[U-Boot] [PATCH v4 0/20] ARM: UniPhier: bug fixes, refactorings and new features
This series contains: - bug fixes and refactoring of SBC init code - add missing reset controls - support 1CS support card for all the SoCs - add xHCI driver
Masahiro Yamada (20): ARM: UniPhier: move SoC sources to mach-uniphier ARM: UniPhier: move SoC headers to mach-uniphier/include/mach ARM: UniPhier: include <mach/*.h> instead of <asm/arch/*.h> ARM: UniPhier: fix comments in PH1-Pro4 SBC code ARM: UniPhier: fix SBC init code ARM: UniPhier: split clkrst_init() into two functions ARM: UniPhier: reset NAND core in SPL for non-NAND boot mode ARM: UniPhier: enable STDMAC for EHCI ARM: UniPhier: remove EHCI platform devices ARM: UniPhier: move uniphier_ehci_reset() function ARM: UniPhier: replace "usb-ehci" with "generic-ehci" ARM: UniPhier: add I/O pin settings for xHCI on PH1-Pro4 ARM: UniPhier: enable xHCI and GIO cores for PH1-Pro4 ARM: UniPhier: add xHCI device nodes to PH1-Pro4 device tree usb: UniPhier: add UniPhier on-chip xHCI host driver support ARM: UniPhier: switch to xHCI for PH1-Pro4 ARM: UniPhier: support 1CS support card for all the UniPhier SoCs ARM: UniPhier: switch to 1CS support card ARM: UniPhier: consolidate MEMCONF setting code ARM: UniPhier: remove stop_mpll() from PH1-Pro4 PLL initialization
MAINTAINERS | 3 +- arch/arm/Kconfig | 2 +- arch/arm/Makefile | 1 + arch/arm/cpu/armv7/Makefile | 1 - arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c | 28 ----- arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c | 29 ----- arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c | 75 ------------- arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c | 28 ----- arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c | 29 ----- arch/arm/dts/uniphier-ph1-ld4.dtsi | 8 +- arch/arm/dts/uniphier-ph1-pro4-ref.dts | 5 +- arch/arm/dts/uniphier-ph1-pro4.dtsi | 22 +++- arch/arm/dts/uniphier-ph1-sld3.dtsi | 10 +- arch/arm/dts/uniphier-ph1-sld8.dtsi | 8 +- arch/arm/include/asm/arch-uniphier/ehci-uniphier.h | 33 ------ .../{cpu/armv7/uniphier => mach-uniphier}/Kconfig | 0 .../{cpu/armv7/uniphier => mach-uniphier}/Makefile | 1 + .../uniphier => mach-uniphier}/board_common.c | 2 +- .../board_early_init_f.c | 9 +- .../board_early_init_r.c | 2 +- .../uniphier => mach-uniphier}/board_late_init.c | 0 .../uniphier => mach-uniphier}/cache_uniphier.c | 2 +- .../armv7/uniphier => mach-uniphier}/cmd_ddrphy.c | 2 +- .../armv7/uniphier => mach-uniphier}/cmd_pinmon.c | 4 +- .../armv7/uniphier => mach-uniphier}/cpu_info.c | 2 +- .../uniphier => mach-uniphier}/ddrphy_training.c | 2 +- .../armv7/uniphier => mach-uniphier}/dram_init.c | 0 .../include/mach}/arm-mpcore.h | 0 .../include/mach}/bcu-regs.h | 0 .../include/mach}/board.h | 0 .../include/mach}/boot-device.h | 0 .../include/mach}/ddrphy-regs.h | 0 .../include/mach}/debug-uart.S | 0 .../include/mach}/led.h | 0 .../include/mach}/mio-regs.h | 0 .../include/mach}/platdevice.h | 2 - .../include/mach}/sbc-regs.h | 0 .../include/mach}/sc-regs.h | 17 ++- .../include/mach}/sg-regs.h | 119 +-------------------- .../include/mach}/ssc-regs.h | 0 .../include/mach}/umc-regs.h | 0 .../uniphier => mach-uniphier}/init_page_table.S | 0 .../uniphier => mach-uniphier}/lowlevel_init.S | 8 +- arch/arm/mach-uniphier/memconf.c | 104 ++++++++++++++++++ .../ph1-pro4 => mach-uniphier/ph1-ld4}/Makefile | 6 +- .../uniphier => mach-uniphier}/ph1-ld4/bcu_init.c | 2 +- .../uniphier => mach-uniphier}/ph1-ld4/boot-mode.c | 0 arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c | 42 ++++++++ .../ph1-ld4/ddrphy_init.c | 2 +- arch/arm/mach-uniphier/ph1-ld4/early_clkrst_init.c | 1 + .../ph1-ld4/lowlevel_debug.S | 4 +- .../uniphier => mach-uniphier}/ph1-ld4/pinctrl.c | 2 +- .../ph1-ld4/platdevice.c | 16 +-- .../uniphier => mach-uniphier}/ph1-ld4/pll_init.c | 4 +- .../ph1-ld4/pll_spectrum.c | 0 arch/arm/mach-uniphier/ph1-ld4/sbc_init.c | 1 + .../ph1-ld4/sbc_init_3cs.c} | 15 ++- arch/arm/mach-uniphier/ph1-ld4/sg_init.c | 19 ++++ .../uniphier => mach-uniphier}/ph1-ld4/umc_init.c | 4 +- .../ph1-ld4 => mach-uniphier/ph1-pro4}/Makefile | 6 +- .../ph1-pro4/boot-mode.c | 6 +- arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c | 57 ++++++++++ .../ph1-pro4/ddrphy_init.c | 2 +- .../ph1-pro4/early_clkrst_init.c} | 16 +-- .../ph1-pro4/lowlevel_debug.S | 6 +- .../uniphier => mach-uniphier}/ph1-pro4/pinctrl.c | 9 +- .../ph1-pro4/platdevice.c | 13 +-- .../uniphier => mach-uniphier}/ph1-pro4/pll_init.c | 21 +--- .../ph1-pro4/pll_spectrum.c | 2 +- arch/arm/mach-uniphier/ph1-pro4/sbc_init.c | 43 ++++++++ arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c | 43 ++++++++ arch/arm/mach-uniphier/ph1-pro4/sg_init.c | 19 ++++ .../uniphier => mach-uniphier}/ph1-pro4/umc_init.c | 4 +- .../uniphier => mach-uniphier}/ph1-sld8/Makefile | 6 +- .../uniphier => mach-uniphier}/ph1-sld8/bcu_init.c | 0 .../ph1-sld8/boot-mode.c | 0 arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c | 1 + .../ph1-sld8/ddrphy_init.c | 2 +- .../arm/mach-uniphier/ph1-sld8/early_clkrst_init.c | 1 + .../ph1-sld8/lowlevel_debug.S | 4 +- .../uniphier => mach-uniphier}/ph1-sld8/pinctrl.c | 2 +- .../ph1-sld8/platdevice.c | 16 +-- .../uniphier => mach-uniphier}/ph1-sld8/pll_init.c | 4 +- .../ph1-sld8/pll_spectrum.c | 0 arch/arm/mach-uniphier/ph1-sld8/sbc_init.c | 1 + .../ph1-sld8/sbc_init_3cs.c} | 32 +++--- .../uniphier => mach-uniphier}/ph1-sld8/sg_init.c | 0 .../uniphier => mach-uniphier}/ph1-sld8/umc_init.c | 4 +- .../uniphier => mach-uniphier}/print_misc_info.c | 2 +- .../{cpu/armv7/uniphier => mach-uniphier}/reset.c | 2 +- .../{cpu/armv7/uniphier => mach-uniphier}/smp.S | 4 +- .../{cpu/armv7/uniphier => mach-uniphier}/spl.c | 17 +-- .../uniphier => mach-uniphier}/support_card.c | 4 +- .../{cpu/armv7/uniphier => mach-uniphier}/timer.c | 2 +- configs/ph1_ld4_defconfig | 2 +- configs/ph1_pro4_defconfig | 4 +- configs/ph1_sld8_defconfig | 2 +- doc/README.uniphier | 3 +- drivers/usb/host/Kconfig | 10 +- drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-uniphier.c | 25 ++--- drivers/usb/host/xhci-uniphier.c | 85 +++++++++++++++ include/configs/uniphier.h | 3 + include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 105 files changed, 623 insertions(+), 541 deletions(-) delete mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c delete mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c delete mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c delete mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c delete mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c delete mode 100644 arch/arm/include/asm/arch-uniphier/ehci-uniphier.h rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/Kconfig (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/Makefile (97%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/board_common.c (95%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/board_early_init_f.c (71%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/board_early_init_r.c (89%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/board_late_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/cache_uniphier.c (99%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/cmd_ddrphy.c (99%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/cmd_pinmon.c (90%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/cpu_info.c (97%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ddrphy_training.c (98%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/dram_init.c (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/arm-mpcore.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/bcu-regs.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/board.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/boot-device.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/ddrphy-regs.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/debug-uart.S (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/led.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/mio-regs.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/platdevice.h (93%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/sbc-regs.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/sc-regs.h (78%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/sg-regs.h (68%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/ssc-regs.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/umc-regs.h (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/init_page_table.S (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/lowlevel_init.S (97%) create mode 100644 arch/arm/mach-uniphier/memconf.c rename arch/arm/{cpu/armv7/uniphier/ph1-pro4 => mach-uniphier/ph1-ld4}/Makefile (50%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/bcu_init.c (96%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/boot-mode.c (100%) create mode 100644 arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/ddrphy_init.c (97%) create mode 100644 arch/arm/mach-uniphier/ph1-ld4/early_clkrst_init.c rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/lowlevel_debug.S (89%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/pinctrl.c (98%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/platdevice.c (58%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/pll_init.c (98%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/pll_spectrum.c (100%) create mode 100644 arch/arm/mach-uniphier/ph1-ld4/sbc_init.c rename arch/arm/{cpu/armv7/uniphier/ph1-ld4/sbc_init.c => mach-uniphier/ph1-ld4/sbc_init_3cs.c} (83%) create mode 100644 arch/arm/mach-uniphier/ph1-ld4/sg_init.c rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/umc_init.c (98%) rename arch/arm/{cpu/armv7/uniphier/ph1-ld4 => mach-uniphier/ph1-pro4}/Makefile (51%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/boot-mode.c (96%) create mode 100644 arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/ddrphy_init.c (97%) rename arch/arm/{cpu/armv7/uniphier/ph1-ld4/clkrst_init.c => mach-uniphier/ph1-pro4/early_clkrst_init.c} (52%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/lowlevel_debug.S (87%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/pinctrl.c (85%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/platdevice.c (61%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/pll_init.c (91%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/pll_spectrum.c (89%) create mode 100644 arch/arm/mach-uniphier/ph1-pro4/sbc_init.c create mode 100644 arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c create mode 100644 arch/arm/mach-uniphier/ph1-pro4/sg_init.c rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/umc_init.c (98%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/Makefile (50%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/bcu_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/boot-mode.c (100%) create mode 100644 arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/ddrphy_init.c (98%) create mode 100644 arch/arm/mach-uniphier/ph1-sld8/early_clkrst_init.c rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/lowlevel_debug.S (89%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/pinctrl.c (98%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/platdevice.c (58%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/pll_init.c (98%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/pll_spectrum.c (100%) create mode 100644 arch/arm/mach-uniphier/ph1-sld8/sbc_init.c rename arch/arm/{cpu/armv7/uniphier/ph1-sld8/sbc_init.c => mach-uniphier/ph1-sld8/sbc_init_3cs.c} (63%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/sg_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/umc_init.c (98%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/print_misc_info.c (88%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/reset.c (94%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/smp.S (95%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/spl.c (81%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/support_card.c (98%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/timer.c (96%) create mode 100644 drivers/usb/host/xhci-uniphier.c
Move arch/arm/cpu/armv7/uniphier/* -> arch/arm/mach-uniphier/*
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Changes in v4: None Changes in v3: - Newly added
Changes in v2: None
MAINTAINERS | 2 +- arch/arm/Kconfig | 2 +- arch/arm/Makefile | 1 + arch/arm/cpu/armv7/Makefile | 1 - arch/arm/{cpu/armv7/uniphier => mach-uniphier}/Kconfig | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/Makefile | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/board_common.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/board_early_init_f.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/board_early_init_r.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/board_late_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/cache_uniphier.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/cmd_ddrphy.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/cmd_pinmon.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/cpu_info.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ddrphy_training.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/dram_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/init_page_table.S | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/lowlevel_init.S | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/Makefile | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/bcu_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/boot-mode.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/clkrst_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/ddrphy_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/lowlevel_debug.S | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/pinctrl.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/platdevice.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/pll_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/pll_spectrum.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/sbc_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/sg_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/umc_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/Makefile | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/boot-mode.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/clkrst_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/ddrphy_init.c | 0 .../arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/lowlevel_debug.S | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/pinctrl.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/platdevice.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/pll_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/pll_spectrum.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/sbc_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/sg_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/umc_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/Makefile | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/bcu_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/boot-mode.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/clkrst_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/ddrphy_init.c | 0 .../arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/lowlevel_debug.S | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/pinctrl.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/platdevice.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/pll_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/pll_spectrum.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/sbc_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/sg_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/umc_init.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/print_misc_info.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/reset.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/smp.S | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/spl.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/support_card.c | 0 arch/arm/{cpu/armv7/uniphier => mach-uniphier}/timer.c | 0 62 files changed, 3 insertions(+), 3 deletions(-) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/Kconfig (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/Makefile (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/board_common.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/board_early_init_f.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/board_early_init_r.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/board_late_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/cache_uniphier.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/cmd_ddrphy.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/cmd_pinmon.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/cpu_info.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ddrphy_training.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/dram_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/init_page_table.S (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/lowlevel_init.S (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/Makefile (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/bcu_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/boot-mode.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/clkrst_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/ddrphy_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/lowlevel_debug.S (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/pinctrl.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/platdevice.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/pll_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/pll_spectrum.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/sbc_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/sg_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-ld4/umc_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/Makefile (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/boot-mode.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/clkrst_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/ddrphy_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/lowlevel_debug.S (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/pinctrl.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/platdevice.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/pll_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/pll_spectrum.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/sbc_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/sg_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-pro4/umc_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/Makefile (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/bcu_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/boot-mode.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/clkrst_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/ddrphy_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/lowlevel_debug.S (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/pinctrl.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/platdevice.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/pll_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/pll_spectrum.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/sbc_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/sg_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/ph1-sld8/umc_init.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/print_misc_info.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/reset.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/smp.S (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/spl.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/support_card.c (100%) rename arch/arm/{cpu/armv7/uniphier => mach-uniphier}/timer.c (100%)
