[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Albert,
please pull from u-boot-imx.
The following changes since commit 96d04c3150ae9284500aef48803d7d132968f2b2:
IDE: fix compiler warnings (2011-04-30 23:29:55 +0200)
are available in the git repository at: git://www.denx.de/git/u-boot-imx.git master
Fabio Estevam (2): MX31: mx31pdk: Add watchdog support gpio: imx: Fix return value on error
Stefano Babic (2): MX31: removed warning due to missing prototype MX31: change return value of get_cpu_rev
arch/arm/cpu/arm1136/mx31/generic.c | 31 ++++++++++++++++------------ arch/arm/include/asm/arch-mx31/clock.h | 1 + arch/arm/include/asm/arch-mx31/imx-regs.h | 2 +- board/freescale/mx31pdk/mx31pdk.c | 16 +++++++++++++++ drivers/gpio/mxc_gpio.c | 5 ++- include/configs/mx31pdk.h | 3 ++ 6 files changed, 42 insertions(+), 16 deletions(-)
Best regards, Stefano Babic
Le 09/05/2011 13:49, Stefano Babic a écrit :
Hi Albert,
Hi Stefano,
This is weird: if I 'git fetch' your repo, I don't get a new master branch from it (previous fetch was when you sent out your previous pull request. The master I see from you is at "mx31pdk: Clean up mx31pdk.h file" (97ed77ba9c12158860b6a94caaa60df437588973), which is not in the list above. Can you double-check?
Amicalement,
Hi Albert,
Hi Albert,
Hi Stefano,
Sorry, my fault. I have already added a further patch to the master branch, instead of using my "next" as I am used to until you merge my master into u-boot-arm. It shoould be OK now.
Hi Stefano,
It is, thanks.
Amicalement,
Hi Stefano,
Hi Albert,
Applied, thanks.
Amicalement,
Albert ARIBAUD
Stefano Babic
