test"); + node = fdt_path_offset(blob, "/e-test@3"); ut_assert(node > 0); ut_assertok(uclass_get_device_by_of_offset(UCLASS_TEST_FDT, node, &dev)); - ut_asserteq_str("e-test", dev->name); + ut_asserteq_str("e-test@3", dev->name);
/* This node should not be bound */ node = fdt_path_offset(blob, "/junk");
Hi Heiko,
def test_ut(u_boot_console, ut_subtest): """Execute a "ut" subtest.""" output = u_boot_console.run_command('ut ' + ut_subtest)
ro {
wp-ro {
rw {
gpio_a: gpios@0 {
gpio_b: gpios@1 {
emul@1f,0 {
reset@1 {
usb@0 {
flash-stick {
usb@1 {
flash-stick {
usb@2 {
spmi: spmi@0 {
a-test {
junk {
no-compatible {
b-test {
some-bus {
d-test {
e-test {
clk@0 {
eth_3: sbe5 {
adc@0 {
emul@1f,0 {
reset@0 {
reset@1 {
rproc_1: rproc@1 {
rproc_2: rproc@2 {
usb_0: usb@0 {
flash-stick {
usb_1: usb@1 {
usb_2: usb@2 {
spmi: spmi@0 {
pci {
rw-mrc-cache {
gpioa {
gpioa@0 {
What about just gpio@0?
gpiob {
gpiob@20 {
and gpio@20?
gpioc {
gpiod {
gpioe {
gpiof {
microcode {
update@0 {
update_0 {
update0?
update@1 {
update_1 {
update@2 {
update_2 {
pci {
pch_pinctrl {
@@ -217,7 +217,7 @@
pci {
rw-mrc-cache {
gpio_a: gpioa {
gpio_a: gpioa@0 {
ditto
gpio_b: gpiob {
gpio_c: gpioc {
tpm {
tpm@fed40000 { reg = <0xfed40000 0x5000>; compatible = "infineon,slb9635lpc"; }; microcode {
update@0 {
update_1 {
This should be update0.
pch_pinctrl {
soc_gpio@0 {
pci {
samsung_4 {
samsung_8 {
rw-mrc-cache {
gpio_a: gpioa {
gpio_b: gpiob {
gpio_c: gpioc {
tpm {
update@0 {
update_1 {
pci {
rw-mrc-cache {
gpioa {
gpiob {
gpioc {
tpm {
pci {
rw-mrc-cache {
gpioa {
gpiob {
gpioc {
gpiod {
gpioe {
gpiof {
microcode {
update@0 {
update_0 {
update@1 {
update_1 {
microcode {
update@0 {
update_0 {
update@1 {
update_1 {
update@2 {
update_2 {
update@3 {
update_3 {
update@4 {
update_4 {
pci {
gpioa {
gpiob {
gpioc {
microcode {
update@0 {
update_0 {
pci {
gpioa {
gpiob {
pci {
rw-mrc-cache {
gpioa {
gpiob {
/* GPIO E0 */
soc_gpio_s5_0@0 {
/* GPIO E1 */
soc_gpio_s5_1@0 {
/* GPIO E2 */
soc_gpio_s5_2@0 {
@@ -98,7 +98,7 @@
pci {
rw-mrc-cache {
gpioa {
gpiob {
gpioc {
gpiod {
gpioe {
gpiof {
microcode {
update@0 {
update_0 {
update@1 {
update_1 {
pci {
pci {
rtc {
serial: serial {
Example:
[snip]
Regards, Bin
Hello Bin
Am 18.04.2016 um 04:21 schrieb Bin Meng:
Hi Heiko,
rw-mrc-cache {
gpioa {
gpioa@0 {
I just added the missing @offset ... I am fine renaming it also from gpioa to just gpio ...
gpiob {
gpiob@20 {
and gpio@20?
I am fine with it ...
gpioc {
gpiod {
gpioe {
gpiof {
microcode {
update@0 {
update_0 {
update0?
Ok.
update@1 {
#include "microcode/m0130673322.dtsi" };update_1 {
update@2 {
#include "microcode/m0130679901.dtsi" }; };update_2 {
pci {
pch_pinctrl {
@@ -217,7 +217,7 @@
pci {
rw-mrc-cache {
gpio_a: gpioa {
gpio_a: gpioa@0 {
ditto
Yes, we should solve this in a common way ... could you test my changes on a hw? But what is with the reference "gpio_a" ?
gpio_b: gpiob {
gpio_c: gpioc {
tpm {
update@0 {
update_1 {
Oh, typo, thanks.
pch_pinctrl {
soc_gpio@0 {
pci {
samsung_4 {
samsung_8 {
rw-mrc-cache {
gpio_a: gpioa {
gpio_b: gpiob {
gpio_c: gpioc {
tpm {
update@0 {
update_1 {
pci {
rw-mrc-cache {
gpioa {
gpiob {
gpioc {
tpm {
pci {
rw-mrc-cache {
gpioa {
gpiob {
gpioc {
gpiod {
gpioe {
gpiof {
microcode {
update@0 {
#include "microcode/m0130673322.dtsi" };update_0 {
update@1 {
#include "microcode/m0130679901.dtsi" }; };update_1 {
microcode {
update@0 {
#include "microcode/m12306a2_00000008.dtsi" };update_0 {
update@1 {
#include "microcode/m12306a4_00000007.dtsi" };update_1 {
update@2 {
#include "microcode/m12306a5_00000007.dtsi" };update_2 {
update@3 {
#include "microcode/m12306a8_00000010.dtsi" };update_3 {
update@4 {
#include "microcode/m12306a9_0000001b.dtsi" }; };update_4 {
pci {
gpioa {
gpiob {
gpioc {
microcode {
update@0 {
#include "microcode/m0220661105_cv.dtsi" }; };update_0 {
pci {
gpioa {
gpiob {
pci {
rw-mrc-cache {
gpioa {
gpiob {
/* GPIO E0 */
soc_gpio_s5_0@0 {
/* GPIO E1 */
soc_gpio_s5_1@0 {
/* GPIO E2 */
soc_gpio_s5_2@0 {
@@ -98,7 +98,7 @@
pci {
rw-mrc-cache {
gpioa {
gpiob {
gpioc {
gpiod {
gpioe {
gpiof {
microcode {
update@0 {
update@1 {
pci {
pci {
rtc {
serial: serial {
};memory@0 { device_type = "memory"; reg = <0 0>; };
Example:
[snip]
Regards, Bin
Thanks for the review!
bye, Heiko
Bin Meng
Heiko Schocher
