[PATCH v1 0/2] Misc Tegra changes
Include changes which are single commits with small changes
- adjust Tegra 2 pinmux parsing logic - update documentation to reflect current state
Svyatoslav Ryhel (2): pinctrl: tegra20: adjust pin type detection doc: board: tegra: update device information
doc/board/asus/grouper.rst | 12 ++++++------ doc/board/asus/transformer_t20.rst | 6 +++--- doc/board/asus/transformer_t30.rst | 13 +++++++------ doc/board/htc/endeavoru.rst | 9 ++++----- doc/board/lg/x3_t30.rst | 20 ++++++++++---------- doc/board/microsoft/surface-rt.rst | 4 ++-- doc/board/wexler/qc750.rst | 9 ++++----- drivers/pinctrl/tegra/pinctrl-tegra20.c | 4 ++-- 8 files changed, 38 insertions(+), 39 deletions(-)
Pin detection on t20 depends on node name. With recent changes in node naming, let's remove '_' to be safe about both '_' or '-' use.
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/pinctrl/tegra/pinctrl-tegra20.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pinctrl/tegra/pinctrl-tegra20.c b/drivers/pinctrl/tegra/pinctrl-tegra20.c index d5171b8be23..d59b3ec7b5d 100644 --- a/drivers/pinctrl/tegra/pinctrl-tegra20.c +++ b/drivers/pinctrl/tegra/pinctrl-tegra20.c @@ -97,9 +97,9 @@ static int tegra_pinctrl_set_state(struct udevice *dev, struct udevice *config) * then actual pins setup (with node name prefix * conf_*) and then drive setup. */ - if (!strncmp(child->name, "conf_", 5)) + if (!strncmp(child->name, "conf", 4)) tegra_pinctrl_set_pin(child); - else if (!strncmp(child->name, "drive_", 6)) + else if (!strncmp(child->name, "drive", 5)) debug("%s: drive configuration is not supported\n", __func__); else tegra_pinctrl_set_func(child);
Adjust and update existing manuals to reflect the most recent updates.
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- doc/board/asus/grouper.rst | 12 ++++++------ doc/board/asus/transformer_t20.rst | 6 +++--- doc/board/asus/transformer_t30.rst | 13 +++++++------ doc/board/htc/endeavoru.rst | 9 ++++----- doc/board/lg/x3_t30.rst | 20 ++++++++++---------- doc/board/microsoft/surface-rt.rst | 4 ++-- doc/board/wexler/qc750.rst | 9 ++++----- 7 files changed, 36 insertions(+), 37 deletions(-)
diff --git a/doc/board/asus/grouper.rst b/doc/board/asus/grouper.rst index d56a9ca3921..14469582907 100644 --- a/doc/board/asus/grouper.rst +++ b/doc/board/asus/grouper.rst @@ -25,7 +25,7 @@ along with cellular one.
.. code-block:: bash
- $ export CROSS_COMPILE=arm-linux-gnueabi- + $ export CROSS_COMPILE=arm-none-eabi- $ make grouper_defconfig # For all grouper versions and tilapia $ make
@@ -79,18 +79,18 @@ Flashing with the NV3P protocol *******************************
Nv3p is a custom Nvidia protocol used to recover bricked devices. Devices can -enter it either by using ``wheelie`` with the correct ``blob.bin`` file or by -pre-loading vendor bootloader with the Fusée Gelée. +enter it by pre-loading vendor bootloader with the Fusée Gelée.
With nv3p, ``repart-block.bin`` is used. It contains BCT and a bootloader in encrypted state in form, which can just be written RAW at the start of eMMC.
- $ wheelie --blob blob.bin - $ nvflash --resume --rawdevicewrite 0 1024 repart-block.bin + $ ./run_bootloader.sh -s T30 -t ./bct/grouper.bct -b android_bootloader.bin + $ ./utiils/nvflash_v1.13.87205 --resume --rawdevicewrite 0 1024 repart-block.bin
-When flashing is done, reboot the device. +When flashing is done, reboot the device. Note that if you have cellular version, +use ``tilapia.bct``.
Flashing with a pre-loaded U-Boot ********************************* diff --git a/doc/board/asus/transformer_t20.rst b/doc/board/asus/transformer_t20.rst index d4bc12d1619..4f4f893c3a8 100644 --- a/doc/board/asus/transformer_t20.rst +++ b/doc/board/asus/transformer_t20.rst @@ -25,7 +25,7 @@ defconfig. Valid fragments are ``tf101.config``, ``tf101g.config`` and
- $ export CROSS_COMPILE=arm-linux-gnueabi- + $ export CROSS_COMPILE=arm-none-eabi- $ make transformer_t20_defconfig tf101.config # For TF101 $ make
@@ -84,8 +84,8 @@ encrypted state in form, which can just be written RAW at the start of eMMC.
- $ wheelie --blob blob.bin - $ nvflash --resume --rawdevicewrite 0 1024 repart-block.bin + $ wheelie -1 --bl bootloader.bin --bct tf101.bct --odm 0x300d8011 || break + $ nvflash --resume --rawdevicewrite 0 2048 repart-block.bin
diff --git a/doc/board/asus/transformer_t30.rst b/doc/board/asus/transformer_t30.rst index bebc4b9fad3..012a38251aa 100644 --- a/doc/board/asus/transformer_t30.rst +++ b/doc/board/asus/transformer_t30.rst @@ -22,6 +22,7 @@ Build U-Boot
U-Boot features ability to detect transformer device model on which it is loaded. The list of supported devices include: + - ASUS Transformer Prime TF201 - ASUS Transformer Pad (3G/LTE) TF300T/TG/TL - ASUS Transformer Infinity TF700T @@ -30,7 +31,7 @@ loaded. The list of supported devices include:
- $ export CROSS_COMPILE=arm-linux-gnueabi- + $ export CROSS_COMPILE=arm-none-eabi- $ make transformer_t30_defconfig $ make
@@ -84,18 +85,18 @@ Flashing with the NV3P protocol *******************************
- $ wheelie --blob blob.bin - $ nvflash --resume --rawdevicewrite 0 1024 repart-block.bin + $ ./run_bootloader.sh -s T30 -t ./bct/tf201.bct -b android_bootloader.bin + $ ./utiils/nvflash_v1.13.87205 --resume --rawdevicewrite 0 1024 repart-block.bin
-When flashing is done, reboot the device. +When flashing is done, reboot the device. Note that you should adjust bct file +name according to your device.