diff --git a/MAINTAINERS b/MAINTAINERS index eef70d0..f9d1987 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -162,7 +162,7 @@ ARM UNIPHIER M: Masahiro Yamada yamada.m@jp.panasonic.com S: Maintained T: git git://git.denx.de/u-boot-uniphier.git -F: arch/arm/cpu/armv7/uniphier/ +F: arch/arm/mach-uniphier/ F: arch/arm/include/asm/arch-uniphier/ F: configs/ph1_*_defconfig N: uniphier diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 820ba1c..1cd49e3 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -748,7 +748,7 @@ source "arch/arm/cpu/armv7/s5pc1xx/Kconfig"
source "arch/arm/mach-tegra/Kconfig"
-source "arch/arm/cpu/armv7/uniphier/Kconfig" +source "arch/arm/mach-uniphier/Kconfig"
source "arch/arm/mach-versatile/Kconfig"
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 878ae26..08946de 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -15,6 +15,7 @@ machine-$(CONFIG_ARCH_NOMADIK) += nomadik # TODO: rename CONFIG_ORION5X -> CONFIG_ARCH_ORION5X machine-$(CONFIG_ORION5X) += orion5x machine-$(CONFIG_TEGRA) += tegra +machine-$(CONFIG_ARCH_UNIPHIER) += uniphier machine-$(CONFIG_ARCH_VERSATILE) += versatile
machdirs := $(patsubst %,arch/arm/mach-%/,$(machine-y)) diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index b228ed6..ad22489 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -56,6 +56,5 @@ obj-$(CONFIG_SOCFPGA) += socfpga/ obj-$(if $(filter stv0991,$(SOC)),y) += stv0991/ obj-$(CONFIG_ARCH_SUNXI) += sunxi/ obj-$(CONFIG_U8500) += u8500/ -obj-$(CONFIG_ARCH_UNIPHIER) += uniphier/ obj-$(CONFIG_VF610) += vf610/ obj-$(CONFIG_ZYNQ) += zynq/ diff --git a/arch/arm/cpu/armv7/uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig similarity index 100% rename from arch/arm/cpu/armv7/uniphier/Kconfig rename to arch/arm/mach-uniphier/Kconfig diff --git a/arch/arm/cpu/armv7/uniphier/Makefile b/arch/arm/mach-uniphier/Makefile similarity index 100% rename from arch/arm/cpu/armv7/uniphier/Makefile rename to arch/arm/mach-uniphier/Makefile diff --git a/arch/arm/cpu/armv7/uniphier/board_common.c b/arch/arm/mach-uniphier/board_common.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/board_common.c rename to arch/arm/mach-uniphier/board_common.c diff --git a/arch/arm/cpu/armv7/uniphier/board_early_init_f.c b/arch/arm/mach-uniphier/board_early_init_f.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/board_early_init_f.c rename to arch/arm/mach-uniphier/board_early_init_f.c diff --git a/arch/arm/cpu/armv7/uniphier/board_early_init_r.c b/arch/arm/mach-uniphier/board_early_init_r.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/board_early_init_r.c rename to arch/arm/mach-uniphier/board_early_init_r.c diff --git a/arch/arm/cpu/armv7/uniphier/board_late_init.c b/arch/arm/mach-uniphier/board_late_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/board_late_init.c rename to arch/arm/mach-uniphier/board_late_init.c diff --git a/arch/arm/cpu/armv7/uniphier/cache_uniphier.c b/arch/arm/mach-uniphier/cache_uniphier.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/cache_uniphier.c rename to arch/arm/mach-uniphier/cache_uniphier.c diff --git a/arch/arm/cpu/armv7/uniphier/cmd_ddrphy.c b/arch/arm/mach-uniphier/cmd_ddrphy.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/cmd_ddrphy.c rename to arch/arm/mach-uniphier/cmd_ddrphy.c diff --git a/arch/arm/cpu/armv7/uniphier/cmd_pinmon.c b/arch/arm/mach-uniphier/cmd_pinmon.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/cmd_pinmon.c rename to arch/arm/mach-uniphier/cmd_pinmon.c diff --git a/arch/arm/cpu/armv7/uniphier/cpu_info.c b/arch/arm/mach-uniphier/cpu_info.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/cpu_info.c rename to arch/arm/mach-uniphier/cpu_info.c diff --git a/arch/arm/cpu/armv7/uniphier/ddrphy_training.c b/arch/arm/mach-uniphier/ddrphy_training.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ddrphy_training.c rename to arch/arm/mach-uniphier/ddrphy_training.c diff --git a/arch/arm/cpu/armv7/uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/dram_init.c rename to arch/arm/mach-uniphier/dram_init.c diff --git a/arch/arm/cpu/armv7/uniphier/init_page_table.S b/arch/arm/mach-uniphier/init_page_table.S similarity index 100% rename from arch/arm/cpu/armv7/uniphier/init_page_table.S rename to arch/arm/mach-uniphier/init_page_table.S diff --git a/arch/arm/cpu/armv7/uniphier/lowlevel_init.S b/arch/arm/mach-uniphier/lowlevel_init.S similarity index 100% rename from arch/arm/cpu/armv7/uniphier/lowlevel_init.S rename to arch/arm/mach-uniphier/lowlevel_init.S diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile b/arch/arm/mach-uniphier/ph1-ld4/Makefile similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile rename to arch/arm/mach-uniphier/ph1-ld4/Makefile diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c b/arch/arm/mach-uniphier/ph1-ld4/bcu_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c rename to arch/arm/mach-uniphier/ph1-ld4/bcu_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c b/arch/arm/mach-uniphier/ph1-ld4/boot-mode.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c rename to arch/arm/mach-uniphier/ph1-ld4/boot-mode.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c b/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c rename to arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/ddrphy_init.c b/arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/ddrphy_init.c rename to arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/lowlevel_debug.S b/arch/arm/mach-uniphier/ph1-ld4/lowlevel_debug.S similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/lowlevel_debug.S rename to arch/arm/mach-uniphier/ph1-ld4/lowlevel_debug.S diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c b/arch/arm/mach-uniphier/ph1-ld4/pinctrl.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c rename to arch/arm/mach-uniphier/ph1-ld4/pinctrl.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/platdevice.c b/arch/arm/mach-uniphier/ph1-ld4/platdevice.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/platdevice.c rename to arch/arm/mach-uniphier/ph1-ld4/platdevice.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c b/arch/arm/mach-uniphier/ph1-ld4/pll_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c rename to arch/arm/mach-uniphier/ph1-ld4/pll_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c b/arch/arm/mach-uniphier/ph1-ld4/pll_spectrum.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c rename to arch/arm/mach-uniphier/ph1-ld4/pll_spectrum.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c b/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c rename to arch/arm/mach-uniphier/ph1-ld4/sbc_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c b/arch/arm/mach-uniphier/ph1-ld4/sg_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c rename to arch/arm/mach-uniphier/ph1-ld4/sg_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c b/arch/arm/mach-uniphier/ph1-ld4/umc_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c rename to arch/arm/mach-uniphier/ph1-ld4/umc_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile b/arch/arm/mach-uniphier/ph1-pro4/Makefile similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile rename to arch/arm/mach-uniphier/ph1-pro4/Makefile diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c b/arch/arm/mach-uniphier/ph1-pro4/boot-mode.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c rename to arch/arm/mach-uniphier/ph1-pro4/boot-mode.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c b/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c rename to arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/ddrphy_init.c b/arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-pro4/ddrphy_init.c rename to arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/lowlevel_debug.S b/arch/arm/mach-uniphier/ph1-pro4/lowlevel_debug.S similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-pro4/lowlevel_debug.S rename to arch/arm/mach-uniphier/ph1-pro4/lowlevel_debug.S diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c b/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c rename to arch/arm/mach-uniphier/ph1-pro4/pinctrl.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/platdevice.c b/arch/arm/mach-uniphier/ph1-pro4/platdevice.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-pro4/platdevice.c rename to arch/arm/mach-uniphier/ph1-pro4/platdevice.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c b/arch/arm/mach-uniphier/ph1-pro4/pll_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c rename to arch/arm/mach-uniphier/ph1-pro4/pll_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c b/arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c rename to arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c b/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c rename to arch/arm/mach-uniphier/ph1-pro4/sbc_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c b/arch/arm/mach-uniphier/ph1-pro4/sg_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c rename to arch/arm/mach-uniphier/ph1-pro4/sg_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c b/arch/arm/mach-uniphier/ph1-pro4/umc_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c rename to arch/arm/mach-uniphier/ph1-pro4/umc_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile b/arch/arm/mach-uniphier/ph1-sld8/Makefile similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile rename to arch/arm/mach-uniphier/ph1-sld8/Makefile diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c b/arch/arm/mach-uniphier/ph1-sld8/bcu_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c rename to arch/arm/mach-uniphier/ph1-sld8/bcu_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c b/arch/arm/mach-uniphier/ph1-sld8/boot-mode.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c rename to arch/arm/mach-uniphier/ph1-sld8/boot-mode.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c b/arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c rename to arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/ddrphy_init.c b/arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-sld8/ddrphy_init.c rename to arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/lowlevel_debug.S b/arch/arm/mach-uniphier/ph1-sld8/lowlevel_debug.S similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-sld8/lowlevel_debug.S rename to arch/arm/mach-uniphier/ph1-sld8/lowlevel_debug.S diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c b/arch/arm/mach-uniphier/ph1-sld8/pinctrl.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c rename to arch/arm/mach-uniphier/ph1-sld8/pinctrl.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/platdevice.c b/arch/arm/mach-uniphier/ph1-sld8/platdevice.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-sld8/platdevice.c rename to arch/arm/mach-uniphier/ph1-sld8/platdevice.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c b/arch/arm/mach-uniphier/ph1-sld8/pll_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c rename to arch/arm/mach-uniphier/ph1-sld8/pll_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c b/arch/arm/mach-uniphier/ph1-sld8/pll_spectrum.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c rename to arch/arm/mach-uniphier/ph1-sld8/pll_spectrum.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c b/arch/arm/mach-uniphier/ph1-sld8/sbc_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c rename to arch/arm/mach-uniphier/ph1-sld8/sbc_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c b/arch/arm/mach-uniphier/ph1-sld8/sg_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c rename to arch/arm/mach-uniphier/ph1-sld8/sg_init.c diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c b/arch/arm/mach-uniphier/ph1-sld8/umc_init.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c rename to arch/arm/mach-uniphier/ph1-sld8/umc_init.c diff --git a/arch/arm/cpu/armv7/uniphier/print_misc_info.c b/arch/arm/mach-uniphier/print_misc_info.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/print_misc_info.c rename to arch/arm/mach-uniphier/print_misc_info.c diff --git a/arch/arm/cpu/armv7/uniphier/reset.c b/arch/arm/mach-uniphier/reset.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/reset.c rename to arch/arm/mach-uniphier/reset.c diff --git a/arch/arm/cpu/armv7/uniphier/smp.S b/arch/arm/mach-uniphier/smp.S similarity index 100% rename from arch/arm/cpu/armv7/uniphier/smp.S rename to arch/arm/mach-uniphier/smp.S diff --git a/arch/arm/cpu/armv7/uniphier/spl.c b/arch/arm/mach-uniphier/spl.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/spl.c rename to arch/arm/mach-uniphier/spl.c diff --git a/arch/arm/cpu/armv7/uniphier/support_card.c b/arch/arm/mach-uniphier/support_card.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/support_card.c rename to arch/arm/mach-uniphier/support_card.c diff --git a/arch/arm/cpu/armv7/uniphier/timer.c b/arch/arm/mach-uniphier/timer.c similarity index 100% rename from arch/arm/cpu/armv7/uniphier/timer.c rename to arch/arm/mach-uniphier/timer.c
Move arch/arm/include/asm/arch-uniphier/* -> arch/arm/mach-uniphier/include/mach/*
Changes in v2: None
MAINTAINERS | 1 - .../asm/arch-uniphier => mach-uniphier/include/mach}/arm-mpcore.h | 0 .../{include/asm/arch-uniphier => mach-uniphier/include/mach}/bcu-regs.h | 0 .../{include/asm/arch-uniphier => mach-uniphier/include/mach}/board.h | 0 .../asm/arch-uniphier => mach-uniphier/include/mach}/boot-device.h | 0 .../asm/arch-uniphier => mach-uniphier/include/mach}/ddrphy-regs.h | 0 .../asm/arch-uniphier => mach-uniphier/include/mach}/debug-uart.S | 0 .../asm/arch-uniphier => mach-uniphier/include/mach}/ehci-uniphier.h | 0 arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/led.h | 0 .../{include/asm/arch-uniphier => mach-uniphier/include/mach}/mio-regs.h | 0 .../asm/arch-uniphier => mach-uniphier/include/mach}/platdevice.h | 0 .../{include/asm/arch-uniphier => mach-uniphier/include/mach}/sbc-regs.h | 0 .../{include/asm/arch-uniphier => mach-uniphier/include/mach}/sc-regs.h | 0 .../{include/asm/arch-uniphier => mach-uniphier/include/mach}/sg-regs.h | 0 .../{include/asm/arch-uniphier => mach-uniphier/include/mach}/ssc-regs.h | 0 .../{include/asm/arch-uniphier => mach-uniphier/include/mach}/umc-regs.h | 0 16 files changed, 1 deletion(-) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/arm-mpcore.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/bcu-regs.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/board.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/boot-device.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/ddrphy-regs.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/debug-uart.S (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/ehci-uniphier.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/led.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/mio-regs.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/platdevice.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/sbc-regs.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/sc-regs.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/sg-regs.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/ssc-regs.h (100%) rename arch/arm/{include/asm/arch-uniphier => mach-uniphier/include/mach}/umc-regs.h (100%)
diff --git a/MAINTAINERS b/MAINTAINERS index f9d1987..5881b38 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -163,7 +163,6 @@ M: Masahiro Yamada yamada.m@jp.panasonic.com S: Maintained T: git git://git.denx.de/u-boot-uniphier.git F: arch/arm/mach-uniphier/ -F: arch/arm/include/asm/arch-uniphier/ F: configs/ph1_*_defconfig N: uniphier
diff --git a/arch/arm/include/asm/arch-uniphier/arm-mpcore.h b/arch/arm/mach-uniphier/include/mach/arm-mpcore.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/arm-mpcore.h rename to arch/arm/mach-uniphier/include/mach/arm-mpcore.h diff --git a/arch/arm/include/asm/arch-uniphier/bcu-regs.h b/arch/arm/mach-uniphier/include/mach/bcu-regs.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/bcu-regs.h rename to arch/arm/mach-uniphier/include/mach/bcu-regs.h diff --git a/arch/arm/include/asm/arch-uniphier/board.h b/arch/arm/mach-uniphier/include/mach/board.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/board.h rename to arch/arm/mach-uniphier/include/mach/board.h diff --git a/arch/arm/include/asm/arch-uniphier/boot-device.h b/arch/arm/mach-uniphier/include/mach/boot-device.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/boot-device.h rename to arch/arm/mach-uniphier/include/mach/boot-device.h diff --git a/arch/arm/include/asm/arch-uniphier/ddrphy-regs.h b/arch/arm/mach-uniphier/include/mach/ddrphy-regs.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/ddrphy-regs.h rename to arch/arm/mach-uniphier/include/mach/ddrphy-regs.h diff --git a/arch/arm/include/asm/arch-uniphier/debug-uart.S b/arch/arm/mach-uniphier/include/mach/debug-uart.S similarity index 100% rename from arch/arm/include/asm/arch-uniphier/debug-uart.S rename to arch/arm/mach-uniphier/include/mach/debug-uart.S diff --git a/arch/arm/include/asm/arch-uniphier/ehci-uniphier.h b/arch/arm/mach-uniphier/include/mach/ehci-uniphier.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/ehci-uniphier.h rename to arch/arm/mach-uniphier/include/mach/ehci-uniphier.h diff --git a/arch/arm/include/asm/arch-uniphier/led.h b/arch/arm/mach-uniphier/include/mach/led.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/led.h rename to arch/arm/mach-uniphier/include/mach/led.h diff --git a/arch/arm/include/asm/arch-uniphier/mio-regs.h b/arch/arm/mach-uniphier/include/mach/mio-regs.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/mio-regs.h rename to arch/arm/mach-uniphier/include/mach/mio-regs.h diff --git a/arch/arm/include/asm/arch-uniphier/platdevice.h b/arch/arm/mach-uniphier/include/mach/platdevice.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/platdevice.h rename to arch/arm/mach-uniphier/include/mach/platdevice.h diff --git a/arch/arm/include/asm/arch-uniphier/sbc-regs.h b/arch/arm/mach-uniphier/include/mach/sbc-regs.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/sbc-regs.h rename to arch/arm/mach-uniphier/include/mach/sbc-regs.h diff --git a/arch/arm/include/asm/arch-uniphier/sc-regs.h b/arch/arm/mach-uniphier/include/mach/sc-regs.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/sc-regs.h rename to arch/arm/mach-uniphier/include/mach/sc-regs.h diff --git a/arch/arm/include/asm/arch-uniphier/sg-regs.h b/arch/arm/mach-uniphier/include/mach/sg-regs.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/sg-regs.h rename to arch/arm/mach-uniphier/include/mach/sg-regs.h diff --git a/arch/arm/include/asm/arch-uniphier/ssc-regs.h b/arch/arm/mach-uniphier/include/mach/ssc-regs.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/ssc-regs.h rename to arch/arm/mach-uniphier/include/mach/ssc-regs.h diff --git a/arch/arm/include/asm/arch-uniphier/umc-regs.h b/arch/arm/mach-uniphier/include/mach/umc-regs.h similarity index 100% rename from arch/arm/include/asm/arch-uniphier/umc-regs.h rename to arch/arm/mach-uniphier/include/mach/umc-regs.h
Since commit 0e7368c6c426 (kbuild: prepare for moving headers into mach-*/include/mach), we can replace #include <asm/arch/*.h> with <mach/*.h> so we do not need to create the symbolic link during the build.
