[U-Boot] [PATCH v4 0/3] This series adds support for gpio-leds "default-state" property. The
main usecase in mind are LEDs which indicate a state like "power on". With this patchset applied, all you have to do is: Add a gpio-led node with 'default-state = "on";' property to your device tree. And the LED will automatically light up during U-Boot startup.
Changes in v4: - don't break 'make tests' - gpio_a pin 4 is already use by dm_test_gpio_phandles() -> we switch to use pin 5 and 6 - adjust dm_test_led_base() to the fact that we have two more LEDs, now - rebased on 2600df4f8ef12ece9cec13030005919e0ba2b0d5 (master 2018-04-09)
Changes in v3: - use ofnode_read_bool() instead of ofnode_read_string() to determine if LED node has the default-state property
Changes in v2: - rebase to v2018.05-rc1 - add dm_test_led_default_state() to tests/dm/led.c
Patrick Bruenn (3): dm: led: Support "default-state" property dm: led: auto probe() LEDs with "default-state" dm: led: add testcase for "default-state" property
arch/sandbox/dts/test.dts | 12 ++++++++++++ drivers/led/led_gpio.c | 25 ++++++++++++++++++++++++- test/dm/led.c | 20 +++++++++++++++++++- 3 files changed, 55 insertions(+), 2 deletions(-)
Add support for the device tree property "default-state". This feature might be useful for LEDs indicating "power on" or similar states.
Note: Even with this commit gpio-leds remain in reset state. That's because the led_gpio is not probed until DM_FLAG_ACTIVATED is set.
Signed-off-by: Patrick Bruenn p.bruenn@beckhoff.com
Changes in v4: - don't break 'make tests' - rebased on 2600df4f8ef12ece9cec13030005919e0ba2b0d5 (master 2018-04-09)
drivers/led/led_gpio.c | 16 +++++++++++++++- 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/drivers/led/led_gpio.c b/drivers/led/led_gpio.c index 9976635887..e68d8d3864 100644 --- a/drivers/led/led_gpio.c +++ b/drivers/led/led_gpio.c @@ -60,11 +60,25 @@ static int led_gpio_probe(struct udevice *dev) { struct led_uc_plat *uc_plat = dev_get_uclass_platdata(dev); struct led_gpio_priv *priv = dev_get_priv(dev); + const char *default_state; + int ret;
/* Ignore the top-level LED node */ if (!uc_plat->label) return 0; - return gpio_request_by_name(dev, "gpios", 0, &priv->gpio, GPIOD_IS_OUT); + + ret = gpio_request_by_name(dev, "gpios", 0, &priv->gpio, GPIOD_IS_OUT); + if (ret) + return ret; + + default_state = dev_read_string(dev, "default-state"); + if (default_state) { + if (!strncmp(default_state, "on", 2)) + gpio_led_set_state(dev, LEDST_ON); + else if (!strncmp(default_state, "off", 3)) + gpio_led_set_state(dev, LEDST_OFF); + } + return 0; }
static int led_gpio_remove(struct udevice *dev)
On Wed, Apr 11, 2018 at 11:16:27AM +0200, linux-kernel-dev@beckhoff.com wrote:
To avoid board specificy LED activation code, automatically activate gpio-leds with "default-state" property during bind().
Signed-off-by: Patrick Bruenn p.bruenn@beckhoff.com ---
Changes in v4: None Changes in v3: None Changes in v2: None
drivers/led/led_gpio.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/led/led_gpio.c b/drivers/led/led_gpio.c index e68d8d3864..f5b3b63493 100644 --- a/drivers/led/led_gpio.c +++ b/drivers/led/led_gpio.c @@ -11,6 +11,7 @@ #include <led.h> #include <asm/gpio.h> #include <dm/lists.h> +#include <dm/uclass-internal.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -120,6 +121,14 @@ static int led_gpio_bind(struct udevice *parent) return ret; uc_plat = dev_get_uclass_platdata(dev); uc_plat->label = label; + + if (ofnode_read_bool(node, "default-state")) { + struct udevice *devp; + + ret = uclass_get_device_tail(dev, 0, &devp); + if (ret) + return ret; + } }
On Wed, Apr 11, 2018 at 11:16:28AM +0200, linux-kernel-dev@beckhoff.com wrote:
Add two more gpio-leds to sandbox test device tree with default-state property set to "on"/"off". Add dm_test_led_default_state() to check that these new LED's are set to LEDST_ON and LEDST_OFF.
Signed-off-by: Patrick Bruenn p.bruenn@beckhoff.com --- patman complains about: test/dm/led.c:45: check: Please use a blank line after function/struct/union/enum declarations. I compared with other DM_TEST() usage and decided to ignore this check. Should we fix the macro, patman or keep ignoring this?
Changes in v4: - gpio_a pin 4 is already use by dm_test_gpio_phandles() -> we switch to use pin 5 and 6 - adjust dm_test_led_base() to the fact that we have two more LEDs, now
arch/sandbox/dts/test.dts | 12 ++++++++++++ test/dm/led.c | 20 +++++++++++++++++++- 2 files changed, 31 insertions(+), 1 deletion(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 06d0e8ce85..2f104af960 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -254,6 +254,18 @@ gpios = <&gpio_a 2 0>; label = "sandbox:green"; }; + + default_on { + gpios = <&gpio_a 5 0>; + label = "sandbox:default_on"; + default-state = "on"; + }; + + default_off { + gpios = <&gpio_a 6 0>; + label = "sandbox:default_off"; + default-state = "off"; + }; };
mbox: mbox { diff --git a/test/dm/led.c b/test/dm/led.c index fde700be38..af05cd78b6 100644 --- a/test/dm/led.c +++ b/test/dm/led.c @@ -22,12 +22,30 @@ static int dm_test_led_base(struct unit_test_state *uts) ut_assertok(uclass_get_device(UCLASS_LED, 0, &dev)); ut_assertok(uclass_get_device(UCLASS_LED, 1, &dev)); ut_assertok(uclass_get_device(UCLASS_LED, 2, &dev)); - ut_asserteq(-ENODEV, uclass_get_device(UCLASS_LED, 3, &dev)); + ut_assertok(uclass_get_device(UCLASS_LED, 3, &dev)); + ut_assertok(uclass_get_device(UCLASS_LED, 4, &dev)); + ut_asserteq(-ENODEV, uclass_get_device(UCLASS_LED, 5, &dev));
return 0; } DM_TEST(dm_test_led_base, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
+/* Test of the LED 'default-state' device tree property */ +static int dm_test_led_default_state(struct unit_test_state *uts) +{ + struct udevice *dev; + + /* Check that we handle the default-state property correctly. */ + ut_assertok(led_get_by_label("sandbox:default_on", &dev)); + ut_asserteq(LEDST_ON, led_get_state(dev)); + + ut_assertok(led_get_by_label("sandbox:default_off", &dev)); + ut_asserteq(LEDST_OFF, led_get_state(dev)); + + return 0; +} +DM_TEST(dm_test_led_default_state, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + /* Test of the led uclass using the led_gpio driver */ static int dm_test_led_gpio(struct unit_test_state *uts) {
On Wed, Apr 11, 2018 at 11:16:29AM +0200, linux-kernel-dev@beckhoff.com wrote:
