RE: [U-Boot-Users] how to run hello_world
7 Oct
2004
7 Oct
'04
7:38 p.m.
As described in u-boot readme file
In case you didn't know, the DULG is also a great source of info. http://www.denx.de/twiki/bin/view/DULG/Manual
to run hello_world example we have to write "loads" but this command doesnt seem to work with me and give the following msg Unknown command 'loads' - try 'help'
Make sure you have CFG_CMD_LOADS (or CONFIG_CMD_DFL) included in the definition of CONFIG_COMMANDS your board's config header file.
and when i give the command go 40004 Hello World! This is a test. following error msg appears ## Starting application at 0x00040004 ... Bus Fault @ 0x00000700, fixup 0x00000000 Machine check in kernel mode.
This is expected behavior if you haven't loaded the program.
Regards, -Craig
7517
Smith, Craig