Changes in v2: None
arch/arm/mach-uniphier/board_common.c | 2 +- arch/arm/mach-uniphier/board_early_init_f.c | 4 ++-- arch/arm/mach-uniphier/board_early_init_r.c | 2 +- arch/arm/mach-uniphier/cache_uniphier.c | 2 +- arch/arm/mach-uniphier/cmd_ddrphy.c | 2 +- arch/arm/mach-uniphier/cmd_pinmon.c | 4 ++-- arch/arm/mach-uniphier/cpu_info.c | 2 +- arch/arm/mach-uniphier/ddrphy_training.c | 2 +- arch/arm/mach-uniphier/include/mach/platdevice.h | 2 +- arch/arm/mach-uniphier/lowlevel_init.S | 8 ++++---- arch/arm/mach-uniphier/ph1-ld4/bcu_init.c | 2 +- arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c | 2 +- arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c | 2 +- arch/arm/mach-uniphier/ph1-ld4/lowlevel_debug.S | 4 ++-- arch/arm/mach-uniphier/ph1-ld4/pinctrl.c | 2 +- arch/arm/mach-uniphier/ph1-ld4/platdevice.c | 2 +- arch/arm/mach-uniphier/ph1-ld4/pll_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-ld4/sbc_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-ld4/sg_init.c | 2 +- arch/arm/mach-uniphier/ph1-ld4/umc_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/boot-mode.c | 6 +++--- arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c | 2 +- arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c | 2 +- arch/arm/mach-uniphier/ph1-pro4/lowlevel_debug.S | 6 +++--- arch/arm/mach-uniphier/ph1-pro4/pinctrl.c | 2 +- arch/arm/mach-uniphier/ph1-pro4/platdevice.c | 2 +- arch/arm/mach-uniphier/ph1-pro4/pll_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c | 2 +- arch/arm/mach-uniphier/ph1-pro4/sbc_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-pro4/sg_init.c | 2 +- arch/arm/mach-uniphier/ph1-pro4/umc_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c | 2 +- arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c | 2 +- arch/arm/mach-uniphier/ph1-sld8/lowlevel_debug.S | 4 ++-- arch/arm/mach-uniphier/ph1-sld8/pinctrl.c | 2 +- arch/arm/mach-uniphier/ph1-sld8/platdevice.c | 2 +- arch/arm/mach-uniphier/ph1-sld8/pll_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-sld8/sbc_init.c | 4 ++-- arch/arm/mach-uniphier/ph1-sld8/umc_init.c | 4 ++-- arch/arm/mach-uniphier/print_misc_info.c | 2 +- arch/arm/mach-uniphier/reset.c | 2 +- arch/arm/mach-uniphier/smp.S | 4 ++-- arch/arm/mach-uniphier/spl.c | 4 ++-- arch/arm/mach-uniphier/support_card.c | 4 ++-- arch/arm/mach-uniphier/timer.c | 2 +- drivers/usb/host/ehci-uniphier.c | 2 +- 46 files changed, 69 insertions(+), 69 deletions(-)
diff --git a/arch/arm/mach-uniphier/board_common.c b/arch/arm/mach-uniphier/board_common.c index 3fb26c6..5f2d5f6 100644 --- a/arch/arm/mach-uniphier/board_common.c +++ b/arch/arm/mach-uniphier/board_common.c @@ -6,7 +6,7 @@ */
#include <common.h> -#include <asm/arch/led.h> +#include <mach/led.h>
/* * Routine: board_init diff --git a/arch/arm/mach-uniphier/board_early_init_f.c b/arch/arm/mach-uniphier/board_early_init_f.c index d25bbae..bf81345 100644 --- a/arch/arm/mach-uniphier/board_early_init_f.c +++ b/arch/arm/mach-uniphier/board_early_init_f.c @@ -5,8 +5,8 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#include <asm/arch/led.h> -#include <asm/arch/board.h> +#include <mach/led.h> +#include <mach/board.h>
void pin_init(void);
diff --git a/arch/arm/mach-uniphier/board_early_init_r.c b/arch/arm/mach-uniphier/board_early_init_r.c index cb7e04f..579fe70 100644 --- a/arch/arm/mach-uniphier/board_early_init_r.c +++ b/arch/arm/mach-uniphier/board_early_init_r.c @@ -6,7 +6,7 @@ */
#include <common.h> -#include <asm/arch/board.h> +#include <mach/board.h>
int board_early_init_r(void) { diff --git a/arch/arm/mach-uniphier/cache_uniphier.c b/arch/arm/mach-uniphier/cache_uniphier.c index e47f977..52f3c7c 100644 --- a/arch/arm/mach-uniphier/cache_uniphier.c +++ b/arch/arm/mach-uniphier/cache_uniphier.c @@ -8,7 +8,7 @@ #include <common.h> #include <asm/io.h> #include <asm/armv7.h> -#include <asm/arch/ssc-regs.h> +#include <mach/ssc-regs.h>
#ifdef CONFIG_UNIPHIER_L2CACHE_ON static void uniphier_cache_maint_all(u32 operation) diff --git a/arch/arm/mach-uniphier/cmd_ddrphy.c b/arch/arm/mach-uniphier/cmd_ddrphy.c index 431d901..5f44927 100644 --- a/arch/arm/mach-uniphier/cmd_ddrphy.c +++ b/arch/arm/mach-uniphier/cmd_ddrphy.c @@ -7,7 +7,7 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/ddrphy-regs.h> +#include <mach/ddrphy-regs.h>
/* Select either decimal or hexadecimal */ #if 1 diff --git a/arch/arm/mach-uniphier/cmd_pinmon.c b/arch/arm/mach-uniphier/cmd_pinmon.c index 3c1b325..8be2ed4 100644 --- a/arch/arm/mach-uniphier/cmd_pinmon.c +++ b/arch/arm/mach-uniphier/cmd_pinmon.c @@ -6,8 +6,8 @@ */
#include <common.h> -#include <asm/arch/boot-device.h> -#include <asm/arch/sbc-regs.h> +#include <mach/boot-device.h> +#include <mach/sbc-regs.h>
static int do_pinmon(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { diff --git a/arch/arm/mach-uniphier/cpu_info.c b/arch/arm/mach-uniphier/cpu_info.c index 86d079a..13a0b1e 100644 --- a/arch/arm/mach-uniphier/cpu_info.c +++ b/arch/arm/mach-uniphier/cpu_info.c @@ -7,7 +7,7 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/sg-regs.h> +#include <mach/sg-regs.h>
int print_cpuinfo(void) { diff --git a/arch/arm/mach-uniphier/ddrphy_training.c b/arch/arm/mach-uniphier/ddrphy_training.c index cc8b8ad..b1d46cf 100644 --- a/arch/arm/mach-uniphier/ddrphy_training.c +++ b/arch/arm/mach-uniphier/ddrphy_training.c @@ -7,7 +7,7 @@
void ddrphy_prepare_training(struct ddrphy __iomem *phy, int rank) { diff --git a/arch/arm/mach-uniphier/include/mach/platdevice.h b/arch/arm/mach-uniphier/include/mach/platdevice.h index 62a5126..b004c2f 100644 --- a/arch/arm/mach-uniphier/include/mach/platdevice.h +++ b/arch/arm/mach-uniphier/include/mach/platdevice.h @@ -21,6 +21,6 @@ U_BOOT_DEVICE(serial##n) = { \ .platdata = &serial_device##n \ };
-#include <asm/arch/ehci-uniphier.h> +#include <mach/ehci-uniphier.h>
#endif /* ARCH_PLATDEVICE_H */ diff --git a/arch/arm/mach-uniphier/lowlevel_init.S b/arch/arm/mach-uniphier/lowlevel_init.S index c208ab6..4b8b623 100644 --- a/arch/arm/mach-uniphier/lowlevel_init.S +++ b/arch/arm/mach-uniphier/lowlevel_init.S @@ -8,9 +8,9 @@ #include <config.h> #include <linux/linkage.h> #include <asm/system.h> -#include <asm/arch/led.h> -#include <asm/arch/arm-mpcore.h> -#include <asm/arch/sbc-regs.h> +#include <mach/led.h> +#include <mach/arm-mpcore.h> +#include <mach/sbc-regs.h>
ENTRY(lowlevel_init) mov r8, lr @ persevere link reg across call @@ -122,7 +122,7 @@ ENTRY(enable_mmu) mov pc, lr ENDPROC(enable_mmu)
#define BOOT_RAM_SIZE (SSC_WAY_SIZE) #define BOOT_WAY_BITS (0x00000100) /* way 8 */ diff --git a/arch/arm/mach-uniphier/ph1-ld4/bcu_init.c b/arch/arm/mach-uniphier/ph1-ld4/bcu_init.c index 85f37f2..837e0d1 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/bcu_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/bcu_init.c @@ -7,7 +7,7 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/bcu-regs.h> +#include <mach/bcu-regs.h>
#define ch(x) ((x) >= 32 ? 0 : (x) < 0 ? 0x11111111 : 0x11111111 << (x))
diff --git a/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c b/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c index 18965a9..6a9d144 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c @@ -7,7 +7,7 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/sc-regs.h> +#include <mach/sc-regs.h>
void clkrst_init(void) { diff --git a/arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c b/arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c index 60fc5ad..a47e87a 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/ddrphy_init.c @@ -6,7 +6,7 @@
#include <linux/types.h> #include <asm/io.h> -#include <asm/arch/ddrphy-regs.h> +#include <mach/ddrphy-regs.h>
void ddrphy_init(struct ddrphy __iomem *phy, int freq, int size) { diff --git a/arch/arm/mach-uniphier/ph1-ld4/lowlevel_debug.S b/arch/arm/mach-uniphier/ph1-ld4/lowlevel_debug.S index c0778a0..7928c5c 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/lowlevel_debug.S +++ b/arch/arm/mach-uniphier/ph1-ld4/lowlevel_debug.S @@ -8,10 +8,10 @@ */
#include <linux/linkage.h> -#include <asm/arch/sg-regs.h> +#include <mach/sg-regs.h>
#define UART_CLK 36864000 -#include <asm/arch/debug-uart.S> +#include <mach/debug-uart.S>
ENTRY(setup_lowlevel_debug) init_debug_uart r0, r1, r2 diff --git a/arch/arm/mach-uniphier/ph1-ld4/pinctrl.c b/arch/arm/mach-uniphier/ph1-ld4/pinctrl.c index a742940..15d81eb 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/pinctrl.c +++ b/arch/arm/mach-uniphier/ph1-ld4/pinctrl.c @@ -6,7 +6,7 @@
void pin_init(void) { diff --git a/arch/arm/mach-uniphier/ph1-ld4/platdevice.c b/arch/arm/mach-uniphier/ph1-ld4/platdevice.c index 9d51299..5a3fbdc 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/platdevice.c +++ b/arch/arm/mach-uniphier/ph1-ld4/platdevice.c @@ -5,7 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#include <asm/arch/platdevice.h> +#include <mach/platdevice.h>
#define UART_MASTER_CLK 36864000
diff --git a/arch/arm/mach-uniphier/ph1-ld4/pll_init.c b/arch/arm/mach-uniphier/ph1-ld4/pll_init.c index b83582f..985e14f 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/pll_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/pll_init.c @@ -6,8 +6,8 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/sc-regs.h> -#include <asm/arch/sg-regs.h> +#include <mach/sc-regs.h> +#include <mach/sg-regs.h>
#undef DPLL_SSC_RATE_1PER
diff --git a/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c b/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c index 4839c94..f44195d 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c @@ -7,8 +7,8 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/sbc-regs.h> -#include <asm/arch/sg-regs.h> +#include <mach/sbc-regs.h> +#include <mach/sg-regs.h>
void sbc_init(void) { diff --git a/arch/arm/mach-uniphier/ph1-ld4/sg_init.c b/arch/arm/mach-uniphier/ph1-ld4/sg_init.c index 2cc5df6..e6bfa97 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/sg_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/sg_init.c @@ -7,7 +7,7 @@
void sg_init(void) { diff --git a/arch/arm/mach-uniphier/ph1-ld4/umc_init.c b/arch/arm/mach-uniphier/ph1-ld4/umc_init.c index bbc3dcb..081b028 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/umc_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/umc_init.c @@ -6,8 +6,8 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/umc-regs.h> -#include <asm/arch/ddrphy-regs.h> +#include <mach/umc-regs.h> +#include <mach/ddrphy-regs.h>
static void umc_start_ssif(void __iomem *ssif_base) { diff --git a/arch/arm/mach-uniphier/ph1-pro4/boot-mode.c b/arch/arm/mach-uniphier/ph1-pro4/boot-mode.c index c31b74b..9894c1a 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/boot-mode.c +++ b/arch/arm/mach-uniphier/ph1-pro4/boot-mode.c @@ -8,9 +8,9 @@ #include <common.h> #include <spl.h> #include <asm/io.h> -#include <asm/arch/boot-device.h> -#include <asm/arch/sg-regs.h> -#include <asm/arch/sbc-regs.h> +#include <mach/boot-device.h> +#include <mach/sg-regs.h> +#include <mach/sbc-regs.h>
struct boot_device_info boot_device_table[] = { {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, EraseSize 128KB, Addr 4)"}, diff --git a/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c b/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c index 18965a9..6a9d144 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c @@ -7,7 +7,7 @@
void clkrst_init(void) { diff --git a/arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c b/arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c index c5d1f60..7df5aea 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/ddrphy_init.c @@ -6,7 +6,7 @@
void ddrphy_init(struct ddrphy __iomem *phy, int freq, int size) { diff --git a/arch/arm/mach-uniphier/ph1-pro4/lowlevel_debug.S b/arch/arm/mach-uniphier/ph1-pro4/lowlevel_debug.S index a793b7c..45aef7a 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/lowlevel_debug.S +++ b/arch/arm/mach-uniphier/ph1-pro4/lowlevel_debug.S @@ -8,11 +8,11 @@ */
#include <linux/linkage.h> -#include <asm/arch/sc-regs.h> -#include <asm/arch/sg-regs.h> +#include <mach/sc-regs.h> +#include <mach/sg-regs.h>
#define UART_CLK 73728000 -#include <asm/arch/debug-uart.S> +#include <mach/debug-uart.S>
ENTRY(setup_lowlevel_debug) ldr r0, =SC_CLKCTRL diff --git a/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c b/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c index 4e3d476..c8c0267 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c +++ b/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c @@ -6,7 +6,7 @@
void pin_init(void) { diff --git a/arch/arm/mach-uniphier/ph1-pro4/platdevice.c b/arch/arm/mach-uniphier/ph1-pro4/platdevice.c index 31ee2a2..5fc5d38 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/platdevice.c +++ b/arch/arm/mach-uniphier/ph1-pro4/platdevice.c @@ -5,7 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
#define UART_MASTER_CLK 73728000
diff --git a/arch/arm/mach-uniphier/ph1-pro4/pll_init.c b/arch/arm/mach-uniphier/ph1-pro4/pll_init.c index 1db90f8..3d29548 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/pll_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/pll_init.c @@ -6,8 +6,8 @@
diff --git a/arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c b/arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c index 4538d1a..ff9c73f 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c +++ b/arch/arm/mach-uniphier/ph1-pro4/pll_spectrum.c @@ -6,7 +6,7 @@
void enable_dpll_ssc(void) { diff --git a/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c b/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c index 3c82a1a..37acfb5 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c @@ -7,8 +7,8 @@
void sbc_init(void) { diff --git a/arch/arm/mach-uniphier/ph1-pro4/sg_init.c b/arch/arm/mach-uniphier/ph1-pro4/sg_init.c index b7c4b10..c25afa8 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/sg_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/sg_init.c @@ -7,7 +7,7 @@
void sg_init(void) { diff --git a/arch/arm/mach-uniphier/ph1-pro4/umc_init.c b/arch/arm/mach-uniphier/ph1-pro4/umc_init.c index 2d1bde6..6cbb6b2 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/umc_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/umc_init.c @@ -6,8 +6,8 @@
