[PATCH] rockchip: rk3328: Add support for FriendlyARM NanoPi R2S
This adds support for the NanoPi R2S from FriendlyArm.
Rockchip RK3328 SoC 1GB DDR4 RAM Gigabit Ethernet (WAN) Gigabit Ethernet (USB3) (LAN) USB 2.0 Host Port MicroSD slot Reset button WAN - LAN - SYS LED
Signed-off-by: David Bauer mail@david-bauer.net --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi | 34 +++ arch/arm/dts/rk3328-nanopi-r2s.dts | 317 +++++++++++++++++++++ board/rockchip/evb_rk3328/MAINTAINERS | 7 + configs/nanopi-r2s-rk3328_defconfig | 99 +++++++ 5 files changed, 458 insertions(+) create mode 100644 arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi create mode 100644 arch/arm/dts/rk3328-nanopi-r2s.dts create mode 100644 configs/nanopi-r2s-rk3328_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index cee10f533f..a6bd8ea0d8 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -107,6 +107,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3308) += \
dtb-$(CONFIG_ROCKCHIP_RK3328) += \ rk3328-evb.dtb \ + rk3328-nanopi-r2s.dtb \ rk3328-roc-cc.dtb \ rk3328-rock64.dtb \ rk3328-rock-pi-e.dtb diff --git a/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi b/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi new file mode 100644 index 0000000000..4159348402 --- /dev/null +++ b/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2018-2019 Rockchip Electronics Co., Ltd + * (C) Copyright 2020 David Bauer + */ + +#include "rk3328-u-boot.dtsi" +#include "rk3328-sdram-ddr4-666.dtsi" +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &sdmmc, &emmc; + }; +}; + +&gpio0 { + u-boot,dm-spl; +}; + +&pinctrl { + u-boot,dm-spl; +}; + +&sdmmc0m1_gpio { + u-boot,dm-spl; +}; + +&pcfg_pull_up_4ma { + u-boot,dm-spl; +}; + +/* Need this and all the pinctrl/gpio stuff above to set pinmux */ +&vcc_sd { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/rk3328-nanopi-r2s.dts b/arch/arm/dts/rk3328-nanopi-r2s.dts new file mode 100644 index 0000000000..2a3c8b6012 --- /dev/null +++ b/arch/arm/dts/rk3328-nanopi-r2s.dts @@ -0,0 +1,317 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 David Bauer mail@david-bauer.net + */ + +/dts-v1/; + +#include <dt-bindings/input/input.h> +#include <dt-bindings/gpio/gpio.h> +#include "rk3328.dtsi" + +/ { + model = "FriendlyARM NanoPi R2S"; + compatible = "friendlyarm,nanopi-r2s", "rockchip,rk3328"; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + gmac_clkin: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "gmac_clkin"; + #clock-cells = <0>; + }; + + vcc_sd: sdmmc-regulator { + compatible = "regulator-fixed"; + gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0m1_gpio>; + regulator-name = "vcc_sd"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_io>; + }; + + vcc_sys: vcc-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc_rtl8153: vcc-rtl8153-regulator { + compatible = "regulator-fixed"; + gpio = <&gpio2 RK_PC6 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&rtl8153_en_drv>; + regulator-always-on; + regulator-name = "vcc_rtl8153"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + }; + + leds { + compatible = "gpio-leds"; + + pinctrl-names = "default"; + pinctrl-0 = <&led_pins>; + + sys { + gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; + label = "nanopi-r2s:red:sys"; + }; + + lan { + gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_HIGH>; + label = "nanopi-r2s:green:lan"; + }; + + wan { + gpios = <&gpio2 RK_PC2 GPIO_ACTIVE_HIGH>; + label = "nanopi-r2s:green:wan"; + }; + }; + + gpio_keys { + compatible = "gpio-keys-polled"; + poll-interval = <100>; + + pinctrl-names = "default"; + pinctrl-0 = <&button_pins>; + + reset { + label = "Reset Button"; + gpios = <&gpio0 RK_PA0 GPIO_ACTIVE_LOW>; + linux,code = <KEY_RESTART>; + debounce-interval = <50>; + }; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_arm>; +}; + +&cpu1 { + cpu-supply = <&vdd_arm>; +}; + +&cpu2 { + cpu-supply = <&vdd_arm>; +}; + +&cpu3 { + cpu-supply = <&vdd_arm>; +}; + +&gmac2io { + assigned-clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_EXT>; + assigned-clock-parents = <&gmac_clkin>, <&gmac_clkin>; + clock_in_out = "input"; + phy-supply = <&vcc_io>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmiim1_pins>; + snps,force_thresh_dma_mode; + snps,reset-gpio = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x24>; + rx_delay = <0x18>; + status = "okay"; +}; + +&i2c1 { + status = "okay"; + + rk805: rk805@18 { + compatible = "rockchip,rk805"; + reg = <0x18>; + interrupt-parent = <&gpio2>; + interrupts = <6 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk805-clkout2"; + gpio-controller; + #gpio-cells = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc_sys>; + vcc2-supply = <&vcc_sys>; + vcc3-supply = <&vcc_sys>; + vcc4-supply = <&vcc_sys>; + vcc5-supply = <&vcc_io>; + vcc6-supply = <&vcc_sys>; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <12500>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vdd_arm: DCDC_REG2 { + regulator-name = "vdd_arm"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <12500>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <950000>; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_io: DCDC_REG4 { + regulator-name = "vcc_io"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_18: LDO_REG1 { + regulator-name = "vcc_18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc18_emmc: LDO_REG2 { + regulator-name = "vcc18_emmc"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_10: LDO_REG3 { + regulator-name = "vdd_10"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + }; + }; +}; + +&io_domains { + status = "okay"; + + vccio1-supply = <&vcc_io>; + vccio2-supply = <&vcc18_emmc>; + vccio3-supply = <&vcc_io>; + vccio4-supply = <&vcc_18>; + vccio5-supply = <&vcc_io>; + vccio6-supply = <&vcc_io>; + pmuio-supply = <&vcc_io>; +}; + +&pinctrl { + leds { + led_pins: led_pins { + rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>, + <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>, + <2 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + button { + button_pins: button_pins { + rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb { + rtl8153_en_drv: rtl8153-en-drv { + rockchip,pins = <2 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + disable-wp; + max-frequency = <150000000>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_dectn &sdmmc0_bus4>; + vmmc-supply = <&vcc_sd>; + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <0>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&u2phy { + status = "okay"; + + u2phy_host: host-port { + status = "okay"; + }; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3328/MAINTAINERS b/board/rockchip/evb_rk3328/MAINTAINERS index e7dd59ff4e..14fda46e8f 100644 --- a/board/rockchip/evb_rk3328/MAINTAINERS +++ b/board/rockchip/evb_rk3328/MAINTAINERS @@ -5,6 +5,13 @@ F: board/rockchip/evb_rk3328 F: include/configs/evb_rk3328.h F: configs/evb-rk3328_defconfig
+NANOPI-R2S-RK3328 +M: David Bauer mail@david-bauer.net +S: Maintained +F: configs/nanopi-r2s-rk3328_defconfig +F: arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi +F: arch/arm/dts/rk3328-nanopi-r2s.dts + ROC-RK3328-CC M: Loic Devulder ldevulder@suse.com M: Chen-Yu Tsai wens@csie.org diff --git a/configs/nanopi-r2s-rk3328_defconfig b/configs/nanopi-r2s-rk3328_defconfig new file mode 100644 index 0000000000..2c028e9d0b --- /dev/null +++ b/configs/nanopi-r2s-rk3328_defconfig @@ -0,0 +1,99 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_ROCKCHIP_RK3328=y +CONFIG_TPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_TPL_LIBCOMMON_SUPPORT=y +CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xFF130000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SMBIOS_PRODUCT_NAME="nanopi_r2s_rk3328" +CONFIG_DEBUG_UART=y +CONFIG_TPL_SYS_MALLOC_F_LEN=0x800 +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-nanopi-r2s.dtb" +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_TPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_TPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3328-nanopi-r2s" +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_TPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_TPL_DM=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_TPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_TPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_FASTBOOT_BUF_ADDR=0x800800 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_SPL_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_DM_RESET=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +# CONFIG_TPL_SYSRESET is not set +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC2=y +CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_TPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y +CONFIG_SMBIOS_MANUFACTURER="pine64"
Hi David,
Does this board dts available in kernel mainline?