Flashing with a pre-loaded U-Boot ********************************* diff --git a/doc/board/htc/endeavoru.rst b/doc/board/htc/endeavoru.rst index e0edefe28ae..53df2d09a6f 100644 --- a/doc/board/htc/endeavoru.rst +++ b/doc/board/htc/endeavoru.rst @@ -21,7 +21,7 @@ Build U-Boot
- $ export CROSS_COMPILE=arm-linux-gnueabi- + $ export CROSS_COMPILE=arm-none-eabi- $ make endeavoru_defconfig $ make
@@ -72,16 +72,15 @@ Flashing with the NV3P protocol *******************************
- $ wheelie --blob blob.bin - $ nvflash --resume --rawdevicewrite 0 1024 repart-block.bin + $ ./run_bootloader.sh -s T30 -t ./bct/endeavoru.bct -b android_bootloader.bin + $ ./utiils/nvflash_v1.13.87205 --resume --rawdevicewrite 0 1024 repart-block.bin
diff --git a/doc/board/lg/x3_t30.rst b/doc/board/lg/x3_t30.rst index 618b00d34e3..9ff75034b72 100644 --- a/doc/board/lg/x3_t30.rst +++ b/doc/board/lg/x3_t30.rst @@ -24,7 +24,7 @@ board defconfig. Valid fragments are ``p880.config`` and ``p895.config``.
- $ export CROSS_COMPILE=arm-linux-gnueabi- + $ export CROSS_COMPILE=arm-none-eabi- $ make x3_t30_defconfig p895.config # For LG Optimus Vu $ make
@@ -75,18 +75,18 @@ Flashing with the NV3P protocol *******************************
- $ wheelie --blob blob.bin - $ nvflash --resume --rawdevicewrite 0 1024 repart-block.bin + $ ./run_bootloader.sh -s T30 -t ./bct/p895.bct -b android_bootloader.bin + $ ./utiils/nvflash_v1.13.87205 --resume --rawdevicewrite 0 1024 repart-block.bin
-When flashing is done, reboot the device. +When flashing is done, reboot the device. Note that if you have Optimus 4x HD, +use ``p880.bct``.
Flashing with a pre-loaded U-Boot ********************************* @@ -122,7 +122,7 @@ the user to use/partition it in any way the user desires. Self Upgrading --------------
-Place your ``u-boot-dtb-tegra.bin`` on the first partition of the eMMC (using -ability of u-boot to mount it). Enter bootmenu, choose update bootloader option -with Power button and U-Boot should update itself. Once the process is -completed, U-Boot will ask to press any button to reboot. +Place your ``u-boot-dtb-tegra.bin`` on the first partition of the eMMC or MicroSD +card if it is supported (using ability of u-boot to mount it). Enter bootmenu, +choose update bootloader option with Power button and U-Boot should update itself. +Once the process is completed, U-Boot will ask to press any button to reboot. diff --git a/doc/board/microsoft/surface-rt.rst b/doc/board/microsoft/surface-rt.rst index b5645e79340..2b29cce40a9 100644 --- a/doc/board/microsoft/surface-rt.rst +++ b/doc/board/microsoft/surface-rt.rst @@ -14,7 +14,7 @@ Build U-Boot
- $ export CROSS_COMPILE=arm-linux-gnueabi- + $ export CROSS_COMPILE=arm-none-eabi- $ make surface-rt_defconfig $ make
@@ -38,4 +38,4 @@ directory with To boot Linux, U-Boot will look for an ``extlinux.conf`` on MicroSD and then on eMMC. Additionally, if the Volume Down button is pressed while loading, the device will enter bootmenu. Bootmenu contains entries to mount MicroSD and eMMC -as mass storage, fastboot, reboot, reboot RCM, poweroffand enter U-Boot console. +as mass storage, fastboot, reboot, reboot RCM, poweroff and enter U-Boot console. diff --git a/doc/board/wexler/qc750.rst b/doc/board/wexler/qc750.rst index b61e40176b0..169629c7e47 100644 --- a/doc/board/wexler/qc750.rst +++ b/doc/board/wexler/qc750.rst @@ -21,7 +21,7 @@ Build U-Boot
- $ export CROSS_COMPILE=arm-linux-gnueabi- + $ export CROSS_COMPILE=arm-none-eabi- $ make qc750_defconfig $ make
@@ -71,16 +71,15 @@ pre-loading just built U-Boot into RAM. Flashing with the NV3P protocol *******************************
-Nv3p is a custom Nvidia protocol used to recover bricked devices. Devices can -enter it either by using ``wheelie`` with the correct ``blob.bin`` file or by -pre-loading vendor bootloader with the Fusée Gelée. +Nv3p is a custom Nvidia protocol used to recover bricked devices. Tegrarcm is +used to handle such state.
- $ wheelie --bct qc750.bct --bl bootloader.bin + $ tegrarcm --bct qc750.bct --bootloader android_bootloader.bin --loadaddr 0x80108000 $ nvflash --resume --rawdevicewrite 0 1024 repart-block.bin
Svyatoslav Ryhel