static void umc_start_ssif(void __iomem *ssif_base) { diff --git a/arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c b/arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c index 18965a9..6a9d144 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c +++ b/arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c @@ -7,7 +7,7 @@
void clkrst_init(void) { diff --git a/arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c b/arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c index a5eafef..304edfb 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c +++ b/arch/arm/mach-uniphier/ph1-sld8/ddrphy_init.c @@ -7,7 +7,7 @@ #include <config.h> #include <linux/types.h> #include <asm/io.h> -#include <asm/arch/ddrphy-regs.h> +#include <mach/ddrphy-regs.h>
void ddrphy_init(struct ddrphy __iomem *phy, int freq, int size) { diff --git a/arch/arm/mach-uniphier/ph1-sld8/lowlevel_debug.S b/arch/arm/mach-uniphier/ph1-sld8/lowlevel_debug.S index a413e5f..73f0f63 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/lowlevel_debug.S +++ b/arch/arm/mach-uniphier/ph1-sld8/lowlevel_debug.S @@ -8,10 +8,10 @@ */
#define UART_CLK 80000000 -#include <asm/arch/debug-uart.S> +#include <mach/debug-uart.S>
ENTRY(setup_lowlevel_debug) init_debug_uart r0, r1, r2 diff --git a/arch/arm/mach-uniphier/ph1-sld8/pinctrl.c b/arch/arm/mach-uniphier/ph1-sld8/pinctrl.c index 5e80335..4c494ff 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/pinctrl.c +++ b/arch/arm/mach-uniphier/ph1-sld8/pinctrl.c @@ -6,7 +6,7 @@
void pin_init(void) { diff --git a/arch/arm/mach-uniphier/ph1-sld8/platdevice.c b/arch/arm/mach-uniphier/ph1-sld8/platdevice.c index ea0691d..ee6d3e2 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/platdevice.c +++ b/arch/arm/mach-uniphier/ph1-sld8/platdevice.c @@ -5,7 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
#define UART_MASTER_CLK 80000000
diff --git a/arch/arm/mach-uniphier/ph1-sld8/pll_init.c b/arch/arm/mach-uniphier/ph1-sld8/pll_init.c index 4b82700..8851007 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/pll_init.c +++ b/arch/arm/mach-uniphier/ph1-sld8/pll_init.c @@ -6,8 +6,8 @@
static void dpll_init(void) { diff --git a/arch/arm/mach-uniphier/ph1-sld8/sbc_init.c b/arch/arm/mach-uniphier/ph1-sld8/sbc_init.c index 5efee9c..febd0e4 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/sbc_init.c +++ b/arch/arm/mach-uniphier/ph1-sld8/sbc_init.c @@ -7,8 +7,8 @@
void sbc_init(void) { diff --git a/arch/arm/mach-uniphier/ph1-sld8/umc_init.c b/arch/arm/mach-uniphier/ph1-sld8/umc_init.c index 2fbc73a..302611e 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/umc_init.c +++ b/arch/arm/mach-uniphier/ph1-sld8/umc_init.c @@ -6,8 +6,8 @@
static void umc_start_ssif(void __iomem *ssif_base) { diff --git a/arch/arm/mach-uniphier/print_misc_info.c b/arch/arm/mach-uniphier/print_misc_info.c index 69cfab5..22ea512 100644 --- a/arch/arm/mach-uniphier/print_misc_info.c +++ b/arch/arm/mach-uniphier/print_misc_info.c @@ -5,7 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
int misc_init_f(void) { diff --git a/arch/arm/mach-uniphier/reset.c b/arch/arm/mach-uniphier/reset.c index 50d1fed..005fbcf 100644 --- a/arch/arm/mach-uniphier/reset.c +++ b/arch/arm/mach-uniphier/reset.c @@ -7,7 +7,7 @@
void reset_cpu(unsigned long ignored) { diff --git a/arch/arm/mach-uniphier/smp.S b/arch/arm/mach-uniphier/smp.S index 25ba981..18e3a9d 100644 --- a/arch/arm/mach-uniphier/smp.S +++ b/arch/arm/mach-uniphier/smp.S @@ -8,8 +8,8 @@ #include <config.h> #include <linux/linkage.h> #include <asm/system.h> -#include <asm/arch/led.h> -#include <asm/arch/sbc-regs.h> +#include <mach/led.h> +#include <mach/sbc-regs.h>
/* Entry point of U-Boot main program for the secondary CPU */ LENTRY(secondary_entry) diff --git a/arch/arm/mach-uniphier/spl.c b/arch/arm/mach-uniphier/spl.c index 8a4eafc..5cdf69a 100644 --- a/arch/arm/mach-uniphier/spl.c +++ b/arch/arm/mach-uniphier/spl.c @@ -8,8 +8,8 @@ #include <common.h> #include <spl.h> #include <linux/compiler.h> -#include <asm/arch/led.h> -#include <asm/arch/board.h> +#include <mach/led.h> +#include <mach/board.h>
void __weak bcu_init(void) { diff --git a/arch/arm/mach-uniphier/support_card.c b/arch/arm/mach-uniphier/support_card.c index 443224c..e7b4158 100644 --- a/arch/arm/mach-uniphier/support_card.c +++ b/arch/arm/mach-uniphier/support_card.c @@ -7,7 +7,7 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/board.h> +#include <mach/board.h>
#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD)
@@ -112,7 +112,7 @@ int board_eth_init(bd_t *bis) #if !defined(CONFIG_SYS_NO_FLASH)
#include <mtd/cfi_flash.h> -#include <asm/arch/sbc-regs.h> +#include <mach/sbc-regs.h>
struct memory_bank { phys_addr_t base; diff --git a/arch/arm/mach-uniphier/timer.c b/arch/arm/mach-uniphier/timer.c index 6edc084..adef08d 100644 --- a/arch/arm/mach-uniphier/timer.c +++ b/arch/arm/mach-uniphier/timer.c @@ -7,7 +7,7 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/arm-mpcore.h> +#include <mach/arm-mpcore.h>
#define PERIPHCLK (50 * 1000 * 1000) /* 50 MHz */ #define PRESCALER ((PERIPHCLK) / (CONFIG_SYS_TIMER_RATE) - 1) diff --git a/drivers/usb/host/ehci-uniphier.c b/drivers/usb/host/ehci-uniphier.c index 32a4375..42e2204 100644 --- a/drivers/usb/host/ehci-uniphier.c +++ b/drivers/usb/host/ehci-uniphier.c @@ -8,7 +8,7 @@ #include <common.h> #include <linux/err.h> #include <usb.h> -#include <asm/arch/ehci-uniphier.h> +#include <mach/ehci-uniphier.h> #include "ehci.h"
#ifdef CONFIG_OF_CONTROL
Changes in v4: None Changes in v3: None Changes in v2: None
arch/arm/mach-uniphier/ph1-pro4/sbc_init.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c b/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c index 37acfb5..6940559 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ @@ -35,8 +35,8 @@ void sbc_init(void) /* * Boot Swap Off: boot from mask ROM * 0x00000000-0x01ffffff: mask ROM - * 0x02000000-0x3effffff: memory bank (31MB) - * 0x03f00000-0x3fffffff: peripherals (1MB) + * 0x02000000-0x03efffff: memory bank (31MB) + * 0x03f00000-0x03ffffff: peripherals (1MB) */ writel(0x0000be01, SBBASE0); /* dummy */ writel(0x0200be01, SBBASE1);
Now UniPhier SoCs only work with CONFIG_SPL and the function sbc_init() is called from SPL. The conditional #if !defined(CONFIG_SPL_BUILD) has no point any more.
arch/arm/mach-uniphier/ph1-ld4/sbc_init.c | 11 +++++------ arch/arm/mach-uniphier/ph1-pro4/sbc_init.c | 10 +++++----- arch/arm/mach-uniphier/ph1-sld8/sbc_init.c | 28 ++++++++++++++-------------- 3 files changed, 24 insertions(+), 25 deletions(-)
diff --git a/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c b/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c index f44195d..374a8c0 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ @@ -25,13 +25,12 @@ void sbc_init(void) writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14);
-#if !defined(CONFIG_SPL_BUILD) /* XECS0: boot/sub memory (boot swap = off/on) */ writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00); writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01); writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02); writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04); -#endif + /* XECS3: peripherals */ writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL30); writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL31); @@ -43,9 +42,9 @@ void sbc_init(void) writel(0x0400bc01, SBBASE1); writel(0x0800bf01, SBBASE3);
-#if !defined(CONFIG_SPL_BUILD) /* enable access to sub memory when boot swap is on */ - sg_set_pinsel(155, 1); /* PORT24 -> XECS0 */ -#endif + if (boot_is_swapped()) + sg_set_pinsel(155, 1); /* PORT24 -> XECS0 */ + sg_set_pinsel(156, 1); /* PORT25 -> XECS3 */ } diff --git a/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c b/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c index 6940559..4cc5e75 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c @@ -42,13 +42,12 @@ void sbc_init(void) writel(0x0200be01, SBBASE1); } #elif defined(CONFIG_DCC_MICRO_SUPPORT_CARD) -#if !defined(CONFIG_SPL_BUILD) /* XECS0: boot/sub memory (boot swap = off/on) */ writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00); writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01); writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02); writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04); -#endif + /* XECS1: sub/boot memory (boot swap = off/on) */ writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); @@ -65,9 +64,10 @@ void sbc_init(void) writel(0x0400bc01, SBBASE1); /* sub memory */ writel(0x0800bf01, SBBASE3); /* peripherals */
-#if !defined(CONFIG_SPL_BUILD) - sg_set_pinsel(318, 5); /* PORT22 -> XECS0 */ -#endif + /* enable access to sub memory when boot swap is on */ + if (boot_is_swapped()) + sg_set_pinsel(318, 5); /* PORT22 -> XECS0 */ + sg_set_pinsel(313, 5); /* PORT15 -> XECS3 */ writel(0x00000001, SG_LOADPINCTRL);
diff --git a/arch/arm/mach-uniphier/ph1-sld8/sbc_init.c b/arch/arm/mach-uniphier/ph1-sld8/sbc_init.c index febd0e4..fdef88e 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/sbc_init.c +++ b/arch/arm/mach-uniphier/ph1-sld8/sbc_init.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ @@ -19,18 +19,18 @@ void sbc_init(void) tmp &= 0xfffffcff; writel(tmp, PC0CTRL);
-#if !defined(CONFIG_SPL_BUILD) - /* XECS0 : dummy */ - writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00); - writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01); - writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02); - writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04); -#endif - /* XECS1 : boot memory (always boot swap = on) */ - writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); - writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); - writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); - writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); + /* + * SBCTRL0* does not need settings because PH1-sLD8 has no support for + * XECS0. The boot swap must be enabled to boot from the support card. + */ + + if (boot_is_swapped()) { + /* XECS1 : boot memory if boot swap is on */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); + }
/* XECS4 : sub memory */ writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL40); @@ -54,5 +54,5 @@ void sbc_init(void) sg_set_pinsel(135, 16); /* XIRQ7 -> XECS5 */
/* dummy read to assure write process */ - readl(SG_PINCTRL(33)); + readl(SG_PINCTRL(0)); }
Split the current clkrst_init() into two functions:
- early_clkrst_init(): called from SPL Deassert the reset signals of the memory controller and some other basic cores.
- clkrst_init(): called from main U-boot Deassert the reset signals that are necessary for the access to peripherals etc.
arch/arm/mach-uniphier/board_early_init_f.c | 5 ++++ arch/arm/mach-uniphier/ph1-ld4/Makefile | 4 +-- arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c | 22 +++++++++++----- arch/arm/mach-uniphier/ph1-ld4/early_clkrst_init.c | 1 + arch/arm/mach-uniphier/ph1-pro4/Makefile | 4 +-- arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c | 22 +++++++++++----- .../arm/mach-uniphier/ph1-pro4/early_clkrst_init.c | 26 +++++++++++++++++++ arch/arm/mach-uniphier/ph1-sld8/Makefile | 4 +-- arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c | 30 +--------------------- .../arm/mach-uniphier/ph1-sld8/early_clkrst_init.c | 1 + arch/arm/mach-uniphier/spl.c | 4 +-- 11 files changed, 74 insertions(+), 49 deletions(-) create mode 100644 arch/arm/mach-uniphier/ph1-ld4/early_clkrst_init.c create mode 100644 arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c create mode 100644 arch/arm/mach-uniphier/ph1-sld8/early_clkrst_init.c
diff --git a/arch/arm/mach-uniphier/board_early_init_f.c b/arch/arm/mach-uniphier/board_early_init_f.c index bf81345..7108740 100644 --- a/arch/arm/mach-uniphier/board_early_init_f.c +++ b/arch/arm/mach-uniphier/board_early_init_f.c @@ -9,6 +9,7 @@ #include <mach/board.h>
void pin_init(void); +void clkrst_init(void);
int board_early_init_f(void) { @@ -18,5 +19,9 @@ int board_early_init_f(void)
led_write(U, 1, , );
+ clkrst_init(); + + led_write(U, 2, , ); + return 0; } diff --git a/arch/arm/mach-uniphier/ph1-ld4/Makefile b/arch/arm/mach-uniphier/ph1-ld4/Makefile index 72f4663..927640a 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/Makefile +++ b/arch/arm/mach-uniphier/ph1-ld4/Makefile @@ -4,10 +4,10 @@
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_DEBUG_LL) += lowlevel_debug.o -obj-y += bcu_init.o sbc_init.o sg_init.o pll_init.o clkrst_init.o \ +obj-y += bcu_init.o sbc_init.o sg_init.o pll_init.o early_clkrst_init.o \ pll_spectrum.o umc_init.o ddrphy_init.o else -obj-$(CONFIG_BOARD_EARLY_INIT_F) += pinctrl.o +obj-$(CONFIG_BOARD_EARLY_INIT_F) += pinctrl.o clkrst_init.o obj-$(if $(CONFIG_OF_CONTROL),,y) += platdevice.o endif
diff --git a/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c b/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c index 6a9d144..158132c 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c @@ -1,11 +1,10 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ */
-#include <common.h> #include <asm/io.h> #include <mach/sc-regs.h>
@@ -15,15 +14,26 @@ void clkrst_init(void)
/* deassert reset */ tmp = readl(SC_RSTCTRL); - tmp |= SC_RSTCTRL_NRST_ETHER | SC_RSTCTRL_NRST_UMC1 - | SC_RSTCTRL_NRST_UMC0 | SC_RSTCTRL_NRST_NAND; +#ifdef CONFIG_UNIPHIER_ETH + tmp |= SC_RSTCTRL_NRST_ETHER; +#endif +#ifdef CONFIG_NAND_DENALI + tmp |= SC_RSTCTRL_NRST_NAND; +#endif writel(tmp, SC_RSTCTRL); readl(SC_RSTCTRL); /* dummy read */
