[U-Boot] [PATCH] Fix build of socfpga targets when CONFIG_SPL is not set (i.e., you do not want to generate preloader image)
Disabling preloader generation on socfpga have issue with the Kconfig rules. Disabling it in the menuconfig gave error on console, and building with CONFIG_SPL=n resulted in compile error.
Signed-off-by: Eric Hoffman ehoffman@videotron.ca ---
arch/arm/Kconfig | 4 ++-- include/configs/socfpga_common.h | 2 ++ 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f6d57f5505..0ffdf2ef7f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -707,14 +707,14 @@ config ARCH_SOCFPGA select CPU_V7 select SUPPORT_SPL select OF_CONTROL - select SPL_OF_CONTROL + select SPL_OF_CONTROL if SPL select DM select DM_SPI_FLASH select DM_SPI select ENABLE_ARM_SOC_BOOT0_HOOK select ARCH_EARLY_INIT_R select ARCH_MISC_INIT - select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION + select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION if SPL select SYS_THUMB_BUILD imply CMD_MTDPARTS imply CRC32_VERIFY diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 66e7c4fc8b..b2fa30a59f 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -20,7 +20,9 @@ #define CONFIG_TIMESTAMP /* Print image info with timestamp */
/* add target to build it automatically upon "make" */ +#if defined(CONFIG_SPL) #define CONFIG_BUILD_TARGET "u-boot-with-spl.sfp" +#endif
/* * Memory configurations
Éric Hoffman