Thanks,
- Kever
- rk3328-nanopi-r2s.dtb \ rk3328-roc-cc.dtb \ rk3328-rock64.dtb \ rk3328-rock-pi-e.dtb
- (C) Copyright 2018-2019 Rockchip Electronics Co., Ltd
- (C) Copyright 2020 David Bauer
- chosen {
+&gpio0 {
- u-boot,dm-spl;
+&pinctrl {
- u-boot,dm-spl;
+&sdmmc0m1_gpio {
- u-boot,dm-spl;
- u-boot,dm-spl;
- u-boot,dm-spl;
- Copyright (c) 2020 David Bauer mail@david-bauer.net
+/dts-v1/;
- model = "FriendlyARM NanoPi R2S";
- compatible = "friendlyarm,nanopi-r2s", "rockchip,rk3328";
- chosen {
- gmac_clkin: external-gmac-clock {
#clock-cells = <0>;
- vcc_sd: sdmmc-regulator {
- vcc_sys: vcc-sys {
regulator-boot-on;
- vcc_rtl8153: vcc-rtl8153-regulator {
enable-active-high;
- leds {
sys {
lan {
wan {
- gpio_keys {
reset {
+&cpu0 {
- cpu-supply = <&vdd_arm>;
+&cpu1 {
+&cpu2 {
+&cpu3 {
+&gmac2io {
- assigned-clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_EXT>;
- assigned-clock-parents = <&gmac_clkin>, <&gmac_clkin>;
- clock_in_out = "input";
- phy-supply = <&vcc_io>;
- phy-mode = "rgmii";
- pinctrl-names = "default";
- pinctrl-0 = <&rgmiim1_pins>;
- snps,force_thresh_dma_mode;
- snps,reset-gpio = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 10000 50000>;
- tx_delay = <0x24>;
- rx_delay = <0x18>;
- status = "okay";
+&i2c1 {
- status = "okay";
- rk805: rk805@18 {
reg = <0x18>;
#clock-cells = <1>;
gpio-controller;
#gpio-cells = <2>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_io: DCDC_REG4 {
regulator-boot-on;
vcc_18: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
vdd_10: LDO_REG3 {
regulator-boot-on;
+&io_domains {
- status = "okay";
- vccio1-supply = <&vcc_io>;
- vccio2-supply = <&vcc18_emmc>;
- vccio3-supply = <&vcc_io>;
- vccio4-supply = <&vcc_18>;
- vccio5-supply = <&vcc_io>;
- vccio6-supply = <&vcc_io>;
- pmuio-supply = <&vcc_io>;
+&pinctrl {
- leds {
- button {
- pmic {
- usb {
+&sdmmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- disable-wp;
- max-frequency = <150000000>;
- pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_dectn &sdmmc0_bus4>;
- vmmc-supply = <&vcc_sd>;
- status = "okay";
+&tsadc {
- rockchip,hw-tshut-mode = <0>;
- rockchip,hw-tshut-polarity = <0>;
- status = "okay";
+&uart2 {
- status = "okay";
+&u2phy {
- status = "okay";
- u2phy_host: host-port {
status = "okay";
+&usb_host0_ehci {
- status = "okay";
+&usb_host0_ohci {
- status = "okay";
- ROC-RK3328-CC M: Loic Devulder ldevulder@suse.com M: Chen-Yu Tsai wens@csie.org
Hi Kenver,
On 7/22/20 3:50 AM, Kever Yang wrote:
Hi David,
<Resending as it didn't reach the U-Boot MX>
I'm in the process of mainlining the board to kernel too (planning to submit it within the next week).
The DTS however is identical to the one I'm submitting here. See https://github.com/blocktrron/linux-nanopi-r2s
Best wishes David
Thanks,
- Kever
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index cee10f533f..a6bd8ea0d8 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -107,6 +107,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3308) += \ dtb-$(CONFIG_ROCKCHIP_RK3328) += \ rk3328-evb.dtb \ + rk3328-nanopi-r2s.dtb \ rk3328-roc-cc.dtb \ rk3328-rock64.dtb \ rk3328-rock-pi-e.dtb diff --git a/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi b/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi new file mode 100644 index 0000000000..4159348402 --- /dev/null +++ b/arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+/dts-v1/;
+&usb_host0_ohci { + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3328/MAINTAINERS b/board/rockchip/evb_rk3328/MAINTAINERS index e7dd59ff4e..14fda46e8f 100644 --- a/board/rockchip/evb_rk3328/MAINTAINERS +++ b/board/rockchip/evb_rk3328/MAINTAINERS @@ -5,6 +5,13 @@ F: board/rockchip/evb_rk3328 F: include/configs/evb_rk3328.h F: configs/evb-rk3328_defconfig +NANOPI-R2S-RK3328 +M: David Bauer mail@david-bauer.net +S: Maintained +F: configs/nanopi-r2s-rk3328_defconfig +F: arch/arm/dts/rk3328-nanopi-r2s-u-boot.dtsi +F: arch/arm/dts/rk3328-nanopi-r2s.dts
David Bauer
Kever Yang