/* privide clocks */ tmp = readl(SC_CLKCTRL); - tmp |= SC_CLKCTRL_CLK_ETHER | SC_CLKCTRL_CLK_MIO | SC_CLKCTRL_CLK_UMC - | SC_CLKCTRL_CLK_NAND | SC_CLKCTRL_CLK_SBC | SC_CLKCTRL_CLK_PERI; +#ifdef CONFIG_UNIPHIER_ETH + tmp |= SC_CLKCTRL_CLK_ETHER; +#endif +#ifdef CONFIG_USB_EHCI_UNIPHIER + tmp |= SC_CLKCTRL_CLK_MIO; +#endif +#ifdef CONFIG_NAND_DENALI + tmp |= SC_CLKCTRL_CLK_NAND; +#endif writel(tmp, SC_CLKCTRL); readl(SC_CLKCTRL); /* dummy read */ } diff --git a/arch/arm/mach-uniphier/ph1-ld4/early_clkrst_init.c b/arch/arm/mach-uniphier/ph1-ld4/early_clkrst_init.c new file mode 100644 index 0000000..d7ef16b --- /dev/null +++ b/arch/arm/mach-uniphier/ph1-ld4/early_clkrst_init.c @@ -0,0 +1 @@ +#include "../ph1-pro4/early_clkrst_init.c" diff --git a/arch/arm/mach-uniphier/ph1-pro4/Makefile b/arch/arm/mach-uniphier/ph1-pro4/Makefile index e330fda..0390506 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/Makefile +++ b/arch/arm/mach-uniphier/ph1-pro4/Makefile @@ -4,10 +4,10 @@
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_DEBUG_LL) += lowlevel_debug.o -obj-y += sbc_init.o sg_init.o pll_init.o clkrst_init.o \ +obj-y += sbc_init.o sg_init.o pll_init.o early_clkrst_init.o \ pll_spectrum.o umc_init.o ddrphy_init.o else -obj-$(CONFIG_BOARD_EARLY_INIT_F) += pinctrl.o +obj-$(CONFIG_BOARD_EARLY_INIT_F) += pinctrl.o clkrst_init.o obj-$(if $(CONFIG_OF_CONTROL),,y) += platdevice.o endif
diff --git a/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c b/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c index 6a9d144..158132c 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c @@ -1,11 +1,10 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ */
/* privide clocks */ tmp = readl(SC_CLKCTRL); - tmp |= SC_CLKCTRL_CLK_ETHER | SC_CLKCTRL_CLK_MIO | SC_CLKCTRL_CLK_UMC - | SC_CLKCTRL_CLK_NAND | SC_CLKCTRL_CLK_SBC | SC_CLKCTRL_CLK_PERI; +#ifdef CONFIG_UNIPHIER_ETH + tmp |= SC_CLKCTRL_CLK_ETHER; +#endif +#ifdef CONFIG_USB_EHCI_UNIPHIER + tmp |= SC_CLKCTRL_CLK_MIO; +#endif +#ifdef CONFIG_NAND_DENALI + tmp |= SC_CLKCTRL_CLK_NAND; +#endif writel(tmp, SC_CLKCTRL); readl(SC_CLKCTRL); /* dummy read */ } diff --git a/arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c b/arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c new file mode 100644 index 0000000..6c006f3 --- /dev/null +++ b/arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c @@ -0,0 +1,26 @@ +/* + * Copyright (C) 2011-2015 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/io.h> +#include <mach/sc-regs.h> + +void early_clkrst_init(void) +{ + u32 tmp; + + /* deassert reset */ + tmp = readl(SC_RSTCTRL); + tmp |= SC_RSTCTRL_NRST_UMC1 | SC_RSTCTRL_NRST_UMC0; + writel(tmp, SC_RSTCTRL); + readl(SC_RSTCTRL); /* dummy read */ + + /* privide clocks */ + tmp = readl(SC_CLKCTRL); + tmp |= SC_CLKCTRL_CLK_UMC | SC_CLKCTRL_CLK_SBC | SC_CLKCTRL_CLK_PERI; + writel(tmp, SC_CLKCTRL); + readl(SC_CLKCTRL); /* dummy read */ +} diff --git a/arch/arm/mach-uniphier/ph1-sld8/Makefile b/arch/arm/mach-uniphier/ph1-sld8/Makefile index 72f4663..927640a 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/Makefile +++ b/arch/arm/mach-uniphier/ph1-sld8/Makefile @@ -4,10 +4,10 @@
diff --git a/arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c b/arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c index 6a9d144..8d3435d 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c +++ b/arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c @@ -1,29 +1 @@ -/* - * Copyright (C) 2011-2014 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/io.h> -#include <mach/sc-regs.h> - -void clkrst_init(void) -{ - u32 tmp; - - /* deassert reset */ - tmp = readl(SC_RSTCTRL); - tmp |= SC_RSTCTRL_NRST_ETHER | SC_RSTCTRL_NRST_UMC1 - | SC_RSTCTRL_NRST_UMC0 | SC_RSTCTRL_NRST_NAND; - writel(tmp, SC_RSTCTRL); - readl(SC_RSTCTRL); /* dummy read */ - - /* privide clocks */ - tmp = readl(SC_CLKCTRL); - tmp |= SC_CLKCTRL_CLK_ETHER | SC_CLKCTRL_CLK_MIO | SC_CLKCTRL_CLK_UMC - | SC_CLKCTRL_CLK_NAND | SC_CLKCTRL_CLK_SBC | SC_CLKCTRL_CLK_PERI; - writel(tmp, SC_CLKCTRL); - readl(SC_CLKCTRL); /* dummy read */ -} +#include "../ph1-ld4/clkrst_init.c" diff --git a/arch/arm/mach-uniphier/ph1-sld8/early_clkrst_init.c b/arch/arm/mach-uniphier/ph1-sld8/early_clkrst_init.c new file mode 100644 index 0000000..dd236b7 --- /dev/null +++ b/arch/arm/mach-uniphier/ph1-sld8/early_clkrst_init.c @@ -0,0 +1 @@ +#include "../ph1-ld4/early_clkrst_init.c" diff --git a/arch/arm/mach-uniphier/spl.c b/arch/arm/mach-uniphier/spl.c index 5cdf69a..c8a2469 100644 --- a/arch/arm/mach-uniphier/spl.c +++ b/arch/arm/mach-uniphier/spl.c @@ -18,7 +18,7 @@ void sbc_init(void); void sg_init(void); void pll_init(void); void pin_init(void); -void clkrst_init(void); +void early_clkrst_init(void); int umc_init(void); void enable_dpll_ssc(void);
@@ -38,7 +38,7 @@ void spl_board_init(void)
led_write(L, 0, , );
- clkrst_init(); + early_clkrst_init();
led_write(L, 1, , );
For all the UniPhier SoCs so far, the reset signal of the NAND core is automatically deasserted after the PLL gets stabled. (The bit 2 of SC_RSTCTRL is default to one.)
This causes a fatal problem on the NAND controller of PH1-LD4. For that SoC, the NAND I/O pins are not set up yet at the power-on reset except the NAND boot mode. As a result, the NAND controller begins automatic device scanning with wrong I/O pins and finally hangs up.
Actually, U-Boot dies after printing "NAND:" on the console unless the boot mode latch detected the NAND boot mode.
To work around this problem, reset the NAND core in SPL for non-NAND boot modes. If CONFIG_NAND_DENALI is enabled, the reset signal is deasserted again in U-Boot proper. At this time, I/O pins have been correctly set up, the device scanning should succeed.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Changes in v4: None Changes in v3: None Changes in v2: - Added
arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c b/arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c index 6c006f3..e18bf9c 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/early_clkrst_init.c @@ -5,6 +5,8 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <common.h> +#include <spl.h> #include <asm/io.h> #include <mach/sc-regs.h>
@@ -14,7 +16,10 @@ void early_clkrst_init(void)
/* deassert reset */ tmp = readl(SC_RSTCTRL); + tmp |= SC_RSTCTRL_NRST_UMC1 | SC_RSTCTRL_NRST_UMC0; + if (spl_boot_device() != BOOT_DEVICE_NAND) + tmp &= ~SC_RSTCTRL_NRST_NAND; writel(tmp, SC_RSTCTRL); readl(SC_RSTCTRL); /* dummy read */
Deassert the reset signal and provide the clock for STDMAC core. This is necessary for the USB 2.0 host controllers.
arch/arm/mach-uniphier/include/mach/sc-regs.h | 2 ++ arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c | 5 ++++- arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c | 5 ++++- 3 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-uniphier/include/mach/sc-regs.h b/arch/arm/mach-uniphier/include/mach/sc-regs.h index 1197bb5..daeeec9 100644 --- a/arch/arm/mach-uniphier/include/mach/sc-regs.h +++ b/arch/arm/mach-uniphier/include/mach/sc-regs.h @@ -39,6 +39,7 @@
#define SC_RSTCTRL (SC_BASE_ADDR | 0x2000) #define SC_RSTCTRL_NRST_ETHER (0x1 << 12) +#define SC_RSTCTRL_NRST_STDMAC (0x1 << 10) #define SC_RSTCTRL_NRST_UMC1 (0x1 << 5) #define SC_RSTCTRL_NRST_UMC0 (0x1 << 4) #define SC_RSTCTRL_NRST_NAND (0x1 << 2) @@ -49,6 +50,7 @@ #define SC_CLKCTRL (SC_BASE_ADDR | 0x2104) #define SC_CLKCTRL_CLK_ETHER (0x1 << 12) #define SC_CLKCTRL_CLK_MIO (0x1 << 11) +#define SC_CLKCTRL_CLK_STDMAC (0x1 << 10) #define SC_CLKCTRL_CLK_UMC (0x1 << 4) #define SC_CLKCTRL_CLK_NAND (0x1 << 2) #define SC_CLKCTRL_CLK_SBC (0x1 << 1) diff --git a/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c b/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c index 158132c..9fb0342 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/clkrst_init.c @@ -17,6 +17,9 @@ void clkrst_init(void) #ifdef CONFIG_UNIPHIER_ETH tmp |= SC_RSTCTRL_NRST_ETHER; #endif +#ifdef CONFIG_USB_EHCI_UNIPHIER + tmp |= SC_RSTCTRL_NRST_STDMAC; +#endif #ifdef CONFIG_NAND_DENALI tmp |= SC_RSTCTRL_NRST_NAND; #endif @@ -29,7 +32,7 @@ void clkrst_init(void) tmp |= SC_CLKCTRL_CLK_ETHER; #endif #ifdef CONFIG_USB_EHCI_UNIPHIER - tmp |= SC_CLKCTRL_CLK_MIO; + tmp |= SC_CLKCTRL_CLK_MIO | SC_CLKCTRL_CLK_STDMAC; #endif #ifdef CONFIG_NAND_DENALI tmp |= SC_CLKCTRL_CLK_NAND; diff --git a/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c b/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c index 158132c..9fb0342 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c @@ -17,6 +17,9 @@ void clkrst_init(void) #ifdef CONFIG_UNIPHIER_ETH tmp |= SC_RSTCTRL_NRST_ETHER; #endif +#ifdef CONFIG_USB_EHCI_UNIPHIER + tmp |= SC_RSTCTRL_NRST_STDMAC; +#endif #ifdef CONFIG_NAND_DENALI tmp |= SC_RSTCTRL_NRST_NAND; #endif @@ -29,7 +32,7 @@ void clkrst_init(void) tmp |= SC_CLKCTRL_CLK_ETHER; #endif #ifdef CONFIG_USB_EHCI_UNIPHIER - tmp |= SC_CLKCTRL_CLK_MIO; + tmp |= SC_CLKCTRL_CLK_MIO | SC_CLKCTRL_CLK_STDMAC; #endif #ifdef CONFIG_NAND_DENALI tmp |= SC_CLKCTRL_CLK_NAND;
Now UniPhier platform highly depends on Device Tree configuration (CONFIG_OF_CONTROL is select'ed by Kconfig). Since the EHCI is only used on main U-Boot, we can drop platform devices of the EHCI controllers. We still keep UART platform devices because they might be useful for SPL.
arch/arm/mach-uniphier/include/mach/ehci-uniphier.h | 8 +------- arch/arm/mach-uniphier/include/mach/platdevice.h | 2 -- arch/arm/mach-uniphier/ph1-ld4/platdevice.c | 14 +------------- arch/arm/mach-uniphier/ph1-pro4/platdevice.c | 11 +---------- arch/arm/mach-uniphier/ph1-sld8/platdevice.c | 14 +------------- drivers/usb/host/Kconfig | 2 +- drivers/usb/host/ehci-uniphier.c | 14 +------------- 7 files changed, 6 insertions(+), 59 deletions(-)
diff --git a/arch/arm/mach-uniphier/include/mach/ehci-uniphier.h b/arch/arm/mach-uniphier/include/mach/ehci-uniphier.h index e9c5fb4..3ba3183 100644 --- a/arch/arm/mach-uniphier/include/mach/ehci-uniphier.h +++ b/arch/arm/mach-uniphier/include/mach/ehci-uniphier.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2014 Panasonic Corporation + * Copyright (C) 2014-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ @@ -12,12 +12,6 @@ #include <asm/io.h> #include "mio-regs.h"
-struct uniphier_ehci_platform_data { - unsigned long base; -}; - -extern struct uniphier_ehci_platform_data uniphier_ehci_platdata[]; - static inline void uniphier_ehci_reset(int index, int on) { u32 tmp; diff --git a/arch/arm/mach-uniphier/include/mach/platdevice.h b/arch/arm/mach-uniphier/include/mach/platdevice.h index b004c2f..cdf7d13 100644 --- a/arch/arm/mach-uniphier/include/mach/platdevice.h +++ b/arch/arm/mach-uniphier/include/mach/platdevice.h @@ -21,6 +21,4 @@ U_BOOT_DEVICE(serial##n) = { \ .platdata = &serial_device##n \ };
-#include <mach/ehci-uniphier.h> - #endif /* ARCH_PLATDEVICE_H */ diff --git a/arch/arm/mach-uniphier/ph1-ld4/platdevice.c b/arch/arm/mach-uniphier/ph1-ld4/platdevice.c index 5a3fbdc..c0e6294 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/platdevice.c +++ b/arch/arm/mach-uniphier/ph1-ld4/platdevice.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2014 Panasonic Corporation + * Copyright (C) 2014-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ @@ -13,15 +13,3 @@ SERIAL_DEVICE(0, 0x54006800, UART_MASTER_CLK) SERIAL_DEVICE(1, 0x54006900, UART_MASTER_CLK) SERIAL_DEVICE(2, 0x54006a00, UART_MASTER_CLK) SERIAL_DEVICE(3, 0x54006b00, UART_MASTER_CLK) - -struct uniphier_ehci_platform_data uniphier_ehci_platdata[] = { - { - .base = 0x5a800100, - }, - { - .base = 0x5a810100, - }, - { - .base = 0x5a820100, - }, -}; diff --git a/arch/arm/mach-uniphier/ph1-pro4/platdevice.c b/arch/arm/mach-uniphier/ph1-pro4/platdevice.c index 5fc5d38..7440ced 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/platdevice.c +++ b/arch/arm/mach-uniphier/ph1-pro4/platdevice.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2014 Panasonic Corporation + * Copyright (C) 2014-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ @@ -13,12 +13,3 @@ SERIAL_DEVICE(0, 0x54006800, UART_MASTER_CLK) SERIAL_DEVICE(1, 0x54006900, UART_MASTER_CLK) SERIAL_DEVICE(2, 0x54006a00, UART_MASTER_CLK) SERIAL_DEVICE(3, 0x54006b00, UART_MASTER_CLK) - -struct uniphier_ehci_platform_data uniphier_ehci_platdata[] = { - { - .base = 0x5a800100, - }, - { - .base = 0x5a810100, - }, -}; diff --git a/arch/arm/mach-uniphier/ph1-sld8/platdevice.c b/arch/arm/mach-uniphier/ph1-sld8/platdevice.c index ee6d3e2..aa334a1 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/platdevice.c +++ b/arch/arm/mach-uniphier/ph1-sld8/platdevice.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2014 Panasonic Corporation + * Copyright (C) 2014-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ @@ -13,15 +13,3 @@ SERIAL_DEVICE(0, 0x54006800, UART_MASTER_CLK) SERIAL_DEVICE(1, 0x54006900, UART_MASTER_CLK) SERIAL_DEVICE(2, 0x54006a00, UART_MASTER_CLK) SERIAL_DEVICE(3, 0x54006b00, UART_MASTER_CLK) - -struct uniphier_ehci_platform_data uniphier_ehci_platdata[] = { - { - .base = 0x5a800100, - }, - { - .base = 0x5a810100, - }, - { - .base = 0x5a820100, - }, -}; diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 30d1457..0e005c2 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -47,7 +47,7 @@ if USB_EHCI_HCD
config USB_EHCI_UNIPHIER bool "Support for Panasonic UniPhier on-chip EHCI USB controller" - depends on ARCH_UNIPHIER + depends on ARCH_UNIPHIER && OF_CONTROL default y ---help--- Enables support for the on-chip EHCI controller on Panasonic diff --git a/drivers/usb/host/ehci-uniphier.c b/drivers/usb/host/ehci-uniphier.c index 42e2204..68959ef 100644 --- a/drivers/usb/host/ehci-uniphier.c +++ b/drivers/usb/host/ehci-uniphier.c @@ -9,10 +9,9 @@ #include <linux/err.h> #include <usb.h> #include <mach/ehci-uniphier.h> +#include <fdtdec.h> #include "ehci.h"
-#ifdef CONFIG_OF_CONTROL -#include <fdtdec.h> DECLARE_GLOBAL_DATA_PTR;
#define FDT gd->fdt_blob @@ -35,18 +34,7 @@ static int get_uniphier_ehci_base(int index, struct ehci_hccr **base)
return -ENODEV; /* not found */ } -#else -static int get_uniphier_ehci_base(int index, struct ehci_hccr **base) -{ - *base = (struct ehci_hccr *)uniphier_ehci_platdata[index].base; - return 0; -} -#endif
-/* - * Create the appropriate control structures to manage - * a new EHCI host controller. - */ int ehci_hcd_init(int index, enum usb_init_type init, struct ehci_hccr **hccr, struct ehci_hcor **hcor) {
Because uniphier_ehci_reset() is only called from ehci-uniphier.c, it can be a static function there.
