[U-Boot] [PATCH 1/1] console: USB: KBD: Fix incorrect autoboot timeout
Autoboot timeout defined by CONFIG_BOOTDELAY will not be accurate if CONFIG_USB_KEYBOARD and CONFIG_SYS_USB_EVENT_POLL are defined in configuration file and when tstc() function for checking key pressed takes longer time than 10 ms (e.g., 50 ms) to finish.
Signed-off-by: Jim Lin jilin@nvidia.com --- common/main.c | 13 ++++++++++--- 1 files changed, 10 insertions(+), 3 deletions(-)
diff --git a/common/main.c b/common/main.c index b145f85..8cdfb8b 100644 --- a/common/main.c +++ b/common/main.c @@ -225,6 +225,7 @@ static inline int abortboot(int bootdelay) { int abort = 0; + unsigned long ts;
#ifdef CONFIG_MENUPROMPT printf(CONFIG_MENUPROMPT); @@ -248,11 +249,13 @@ int abortboot(int bootdelay) #endif
while ((bootdelay > 0) && (!abort)) { - int i; + int i, j;
--bootdelay; /* delay 100 * 10ms */ - for (i=0; !abort && i<100; ++i) { + j = 100; + for (i = 0; !abort && i < j; ++i) { + ts = get_timer(0); if (tstc()) { /* we got a key press */ abort = 1; /* don't auto boot */ bootdelay = 0; /* no more delay */ @@ -263,7 +266,11 @@ int abortboot(int bootdelay) # endif break; } - udelay(10000); + ts = get_timer(ts); + if (ts < 10) + mdelay(10 - ts); + else + j = 1000 / (int) ts; }
printf("\b\b\b%2d ", bootdelay);
Dear Jim Lin,
j = 100;
udelay(10000);
ts = get_timer(ts);
if (ts < 10)
mdelay(10 - ts);
else
}j = 1000 / (int) ts;
This is a pretty awkward implementation. If you feel the current plain delay loop based approach is not exact enough, then please implement a real timeout - you are calling the timer anyway, so just use the timer values instead of a loop count.
On Wed, 2013-01-23 at 16:38 +0800, Wolfgang Denk wrote:
Dear Jim Lin,
j = 100;
udelay(10000);
ts = get_timer(ts);
if (ts < 10)
mdelay(10 - ts);
else
Thanks for pointing this out. I will improve it and resend.
----------------------------------------------------------------------------------- This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message. -----------------------------------------------------------------------------------
Jim Lin