.../arm/mach-uniphier/include/mach/ehci-uniphier.h | 27 ---------------------- drivers/usb/host/ehci-uniphier.c | 15 +++++++++++- 2 files changed, 14 insertions(+), 28 deletions(-) delete mode 100644 arch/arm/mach-uniphier/include/mach/ehci-uniphier.h
diff --git a/arch/arm/mach-uniphier/include/mach/ehci-uniphier.h b/arch/arm/mach-uniphier/include/mach/ehci-uniphier.h deleted file mode 100644 index 3ba3183..0000000 --- a/arch/arm/mach-uniphier/include/mach/ehci-uniphier.h +++ /dev/null @@ -1,27 +0,0 @@ -/* - * Copyright (C) 2014-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __PLAT_UNIPHIER_EHCI_H -#define __PLAT_UNIPHIER_EHCI_H - -#include <linux/types.h> -#include <asm/io.h> -#include "mio-regs.h" - -static inline void uniphier_ehci_reset(int index, int on) -{ - u32 tmp; - - tmp = readl(MIO_USB_RSTCTRL(index)); - if (on) - tmp &= ~MIO_USB_RSTCTRL_XRST; - else - tmp |= MIO_USB_RSTCTRL_XRST; - writel(tmp, MIO_USB_RSTCTRL(index)); -} - -#endif /* __PLAT_UNIPHIER_EHCI_H */ diff --git a/drivers/usb/host/ehci-uniphier.c b/drivers/usb/host/ehci-uniphier.c index 68959ef..b5ec296 100644 --- a/drivers/usb/host/ehci-uniphier.c +++ b/drivers/usb/host/ehci-uniphier.c @@ -7,8 +7,9 @@
#include <common.h> #include <linux/err.h> +#include <asm/io.h> #include <usb.h> -#include <mach/ehci-uniphier.h> +#include <mach/mio-regs.h> #include <fdtdec.h> #include "ehci.h"
@@ -35,6 +36,18 @@ static int get_uniphier_ehci_base(int index, struct ehci_hccr **base) return -ENODEV; /* not found */ }
+static void uniphier_ehci_reset(int index, int on) +{ + u32 tmp; + + tmp = readl(MIO_USB_RSTCTRL(index)); + if (on) + tmp &= ~MIO_USB_RSTCTRL_XRST; + else + tmp |= MIO_USB_RSTCTRL_XRST; + writel(tmp, MIO_USB_RSTCTRL(index)); +} + int ehci_hcd_init(int index, enum usb_init_type init, struct ehci_hccr **hccr, struct ehci_hcor **hcor) {
EHCI host controllers have a common register interface. We may wish to implement a generic EHCI driver someday.
arch/arm/dts/uniphier-ph1-ld4.dtsi | 8 ++++---- arch/arm/dts/uniphier-ph1-pro4.dtsi | 6 +++--- arch/arm/dts/uniphier-ph1-sld3.dtsi | 10 +++++----- arch/arm/dts/uniphier-ph1-sld8.dtsi | 8 ++++---- 4 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/arch/arm/dts/uniphier-ph1-ld4.dtsi b/arch/arm/dts/uniphier-ph1-ld4.dtsi index 2a3dd73..8ed7bbf 100644 --- a/arch/arm/dts/uniphier-ph1-ld4.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld4.dtsi @@ -1,7 +1,7 @@ /* * Device Tree Source for UniPhier PH1-LD4 SoC * - * Copyright (C) 2014 Panasonic Corporation + * Copyright (C) 2014-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ @@ -94,19 +94,19 @@ };
usb0: usb@5a800100 { - compatible = "panasonic,uniphier-ehci", "usb-ehci"; + compatible = "panasonic,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a800100 0x100>; };
usb1: usb@5a810100 { - compatible = "panasonic,uniphier-ehci", "usb-ehci"; + compatible = "panasonic,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a810100 0x100>; };
usb2: usb@5a820100 { - compatible = "panasonic,uniphier-ehci", "usb-ehci"; + compatible = "panasonic,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a820100 0x100>; }; diff --git a/arch/arm/dts/uniphier-ph1-pro4.dtsi b/arch/arm/dts/uniphier-ph1-pro4.dtsi index 49e375e..3f1001b 100644 --- a/arch/arm/dts/uniphier-ph1-pro4.dtsi +++ b/arch/arm/dts/uniphier-ph1-pro4.dtsi @@ -1,7 +1,7 @@ /* * Device Tree Source for UniPhier PH1-Pro4 SoC * - * Copyright (C) 2014 Panasonic Corporation + * Copyright (C) 2014-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ @@ -120,13 +120,13 @@ };
usb1: usb@5a810100 { - compatible = "panasonic,uniphier-ehci", "usb-ehci"; + compatible = "panasonic,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a810100 0x100>; }; diff --git a/arch/arm/dts/uniphier-ph1-sld3.dtsi b/arch/arm/dts/uniphier-ph1-sld3.dtsi index f5529d2..88322c6 100644 --- a/arch/arm/dts/uniphier-ph1-sld3.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld3.dtsi @@ -1,7 +1,7 @@ /* * Device Tree Source for UniPhier PH1-sLD3 SoC * - * Copyright (C) 2014 Panasonic Corporation + * Copyright (C) 2014-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ @@ -93,25 +93,25 @@ };
usb3: usb@5a830100 { - compatible = "panasonic,uniphier-ehci", "usb-ehci"; + compatible = "panasonic,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a830100 0x100>; }; diff --git a/arch/arm/dts/uniphier-ph1-sld8.dtsi b/arch/arm/dts/uniphier-ph1-sld8.dtsi index 0ea76e5..1b3eb22 100644 --- a/arch/arm/dts/uniphier-ph1-sld8.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld8.dtsi @@ -1,7 +1,7 @@ /* * Device Tree Source for UniPhier PH1-sLD8 SoC * - * Copyright (C) 2014 Panasonic Corporation + * Copyright (C) 2014-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ @@ -94,19 +94,19 @@ };
This is necessary to use the xHCI cores for PH1-Pro4.
arch/arm/mach-uniphier/ph1-pro4/pinctrl.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c b/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c index c8c0267..f382ef4 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c +++ b/arch/arm/mach-uniphier/ph1-pro4/pinctrl.c @@ -41,6 +41,13 @@ void pin_init(void) sg_set_pinsel(54, 0); /* NRYBY0 -> NRYBY0 */ #endif
+#ifdef CONFIG_USB_XHCI_UNIPHIER + sg_set_pinsel(180, 0); /* USB0VBUS -> USB0VBUS */ + sg_set_pinsel(181, 0); /* USB0OD -> USB0OD */ + sg_set_pinsel(182, 0); /* USB1VBUS -> USB1VBUS */ + sg_set_pinsel(183, 0); /* USB1OD -> USB1OD */ +#endif + #ifdef CONFIG_USB_EHCI_UNIPHIER sg_set_pinsel(184, 0); /* USB2VBUS -> USB2VBUS */ sg_set_pinsel(185, 0); /* USB2OD -> USB2OD */
This is necessary to use the USB 3.0 host controllers on PH1-Pro4.
arch/arm/mach-uniphier/include/mach/sc-regs.h | 11 ++++++++++- arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c | 15 +++++++++++++++ 2 files changed, 25 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-uniphier/include/mach/sc-regs.h b/arch/arm/mach-uniphier/include/mach/sc-regs.h index daeeec9..397ace8 100644 --- a/arch/arm/mach-uniphier/include/mach/sc-regs.h +++ b/arch/arm/mach-uniphier/include/mach/sc-regs.h @@ -1,7 +1,7 @@ /* * UniPhier SC (System Control) block registers * - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Panasonic Corporation * * SPDX-License-Identifier: GPL-2.0+ */ @@ -38,19 +38,28 @@ #define SC_VPLL27BCTRL3 (SC_BASE_ADDR | 0x1298)
#define SC_RSTCTRL (SC_BASE_ADDR | 0x2000) +#define SC_RSTCTRL_NRST_USB3B0 (0x1 << 17) +#define SC_RSTCTRL_NRST_USB3C0 (0x1 << 16) #define SC_RSTCTRL_NRST_ETHER (0x1 << 12) #define SC_RSTCTRL_NRST_STDMAC (0x1 << 10) +#define SC_RSTCTRL_NRST_GIO (0x1 << 6) #define SC_RSTCTRL_NRST_UMC1 (0x1 << 5) #define SC_RSTCTRL_NRST_UMC0 (0x1 << 4) #define SC_RSTCTRL_NRST_NAND (0x1 << 2)
#define SC_RSTCTRL2 (SC_BASE_ADDR | 0x2004) +#define SC_RSTCTRL2_NRST_USB3B1 (0x1 << 17) +#define SC_RSTCTRL2_NRST_USB3C1 (0x1 << 16) + #define SC_RSTCTRL3 (SC_BASE_ADDR | 0x2008)
#define SC_CLKCTRL (SC_BASE_ADDR | 0x2104) +#define SC_CLKCTRL_CLK_USB31 (0x1 << 17) +#define SC_CLKCTRL_CLK_USB30 (0x1 << 16) #define SC_CLKCTRL_CLK_ETHER (0x1 << 12) #define SC_CLKCTRL_CLK_MIO (0x1 << 11) #define SC_CLKCTRL_CLK_STDMAC (0x1 << 10) +#define SC_CLKCTRL_CLK_GIO (0x1 << 6) #define SC_CLKCTRL_CLK_UMC (0x1 << 4) #define SC_CLKCTRL_CLK_NAND (0x1 << 2) #define SC_CLKCTRL_CLK_SBC (0x1 << 1) diff --git a/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c b/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c index 9fb0342..03e932b 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/clkrst_init.c @@ -14,6 +14,10 @@ void clkrst_init(void)
/* deassert reset */ tmp = readl(SC_RSTCTRL); +#ifdef CONFIG_USB_XHCI_UNIPHIER + tmp |= SC_RSTCTRL_NRST_USB3B0 | SC_RSTCTRL_NRST_USB3C0 | + SC_RSTCTRL_NRST_GIO; +#endif #ifdef CONFIG_UNIPHIER_ETH tmp |= SC_RSTCTRL_NRST_ETHER; #endif @@ -26,6 +30,13 @@ void clkrst_init(void) writel(tmp, SC_RSTCTRL); readl(SC_RSTCTRL); /* dummy read */
+#ifdef CONFIG_USB_XHCI_UNIPHIER + tmp = readl(SC_RSTCTRL2); + tmp |= SC_RSTCTRL2_NRST_USB3B1 | SC_RSTCTRL2_NRST_USB3C1; + writel(tmp, SC_RSTCTRL2); + readl(SC_RSTCTRL2); /* dummy read */ +#endif + /* privide clocks */ tmp = readl(SC_CLKCTRL); #ifdef CONFIG_UNIPHIER_ETH @@ -34,6 +45,10 @@ void clkrst_init(void) #ifdef CONFIG_USB_EHCI_UNIPHIER tmp |= SC_CLKCTRL_CLK_MIO | SC_CLKCTRL_CLK_STDMAC; #endif +#ifdef CONFIG_USB_XHCI_UNIPHIER + tmp |= SC_CLKCTRL_CLK_USB31 | SC_CLKCTRL_CLK_USB30 | + SC_CLKCTRL_CLK_GIO; +#endif #ifdef CONFIG_NAND_DENALI tmp |= SC_CLKCTRL_CLK_NAND; #endif
Each USB port corresponds to the following IP core: port0: xHCI (0x65a00000) SS+HS port1: xHCI (0x65c00000) HS (SS PHY is not implemented) port2: EHCI (0x5a800100) HS port3: EHCI (0x5a810100) HS
arch/arm/dts/uniphier-ph1-pro4-ref.dts | 5 +---- arch/arm/dts/uniphier-ph1-pro4.dtsi | 16 ++++++++++++++-- 2 files changed, 15 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/uniphier-ph1-pro4-ref.dts b/arch/arm/dts/uniphier-ph1-pro4-ref.dts index d9e7a8c..5bec92b 100644 --- a/arch/arm/dts/uniphier-ph1-pro4-ref.dts +++ b/arch/arm/dts/uniphier-ph1-pro4-ref.dts @@ -36,6 +36,7 @@ i2c3 = &i2c3; i2c5 = &i2c5; i2c6 = &i2c6; + usb0 = &usb0; }; };
@@ -54,7 +55,3 @@ &usb0 { status = "okay"; }; - -&usb1 { - status = "okay"; -}; diff --git a/arch/arm/dts/uniphier-ph1-pro4.dtsi b/arch/arm/dts/uniphier-ph1-pro4.dtsi index 3f1001b..1247779 100644 --- a/arch/arm/dts/uniphier-ph1-pro4.dtsi +++ b/arch/arm/dts/uniphier-ph1-pro4.dtsi @@ -119,18 +119,30 @@ status = "ok"; };
- usb0: usb@5a800100 { + usb2: usb@5a800100 { compatible = "panasonic,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a800100 0x100>; };
- usb1: usb@5a810100 { + usb3: usb@5a810100 { compatible = "panasonic,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a810100 0x100>; };
+ usb0: usb@65a00000 { + compatible = "panasonic,uniphier-xhci", "generic-xhci"; + status = "disabled"; + reg = <0x65a00000 0x100>; + }; + + usb1: usb@65c00000 { + compatible = "panasonic,uniphier-xhci", "generic-xhci"; + status = "disabled"; + reg = <0x65c00000 0x100>; + }; + nand: nand@68000000 { compatible = "denali,denali-nand-dt"; reg = <0x68000000 0x20>, <0x68100000 0x1000>;
Support xHCI host driver used on Panasonic UniPhier platform.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Acked-by: Marek Vasut marex@denx.de ---
Changes in v4: - use fdtdec_find_aliases_for_id() to get the offset to the node
Changes in v3: None Changes in v2: - add the error check of fdtdec_get_addr()
doc/README.uniphier | 3 +- drivers/usb/host/Kconfig | 8 ++++ drivers/usb/host/Makefile | 1 + drivers/usb/host/xhci-uniphier.c | 85 ++++++++++++++++++++++++++++++++++++++++ include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 6 files changed, 98 insertions(+), 1 deletion(-) create mode 100644 drivers/usb/host/xhci-uniphier.c
diff --git a/doc/README.uniphier b/doc/README.uniphier index aaeb50c..4902533 100644 --- a/doc/README.uniphier +++ b/doc/README.uniphier @@ -73,7 +73,8 @@ Supported devices
- UART (on-chip) - NAND - - USB (2.0) + - USB 2.0 (EHCI) + - USB 3.0 (xHCI) - LAN (on-board SMSC9118) - I2C - EEPROM (connected to the on-board I2C bus) diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 0e005c2..24a595f 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -17,6 +17,14 @@ config USB_XHCI
if USB_XHCI_HCD
+config USB_XHCI_UNIPHIER + bool "Support for Panasonic UniPhier on-chip xHCI USB controller" + depends on ARCH_UNIPHIER + default y + ---help--- + Enables support for the on-chip xHCI controller on Panasonic + UniPhier SoCs. + endif
config USB_EHCI_HCD diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 66d6e9a..eb6f34b 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -48,6 +48,7 @@ obj-$(CONFIG_USB_XHCI_KEYSTONE) += xhci-keystone.o obj-$(CONFIG_USB_XHCI_EXYNOS) += xhci-exynos5.o obj-$(CONFIG_USB_XHCI_OMAP) += xhci-omap.o obj-$(CONFIG_USB_XHCI_PCI) += xhci-pci.o +obj-$(CONFIG_USB_XHCI_UNIPHIER) += xhci-uniphier.o
# designware obj-$(CONFIG_USB_DWC2) += dwc2.o diff --git a/drivers/usb/host/xhci-uniphier.c b/drivers/usb/host/xhci-uniphier.c new file mode 100644 index 0000000..08b15e0 --- /dev/null +++ b/drivers/usb/host/xhci-uniphier.c @@ -0,0 +1,85 @@ +/* + * Copyright (C) 2015 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/err.h> +#include <usb.h> +#include <fdtdec.h> +#include "xhci.h" + +static int get_uniphier_xhci_base(int index, struct xhci_hccr **base) +{ + DECLARE_GLOBAL_DATA_PTR; + int node_list[2]; + fdt_addr_t addr; + int count; + + count = fdtdec_find_aliases_for_id(gd->fdt_blob, "usb", + COMPAT_PANASONIC_XHCI, node_list, + ARRAY_SIZE(node_list)); + + if (index >= count) + return -ENODEV; + + addr = fdtdec_get_addr(gd->fdt_blob, node_list[index], "reg"); + if (addr == FDT_ADDR_T_NONE) + return -ENODEV; + + *base = (struct xhci_hccr *)addr; + + return 0; +} + +#define USB3_RST_CTRL 0x00100040 +#define IOMMU_RST_N (1 << 5) +#define LINK_RST_N (1 << 4) + +static void uniphier_xhci_reset(void __iomem *base, int on) +{ + u32 tmp; + + tmp = readl(base + USB3_RST_CTRL); + + if (on) + tmp &= ~(IOMMU_RST_N | LINK_RST_N); + else + tmp |= IOMMU_RST_N | LINK_RST_N; + + writel(tmp, base + USB3_RST_CTRL); +} + +int xhci_hcd_init(int index, struct xhci_hccr **hccr, struct xhci_hcor **hcor) +{ + int ret; + struct xhci_hccr *cr; + struct xhci_hcor *or; + + ret = get_uniphier_xhci_base(index, &cr); + if (ret < 0) + return ret; + + uniphier_xhci_reset(cr, 0); + + or = (void *)cr + HC_LENGTH(xhci_readl(&cr->cr_capbase)); + + *hccr = cr; + *hcor = or; + + return 0; +} + +void xhci_hcd_stop(int index) +{ + int ret; + struct xhci_hccr *cr; + + ret = get_uniphier_xhci_base(index, &cr); + if (ret < 0) + return; + + uniphier_xhci_reset(cr, 1); +} diff --git a/include/fdtdec.h b/include/fdtdec.h index 1bc70db..1233dfb 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -168,6 +168,7 @@ enum fdt_compat_id { COMPAT_AMS_AS3722, /* AMS AS3722 PMIC */ COMPAT_INTEL_ICH_SPI, /* Intel ICH7/9 SPI controller */ COMPAT_INTEL_QRK_MRC, /* Intel Quark MRC */ + COMPAT_PANASONIC_XHCI, /* Panasonic UniPhier xHCI */
COMPAT_COUNT, }; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index dd58bbb..21933e4 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -76,6 +76,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(AMS_AS3722, "ams,as3722"), COMPAT(INTEL_ICH_SPI, "intel,ich-spi"), COMPAT(INTEL_QRK_MRC, "intel,quark-mrc"), + COMPAT(PANASONIC_XHCI, "panasonic,uniphier-xhci"), };
const char *fdtdec_get_compatible(enum fdt_compat_id id)
PH1-Pro4 includes both EHCI and xHCI IP cores. Unfortunately, U-Boot cannot enable EHCI and xHCI support simultaneously. Some users may wish Super-Speed connection. Disable CONFIG_USB_EHCI_HCD and enable CONFIG_USB_XHCI_HCD.
configs/ph1_pro4_defconfig | 2 +- include/configs/uniphier.h | 3 +++ 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/configs/ph1_pro4_defconfig b/configs/ph1_pro4_defconfig index 242bcf9..42a7a65 100644 --- a/configs/ph1_pro4_defconfig +++ b/configs/ph1_pro4_defconfig @@ -37,6 +37,6 @@ CONFIG_DM_SERIAL=y CONFIG_UNIPHIER_SERIAL=y CONFIG_DM_I2C=y CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y +CONFIG_USB_XHCI_HCD=y CONFIG_USB_STORAGE=y S:CONFIG_SPL_NAND_DENALI=y diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 3f738fb..df89d14 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -88,6 +88,8 @@ /* #define CONFIG_SYS_ICACHE_OFF */ /* #define CONFIG_SYS_DCACHE_OFF */
+#define CONFIG_SYS_CACHELINE_SIZE 32 + /* Comment out the following to enable L2 cache */ #define CONFIG_UNIPHIER_L2CACHE_ON
@@ -186,6 +188,7 @@
/* USB */ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 +#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 4 #define CONFIG_CMD_FAT #define CONFIG_FAT_WRITE #define CONFIG_DOS_PARTITION
Two support card variants are used with UniPhier reference boards: - 1 chip select support card (original CPLD) - 3 chip selects support card (ARIMA-compatible CPLD)
Currently, the former is only supported on PH1-Pro4, but it can be expanded to PH1-LD4, PH1-sLD8 with a little code change.
arch/arm/mach-uniphier/ph1-ld4/Makefile | 4 +- arch/arm/mach-uniphier/ph1-ld4/sbc_init.c | 51 +--------------------- arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c | 50 ++++++++++++++++++++++ arch/arm/mach-uniphier/ph1-pro4/Makefile | 4 +- arch/arm/mach-uniphier/ph1-pro4/sbc_init.c | 32 -------------- arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c | 43 +++++++++++++++++++ arch/arm/mach-uniphier/ph1-sld8/Makefile | 4 +- arch/arm/mach-uniphier/ph1-sld8/sbc_init.c | 59 +------------------------- arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c | 58 +++++++++++++++++++++++++ 9 files changed, 162 insertions(+), 143 deletions(-) create mode 100644 arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c create mode 100644 arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c create mode 100644 arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c
diff --git a/arch/arm/mach-uniphier/ph1-ld4/Makefile b/arch/arm/mach-uniphier/ph1-ld4/Makefile index 927640a..5ce3d8a 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/Makefile +++ b/arch/arm/mach-uniphier/ph1-ld4/Makefile @@ -4,8 +4,10 @@
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_DEBUG_LL) += lowlevel_debug.o -obj-y += bcu_init.o sbc_init.o sg_init.o pll_init.o early_clkrst_init.o \ +obj-y += bcu_init.o sg_init.o pll_init.o early_clkrst_init.o \ pll_spectrum.o umc_init.o ddrphy_init.o +obj-$(CONFIG_PFC_MICRO_SUPPORT_CARD) += sbc_init.o +obj-$(CONFIG_DCC_MICRO_SUPPORT_CARD) += sbc_init_3cs.o else obj-$(CONFIG_BOARD_EARLY_INIT_F) += pinctrl.o clkrst_init.o obj-$(if $(CONFIG_OF_CONTROL),,y) += platdevice.o diff --git a/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c b/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c index 374a8c0..656d7d7 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/sbc_init.c @@ -1,50 +1 @@ -/* - * Copyright (C) 2011-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/io.h> -#include <mach/sbc-regs.h> -#include <mach/sg-regs.h> - -void sbc_init(void) -{ - u32 tmp; - - /* system bus output enable */ - tmp = readl(PC0CTRL); - tmp &= 0xfffffcff; - writel(tmp, PC0CTRL); - - /* XECS1: sub/boot memory (boot swap = off/on) */ - writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); - writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); - writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); - writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); - - /* XECS0: boot/sub memory (boot swap = off/on) */ - writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00); - writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01); - writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02); - writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04); - - /* XECS3: peripherals */ - writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL30); - writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL31); - writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL32); - writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL34); - - /* base address regsiters */ - writel(0x0000bc01, SBBASE0); - writel(0x0400bc01, SBBASE1); - writel(0x0800bf01, SBBASE3); - - /* enable access to sub memory when boot swap is on */ - if (boot_is_swapped()) - sg_set_pinsel(155, 1); /* PORT24 -> XECS0 */ - - sg_set_pinsel(156, 1); /* PORT25 -> XECS3 */ -} +#include "../ph1-pro4/sbc_init.c" diff --git a/arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c b/arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c new file mode 100644 index 0000000..374a8c0 --- /dev/null +++ b/arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c @@ -0,0 +1,50 @@ +/* + * Copyright (C) 2011-2015 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <mach/sbc-regs.h> +#include <mach/sg-regs.h> + +void sbc_init(void) +{ + u32 tmp; + + /* system bus output enable */ + tmp = readl(PC0CTRL); + tmp &= 0xfffffcff; + writel(tmp, PC0CTRL); + + /* XECS1: sub/boot memory (boot swap = off/on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); + + /* XECS0: boot/sub memory (boot swap = off/on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04); + + /* XECS3: peripherals */ + writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL30); + writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL31); + writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL32); + writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL34); + + /* base address regsiters */ + writel(0x0000bc01, SBBASE0); + writel(0x0400bc01, SBBASE1); + writel(0x0800bf01, SBBASE3); + + /* enable access to sub memory when boot swap is on */ + if (boot_is_swapped()) + sg_set_pinsel(155, 1); /* PORT24 -> XECS0 */ + + sg_set_pinsel(156, 1); /* PORT25 -> XECS3 */ +} diff --git a/arch/arm/mach-uniphier/ph1-pro4/Makefile b/arch/arm/mach-uniphier/ph1-pro4/Makefile index 0390506..b88525c 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/Makefile +++ b/arch/arm/mach-uniphier/ph1-pro4/Makefile @@ -4,8 +4,10 @@
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_DEBUG_LL) += lowlevel_debug.o -obj-y += sbc_init.o sg_init.o pll_init.o early_clkrst_init.o \ +obj-y += sg_init.o pll_init.o early_clkrst_init.o \ pll_spectrum.o umc_init.o ddrphy_init.o +obj-$(CONFIG_PFC_MICRO_SUPPORT_CARD) += sbc_init.o +obj-$(CONFIG_DCC_MICRO_SUPPORT_CARD) += sbc_init_3cs.o else obj-$(CONFIG_BOARD_EARLY_INIT_F) += pinctrl.o clkrst_init.o obj-$(if $(CONFIG_OF_CONTROL),,y) += platdevice.o diff --git a/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c b/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c index 4cc5e75..5e75454 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/sbc_init.c @@ -12,7 +12,6 @@
void sbc_init(void) { -#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) /* * Only CS1 is connected to support card. * BKSZ[1:0] should be set to "01". @@ -41,35 +40,4 @@ void sbc_init(void) writel(0x0000be01, SBBASE0); /* dummy */ writel(0x0200be01, SBBASE1); } -#elif defined(CONFIG_DCC_MICRO_SUPPORT_CARD) - /* XECS0: boot/sub memory (boot swap = off/on) */ - writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00); - writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01); - writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02); - writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04); - - /* XECS1: sub/boot memory (boot swap = off/on) */ - writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); - writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); - writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); - writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); - - /* XECS3: peripherals */ - writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL30); - writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL31); - writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL32); - writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL34); - - writel(0x0000bc01, SBBASE0); /* boot memory */ - writel(0x0400bc01, SBBASE1); /* sub memory */ - writel(0x0800bf01, SBBASE3); /* peripherals */ - - /* enable access to sub memory when boot swap is on */ - if (boot_is_swapped()) - sg_set_pinsel(318, 5); /* PORT22 -> XECS0 */ - - sg_set_pinsel(313, 5); /* PORT15 -> XECS3 */ - writel(0x00000001, SG_LOADPINCTRL); - -#endif /* CONFIG_XXX_MICRO_SUPPORT_CARD */ } diff --git a/arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c b/arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c new file mode 100644 index 0000000..67e6d82 --- /dev/null +++ b/arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c @@ -0,0 +1,43 @@ +/* + * Copyright (C) 2011-2015 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <mach/sbc-regs.h> +#include <mach/sg-regs.h> + +void sbc_init(void) +{ + /* XECS0: boot/sub memory (boot swap = off/on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04); + + /* XECS1: sub/boot memory (boot swap = off/on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); + + /* XECS3: peripherals */ + writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL30); + writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL31); + writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL32); + writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL34); + + writel(0x0000bc01, SBBASE0); /* boot memory */ + writel(0x0400bc01, SBBASE1); /* sub memory */ + writel(0x0800bf01, SBBASE3); /* peripherals */ + + /* enable access to sub memory when boot swap is on */ + if (boot_is_swapped()) + sg_set_pinsel(318, 5); /* PORT22 -> XECS0 */ + + sg_set_pinsel(313, 5); /* PORT15 -> XECS3 */ + writel(0x00000001, SG_LOADPINCTRL); +} diff --git a/arch/arm/mach-uniphier/ph1-sld8/Makefile b/arch/arm/mach-uniphier/ph1-sld8/Makefile index 927640a..5ce3d8a 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/Makefile +++ b/arch/arm/mach-uniphier/ph1-sld8/Makefile @@ -4,8 +4,10 @@
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_DEBUG_LL) += lowlevel_debug.o -obj-y += bcu_init.o sbc_init.o sg_init.o pll_init.o early_clkrst_init.o \ +obj-y += bcu_init.o sg_init.o pll_init.o early_clkrst_init.o \ pll_spectrum.o umc_init.o ddrphy_init.o +obj-$(CONFIG_PFC_MICRO_SUPPORT_CARD) += sbc_init.o +obj-$(CONFIG_DCC_MICRO_SUPPORT_CARD) += sbc_init_3cs.o else obj-$(CONFIG_BOARD_EARLY_INIT_F) += pinctrl.o clkrst_init.o obj-$(if $(CONFIG_OF_CONTROL),,y) += platdevice.o diff --git a/arch/arm/mach-uniphier/ph1-sld8/sbc_init.c b/arch/arm/mach-uniphier/ph1-sld8/sbc_init.c index fdef88e..225c0d2 100644 --- a/arch/arm/mach-uniphier/ph1-sld8/sbc_init.c +++ b/arch/arm/mach-uniphier/ph1-sld8/sbc_init.c @@ -1,58 +1 @@ -/* - * Copyright (C) 2011-2015 Panasonic Corporation - * Author: Masahiro Yamada yamada.m@jp.panasonic.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/io.h> -#include <mach/sbc-regs.h> -#include <mach/sg-regs.h> - -void sbc_init(void) -{ - u32 tmp; - - /* system bus output enable */ - tmp = readl(PC0CTRL); - tmp &= 0xfffffcff; - writel(tmp, PC0CTRL); - - /* - * SBCTRL0* does not need settings because PH1-sLD8 has no support for - * XECS0. The boot swap must be enabled to boot from the support card. - */ - - if (boot_is_swapped()) { - /* XECS1 : boot memory if boot swap is on */ - writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); - writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); - writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); - writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); - } - - /* XECS4 : sub memory */ - writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL40); - writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL41); - writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL42); - writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL44); - - /* XECS5 : peripherals */ - writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL50); - writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL51); - writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL52); - writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL54); - - /* base address regsiters */ - writel(0x0000bc01, SBBASE0); /* boot memory */ - writel(0x0900bfff, SBBASE1); /* dummy */ - writel(0x0400bc01, SBBASE4); /* sub memory */ - writel(0x0800bf01, SBBASE5); /* peripherals */ - - sg_set_pinsel(134, 16); /* XIRQ6 -> XECS4 */ - sg_set_pinsel(135, 16); /* XIRQ7 -> XECS5 */ - - /* dummy read to assure write process */ - readl(SG_PINCTRL(0)); -} +#include "../ph1-ld4/sbc_init.c" diff --git a/arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c b/arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c new file mode 100644 index 0000000..fdef88e --- /dev/null +++ b/arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c @@ -0,0 +1,58 @@ +/* + * Copyright (C) 2011-2015 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <mach/sbc-regs.h> +#include <mach/sg-regs.h> + +void sbc_init(void) +{ + u32 tmp; + + /* system bus output enable */ + tmp = readl(PC0CTRL); + tmp &= 0xfffffcff; + writel(tmp, PC0CTRL); + + /* + * SBCTRL0* does not need settings because PH1-sLD8 has no support for + * XECS0. The boot swap must be enabled to boot from the support card. + */ + + if (boot_is_swapped()) { + /* XECS1 : boot memory if boot swap is on */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); + } + + /* XECS4 : sub memory */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL40); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL41); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL42); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL44); + + /* XECS5 : peripherals */ + writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL50); + writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL51); + writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL52); + writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL54); + + /* base address regsiters */ + writel(0x0000bc01, SBBASE0); /* boot memory */ + writel(0x0900bfff, SBBASE1); /* dummy */ + writel(0x0400bc01, SBBASE4); /* sub memory */ + writel(0x0800bf01, SBBASE5); /* peripherals */ + + sg_set_pinsel(134, 16); /* XIRQ6 -> XECS4 */ + sg_set_pinsel(135, 16); /* XIRQ7 -> XECS5 */ + + /* dummy read to assure write process */ + readl(SG_PINCTRL(0)); +}
The 3CS support card (CONFIG_DCC_MICRO_SUPPORT_CARD) used to be used very often before, but it is recently getting a minority. Swith to the 1CS support card (CONFIG_PFC_MICRO_SUPPORT_CARD).
configs/ph1_ld4_defconfig | 2 +- configs/ph1_pro4_defconfig | 2 +- configs/ph1_sld8_defconfig | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/configs/ph1_ld4_defconfig b/configs/ph1_ld4_defconfig index 86b4b15..52bbe9b 100644 --- a/configs/ph1_ld4_defconfig +++ b/configs/ph1_ld4_defconfig @@ -3,7 +3,7 @@ CONFIG_FIT_VERBOSE=y +S:CONFIG_ARM=y +S:CONFIG_ARCH_UNIPHIER=y +S:CONFIG_MACH_PH1_LD4=y -+S:CONFIG_DCC_MICRO_SUPPORT_CARD=y ++S:CONFIG_PFC_MICRO_SUPPORT_CARD=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BDI=y CONFIG_CMD_CONSOLE=y diff --git a/configs/ph1_pro4_defconfig b/configs/ph1_pro4_defconfig index 42a7a65..1517f3c 100644 --- a/configs/ph1_pro4_defconfig +++ b/configs/ph1_pro4_defconfig @@ -3,7 +3,7 @@ CONFIG_FIT_VERBOSE=y +S:CONFIG_ARM=y +S:CONFIG_ARCH_UNIPHIER=y +S:CONFIG_MACH_PH1_PRO4=y -+S:CONFIG_DCC_MICRO_SUPPORT_CARD=y ++S:CONFIG_PFC_MICRO_SUPPORT_CARD=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BDI=y CONFIG_CMD_CONSOLE=y diff --git a/configs/ph1_sld8_defconfig b/configs/ph1_sld8_defconfig index 8e95f17..e3ce5cc 100644 --- a/configs/ph1_sld8_defconfig +++ b/configs/ph1_sld8_defconfig @@ -3,7 +3,7 @@ CONFIG_FIT_VERBOSE=y +S:CONFIG_ARM=y +S:CONFIG_ARCH_UNIPHIER=y +S:CONFIG_MACH_PH1_SLD8=y -+S:CONFIG_DCC_MICRO_SUPPORT_CARD=y ++S:CONFIG_PFC_MICRO_SUPPORT_CARD=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BDI=y CONFIG_CMD_CONSOLE=y
This code is duplicated in ph1-ld4/sg_init.c and ph1-pro4/sg_init.c. Merge the same code into a new file, memconf.c.
The helper functions no longer have to be placed in the header file. Also, move them into memconf.c.
arch/arm/mach-uniphier/Makefile | 1 + arch/arm/mach-uniphier/include/mach/sg-regs.h | 119 +------------------------- arch/arm/mach-uniphier/memconf.c | 104 ++++++++++++++++++++++ arch/arm/mach-uniphier/ph1-ld4/sg_init.c | 11 +-- arch/arm/mach-uniphier/ph1-pro4/sg_init.c | 11 +-- arch/arm/mach-uniphier/spl.c | 11 ++- 6 files changed, 116 insertions(+), 141 deletions(-) create mode 100644 arch/arm/mach-uniphier/memconf.c
diff --git a/arch/arm/mach-uniphier/Makefile b/arch/arm/mach-uniphier/Makefile index df418dd..e7a801b 100644 --- a/arch/arm/mach-uniphier/Makefile +++ b/arch/arm/mach-uniphier/Makefile @@ -7,6 +7,7 @@ ifdef CONFIG_SPL_BUILD obj-y += lowlevel_init.o obj-y += init_page_table.o obj-y += spl.o +obj-y += memconf.o obj-y += ddrphy_training.o
else diff --git a/arch/arm/mach-uniphier/include/mach/sg-regs.h b/arch/arm/mach-uniphier/include/mach/sg-regs.h index 4ae67c8..63408d5 100644 --- a/arch/arm/mach-uniphier/include/mach/sg-regs.h +++ b/arch/arm/mach-uniphier/include/mach/sg-regs.h @@ -1,7 +1,7 @@ /* * UniPhier SG (SoC Glue) block registers * - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Panasonic Corporation * * SPDX-License-Identifier: GPL-2.0+ */ @@ -108,7 +108,6 @@ #else
#include <linux/types.h> -#include <linux/sizes.h> #include <asm/io.h>
static inline void sg_set_pinsel(int n, int value) @@ -117,122 +116,6 @@ static inline void sg_set_pinsel(int n, int value) | SG_PINSEL_MODE(n, value), SG_PINSEL_ADDR(n)); }
-static inline u32 sg_memconf_val_ch0(unsigned long size, int num) -{ - int size_mb = size / num; - u32 ret; - - switch (size_mb) { - case SZ_64M: - ret = SG_MEMCONF_CH0_SZ_64M; - break; - case SZ_128M: - ret = SG_MEMCONF_CH0_SZ_128M; - break; - case SZ_256M: - ret = SG_MEMCONF_CH0_SZ_256M; - break; - case SZ_512M: - ret = SG_MEMCONF_CH0_SZ_512M; - break; - case SZ_1G: - ret = SG_MEMCONF_CH0_SZ_1G; - break; - default: - BUG(); - break; - } - - switch (num) { - case 1: - ret |= SG_MEMCONF_CH0_NUM_1; - break; - case 2: - ret |= SG_MEMCONF_CH0_NUM_2; - break; - default: - BUG(); - break; - } - return ret; -} - -static inline u32 sg_memconf_val_ch1(unsigned long size, int num) -{ - int size_mb = size / num; - u32 ret; - - switch (size_mb) { - case SZ_64M: - ret = SG_MEMCONF_CH1_SZ_64M; - break; - case SZ_128M: - ret = SG_MEMCONF_CH1_SZ_128M; - break; - case SZ_256M: - ret = SG_MEMCONF_CH1_SZ_256M; - break; - case SZ_512M: - ret = SG_MEMCONF_CH1_SZ_512M; - break; - case SZ_1G: - ret = SG_MEMCONF_CH1_SZ_1G; - break; - default: - BUG(); - break; - } - - switch (num) { - case 1: - ret |= SG_MEMCONF_CH1_NUM_1; - break; - case 2: - ret |= SG_MEMCONF_CH1_NUM_2; - break; - default: - BUG(); - break; - } - return ret; -} - -static inline u32 sg_memconf_val_ch2(unsigned long size, int num) -{ - int size_mb = size / num; - u32 ret; - - switch (size_mb) { - case SZ_64M: - ret = SG_MEMCONF_CH2_SZ_64M; - break; - case SZ_128M: - ret = SG_MEMCONF_CH2_SZ_128M; - break; - case SZ_256M: - ret = SG_MEMCONF_CH2_SZ_256M; - break; - case SZ_512M: - ret = SG_MEMCONF_CH2_SZ_512M; - break; - default: - BUG(); - break; - } - - switch (num) { - case 1: - ret |= SG_MEMCONF_CH2_NUM_1; - break; - case 2: - ret |= SG_MEMCONF_CH2_NUM_2; - break; - default: - BUG(); - break; - } - return ret; -} #endif /* __ASSEMBLY__ */
#endif /* ARCH_SG_REGS_H */ diff --git a/arch/arm/mach-uniphier/memconf.c b/arch/arm/mach-uniphier/memconf.c new file mode 100644 index 0000000..bf3c177 --- /dev/null +++ b/arch/arm/mach-uniphier/memconf.c @@ -0,0 +1,104 @@ +/* + * Copyright (C) 2011-2015 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/sizes.h> +#include <asm/io.h> +#include <mach/sg-regs.h> + +static inline u32 sg_memconf_val_ch0(unsigned long size, int num) +{ + int size_mb = size / num; + u32 ret; + + switch (size_mb) { + case SZ_64M: + ret = SG_MEMCONF_CH0_SZ_64M; + break; + case SZ_128M: + ret = SG_MEMCONF_CH0_SZ_128M; + break; + case SZ_256M: + ret = SG_MEMCONF_CH0_SZ_256M; + break; + case SZ_512M: + ret = SG_MEMCONF_CH0_SZ_512M; + break; + case SZ_1G: + ret = SG_MEMCONF_CH0_SZ_1G; + break; + default: + BUG(); + break; + } + + switch (num) { + case 1: + ret |= SG_MEMCONF_CH0_NUM_1; + break; + case 2: + ret |= SG_MEMCONF_CH0_NUM_2; + break; + default: + BUG(); + break; + } + return ret; +} + +static inline u32 sg_memconf_val_ch1(unsigned long size, int num) +{ + int size_mb = size / num; + u32 ret; + + switch (size_mb) { + case SZ_64M: + ret = SG_MEMCONF_CH1_SZ_64M; + break; + case SZ_128M: + ret = SG_MEMCONF_CH1_SZ_128M; + break; + case SZ_256M: + ret = SG_MEMCONF_CH1_SZ_256M; + break; + case SZ_512M: + ret = SG_MEMCONF_CH1_SZ_512M; + break; + case SZ_1G: + ret = SG_MEMCONF_CH1_SZ_1G; + break; + default: + BUG(); + break; + } + + switch (num) { + case 1: + ret |= SG_MEMCONF_CH1_NUM_1; + break; + case 2: + ret |= SG_MEMCONF_CH1_NUM_2; + break; + default: + BUG(); + break; + } + return ret; +} + +void memconf_init(void) +{ + u32 tmp; + + /* Set DDR size */ + tmp = sg_memconf_val_ch0(CONFIG_SDRAM0_SIZE, CONFIG_DDR_NUM_CH0); + tmp |= sg_memconf_val_ch1(CONFIG_SDRAM1_SIZE, CONFIG_DDR_NUM_CH1); +#if CONFIG_SDRAM0_BASE + CONFIG_SDRAM0_SIZE < CONFIG_SDRAM1_BASE + tmp |= SG_MEMCONF_SPARSEMEM; +#endif + writel(tmp, SG_MEMCONF); +} diff --git a/arch/arm/mach-uniphier/ph1-ld4/sg_init.c b/arch/arm/mach-uniphier/ph1-ld4/sg_init.c index e6bfa97..93e44af 100644 --- a/arch/arm/mach-uniphier/ph1-ld4/sg_init.c +++ b/arch/arm/mach-uniphier/ph1-ld4/sg_init.c @@ -1,11 +1,10 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ */
-#include <common.h> #include <asm/io.h> #include <mach/sg-regs.h>
@@ -13,14 +12,6 @@ void sg_init(void) { u32 tmp;
- /* Set DDR size */ - tmp = sg_memconf_val_ch0(CONFIG_SDRAM0_SIZE, CONFIG_DDR_NUM_CH0); - tmp |= sg_memconf_val_ch1(CONFIG_SDRAM1_SIZE, CONFIG_DDR_NUM_CH1); -#if CONFIG_SDRAM0_BASE + CONFIG_SDRAM0_SIZE < CONFIG_SDRAM1_BASE - tmp |= SG_MEMCONF_SPARSEMEM; -#endif - writel(tmp, SG_MEMCONF); - /* Input ports must be enabled before deasserting reset of cores */ tmp = readl(SG_IECTRL); tmp |= 0x1; diff --git a/arch/arm/mach-uniphier/ph1-pro4/sg_init.c b/arch/arm/mach-uniphier/ph1-pro4/sg_init.c index c25afa8..8677666 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/sg_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/sg_init.c @@ -1,11 +1,10 @@ /* - * Copyright (C) 2011-2014 Panasonic Corporation + * Copyright (C) 2011-2015 Panasonic Corporation * Author: Masahiro Yamada yamada.m@jp.panasonic.com * * SPDX-License-Identifier: GPL-2.0+ */
- /* Set DDR size */ - tmp = sg_memconf_val_ch0(CONFIG_SDRAM0_SIZE, CONFIG_DDR_NUM_CH0); - tmp |= sg_memconf_val_ch1(CONFIG_SDRAM1_SIZE, CONFIG_DDR_NUM_CH1); -#if CONFIG_SDRAM0_BASE + CONFIG_SDRAM0_SIZE < CONFIG_SDRAM1_BASE - tmp |= SG_MEMCONF_SPARSEMEM; -#endif - writel(tmp, SG_MEMCONF); - /* Input ports must be enabled before deasserting reset of cores */ tmp = readl(SG_IECTRL); tmp |= 1 << 6; diff --git a/arch/arm/mach-uniphier/spl.c b/arch/arm/mach-uniphier/spl.c index c8a2469..c3d90d0 100644 --- a/arch/arm/mach-uniphier/spl.c +++ b/arch/arm/mach-uniphier/spl.c @@ -18,6 +18,7 @@ void sbc_init(void); void sg_init(void); void pll_init(void); void pin_init(void); +void memconf_init(void); void early_clkrst_init(void); int umc_init(void); void enable_dpll_ssc(void); @@ -38,10 +39,14 @@ void spl_board_init(void)
- early_clkrst_init(); + memconf_init();
+ early_clkrst_init(); + + led_write(L, 2, , ); + { int res;
@@ -51,9 +56,9 @@ void spl_board_init(void) ; } } - led_write(L, 2, , ); + led_write(L, 3, , );
enable_dpll_ssc();
- led_write(L, 3, , ); + led_write(L, 4, , ); }
This function was intended for MN2WS0235 (what we call PH1-Pro4TV). On that SoC, MPLL is already running on the power-on reset and it makes sense to stop the PLL at early boot-up. On the other hand, PH1-Pro4(R) does not have SC_MPLLOSCCTL register, so this function has no point.
Changes in v4: None Changes in v3: - Newly added
Changes in v2: None
arch/arm/mach-uniphier/include/mach/sc-regs.h | 4 ---- arch/arm/mach-uniphier/ph1-pro4/pll_init.c | 17 ----------------- 2 files changed, 21 deletions(-)
diff --git a/arch/arm/mach-uniphier/include/mach/sc-regs.h b/arch/arm/mach-uniphier/include/mach/sc-regs.h index 397ace8..09b9e6e 100644 --- a/arch/arm/mach-uniphier/include/mach/sc-regs.h +++ b/arch/arm/mach-uniphier/include/mach/sc-regs.h @@ -11,10 +11,6 @@
#define SC_BASE_ADDR 0x61840000
-#define SC_MPLLOSCCTL (SC_BASE_ADDR | 0x1184) -#define SC_MPLLOSCCTL_MPLLEN (0x1 << 0) -#define SC_MPLLOSCCTL_MPLLST (0x1 << 1) - #define SC_DPLLCTRL (SC_BASE_ADDR | 0x1200) #define SC_DPLLCTRL_SSC_EN (0x1 << 31) #define SC_DPLLCTRL_FOUTMODE_MASK (0xf << 16) diff --git a/arch/arm/mach-uniphier/ph1-pro4/pll_init.c b/arch/arm/mach-uniphier/ph1-pro4/pll_init.c index 3d29548..2a965a5 100644 --- a/arch/arm/mach-uniphier/ph1-pro4/pll_init.c +++ b/arch/arm/mach-uniphier/ph1-pro4/pll_init.c @@ -46,22 +46,6 @@ static void dpll_init(void) writel(tmp, SC_DPLLCTRL2); }
-static void stop_mpll(void) -{ - u32 tmp; - - tmp = readl(SC_MPLLOSCCTL); - - if (!(tmp & SC_MPLLOSCCTL_MPLLST)) - return; /* already stopped */ - - tmp &= ~SC_MPLLOSCCTL_MPLLEN; - writel(tmp, SC_MPLLOSCCTL); - - while (readl(SC_MPLLOSCCTL) & SC_MPLLOSCCTL_MPLLST) - ; -} - static void vpll_init(void) { u32 tmp, clk_mode_axosel; @@ -157,7 +141,6 @@ static void vpll_init(void) void pll_init(void) { dpll_init(); - stop_mpll(); vpll_init();
Masahiro Yamada
